Repo Transition to GitLab
Fri Apr 26 15:10:32 UTC 2024
On Fri, Apr 26, 2024, 12:49 AM Sebastian Huber <
> On 26.04.24 00:38, Chris Johns wrote:
> > Hi RTEMS Community
> > The git repos on git.rtems.org are open and accepting patches. The
> GitLab repos
> > will move us to main, something we have been waiting to do. Allowing
> commits
> > into the repos means they will be brought across and played on top of
> the new
> > main branch. We have changes in the repo on GitLab as part of our
> testing and
> > new files such as CODEOWNERS.
> > As a result you will check out main and not rename your master to main.
> When will the GitLab available? I can wait with my pending patches so
> that the associated tickets get updated when they are checked in.
The plan is to go live May 1. We expect people to run into minor things we
may have missed in the transition. Discord and devel@ are always there for
help.
How
> will the ticket updates work in GitLab?
When there is a ticket, make a merge request from that. Add your patches.
When ready it will need a review. Comments are made in the UI and need to
be resolved. Then it needs an approval. This is the normal gitlab way.
You can have a branch and MR without an issue.
Whether every change requires an issue is a project process decision but
the lean is to no. You do have to get review and approval.
Approval can come from a larger set of people now.
Are the ticket numbers the same?
I checked your isr priority one and it is the same. I think they all were
preserved for rtems. Some were assigned to other repos/projects and those
appear to have new numbers.
--joel
> embedded brains GmbH & Co. KG
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax:   +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20240426/37b5eac0/attachment.htm>
