[PATCH] bsps/aarch64/raspberrypi: Add system timer support
Kinsey Moore kinsey.moore at oarcorp.com
Wed Apr 24 21:43:00 UTC 2024
Looks good, thanks!
Kinsey
On Tue, Apr 16, 2024 at 5:20 AM Ning Yang <yangn0 at qq.com> wrote:
> The clock from the ARM timer is derived from the system clock. This clock
> can
> change dynamically e.g. if the system goes into reduced power or in low
> power
> mode. Thus the clock speed adapts to the overall system performance
> capabilities. For accurate timing it is recommended to use the system
> timers.
> if BSP_CLOCK_USE_SYSTEMTIMER = 1, use the System Timer, otherwise use the
> ARM
> Timer.
>  bsps/aarch64/raspberrypi/include/bsp/irq.h    | 14 ++++++---
>  .../raspberrypi/include/bsp/raspberrypi.h     |  9 ++++++
>  spec/build/bsps/aarch64/grp.yml               |  3 --
>  .../aarch64/raspberrypi/bspraspberrypi4.yml   |  6 ++--
>  .../bsps/aarch64/raspberrypi/objclock.yml     | 31 +++++++++++++++++++
>  .../aarch64/raspberrypi/objsystemtimer.yml    | 23 ++++++++++++++
>  .../aarch64/raspberrypi/optsystemtimer.yml    | 24 ++++++++++++++
>  7 files changed, 100 insertions(+), 10 deletions(-)
>  create mode 100644 spec/build/bsps/aarch64/raspberrypi/objclock.yml
>  create mode 100644 spec/build/bsps/aarch64/raspberrypi/objsystemtimer.yml
>  create mode 100644 spec/build/bsps/aarch64/raspberrypi/optsystemtimer.yml
> diff --git a/bsps/aarch64/raspberrypi/include/bsp/irq.h
> b/bsps/aarch64/raspberrypi/include/bsp/irq.h
> index 1ff6ae80de..d493e83707 100644
> --- a/bsps/aarch64/raspberrypi/include/bsp/irq.h
> +++ b/bsps/aarch64/raspberrypi/include/bsp/irq.h
> @@ -9,6 +9,7 @@
>   * Copyright (c) 2013 Alan Cudmore
>   * Copyright (c) 2022 Mohd Noor Aman
> + * Copyright (c) 2024 Ning Yang
>   *  The license and distribution terms for this file may be
>   *  found in the file LICENSE in this distribution or at
> @@ -33,15 +34,18 @@
>   * @brief Interrupt support.
> -#define BCM2835_INTC_TOTAL_IRQ       (64 + 8)
> +#define BCM2835_INTC_TOTAL_IRQ       216
>  #define BCM2835_IRQ_SET1_MIN         0
>  #define BCM2835_IRQ_SET2_MIN         32
> -#define BCM2835_IRQ_ID_GPU_TIMER_M0  0
> -#define BCM2835_IRQ_ID_GPU_TIMER_M1  1
> -#define BCM2835_IRQ_ID_GPU_TIMER_M2  2
> -#define BCM2835_IRQ_ID_GPU_TIMER_M3  3
> +#define BCM2711_IRQ_VC_PERIPHERAL_BASE 96
> +/* Interrupt Vectors: System Timer */
> +#define BCM2835_IRQ_ID_GPU_TIMER_M0    (BCM2711_IRQ_VC_PERIPHERAL_BASE +
> 0)
> +#define BCM2835_IRQ_ID_GPU_TIMER_M1    (BCM2711_IRQ_VC_PERIPHERAL_BASE +
> 1)
> +#define BCM2835_IRQ_ID_GPU_TIMER_M2    (BCM2711_IRQ_VC_PERIPHERAL_BASE +
> 2)
> +#define BCM2835_IRQ_ID_GPU_TIMER_M3    (BCM2711_IRQ_VC_PERIPHERAL_BASE +
> 3)
>  #define BCM2835_IRQ_ID_USB           9
>  #define BCM2835_IRQ_ID_AUX           29
> diff --git a/bsps/aarch64/raspberrypi/include/bsp/raspberrypi.h
> b/bsps/aarch64/raspberrypi/include/bsp/raspberrypi.h
> index 55dd9ed1e9..f185d1df57 100644
> --- a/bsps/aarch64/raspberrypi/include/bsp/raspberrypi.h
> +++ b/bsps/aarch64/raspberrypi/include/bsp/raspberrypi.h
> @@ -8,6 +8,7 @@
> @@ -44,6 +45,7 @@
>  #define BCM2711_REG(x)           (*(volatile uint64_t *)(x))
>  #define BCM2711_BIT(n)           (1 << (n))
> +#define BCM2835_REG(addr)        (*(volatile uint32_t*)(addr))
> @@ -198,6 +200,13 @@
>  #define BCM2711_GPU_TIMER_C2         (BCM2711_GPU_TIMER_BASE + 0x14)
>  #define BCM2711_GPU_TIMER_C3         (BCM2711_GPU_TIMER_BASE + 0x18)
> + * NOTE: compatible with the BCM2835 system timer
> +#define BCM2835_GPU_TIMER_CS_M3      BCM2711_GPU_TIMER_CS_M3
> +#define BCM2835_GPU_TIMER_C3         BCM2711_GPU_TIMER_C3
> +#define BCM2835_GPU_TIMER_CLO        BCM2711_GPU_TIMER_CLO
> +#define BCM2835_GPU_TIMER_CS         BCM2711_GPU_TIMER_CS
> diff --git a/spec/build/bsps/aarch64/grp.yml
> b/spec/build/bsps/aarch64/grp.yml
> index 9428fb9435..8f40a9952e 100644
> --- a/spec/build/bsps/aarch64/grp.yml
> +++ b/spec/build/bsps/aarch64/grp.yml
> @@ -12,9 +12,6 @@ install:
>    source:
>    - bsps/aarch64/include/bsp/linker-symbols.h
>    - bsps/aarch64/include/bsp/start.h
> -- destination: ${BSP_INCLUDEDIR}/dev/clock
> -  source:
> -  - bsps/include/dev/clock/arm-generic-timer.h
>  - destination: ${BSP_INCLUDEDIR}/dev/irq
>    source:
>    - bsps/aarch64/include/dev/irq/arm-gic-arch.h
> diff --git a/spec/build/bsps/aarch64/raspberrypi/bspraspberrypi4.yml
> b/spec/build/bsps/aarch64/raspberrypi/bspraspberrypi4.yml
> index a579c094ba..7b6511a8cc 100644
> --- a/spec/build/bsps/aarch64/raspberrypi/bspraspberrypi4.yml
> +++ b/spec/build/bsps/aarch64/raspberrypi/bspraspberrypi4.yml
> @@ -19,6 +19,10 @@ install:
>    - bsps/aarch64/raspberrypi/include/bsp/irq.h
>    - bsps/aarch64/raspberrypi/include/bsp/raspberrypi.h
>  links:
> +- role: build-dependency
> +  uid: objclock
> +  uid: objsystemtimer
>    uid: ../grp
> @@ -50,10 +54,8 @@ source:
>  - bsps/aarch64/raspberrypi/start/bspstart.c
>  - bsps/aarch64/raspberrypi/start/bspstarthooks.c
>  - bsps/aarch64/raspberrypi/start/bspstartmmu.c
> -- bsps/aarch64/shared/clock/arm-generic-timer-aarch64.c
>  - bsps/aarch64/shared/cache/cache.c
>  - bsps/aarch64/shared/mmu/vmsav8-64.c
> -- bsps/shared/dev/clock/arm-generic-timer.c
>  - bsps/shared/dev/irq/arm-gicv2.c
>  - bsps/shared/dev/irq/arm-gicv2-get-attributes.c
>  - bsps/shared/dev/serial/console-termios-init.c
> diff --git a/spec/build/bsps/aarch64/raspberrypi/objclock.yml
> b/spec/build/bsps/aarch64/raspberrypi/objclock.yml
> new file mode 100644
> index 0000000000..c4a8227bc9
> --- /dev/null
> +++ b/spec/build/bsps/aarch64/raspberrypi/objclock.yml
> @@ -0,0 +1,31 @@
> +SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
> +copyrights:
> +  - Copyright (C) 2022 Mohd Noor Aman
> +  - Copyright (C) 2023 Utkarsh Verma
> +  - Copyright (C) 2024 Ning Yang
> +type: build
> +enabled-by:
> +  not: BSP_CLOCK_USE_SYSTEMTIMER
> +build-type: objects
> +cflags: []
> +cppflags: []
> +cxxflags: []
> +includes: []
> +install:
> +- destination: ${BSP_INCLUDEDIR}/dev/clock
> +  source:
> +  - bsps/include/dev/clock/arm-generic-timer.h
> +source:
> +  - bsps/aarch64/shared/clock/arm-generic-timer-aarch64.c
> +  - bsps/shared/dev/clock/arm-generic-timer.c
> +links:
> +  - role: build-dependency
> +    uid: ../optgtusevirt
> +    uid: ../optgtuseps
> +    uid: optsystemtimer
> \ No newline at end of file
> diff --git a/spec/build/bsps/aarch64/raspberrypi/objsystemtimer.yml
> b/spec/build/bsps/aarch64/raspberrypi/objsystemtimer.yml
> index 0000000000..8a91a0555a
> --- /dev/null
> +++ b/spec/build/bsps/aarch64/raspberrypi/objsystemtimer.yml
> @@ -0,0 +1,23 @@
> +copyrights:
> +type: build
> +enabled-by:
> +- BSP_CLOCK_USE_SYSTEMTIMER
> +cflags: []
> +cppflags: []
> +cxxflags: []
> +includes: []
> +install: []
> +source:
> +  - bsps/shared/dev/clock/bcm2835-system-timer.c
> +  - bsps/shared/dev/cpucounter/cpucounterfrequency.c
> +  - bsps/shared/dev/cpucounter/cpucounterread.c
> +links:
> diff --git a/spec/build/bsps/aarch64/raspberrypi/optsystemtimer.yml
> b/spec/build/bsps/aarch64/raspberrypi/optsystemtimer.yml
> index 0000000000..1cceebf22b
> --- /dev/null
> +++ b/spec/build/bsps/aarch64/raspberrypi/optsystemtimer.yml
> @@ -0,0 +1,24 @@
> +copyrights:
> +type: build
> +build-type: option
> +enabled-by: true
> +name: BSP_CLOCK_USE_SYSTEMTIMER
> +description: |
> +  The clock from the ARM timer is derived from the system clock. This
> clock
> can change dynamically e.g. if the system
> +  goes into reduced power or in low power mode. Thus the clock speed
> adapts
> +  capabilities. For accurate timing it is recommended to use the system
> timers.
> +actions:
> +  - get-boolean: null
> +  - define-condition: null
> +  - env-enable: null
> +default:
> +  - enabled-by:
> +    - aarch64/raspberrypi4b
> +    value: false
> +links: []
> 2.34.1
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20240424/f11aa8cd/attachment-0001.htm>
