[PATCH] improved error checking in ticks per timeslice
Kinsey Moore kinsey.moore at oarcorp.com
Thu Mar 14 18:03:16 UTC 2024
It should be in the repo now.
On Thu, Mar 14, 2024 at 12:50 PM zack leung <zakthertemsdev at gmail.com>
wrote:
> Did you check in the code?
> Il mar 12 mar 2024, 21:55 Kinsey Moore <kinsey.moore at oarcorp.com> ha
> scritto:
>> Sorry, I missed this in the deluge of emails. Looks good to me.
>> Kinsey
>> On Tue, Mar 12, 2024 at 8:17 PM zack leung <zakthertemsdev at gmail.com>
>> wrote:
>>> ping
>>> On Fri, 8 Mar 2024 at 22:03, <zakthertemsdev at gmail.com> wrote:
>>>> From: Zack leung <z.liang111 at gmail.com>
>>>>  cpukit/doxygen/appl-config.h          | 3 +--
>>>>  cpukit/include/rtems/confdefs/clock.h | 4 ++++
>>>>  2 files changed, 5 insertions(+), 2 deletions(-)
>>>> diff --git a/cpukit/doxygen/appl-config.h b/cpukit/doxygen/appl-config.h
>>>> index bd7cde628f..f843ebbd39 100644
>>>> --- a/cpukit/doxygen/appl-config.h
>>>> +++ b/cpukit/doxygen/appl-config.h
>>>> @@ -3312,8 +3312,7 @@
>>>>   * @parblock
>>>>   * The following constraints apply to this configuration option:
>>>> - * * The value of the configuration option shall be greater than or
>>>> equal to
>>>> - *   zero.
>>>> + * * The value of the configuration option shall be greater than
>>>> zero.
>>>>   * * The value of the configuration option shall be less than or equal
>>>> to <a
>>>>   *   href="https://en.cppreference.com/w/c/types/integer
>>>> ">UINT32_MAX</a>.
>>>> diff --git a/cpukit/include/rtems/confdefs/clock.h
>>>> b/cpukit/include/rtems/confdefs/clock.h
>>>> index 26519cc70b..bb6c7e0b68 100644
>>>> --- a/cpukit/include/rtems/confdefs/clock.h
>>>> +++ b/cpukit/include/rtems/confdefs/clock.h
>>>> @@ -70,6 +70,10 @@
>>>>    #warning "The clock ticks per second is not an integer"
>>>>  #endif
>>>> +#if defined(CONFIGURE_TICKS_PER_TIMESLICE) &&
>>>> CONFIGURE_TICKS_PER_TIMESLICE <= 0
>>>> +  #error "CONFIGURE_TICKS_PER_TIMESLICE shall be greater than zero"
>>>> +#endif
>>>>  #if CONFIGURE_MICROSECONDS_PER_TICK <= 0
>>>>    #error "CONFIGURE_MICROSECONDS_PER_TICK must be positive"
>>>>  #endif
>>>> 2.43.0
>>>> _______________________________________________
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20240314/81833bf7/attachment.htm>
