RTEMS 7 GDB Build Failure on FreeBSD 13
Mon Mar 18 14:27:11 UTC 2024
Hi
I am going through the logs on the test sweep VMs to see why some builds
are failing. This is due to gdb's requirement for GMP and MPFR. What's the
recommended way to address this? Load native packages?
checking for the correct version of gmp.h... yes
checking for the correct version of mpfr.h... no
configure: error: Building GDB requires GMP 4.2+, and MPFR 3.1.0+.
Try the --with-gmp and/or --with-mpfr options to specify
their locations.  If you obtained GMP and/or MPFR from a vendor
distribution package, make sure that you have installed both the libraries
and the header files.  They may be located in separate packages.
shell cmd failed: /bin/sh -ex
 /usr/home/tester/rtems-cron-7/rtems-source-builde
Thanks.
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20240318/a921ef3d/attachment.htm>
