[PATCH rtems-source-builder 1/2] rtems-tools-6.cfg: Bump hash to account for 5 months of changes
Chris Johns
chrisj at rtems.org
Thu Mar 14 23:47:30 UTC 2024
OK
Thanks
On 14/3/2024 7:00 am, Joel Sherrill wrote:
> In particular, the BSP set definitions for rtems-bsp-builder were
> out of sync with RTEMS and caused unnecessary failures reported to
> the build@ mailing list.
> rtems/config/tools/rtems-tools-6.cfg | 4 ++--
> 1 file changed, 2 insertions(+), 2 deletions(-)
> diff --git a/rtems/config/tools/rtems-tools-6.cfg b/rtems/config/tools/rtems-tools-6.cfg
> index 7ef2052..8abfeea 100644
> --- a/rtems/config/tools/rtems-tools-6.cfg
> +++ b/rtems/config/tools/rtems-tools-6.cfg
> @@ -10,14 +10,14 @@
> %define rtems_tools_source rtems-tools-%{rtems_tools_version}
> %define rtems_tools_ext xz
> %else
> - %define rtems_tools_version f408c0f8d935d53c232c67bed39e4018fd8d7a2a
> + %define rtems_tools_version 12971a8
> %define rtems_tools_ext bz2
> %endif
> %source set rtems-tools https://git.rtems.org/rtems-tools/snapshot/%{rtems_tools_source}.tar.%{rtems_tools_ext}
> %hash sha512 rtems-tools-%{rtems_tools_version}.tar.bz2 \
> - xZIWwcW4y9wOsIY+8XWDAxKk51TwKFHeOw39SS6zxrgE0LOFxfpy/SQeidCRvOUieQPbEmZRUdLyFW1UDEHh3w==
> + SrjY0gweRgWHmqBYj0wFnu1LFkaeNeS05SD1dKVzz2kvs3UCZ6AM8DrLbVe0q4H14DZwmrE3mMgbutsVev0Oxg==
> # Optionally enable/disable building the RTEMS Tools via the command line.
