RTEMS 6 branching
Peter Dufault dufault at hda.com
Wed Apr 24 14:06:54 UTC 2024
> On Apr 24, 2024, at 9:27 AM, Kinsey Moore <kinsey.moore at oarcorp.com> wrote:
> That use case definitely wasn't considered for rtems-lwip and I don't know that it's ever been discussed. If that were intended, I'd expect a "./waf uninstall" target to exist that would remove the installed network stack so that you could install a different one since the different stacks install vastly different sets of headers. IIRC, Chris advocates for installing the network libraries into a different location than the installed BSP to allow you to choose which you want at a later time.
> Kinsey
I've been moving a driver from legacy to bsd so I definitely need to easily switch back and forth for the same BSP for testing.
I agree with Chris, but it's apparently a desirement, not a requirement, so it shouldn't hold up the branching.
Peter
Peter Dufault
HD Associates, Inc.      Software and System Engineering
