[PATCH rtems-libbsd] rtemsbsd: Remove old DHCP init prototype
Kinsey Moore kinsey.moore at oarcorp.com
Wed Mar 13 17:21:57 UTC 2024
This prototype should have been removed with commit
ac4db4cec5b6b1e0a25e910851e50831afb0749d.
 rtemsbsd/include/rtems/bsd/bsd.h | 22 ----------------------
 1 file changed, 22 deletions(-)
diff --git a/rtemsbsd/include/rtems/bsd/bsd.h b/rtemsbsd/include/rtems/bsd/bsd.h
index d5decbf2..7d79e547 100755
--- a/rtemsbsd/include/rtems/bsd/bsd.h
+++ b/rtemsbsd/include/rtems/bsd/bsd.h
@@ -97,28 +97,6 @@ typedef struct {
 rtems_status_code rtems_bsd_initialize(void);
- * @brief Initializes the libbsd and starts a DHCPCD task.
- * The libbsd is initialized via rtems_bsd_initialize().  If this is
- * successful, then the loop back interfaces are created.  If this is
- * successful, then a DHCPCD task is started at the least important priority.
- * The default devices of the BSP are initialized.  Support for
- *   - IF_BRIDGE(4),
- *   - LAGG(4),
- *   - multicast routing,
- *   - UNIX(4), and
- *   - VLAN(4),
- * is enabled.
- * No RTEMS shell commands are registered.
- * @retval RTEMS_SUCCESSFUL Successful operation.
- * @retval otherwise An error occurred.
-rtems_status_code rtems_bsd_initialize_dhcp(void);
  * @brief Configures the lo0 (loopback) interface.
2.39.2
