[PATCH 5/5] bsps: Add xilinx_zynqmp_lp64_a53 BSP variant
Sebastian Huber
Mon Mar 18 16:30:06 UTC 2024
Add a BSP variant without a board-specific name.
.../bsps/aarch64/xilinx-zynqmp/bspa53lp64.yml | 21 +++++++++++++++++++
.../bsps/aarch64/xilinx-zynqmp/optloadoff.yml | 1 +
.../bsps/aarch64/xilinx-zynqmp/optramori.yml | 1 +
spec/build/bsps/objxilinxsupportlp64.yml | 1 +
spec/build/bsps/optxilsupportpath.yml | 1 +
5 files changed, 25 insertions(+)
create mode 100644 spec/build/bsps/aarch64/xilinx-zynqmp/bspa53lp64.yml
diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/bspa53lp64.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/bspa53lp64.yml
new file mode 100644
index 0000000000..42316db4d3
--- /dev/null
+++ b/spec/build/bsps/aarch64/xilinx-zynqmp/bspa53lp64.yml
@@ -0,0 +1,21 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+arch: aarch64
+bsp: xilinx_zynqmp_lp64_a53
+build-type: bsp
+cflags: []
+copyrights:
+- Copyright (C) 2024 embedded brains GmbH
+cppflags: []
+enabled-by: true
+family: xilinx-zynqmp
+includes: []
+install: []
+links:
+- role: build-dependency
+ uid: grp
+ uid: linkcmds_lp64
+ uid: objfdtzynqmp
+source: []
+type: build
diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/optloadoff.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/optloadoff.yml
index 869181a95e..3a78b9af38 100644
--- a/spec/build/bsps/aarch64/xilinx-zynqmp/optloadoff.yml
+++ b/spec/build/bsps/aarch64/xilinx-zynqmp/optloadoff.yml
@@ -9,6 +9,7 @@ copyrights:
- Copyright (C) 2020 On-Line Applications Research (OAR)
default:
- enabled-by:
+ - aarch64/xilinx_zynqmp_lp64_a53
- aarch64/xilinx_zynqmp_ilp32_zu3eg
- aarch64/xilinx_zynqmp_lp64_cfc400x
- aarch64/xilinx_zynqmp_lp64_zu3eg
diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/optramori.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/optramori.yml
index c4d33094fb..33f0946532 100644
--- a/spec/build/bsps/aarch64/xilinx-zynqmp/optramori.yml
+++ b/spec/build/bsps/aarch64/xilinx-zynqmp/optramori.yml
default:
- enabled-by:
diff --git a/spec/build/bsps/objxilinxsupportlp64.yml b/spec/build/bsps/objxilinxsupportlp64.yml
index 330ffc34fd..252851a5aa 100644
--- a/spec/build/bsps/objxilinxsupportlp64.yml
+++ b/spec/build/bsps/objxilinxsupportlp64.yml
@@ -7,6 +7,7 @@ cppflags: []
cxxflags: []
enabled-by:
- bsps/aarch64/xilinx_versal
+- aarch64/xilinx_zynqmp_lp64_a53
- aarch64/xilinx_zynqmp_lp64_qemu
diff --git a/spec/build/bsps/optxilsupportpath.yml b/spec/build/bsps/optxilsupportpath.yml
index 298f9d5286..a90e6d3418 100644
--- a/spec/build/bsps/optxilsupportpath.yml
+++ b/spec/build/bsps/optxilsupportpath.yml
@@ -20,6 +20,7 @@ default:
value: arm/ARMv8/32bit
- enabled-by:
2.35.3
