[PATCH] Do not define CONFIGURE_TICKS_PER_TIMESLICE to 0
Sebastian Huber
Wed Mar 20 07:28:31 UTC 2024
Unconditionally make a CONFIGURE_TICKS_PER_TIMESLICE value less than or equal
to zero an error.
Update #4986.
cpukit/doxygen/appl-config.h | 2 +-
cpukit/include/rtems/confdefs/clock.h | 3 +--
testsuites/ada/tmtests/tm01/init.c | 1 -
testsuites/ada/tmtests/tm02/init.c | 1 -
testsuites/ada/tmtests/tm03/init.c | 1 -
testsuites/ada/tmtests/tm04/init.c | 1 -
testsuites/ada/tmtests/tm05/init.c | 1 -
testsuites/ada/tmtests/tm06/init.c | 1 -
testsuites/ada/tmtests/tm07/init.c | 1 -
testsuites/ada/tmtests/tm08/init.c | 1 -
testsuites/ada/tmtests/tm09/init.c | 1 -
testsuites/ada/tmtests/tm10/init.c | 1 -
testsuites/ada/tmtests/tm11/init.c | 1 -
testsuites/ada/tmtests/tm12/init.c | 1 -
testsuites/ada/tmtests/tm13/init.c | 1 -
testsuites/ada/tmtests/tm14/init.c | 1 -
testsuites/ada/tmtests/tm15/init.c | 1 -
testsuites/ada/tmtests/tm16/init.c | 1 -
testsuites/ada/tmtests/tm17/init.c | 1 -
testsuites/ada/tmtests/tm18/init.c | 1 -
testsuites/ada/tmtests/tm19/init.c | 1 -
testsuites/ada/tmtests/tm20/init.c | 1 -
testsuites/ada/tmtests/tm21/init.c | 1 -
testsuites/ada/tmtests/tm22/init.c | 1 -
testsuites/ada/tmtests/tm23/init.c | 1 -
testsuites/ada/tmtests/tm24/init.c | 1 -
testsuites/ada/tmtests/tm25/init.c | 1 -
testsuites/ada/tmtests/tm28/init.c | 1 -
testsuites/ada/tmtests/tm29/init.c | 1 -
testsuites/ada/tmtests/tmck/init.c | 1 -
testsuites/rhealstone/rhdeadlockbrk/deadlockbrk.c | 1 -
testsuites/rhealstone/rhilatency/ilatency.c | 1 -
testsuites/rhealstone/rhmlatency/mlatency.c | 1 -
testsuites/rhealstone/rhtaskpreempt/taskpreempt.c | 1 -
testsuites/rhealstone/rhtaskswitch/taskswitch.c | 1 -
testsuites/tmtests/tm01/system.h | 1 -
testsuites/tmtests/tm02/system.h | 1 -
testsuites/tmtests/tm03/system.h | 1 -
testsuites/tmtests/tm04/system.h | 1 -
testsuites/tmtests/tm05/system.h | 1 -
testsuites/tmtests/tm06/system.h | 1 -
testsuites/tmtests/tm07/system.h | 1 -
testsuites/tmtests/tm08/system.h | 1 -
testsuites/tmtests/tm09/system.h | 1 -
testsuites/tmtests/tm10/system.h | 1 -
testsuites/tmtests/tm11/system.h | 1 -
testsuites/tmtests/tm12/system.h | 1 -
testsuites/tmtests/tm13/system.h | 1 -
testsuites/tmtests/tm14/system.h | 1 -
testsuites/tmtests/tm15/system.h | 1 -
testsuites/tmtests/tm16/system.h | 1 -
testsuites/tmtests/tm17/system.h | 1 -
testsuites/tmtests/tm18/system.h | 1 -
testsuites/tmtests/tm19/system.h | 1 -
testsuites/tmtests/tm20/system.h | 1 -
testsuites/tmtests/tm21/system.h | 1 -
testsuites/tmtests/tm22/system.h | 1 -
testsuites/tmtests/tm23/system.h | 1 -
testsuites/tmtests/tm24/system.h | 1 -
testsuites/tmtests/tm25/system.h | 1 -
testsuites/tmtests/tm26/system.h | 1 -
testsuites/tmtests/tm27/system.h | 1 -
testsuites/tmtests/tm28/system.h | 1 -
testsuites/tmtests/tm29/system.h | 1 -
testsuites/tmtests/tmck/system.h | 1 -
65 files changed, 2 insertions(+), 66 deletions(-)
diff --git a/cpukit/doxygen/appl-config.h b/cpukit/doxygen/appl-config.h
index 77c89dabf3..81150af066 100644
--- a/cpukit/doxygen/appl-config.h
+++ b/cpukit/doxygen/appl-config.h
@@ -3685,7 +3685,7 @@
* The following constraints apply to this configuration option:
* * The value of the configuration option shall be greater than or equal to
- * zero.
+ * one.
* * The value of the configuration option shall be less than or equal to <a
* href="https://en.cppreference.com/w/c/types/integer">UINT32_MAX</a>.
diff --git a/cpukit/include/rtems/confdefs/clock.h b/cpukit/include/rtems/confdefs/clock.h
index d35757561d..e57daa899b 100644
--- a/cpukit/include/rtems/confdefs/clock.h
+++ b/cpukit/include/rtems/confdefs/clock.h
@@ -70,8 +70,7 @@
#warning "The clock ticks per second is not an integer"
#endif
-#if defined(CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER) \
- && defined(CONFIGURE_TICKS_PER_TIMESLICE) \
+#if defined(CONFIGURE_TICKS_PER_TIMESLICE) \
&& CONFIGURE_TICKS_PER_TIMESLICE <= 0
#error "CONFIGURE_TICKS_PER_TIMESLICE shall be greater than zero"
#endif
diff --git a/testsuites/ada/tmtests/tm01/init.c b/testsuites/ada/tmtests/tm01/init.c
index 6c9ec3ff44..3154b15062 100644
--- a/testsuites/ada/tmtests/tm01/init.c
+++ b/testsuites/ada/tmtests/tm01/init.c
@@ -41,7 +41,6 @@
#define ADA_TEST_NAME "ADA TM 1"
#define CONFIGURE_MAXIMUM_SEMAPHORES 1
-#define CONFIGURE_TICKS_PER_TIMESLICE 0
#define CONFIGURE_POSIX_INIT_THREAD_TABLE
diff --git a/testsuites/ada/tmtests/tm02/init.c b/testsuites/ada/tmtests/tm02/init.c
index 84fc053e17..f393301465 100644
--- a/testsuites/ada/tmtests/tm02/init.c
+++ b/testsuites/ada/tmtests/tm02/init.c
@@ -42,7 +42,6 @@
#define ADA_TEST_NAME "ADA TM 2"
#define CONFIGURE_MAXIMUM_TIMERS 110
#define CONFIGURE_MAXIMUM_SEMAPHORES 101
diff --git a/testsuites/ada/tmtests/tm03/init.c b/testsuites/ada/tmtests/tm03/init.c
index 9e88b1cb55..5db2cc861e 100644
--- a/testsuites/ada/tmtests/tm03/init.c
+++ b/testsuites/ada/tmtests/tm03/init.c
@@ -42,7 +42,6 @@
#define ADA_TEST_NAME "ADA TM 3"
diff --git a/testsuites/ada/tmtests/tm04/init.c b/testsuites/ada/tmtests/tm04/init.c
index 826795e729..2f4312d1f9 100644
--- a/testsuites/ada/tmtests/tm04/init.c
+++ b/testsuites/ada/tmtests/tm04/init.c
@@ -41,7 +41,6 @@
#define ADA_TEST_NAME "ADA TM 4"
diff --git a/testsuites/ada/tmtests/tm05/init.c b/testsuites/ada/tmtests/tm05/init.c
index 9e0036e809..206e20af07 100644
--- a/testsuites/ada/tmtests/tm05/init.c
+++ b/testsuites/ada/tmtests/tm05/init.c
@@ -42,7 +42,6 @@
#define ADA_TEST_NAME "ADA TM 5"
diff --git a/testsuites/ada/tmtests/tm06/init.c b/testsuites/ada/tmtests/tm06/init.c
index e7da9b9a48..42c701d01a 100644
--- a/testsuites/ada/tmtests/tm06/init.c
+++ b/testsuites/ada/tmtests/tm06/init.c
@@ -42,7 +42,6 @@
#define ADA_TEST_NAME "ADA TM 6"
diff --git a/testsuites/ada/tmtests/tm07/init.c b/testsuites/ada/tmtests/tm07/init.c
index e2b2e476f9..582d4f2a77 100644
--- a/testsuites/ada/tmtests/tm07/init.c
+++ b/testsuites/ada/tmtests/tm07/init.c
@@ -42,7 +42,6 @@
#define ADA_TEST_NAME "ADA TM 7"
diff --git a/testsuites/ada/tmtests/tm08/init.c b/testsuites/ada/tmtests/tm08/init.c
index d7a38a816b..4f8baa894c 100644
--- a/testsuites/ada/tmtests/tm08/init.c
+++ b/testsuites/ada/tmtests/tm08/init.c
@@ -42,7 +42,6 @@
#define ADA_TEST_NAME "ADA TM 8"
diff --git a/testsuites/ada/tmtests/tm09/init.c b/testsuites/ada/tmtests/tm09/init.c
index 42482a2f69..6e881dde7c 100644
--- a/testsuites/ada/tmtests/tm09/init.c
+++ b/testsuites/ada/tmtests/tm09/init.c
@@ -41,7 +41,6 @@
#define ADA_TEST_NAME "ADA TM 9"
#define CONFIGURE_MAXIMUM_MESSAGE_QUEUES 1
diff --git a/testsuites/ada/tmtests/tm10/init.c b/testsuites/ada/tmtests/tm10/init.c
index 2102a33243..dad2ddbe21 100644
--- a/testsuites/ada/tmtests/tm10/init.c
+++ b/testsuites/ada/tmtests/tm10/init.c
@@ -41,7 +41,6 @@
#define ADA_TEST_NAME "ADA TM 10"
diff --git a/testsuites/ada/tmtests/tm11/init.c b/testsuites/ada/tmtests/tm11/init.c
index fe34ddf192..588f315dc2 100644
--- a/testsuites/ada/tmtests/tm11/init.c
+++ b/testsuites/ada/tmtests/tm11/init.c
@@ -41,7 +41,6 @@
#define ADA_TEST_NAME "ADA TM 11"
diff --git a/testsuites/ada/tmtests/tm12/init.c b/testsuites/ada/tmtests/tm12/init.c
index 7ac3debe6c..7f20fae43b 100644
--- a/testsuites/ada/tmtests/tm12/init.c
+++ b/testsuites/ada/tmtests/tm12/init.c
@@ -41,7 +41,6 @@
#define ADA_TEST_NAME "ADA TM 12"
diff --git a/testsuites/ada/tmtests/tm13/init.c b/testsuites/ada/tmtests/tm13/init.c
index 66a79607b6..e979602297 100644
--- a/testsuites/ada/tmtests/tm13/init.c
+++ b/testsuites/ada/tmtests/tm13/init.c
@@ -41,7 +41,6 @@
#define ADA_TEST_NAME "ADA TM 13"
diff --git a/testsuites/ada/tmtests/tm14/init.c b/testsuites/ada/tmtests/tm14/init.c
index c9ecdd5826..03d99d081a 100644
--- a/testsuites/ada/tmtests/tm14/init.c
+++ b/testsuites/ada/tmtests/tm14/init.c
@@ -41,7 +41,6 @@
#define ADA_TEST_NAME "ADA TM 14"
diff --git a/testsuites/ada/tmtests/tm15/init.c b/testsuites/ada/tmtests/tm15/init.c
index 710599245a..53e380d0a6 100644
--- a/testsuites/ada/tmtests/tm15/init.c
+++ b/testsuites/ada/tmtests/tm15/init.c
@@ -41,7 +41,6 @@
#define ADA_TEST_NAME "ADA TM 15"
diff --git a/testsuites/ada/tmtests/tm16/init.c b/testsuites/ada/tmtests/tm16/init.c
index b54f3559b5..aa7d907c66 100644
--- a/testsuites/ada/tmtests/tm16/init.c
+++ b/testsuites/ada/tmtests/tm16/init.c
@@ -41,7 +41,6 @@
#define ADA_TEST_NAME "ADA TM 16"
diff --git a/testsuites/ada/tmtests/tm17/init.c b/testsuites/ada/tmtests/tm17/init.c
index e9252771cb..c3ba070e1c 100644
--- a/testsuites/ada/tmtests/tm17/init.c
+++ b/testsuites/ada/tmtests/tm17/init.c
@@ -41,7 +41,6 @@
#define ADA_TEST_NAME "ADA TM 17"
diff --git a/testsuites/ada/tmtests/tm18/init.c b/testsuites/ada/tmtests/tm18/init.c
index 104134d726..29dc4f23e6 100644
--- a/testsuites/ada/tmtests/tm18/init.c
+++ b/testsuites/ada/tmtests/tm18/init.c
@@ -41,7 +41,6 @@
#define ADA_TEST_NAME "ADA TM 18"
diff --git a/testsuites/ada/tmtests/tm19/init.c b/testsuites/ada/tmtests/tm19/init.c
index 1961769118..634f2e0f2b 100644
--- a/testsuites/ada/tmtests/tm19/init.c
+++ b/testsuites/ada/tmtests/tm19/init.c
@@ -41,7 +41,6 @@
#define ADA_TEST_NAME "ADA TM 19"
diff --git a/testsuites/ada/tmtests/tm20/init.c b/testsuites/ada/tmtests/tm20/init.c
index 5f252c2f34..e9ae7d17d7 100644
--- a/testsuites/ada/tmtests/tm20/init.c
+++ b/testsuites/ada/tmtests/tm20/init.c
@@ -42,7 +42,6 @@
#define CONFIGURE_MAXIMUM_TASKS 3
#define ADA_TEST_NAME "ADA TM 20"
diff --git a/testsuites/ada/tmtests/tm21/init.c b/testsuites/ada/tmtests/tm21/init.c
index 06abc7b7f6..cc7de913f4 100644
--- a/testsuites/ada/tmtests/tm21/init.c
+++ b/testsuites/ada/tmtests/tm21/init.c
@@ -47,7 +47,6 @@
#define CONFIGURE_MAXIMUM_REGIONS 100
#define CONFIGURE_MAXIMUM_PORTS 100
#define CONFIGURE_MAXIMUM_PERIODS 100
#define CONFIGURE_MESSAGE_BUFFER_MEMORY \
(CONFIGURE_MAXIMUM_MESSAGE_QUEUES \
diff --git a/testsuites/ada/tmtests/tm22/init.c b/testsuites/ada/tmtests/tm22/init.c
index 929bf75b53..9ad7875a5f 100644
--- a/testsuites/ada/tmtests/tm22/init.c
+++ b/testsuites/ada/tmtests/tm22/init.c
@@ -41,7 +41,6 @@
#define ADA_TEST_NAME "ADA TM 22"
diff --git a/testsuites/ada/tmtests/tm23/init.c b/testsuites/ada/tmtests/tm23/init.c
index 951933f1f4..768bd95df8 100644
--- a/testsuites/ada/tmtests/tm23/init.c
+++ b/testsuites/ada/tmtests/tm23/init.c
@@ -41,7 +41,6 @@
#define ADA_TEST_NAME "ADA TM 23"
diff --git a/testsuites/ada/tmtests/tm24/init.c b/testsuites/ada/tmtests/tm24/init.c
index b90daf0738..8b25ab46bd 100644
--- a/testsuites/ada/tmtests/tm24/init.c
+++ b/testsuites/ada/tmtests/tm24/init.c
@@ -40,7 +40,6 @@
#define CONFIGURE_MAXIMUM_TASKS 111
#define ADA_TEST_NAME "ADA TM 24"
diff --git a/testsuites/ada/tmtests/tm25/init.c b/testsuites/ada/tmtests/tm25/init.c
index 0ebf5a934b..e0bb5bf4f3 100644
--- a/testsuites/ada/tmtests/tm25/init.c
+++ b/testsuites/ada/tmtests/tm25/init.c
@@ -41,7 +41,6 @@
#define ADA_TEST_NAME "ADA TM 25"
diff --git a/testsuites/ada/tmtests/tm28/init.c b/testsuites/ada/tmtests/tm28/init.c
index 484756174c..542135b84e 100644
--- a/testsuites/ada/tmtests/tm28/init.c
+++ b/testsuites/ada/tmtests/tm28/init.c
@@ -41,7 +41,6 @@
#define ADA_TEST_NAME "ADA TM 28"
diff --git a/testsuites/ada/tmtests/tm29/init.c b/testsuites/ada/tmtests/tm29/init.c
index 3f12731be8..f0c509c9b0 100644
--- a/testsuites/ada/tmtests/tm29/init.c
+++ b/testsuites/ada/tmtests/tm29/init.c
@@ -41,7 +41,6 @@
#define ADA_TEST_NAME "ADA TM 29"
#define CONFIGURE_MAXIMUM_PERIODS 111
diff --git a/testsuites/ada/tmtests/tmck/init.c b/testsuites/ada/tmtests/tmck/init.c
index ae32bcc9e7..8c0682be41 100644
--- a/testsuites/ada/tmtests/tmck/init.c
+++ b/testsuites/ada/tmtests/tmck/init.c
@@ -41,7 +41,6 @@
#define ADA_TEST_NAME "ADA TMCK"
diff --git a/testsuites/rhealstone/rhdeadlockbrk/deadlockbrk.c b/testsuites/rhealstone/rhdeadlockbrk/deadlockbrk.c
index 3538003a4a..8154c93338 100644
--- a/testsuites/rhealstone/rhdeadlockbrk/deadlockbrk.c
+++ b/testsuites/rhealstone/rhdeadlockbrk/deadlockbrk.c
@@ -206,7 +206,6 @@ rtems_task Task03( rtems_task_argument ignored )
#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
#define CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER
#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
#define CONFIGURE_MAXIMUM_TASKS 4
diff --git a/testsuites/rhealstone/rhilatency/ilatency.c b/testsuites/rhealstone/rhilatency/ilatency.c
index 2f6b185604..8985453619 100644
--- a/testsuites/rhealstone/rhilatency/ilatency.c
+++ b/testsuites/rhealstone/rhilatency/ilatency.c
@@ -22,7 +22,6 @@
#define CONFIGURE_MAXIMUM_TASKS 2
#define CONFIGURE_SCHEDULER_PRIORITY
diff --git a/testsuites/rhealstone/rhmlatency/mlatency.c b/testsuites/rhealstone/rhmlatency/mlatency.c
index a61e1917e5..76b1113644 100644
--- a/testsuites/rhealstone/rhmlatency/mlatency.c
+++ b/testsuites/rhealstone/rhmlatency/mlatency.c
@@ -151,7 +151,6 @@ rtems_task Task02( rtems_task_argument ignored )
CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE(1, MESSAGE_SIZE)
#define CONFIGURE_INIT
diff --git a/testsuites/rhealstone/rhtaskpreempt/taskpreempt.c b/testsuites/rhealstone/rhtaskpreempt/taskpreempt.c
index c5d2b6c809..00534b094d 100644
--- a/testsuites/rhealstone/rhtaskpreempt/taskpreempt.c
+++ b/testsuites/rhealstone/rhtaskpreempt/taskpreempt.c
@@ -113,7 +113,6 @@ rtems_task Init( rtems_task_argument ignored )
/* configuration information */
diff --git a/testsuites/rhealstone/rhtaskswitch/taskswitch.c b/testsuites/rhealstone/rhtaskswitch/taskswitch.c
index a2cef9fe32..3bcf1ec354 100644
--- a/testsuites/rhealstone/rhtaskswitch/taskswitch.c
+++ b/testsuites/rhealstone/rhtaskswitch/taskswitch.c
@@ -115,7 +115,6 @@ rtems_task Init( rtems_task_argument ignored )
diff --git a/testsuites/tmtests/tm01/system.h b/testsuites/tmtests/tm01/system.h
index 10f694482f..d5f60d3c83 100644
--- a/testsuites/tmtests/tm01/system.h
+++ b/testsuites/tmtests/tm01/system.h
@@ -50,7 +50,6 @@ rtems_id Task_id[ OPERATION_COUNT+1 ]; /* array of task ids */
diff --git a/testsuites/tmtests/tm02/system.h b/testsuites/tmtests/tm02/system.h
index 0b2e4fb59a..66d3912f5a 100644
--- a/testsuites/tmtests/tm02/system.h
+++ b/testsuites/tmtests/tm02/system.h
@@ -47,7 +47,6 @@ rtems_task Init(
#define CONFIGURE_MAXIMUM_TASKS (3 + OPERATION_COUNT)
diff --git a/testsuites/tmtests/tm03/system.h b/testsuites/tmtests/tm03/system.h
--- a/testsuites/tmtests/tm03/system.h
+++ b/testsuites/tmtests/tm03/system.h
diff --git a/testsuites/tmtests/tm04/system.h b/testsuites/tmtests/tm04/system.h
index ecad2b492f..a330fde825 100644
--- a/testsuites/tmtests/tm04/system.h
+++ b/testsuites/tmtests/tm04/system.h
#define CONFIGURE_MAXIMUM_TASKS (4 + OPERATION_COUNT)
diff --git a/testsuites/tmtests/tm05/system.h b/testsuites/tmtests/tm05/system.h
index f00b626c36..28263f3051 100644
--- a/testsuites/tmtests/tm05/system.h
+++ b/testsuites/tmtests/tm05/system.h
@@ -46,7 +46,6 @@ rtems_task Init(
#define CONFIGURE_MAXIMUM_TASKS (2 + OPERATION_COUNT)
diff --git a/testsuites/tmtests/tm06/system.h b/testsuites/tmtests/tm06/system.h
--- a/testsuites/tmtests/tm06/system.h
+++ b/testsuites/tmtests/tm06/system.h
diff --git a/testsuites/tmtests/tm07/system.h b/testsuites/tmtests/tm07/system.h
--- a/testsuites/tmtests/tm07/system.h
+++ b/testsuites/tmtests/tm07/system.h
diff --git a/testsuites/tmtests/tm08/system.h b/testsuites/tmtests/tm08/system.h
index 253cdaba54..7d642bd0a8 100644
--- a/testsuites/tmtests/tm08/system.h
+++ b/testsuites/tmtests/tm08/system.h
diff --git a/testsuites/tmtests/tm09/system.h b/testsuites/tmtests/tm09/system.h
index 3d12c68d07..da2da0b2ec 100644
--- a/testsuites/tmtests/tm09/system.h
+++ b/testsuites/tmtests/tm09/system.h
@@ -51,7 +51,6 @@ rtems_id Task_id[ OPERATION_COUNT+1 ]; /* array of task ids */
CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE(OPERATION_COUNT, MESSAGE_SIZE)
diff --git a/testsuites/tmtests/tm10/system.h b/testsuites/tmtests/tm10/system.h
index ed5e9a12bb..e4c296f625 100644
--- a/testsuites/tmtests/tm10/system.h
+++ b/testsuites/tmtests/tm10/system.h
CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE(OPERATION_COUNT, 16)
diff --git a/testsuites/tmtests/tm11/system.h b/testsuites/tmtests/tm11/system.h
index d4fa9fd404..9a2fc14aab 100644
--- a/testsuites/tmtests/tm11/system.h
+++ b/testsuites/tmtests/tm11/system.h
diff --git a/testsuites/tmtests/tm12/system.h b/testsuites/tmtests/tm12/system.h
--- a/testsuites/tmtests/tm12/system.h
+++ b/testsuites/tmtests/tm12/system.h
diff --git a/testsuites/tmtests/tm13/system.h b/testsuites/tmtests/tm13/system.h
--- a/testsuites/tmtests/tm13/system.h
+++ b/testsuites/tmtests/tm13/system.h
diff --git a/testsuites/tmtests/tm14/system.h b/testsuites/tmtests/tm14/system.h
--- a/testsuites/tmtests/tm14/system.h
+++ b/testsuites/tmtests/tm14/system.h
diff --git a/testsuites/tmtests/tm15/system.h b/testsuites/tmtests/tm15/system.h
index 9586199d27..fffabdf844 100644
--- a/testsuites/tmtests/tm15/system.h
+++ b/testsuites/tmtests/tm15/system.h
@@ -48,7 +48,6 @@ rtems_id Task_id[ OPERATION_COUNT+1 ]; /* array of task ids */
diff --git a/testsuites/tmtests/tm16/system.h b/testsuites/tmtests/tm16/system.h
index b495e374b2..9eb6d69e85 100644
--- a/testsuites/tmtests/tm16/system.h
+++ b/testsuites/tmtests/tm16/system.h
diff --git a/testsuites/tmtests/tm17/system.h b/testsuites/tmtests/tm17/system.h
--- a/testsuites/tmtests/tm17/system.h
+++ b/testsuites/tmtests/tm17/system.h
diff --git a/testsuites/tmtests/tm18/system.h b/testsuites/tmtests/tm18/system.h
--- a/testsuites/tmtests/tm18/system.h
+++ b/testsuites/tmtests/tm18/system.h
diff --git a/testsuites/tmtests/tm19/system.h b/testsuites/tmtests/tm19/system.h
index 3051d62961..bbae1e537f 100644
--- a/testsuites/tmtests/tm19/system.h
+++ b/testsuites/tmtests/tm19/system.h
diff --git a/testsuites/tmtests/tm20/system.h b/testsuites/tmtests/tm20/system.h
index 3128bad743..145477232d 100644
--- a/testsuites/tmtests/tm20/system.h
+++ b/testsuites/tmtests/tm20/system.h
#define CONFIGURE_MAXIMUM_PARTITIONS 1
diff --git a/testsuites/tmtests/tm21/system.h b/testsuites/tmtests/tm21/system.h
index 53f3c01353..ef4e35fc7d 100644
--- a/testsuites/tmtests/tm21/system.h
+++ b/testsuites/tmtests/tm21/system.h
@@ -58,7 +58,6 @@ rtems_task Init(
#define CONFIGURE_MAXIMUM_PORTS OPERATION_COUNT
#define CONFIGURE_MAXIMUM_PERIODS OPERATION_COUNT
diff --git a/testsuites/tmtests/tm22/system.h b/testsuites/tmtests/tm22/system.h
index d256595fe7..621043dc7c 100644
--- a/testsuites/tmtests/tm22/system.h
+++ b/testsuites/tmtests/tm22/system.h
@@ -49,7 +49,6 @@ rtems_task Init(
diff --git a/testsuites/tmtests/tm23/system.h b/testsuites/tmtests/tm23/system.h
index edee889a9e..41722a2c39 100644
--- a/testsuites/tmtests/tm23/system.h
+++ b/testsuites/tmtests/tm23/system.h
#define CONFIGURE_MAXIMUM_TASKS (1 + OPERATION_COUNT)
#define CONFIGURE_MAXIMUM_TIMERS OPERATION_COUNT
diff --git a/testsuites/tmtests/tm24/system.h b/testsuites/tmtests/tm24/system.h
--- a/testsuites/tmtests/tm24/system.h
+++ b/testsuites/tmtests/tm24/system.h
diff --git a/testsuites/tmtests/tm25/system.h b/testsuites/tmtests/tm25/system.h
index 112881f52a..423a30eba8 100644
--- a/testsuites/tmtests/tm25/system.h
+++ b/testsuites/tmtests/tm25/system.h
diff --git a/testsuites/tmtests/tm26/system.h b/testsuites/tmtests/tm26/system.h
index 762a7051b0..d66dfa81dd 100644
--- a/testsuites/tmtests/tm26/system.h
+++ b/testsuites/tmtests/tm26/system.h
#define CONFIGURE_MAXIMUM_TASKS (6 + OPERATION_COUNT)
#define CONFIGURE_INIT_TASK_ATTRIBUTES RTEMS_FLOATING_POINT
diff --git a/testsuites/tmtests/tm27/system.h b/testsuites/tmtests/tm27/system.h
index b3f40c9d8c..4a2723bcd4 100644
--- a/testsuites/tmtests/tm27/system.h
+++ b/testsuites/tmtests/tm27/system.h
diff --git a/testsuites/tmtests/tm28/system.h b/testsuites/tmtests/tm28/system.h
index f570f52849..bec8393510 100644
--- a/testsuites/tmtests/tm28/system.h
+++ b/testsuites/tmtests/tm28/system.h
@@ -49,7 +49,6 @@ rtems_id Task_id[ OPERATION_COUNT+1 ]; /* array of task ids */
diff --git a/testsuites/tmtests/tm29/system.h b/testsuites/tmtests/tm29/system.h
index 0c8e6e48cf..380878abb0 100644
--- a/testsuites/tmtests/tm29/system.h
+++ b/testsuites/tmtests/tm29/system.h
#define CONFIGURE_INIT_TASK_STACK_SIZE (RTEMS_MINIMUM_STACK_SIZE * 2)
diff --git a/testsuites/tmtests/tmck/system.h b/testsuites/tmtests/tmck/system.h
index 6a33ed4374..6fad74389e 100644
--- a/testsuites/tmtests/tmck/system.h
+++ b/testsuites/tmtests/tmck/system.h
@@ -48,7 +48,6 @@ rtems_name Task_name[ OPERATION_COUNT+1 ]; /* array of task names */
2.35.3
