[PATCH v2] bsps: Add BSP_FLUSH_KERNEL_CHAR_OUTPUT BSP option
Kinsey Moore kinsey.moore at oarcorp.com
Tue Mar 19 13:50:00 UTC 2024
The xilinx-zynqmp-rpu bsp_reset() is modified, but not included in the spec
file for the new option. Its family differs from the arm/xilinx-zynqmp BSP
family with a -rpu suffix. I'd be fine with this being enabled for the
AArch64 BSPs as well, but I imagine that's better as a separate patch.
Kinsey
On Tue, Mar 19, 2024 at 3:39 AM Sebastian Huber <
> Make the kernel I/O output character device flushing configurable.  The
> bsp_reset() function should reset the unit and do nothing else.
> The arm/xilinx-zynq and arm/xilinx-zynqmp BSPs were the only ones doing an
> UART
> flush in bsp_reset().  The bsp_reset() function should reset the system
> and do
> nothing more.  Doing additional things like flushing an UART device may not
> make sense for all applications.  Some applications may not use the UART
> device, so it may not be initialized and powered off.  Some applications
> may
> use it with an application-specific protocol which doesn't like the
> additional
> four '\r' during reset.  Doing a UART flush takes some time and some
> applications may prefer a fast reset cycle.  The bsp_reset() is the wrong
> place
> to do specific cleanup functions.
> Flushing the kernel I/O output character device is now optionally done in
> bsp_fatal_extension() depending on the new BSP option
> BSP_FLUSH_KERNEL_CHAR_OUTPUT.
>  bsps/aarch64/xilinx-zynqmp/console/console.c  |  3 ++-
>  bsps/aarch64/xilinx-zynqmp/include/bsp.h      |  2 --
>  bsps/arm/xilinx-zynq/console/debug-console.c  | 10 +++++++++
>  bsps/arm/xilinx-zynq/start/bspreset.c         |  4 ----
>  .../console/console-config.c                  |  3 ++-
>  bsps/arm/xilinx-zynqmp-rpu/include/bsp.h      |  2 --
>  bsps/arm/xilinx-zynqmp-rpu/start/bspreset.c   |  3 ---
>  .../xilinx-zynqmp/console/console-config.c    |  2 +-
>  bsps/arm/xilinx-zynqmp/include/bsp.h          |  2 --
>  bsps/arm/xilinx-zynqmp/start/bspreset.c       |  4 +---
>  bsps/include/bsp/bootcard.h                   |  5 +++++
>  bsps/shared/start/bspfatal-default.c          |  4 ++++
>  spec/build/bsps/bspopts.yml                   |  2 ++
>  spec/build/bsps/optflushkerncharout.yml       | 22 +++++++++++++++++++
>  14 files changed, 49 insertions(+), 19 deletions(-)
>  create mode 100644 spec/build/bsps/optflushkerncharout.yml
> diff --git a/bsps/aarch64/xilinx-zynqmp/console/console.c
> b/bsps/aarch64/xilinx-zynqmp/console/console.c
> index 9ce0b1da63..d1b2850952 100644
> --- a/bsps/aarch64/xilinx-zynqmp/console/console.c
> +++ b/bsps/aarch64/xilinx-zynqmp/console/console.c
> @@ -41,6 +41,7 @@
>  #include <rtems/termiostypes.h>
>  #include <bsp/aarch64-mmu.h>
> +#include <bsp/bootcard.h>
>  #include <bsp/fdt.h>
>  #include <bsp/irq.h>
> @@ -234,7 +235,7 @@ rtems_status_code console_initialize(
>    return RTEMS_SUCCESSFUL;
> -void zynqmp_debug_console_flush(void)
> +void bsp_flush_kernel_char_output(void)
>    zynq_uart_reset_tx_flush(&zynqmp_uart_instances[BSP_CONSOLE_MINOR]);
> diff --git a/bsps/aarch64/xilinx-zynqmp/include/bsp.h
> b/bsps/aarch64/xilinx-zynqmp/include/bsp.h
> index 0ccca8b196..d36abde415 100644
> --- a/bsps/aarch64/xilinx-zynqmp/include/bsp.h
> +++ b/bsps/aarch64/xilinx-zynqmp/include/bsp.h
> @@ -86,8 +86,6 @@ BSP_START_TEXT_SECTION void
> zynqmp_setup_mmu_and_cache(void);
>  BSP_START_TEXT_SECTION void zynqmp_setup_secondary_cpu_mmu_and_cache(
> void );
> -void zynqmp_debug_console_flush(void);
>  uint32_t zynqmp_clock_i2c0(void);
>  uint32_t zynqmp_clock_i2c1(void);
> diff --git a/bsps/arm/xilinx-zynq/console/debug-console.c
> b/bsps/arm/xilinx-zynq/console/debug-console.c
> index d398ca7988..67fcbdf4a1 100644
> --- a/bsps/arm/xilinx-zynq/console/debug-console.c
> +++ b/bsps/arm/xilinx-zynq/console/debug-console.c
> @@ -38,10 +38,20 @@
>  #include <rtems/sysinit.h>
>  #include <bsp.h>
>  #include <dev/serial/zynq-uart.h>
> +#include <dev/serial/zynq-uart-regs.h>
>  #include <bspopts.h>
> +  rtems_termios_device_context *base =
> +    &zynq_uart_instances[BSP_CONSOLE_MINOR].base;
> +  zynq_uart_reset_tx_flush(base);
>  static void zynq_debug_console_out(char c)
> diff --git a/bsps/arm/xilinx-zynq/start/bspreset.c
> b/bsps/arm/xilinx-zynq/start/bspreset.c
> index f8cc3b6999..fcdb1b8ded 100644
> --- a/bsps/arm/xilinx-zynq/start/bspreset.c
> +++ b/bsps/arm/xilinx-zynq/start/bspreset.c
> @@ -33,17 +33,13 @@
>   * POSSIBILITY OF SUCH DAMAGE.
> -#include <bsp.h>
> -#include <dev/serial/zynq-uart.h>
>  void bsp_reset(void)
>    volatile uint32_t *slcr_unlock = (volatile uint32_t *) 0xf8000008;
>    volatile uint32_t *pss_rst_ctrl = (volatile uint32_t *) 0xf8000200;
> -  zynq_uart_reset_tx_flush(&zynq_uart_instances[BSP_CONSOLE_MINOR]);
>    while (true) {
>      *slcr_unlock = 0xdf0d;
>      *pss_rst_ctrl = 0x1;
> diff --git a/bsps/arm/xilinx-zynqmp-rpu/console/console-config.c
> b/bsps/arm/xilinx-zynqmp-rpu/console/console-config.c
> index f52e008f2b..196b2dec58 100644
> --- a/bsps/arm/xilinx-zynqmp-rpu/console/console-config.c
> +++ b/bsps/arm/xilinx-zynqmp-rpu/console/console-config.c
> @@ -35,6 +35,7 @@
> @@ -79,7 +80,7 @@ rtems_status_code console_initialize(
> diff --git a/bsps/arm/xilinx-zynqmp-rpu/include/bsp.h
> b/bsps/arm/xilinx-zynqmp-rpu/include/bsp.h
> index e386bd4b26..060147967c 100644
> --- a/bsps/arm/xilinx-zynqmp-rpu/include/bsp.h
> +++ b/bsps/arm/xilinx-zynqmp-rpu/include/bsp.h
> @@ -83,8 +83,6 @@ extern "C" {
>  BSP_START_TEXT_SECTION void zynqmp_setup_mpu_and_cache(void);
>  #ifdef __cplusplus
>  #endif /* __cplusplus */
> diff --git a/bsps/arm/xilinx-zynqmp-rpu/start/bspreset.c
> b/bsps/arm/xilinx-zynqmp-rpu/start/bspreset.c
> index eecb4da838..a894f55f6e 100644
> --- a/bsps/arm/xilinx-zynqmp-rpu/start/bspreset.c
> +++ b/bsps/arm/xilinx-zynqmp-rpu/start/bspreset.c
> @@ -30,13 +30,10 @@
> -#include <bsp.h>
> -  zynqmp_debug_console_flush();
>    while (true) {
>      /* Wait */
> diff --git a/bsps/arm/xilinx-zynqmp/console/console-config.c
> b/bsps/arm/xilinx-zynqmp/console/console-config.c
> index eadd7f11a2..360d193ba2 100644
> --- a/bsps/arm/xilinx-zynqmp/console/console-config.c
> +++ b/bsps/arm/xilinx-zynqmp/console/console-config.c
> @@ -81,7 +81,7 @@ rtems_status_code console_initialize(
> diff --git a/bsps/arm/xilinx-zynqmp/include/bsp.h
> b/bsps/arm/xilinx-zynqmp/include/bsp.h
> index a08a5feee9..2785e4c2e0 100644
> --- a/bsps/arm/xilinx-zynqmp/include/bsp.h
> +++ b/bsps/arm/xilinx-zynqmp/include/bsp.h
> @@ -79,8 +79,6 @@ extern "C" {
>  BSP_START_TEXT_SECTION void zynqmp_setup_mmu_and_cache(void);
>  #ifdef __cplusplus
> diff --git a/bsps/arm/xilinx-zynqmp/start/bspreset.c
> b/bsps/arm/xilinx-zynqmp/start/bspreset.c
> index b43b19b05f..ed2f4da83a 100644
> --- a/bsps/arm/xilinx-zynqmp/start/bspreset.c
> +++ b/bsps/arm/xilinx-zynqmp/start/bspreset.c
> @@ -30,12 +30,10 @@
> -#include <bsp.h>
>    while (true) {
>      /* Wait */
> diff --git a/bsps/include/bsp/bootcard.h b/bsps/include/bsp/bootcard.h
> index 5f339d65f8..dfdc3ae7e0 100644
> --- a/bsps/include/bsp/bootcard.h
> +++ b/bsps/include/bsp/bootcard.h
> @@ -94,6 +94,11 @@ struct Per_CPU_Control;
>  void bsp_start_on_secondary_processor(struct Per_CPU_Control *cpu_self);
> + * @brief Flushes the kernel I/O output character device provided by the
> BSP.
> +void bsp_flush_kernel_char_output(void);
>  #ifdef __cplusplus
> diff --git a/bsps/shared/start/bspfatal-default.c
> b/bsps/shared/start/bspfatal-default.c
> index 557a0960fa..de3f414407 100644
> --- a/bsps/shared/start/bspfatal-default.c
> +++ b/bsps/shared/start/bspfatal-default.c
> @@ -184,6 +184,10 @@ void bsp_fatal_extension(
>      printk("\n");
>    #endif
> +  #if BSP_FLUSH_KERNEL_CHAR_OUTPUT
> +    bsp_flush_kernel_char_output();
> +  #endif
>     *  Check both conditions -- if you want to ask for reboot, then
>     *  you must have meant to reset the board.
> diff --git a/spec/build/bsps/bspopts.yml b/spec/build/bsps/bspopts.yml
> index 734292f421..b2d8ced4f6 100644
> --- a/spec/build/bsps/bspopts.yml
> +++ b/spec/build/bsps/bspopts.yml
> @@ -25,6 +25,8 @@ links:
>    uid: optincludes
>  - role: build-dependency
>    uid: optcflags
> +- role: build-dependency
> +  uid: optflushkerncharout
>    uid: optlinkflags
> diff --git a/spec/build/bsps/optflushkerncharout.yml
> b/spec/build/bsps/optflushkerncharout.yml
> new file mode 100644
> index 0000000000..845184663a
> --- /dev/null
> +++ b/spec/build/bsps/optflushkerncharout.yml
> @@ -0,0 +1,22 @@
> +SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
> +actions:
> +- get-integer: null
> +- define: null
> +build-type: option
> +copyrights:
> +- Copyright (C) 2024 embedded brains GmbH & Co. KG
> +default:
> +- enabled-by:
> +  - bsps/arm/xilinx-zynq
> +  - bsps/arm/xilinx-zynqmp
> +  value: 1
> +- enabled-by: true
> +  value: 0
> +description: |
> +  If defined to a non-zero value, flush the kernel I/O output character
> device
> +  provided by the BSP when the application exits.
> +enabled-by: true
> +format: '{}'
> +links: []
> +name: BSP_FLUSH_KERNEL_CHAR_OUTPUT
> +type: build
> 2.35.3
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20240319/9c2b381c/attachment-0001.htm>
