[PATCH v2] bsps: Add BSP_FLUSH_KERNEL_CHAR_OUTPUT BSP option
    Sebastian Huber
    Wed Mar 20 15:11:32 UTC 2024
On 19.03.24 18:44, Chris Johns wrote:
> On 20/3/2024 2:03 am, Sebastian Huber wrote:
>> On 19.03.24 14:50, Kinsey Moore wrote:
>>> The xilinx-zynqmp-rpu bsp_reset() is modified, but not included in the spec
>>> file for the new option. Its family differs from the arm/xilinx-zynqmp BSP
>>> family with a -rpu suffix.
>> Yes, but this BSP is quite new. I would prefer to let it not flush anything by
>> default to carry out a reset.
>>> I'd be fine with this being enabled for the AArch64 BSPs as well, but I
>>> imagine that's better as a separate patch.
>> Why should it be enabled by default? The arm/xilinx-zynq and arm/xilinx-zynqmp
>> BSPs were the only ones doing an UART flush in the general termination
>> procedure. It probably was done to address a specific use case (maybe test runs).
> Is the issue the flush is before an infinite loop which means the UART FIFO
> should drain?
>> I don't really like the new bsp_flush_kernel_char_output() function. Another
>> approach could be an API change of
>>   * @ingroup RTEMSAPIKernelCharIO
>>   * @brief Polled character output functions shall have this type.
>> typedef void ( *BSP_output_char_function_type )( char );
>> to something like this
>> typedef int ( *BSP_output_char_function_type )( int action );
>> If action in {0, ..., 255}, then print out the character. If 0x100 is set, then
>> flush the output device. If 0x200 is set, then do Y... The return value could be
>> used to give a status indication.
>> This could then be use for example by test runs, to flush the test output after
>> the end of the test.
> This also requires a code change so is a flush function that bad an option?
You can change the character output handler since this is only a global
variable (BSP_output_char). So, this bsp_flush_kernel_char_output() may
not flush the device used by BSP_output_char. Doing a flush through the
output handler lets you do the flush for the currently used device.
If we change the function type to
then we can add more features later if needed. Another feature which
could be useful is: Output char immediately if possible and return 0,
otherwise do nothing and return -1. This can be used to implement a
full-duplex transfer in polling mode for the kernel I/O stream.
embedded brains GmbH & Co. KG
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
