[PATCH] improved error checking in ticks per timeslice
zack leung
zakthertemsdev at gmail.com
Wed Mar 13 01:17:37 UTC 2024
ping
On Fri, 8 Mar 2024 at 22:03, <zakthertemsdev at gmail.com> wrote:
> From: Zack leung <z.liang111 at gmail.com>
> cpukit/doxygen/appl-config.h | 3 +--
> cpukit/include/rtems/confdefs/clock.h | 4 ++++
> 2 files changed, 5 insertions(+), 2 deletions(-)
> diff --git a/cpukit/doxygen/appl-config.h b/cpukit/doxygen/appl-config.h
> index bd7cde628f..f843ebbd39 100644
> --- a/cpukit/doxygen/appl-config.h
> +++ b/cpukit/doxygen/appl-config.h
> @@ -3312,8 +3312,7 @@
> * @parblock
> * The following constraints apply to this configuration option:
> - * * The value of the configuration option shall be greater than or equal
> to
> - * zero.
> + * * The value of the configuration option shall be greater than zero.
> * * The value of the configuration option shall be less than or equal to
> <a
> * href="https://en.cppreference.com/w/c/types/integer">UINT32_MAX</a>.
> diff --git a/cpukit/include/rtems/confdefs/clock.h
> b/cpukit/include/rtems/confdefs/clock.h
> index 26519cc70b..bb6c7e0b68 100644
> --- a/cpukit/include/rtems/confdefs/clock.h
> +++ b/cpukit/include/rtems/confdefs/clock.h
> @@ -70,6 +70,10 @@
> #warning "The clock ticks per second is not an integer"
> #endif
> +#if defined(CONFIGURE_TICKS_PER_TIMESLICE) &&
> CONFIGURE_TICKS_PER_TIMESLICE <= 0
> + #error "CONFIGURE_TICKS_PER_TIMESLICE shall be greater than zero"
> +#endif
> #if CONFIGURE_MICROSECONDS_PER_TICK <= 0
> #error "CONFIGURE_MICROSECONDS_PER_TICK must be positive"
> #endif
> 2.43.0
URL: <http://lists.rtems.org/pipermail/devel/attachments/20240312/c7e18c5c/attachment.htm>
