GSOC Task
Wed Mar 13 03:41:14 UTC 2024
Thanks. Please add yourself to the table at
https://devel.rtems.org/wiki/GSoC/2024 and (continue to) discuss your
project ideas here/Discord.
On Tue, Mar 12, 2024 at 2:10 PM Matheus Pecoraro <matpecor at gmail.com> wrote:
> Hello, I am a fresh graduate from Brazil. I have developed a simple
> x86_64 kernel in Rust in my free time and thus I am interested in the
> x86_64 BSP project.
> Although I did manage to compile the x86_64 BSP, the hello.exe test
> was hanging, so I did the task with the i386 BSP. I definitely need to
> take a further look into why that is since one of the commits mentions
> an addition that should make the test run successfully, it could be
> something about the way I tried to run it.
>  testsuites/samples/hello/init.c | 1 +
>  1 file changed, 1 insertion(+)
> diff --git a/testsuites/samples/hello/init.c b/testsuites/samples/hello/init.c
> index 83f6342ab3..69d6644784 100644
> --- a/testsuites/samples/hello/init.c
> +++ b/testsuites/samples/hello/init.c
> @@ -42,6 +42,7 @@ static rtems_task Init(
>    rtems_print_printer_fprintf_putc(&rtems_test_printer);
>    TEST_BEGIN();
>    printf( "Hello World\n" );
> +  printf( "Hello From i386\n" );
>    TEST_END();
>    rtems_test_exit( 0 );
> 2.43.0
> devel mailing list
> devel at rtems.org
