[PATCH] testsuites/libtest/dl12: add DL test for incrementally linked object
Ranulfo Raphael
raanulfo at hotmail.com
Thu Mar 7 03:10:48 UTC 2024
This adds a test to verify the incremental linking in RTL.
Update #3740
spec/build/bsps/tstnolibdl.yml | 1 +
spec/build/testsuites/libtests/dl12.yml | 46 ++++++++
spec/build/testsuites/libtests/grp.yml | 2 +
testsuites/libtests/dl12/dl-load.c | 138 ++++++++++++++++++++++++
testsuites/libtests/dl12/dl-load.h | 33 ++++++
testsuites/libtests/dl12/dl12-o1.c | 42 ++++++++
testsuites/libtests/dl12/dl12-o2.c | 42 ++++++++
testsuites/libtests/dl12/dl12.doc | 47 ++++++++
testsuites/libtests/dl12/dl12.scn | 15 +++
testsuites/libtests/dl12/init.c | 103 ++++++++++++++++++
10 files changed, 469 insertions(+)
create mode 100644 spec/build/testsuites/libtests/dl12.yml
create mode 100644 testsuites/libtests/dl12/dl-load.c
create mode 100644 testsuites/libtests/dl12/dl-load.h
create mode 100644 testsuites/libtests/dl12/dl12-o1.c
create mode 100644 testsuites/libtests/dl12/dl12-o2.c
create mode 100644 testsuites/libtests/dl12/dl12.doc
create mode 100644 testsuites/libtests/dl12/dl12.scn
create mode 100644 testsuites/libtests/dl12/init.c
diff --git a/spec/build/bsps/tstnolibdl.yml b/spec/build/bsps/tstnolibdl.yml
index 3e09033f37..7f45f55520 100644
--- a/spec/build/bsps/tstnolibdl.yml
+++ b/spec/build/bsps/tstnolibdl.yml
@@ -15,6 +15,7 @@ actions:
- dl09
- dl10
- dl11
+ - dl12
build-type: option
copyrights:
- Copyright (C) 2020 embedded brains GmbH & Co. KG
diff --git a/spec/build/testsuites/libtests/dl12.yml b/spec/build/testsuites/libtests/dl12.yml
new file mode 100644
index 0000000000..fbd8098358
--- /dev/null
+++ b/spec/build/testsuites/libtests/dl12.yml
@@ -0,0 +1,46 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+build-type: script
+cflags: []
+copyrights:
+- Copyright (C) 2020 embedded brains GmbH & Co. KG
+cppflags: []
+do-build: |
+ path = "testsuites/libtests/dl12/"
+ objs = []
+ objs.append(self.cc(bld, bic, path + "dl12-o1.c"))
+ objs.append(self.cc(bld, bic, path + "dl12-o2.c"))
+ def ld(self, bld, bic, flags, source, target):
+ bld(rule="${LD} " + flags + " ${SRC} -o ${TGT}",
+ source=source,
+ target=target)
+ return target
+ objs = [ld(self, bld, bic, '-r', objs, "testsuites/libtests/dl12/dl12-inc.o")]
+ tar = path + "dl12.tar"
+ self.tar(bld, objs, [path], tar)
+ tar_c, tar_h = self.bin2c(bld, tar)
+ objs = []
+ objs.append(self.cc(bld, bic, tar_c))
+ objs.append(self.cc(bld, bic, path + "init.c", deps=[tar_h], cppflags=bld.env.TEST_DL12_CPPFLAGS))
+ objs.append(self.cc(bld, bic, path + "dl-load.c"))
+ dl12_pre = path + "dl12.pre"
+ self.link_cc(bld, bic, objs, dl12_pre)
+ dl12_sym_o = path + "dl12-sym.o"
+ objs.append(dl12_sym_o)
+ self.rtems_syms(bld, dl12_pre, dl12_sym_o)
+ self.link_cc(bld, bic, objs, "testsuites/libtests/dl12.exe")
+do-configure: null
+enabled-by:
+- and:
+ - not: TEST_DL12_EXCLUDE
+ - BUILD_LIBDL
+includes:
+- testsuites/libtests/dl12
+ldflags: []
+links: []
+prepare-build: null
+prepare-configure: null
+stlib: []
+target: testsuites/libtests/dl12.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/libtests/grp.yml b/spec/build/testsuites/libtests/grp.yml
index fae2396a2f..c63d845983 100644
--- a/spec/build/testsuites/libtests/grp.yml
+++ b/spec/build/testsuites/libtests/grp.yml
@@ -110,6 +110,8 @@ links:
uid: dl10
- role: build-dependency
uid: dl11
+- role: build-dependency
+ uid: dl12
uid: dumpbuf01
diff --git a/testsuites/libtests/dl12/dl-load.c b/testsuites/libtests/dl12/dl-load.c
index 0000000000..e928d0c27d
--- /dev/null
+++ b/testsuites/libtests/dl12/dl-load.c
@@ -0,0 +1,138 @@
+ * Copyright (c) 2014 Chris Johns <chrisj at rtems.org>. All rights reserved.
+ * Copyright (c) 2019 On-Line Applications Research
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#include <stdio.h>
+#include <dlfcn.h>
+#include "dl-load.h"
+#include <rtems/rtl/rtl-shell.h>
+#include <rtems/rtl/rtl-trace.h>
+#define TEST_TRACE 0
+#if TEST_TRACE
+ #define DL_DEBUG_TRACE (RTEMS_RTL_TRACE_ALL & ~RTEMS_RTL_TRACE_ALLOCATOR)
+ #define DL_RTL_CMDS 1
+#else
+ #define DL_DEBUG_TRACE 0
+ #define DL_RTL_CMDS 0
+#endif
+typedef const void *(*call_t)(void);
+static void* dl_load_obj(const char* name)
+ void* handle;
+ int unresolved;
+ char* message = "loaded";
+ printf("load: %s\n", name);
+ handle = dlopen (name, RTLD_NOW | RTLD_GLOBAL);
+ if (!handle)
+ printf("dlopen failed: %s\n", dlerror());
+ return NULL;
+ if (dlinfo (handle, RTLD_DI_UNRESOLVED, &unresolved) < 0)
+ message = "dlinfo error checking unresolved status";
+ else if (unresolved)
+ message = "has unresolved externals";
+ printf ("handle: %p %s\n", handle, message);
+ return handle;
+int dl_load_test(void)
+ void* handle;
+ call_t call;
+ const void* dl_o1_str_addr;
+ const void* dl_o2_str_addr;
+#if DL_DEBUG_TRACE
+ rtems_rtl_trace_set_mask (DL_DEBUG_TRACE);
+#endif
+ handle = dl_load_obj("/dl12-inc.o");
+ if (!handle)
+ return 1;
+#if DL_RTL_CMDS
+ char* list[] = { "rtl", "list", NULL };
+ rtems_rtl_shell_command (2, list);
+ char* sym[] = { "rtl", "sym", NULL };
+ rtems_rtl_shell_command (2, sym);
+#endif
+ call = dlsym (handle, "dl_o1_func");
+ if (call == NULL)
+ printf("dlsym failed: symbol not found\n");
+ return 1;
+ printf("\nAbout to call dl_o1_func at address %p\n", call);
+ dl_o1_str_addr = call ();
+ printf("\ndl_o1_func string literal address: %p\n", dl_o1_str_addr);
+ call = dlsym (handle, "dl_o2_func");
+ if (call == NULL)
+ return 1;
+ printf("\nAbout to call dl_o2_func at address %p\n", call);
+ dl_o2_str_addr = call ();
+ printf("\ndl_o2_func string literal address: %p\n", dl_o2_str_addr);
+ if (dl_o1_str_addr == dl_o2_str_addr) {
+ printf("\nTwo symbols from different object files have the same address!\n");
+ return 1;
+ if (dlclose (handle) < 0)
+ printf("dlclose obj failed: %s\n", dlerror());
+ return 1;
+ printf ("\nhandle: %p closed\n", handle);
+ return 0;
diff --git a/testsuites/libtests/dl12/dl-load.h b/testsuites/libtests/dl12/dl-load.h
index 0000000000..142b195626
--- /dev/null
+++ b/testsuites/libtests/dl12/dl-load.h
@@ -0,0 +1,33 @@
+ * are met:
+#if !defined(_DL_LOAD_H_)
+#define _DL_LOAD_H_
+int dl_load_test(void);
+#endif
diff --git a/testsuites/libtests/dl12/dl12-o1.c b/testsuites/libtests/dl12/dl12-o1.c
index 0000000000..fe7b5d3185
--- /dev/null
+++ b/testsuites/libtests/dl12/dl12-o1.c
@@ -0,0 +1,42 @@
+ * are met:
+#include <rtems/test-printer.h>
+#define printf(...) rtems_printf(&rtems_test_printer, __VA_ARGS__);
+const void *dl_o1_func (void);
+ const char *str = "string_from_dl_o1_func";
+ printf(str);
+ return str;
diff --git a/testsuites/libtests/dl12/dl12-o2.c b/testsuites/libtests/dl12/dl12-o2.c
index 0000000000..9c975ba47e
--- /dev/null
+++ b/testsuites/libtests/dl12/dl12-o2.c
@@ -0,0 +1,42 @@
+ * are met:
+const void *dl_o2_func (void);
+ const char *str = "string_from_dl_o2_func";
+ printf(str);
+ return str;
diff --git a/testsuites/libtests/dl12/dl12.doc b/testsuites/libtests/dl12/dl12.doc
index 0000000000..70544877b2
--- /dev/null
+++ b/testsuites/libtests/dl12/dl12.doc
@@ -0,0 +1,47 @@
+# SPDX-License-Identifier: BSD-2-Clause
+# Copyright (c) 2014 Chris Johns <chrisj at rtems.org>
+# Redistribution and use in source and binary forms, with or without
+# modification, are permitted provided that the following conditions
+# are met:
+# 1. Redistributions of source code must retain the above copyright
+# notice, this list of conditions and the following disclaimer.
+# 2. Redistributions in binary form must reproduce the above copyright
+# notice, this list of conditions and the following disclaimer in the
+# documentation and/or other materials provided with the distribution.
+# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
+# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+# POSSIBILITY OF SUCH DAMAGE.
+This file describes the directives and concepts tested by this test set.
+test set name: dl12
+directives:
+ dlopen
+ dlinfo
+ dlsym
+ dlclose
+concepts:
++ Load an incrementally linked object.
++ Check there are no unresolved externals.
++ Locate the dl_o1_func symbol.
+ Call the dl_o1_func sym and store the returned address.
+ Locate the dl_o2_func symbol.
+ Call the dl_o2_func sym and store the returned address.
+ Compare the returned values. The addresses must not be the same.
++ Unload the object.
diff --git a/testsuites/libtests/dl12/dl12.scn b/testsuites/libtests/dl12/dl12.scn
index 0000000000..b01489cee1
--- /dev/null
+++ b/testsuites/libtests/dl12/dl12.scn
@@ -0,0 +1,15 @@
+*** BEGIN OF TEST libdl (RTL) 12 ***
+load: /dl12-inc.o
+handle: 0x4003d8d0 loaded
+About to call dl_o1_func at address 0x4003df80
+string_from_dl_o1_func
+dl_o1_func string literal address: 0x4003df40
+About to call dl_o2_func at address 0x4003dfa4
+string_from_dl_o2_func
+dl_o2_func string literal address: 0x4003df58
+handle: 0x4003d8d0 closed
+*** END OF TEST libdl (RTL) 12 ***
diff --git a/testsuites/libtests/dl12/init.c b/testsuites/libtests/dl12/init.c
index 0000000000..b2d6001a23
--- /dev/null
+++ b/testsuites/libtests/dl12/init.c
@@ -0,0 +1,103 @@
+ * are met:
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include "tmacros.h"
+#include <errno.h>
+#include <string.h>
+#include <stdint.h>
+#include <unistd.h>
+#include <rtems/rtl/rtl.h>
+#include <rtems/imfs.h>
+const char rtems_test_name[] = "libdl (RTL) 12";
+/* forward declarations to avoid warnings */
+static rtems_task Init(rtems_task_argument argument);
+#include "dl12-tar.h"
+#define TARFILE_START dl12_tar
+#define TARFILE_SIZE dl12_tar_size
+static int test(void)
+ int ret;
+ ret = dl_load_test();
+ if (ret)
+ rtems_test_exit(ret);
+ return 0;
+static void Init(rtems_task_argument arg)
+ int te;
+ TEST_BEGIN();
+ te = rtems_tarfs_load("/", (void *)TARFILE_START, (size_t)TARFILE_SIZE);
+ if (te != 0)
+ printf("untar failed: %d\n", te);
+ rtems_test_exit(1);
+ exit (1);
+ test();
+ TEST_END();
+ rtems_test_exit(0);
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
+#define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS 4
+#define CONFIGURE_MAXIMUM_TASKS 1
+#define CONFIGURE_MAXIMUM_SEMAPHORES 1
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#define CONFIGURE_INIT_TASK_STACK_SIZE (CONFIGURE_MINIMUM_TASK_STACK_SIZE + (4U * 1024U))
+#define CONFIGURE_INIT_TASK_ATTRIBUTES (RTEMS_DEFAULT_ATTRIBUTES | RTEMS_FLOATING_POINT)
+#include <rtems/confdefs.h>
2.44.0
