[Docs] c-user: Clarify CONFIGURE_TICKS_PER_TIMESLICE
Thu Mar 21 14:05:12 UTC 2024
Isn't this content generated from rtems-central?
Shouldn't there also be a change there?
--joel
On Wed, Mar 20, 2024 at 9:24 AM Sebastian Huber <
> Close #4986.
>  c-user/config/general.rst | 2 +-
>  1 file changed, 1 insertion(+), 1 deletion(-)
> diff --git a/c-user/config/general.rst b/c-user/config/general.rst
> index 5ff79e7..61bfa1e 100644
> --- a/c-user/config/general.rst
> +++ b/c-user/config/general.rst
> @@ -1017,7 +1017,7 @@ configured, see
> :ref:`CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER`.
>  The following constraints apply to this configuration option:
> -* The value of the configuration option shall be greater than or equal to
> zero.
> +* The value of the configuration option shall be greater than or equal to
> one.
>  * The value of the configuration option shall be less than or equal to
>    `UINT32_MAX <https://en.cppreference.com/w/c/types/integer>`_.
> 2.35.3
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20240321/243e259d/attachment.htm>
