[PATCH 1/5] bsps: Use bsps/aarch64/xilinx-zynqmp
Mon Mar 18 16:30:02 UTC 2024
 spec/build/bsps/dev/irq/optarmgic-icc-bpr0.yml    | 6 +-----
 spec/build/bsps/dev/irq/optarmgic-icc-igrpen0.yml | 6 +-----
 spec/build/cpukit/optsmp.yml                      | 6 +-----
 3 files changed, 3 insertions(+), 15 deletions(-)
diff --git a/spec/build/bsps/dev/irq/optarmgic-icc-bpr0.yml b/spec/build/bsps/dev/irq/optarmgic-icc-bpr0.yml
index 5338538de0..44d2671eb6 100644
--- a/spec/build/bsps/dev/irq/optarmgic-icc-bpr0.yml
+++ b/spec/build/bsps/dev/irq/optarmgic-icc-bpr0.yml
@@ -15,11 +15,7 @@ default:
   - aarch64/xilinx_versal_aiedge
   - aarch64/xilinx_versal_qemu
   - aarch64/xilinx_versal_vck190
-  - aarch64/xilinx_zynqmp_ilp32_qemu
-  - aarch64/xilinx_zynqmp_ilp32_zu3eg
-  - aarch64/xilinx_zynqmp_lp64_cfc400x
-  - aarch64/xilinx_zynqmp_lp64_qemu
-  - aarch64/xilinx_zynqmp_lp64_zu3eg
+  - bsps/aarch64/xilinx-zynqmp
   value: null
 - enabled-by: true
   value: 0x00000002
diff --git a/spec/build/bsps/dev/irq/optarmgic-icc-igrpen0.yml b/spec/build/bsps/dev/irq/optarmgic-icc-igrpen0.yml
index fbc2dd9227..9b552c3f96 100644
--- a/spec/build/bsps/dev/irq/optarmgic-icc-igrpen0.yml
+++ b/spec/build/bsps/dev/irq/optarmgic-icc-igrpen0.yml
   value: null
 - enabled-by: true
   value: 0x00000001
diff --git a/spec/build/cpukit/optsmp.yml b/spec/build/cpukit/optsmp.yml
index 45d41299da..f78558d6eb 100644
--- a/spec/build/cpukit/optsmp.yml
+++ b/spec/build/cpukit/optsmp.yml
@@ -13,11 +13,6 @@ default:
 description: |
   Enable the Symmetric Multiprocessing (SMP) support
 enabled-by:
-- aarch64/xilinx_zynqmp_ilp32_qemu
-- aarch64/xilinx_zynqmp_ilp32_zu3eg
-- aarch64/xilinx_zynqmp_lp64_cfc400x
-- aarch64/xilinx_zynqmp_lp64_qemu
-- aarch64/xilinx_zynqmp_lp64_zu3eg
 - arm/altcycv_devkit
 - arm/fvp_cortex_r52
 - arm/imx7
@@ -33,6 +28,7 @@ enabled-by:
 - arm/xilinx_zynq_picozed
 - arm/xilinx_zynq_pynq
 - arm/xilinx_zynq_microzed
+- bsps/aarch64/xilinx-zynqmp
 - i386/pc386
 - i386/pc486
 - i386/pc586
2.35.3
