EPICS ioc with RTEMS on Raspberry Pi
Wed Oct 14 23:05:05 UTC 2026
Miroslaw thanks for tracking this down.
Do you have an account on gitlab.rtems.org?
I think this needs a work item (formerly known as an issue) for main.
And a merge request.
@gedare This seems like it should be backported to 6. Thoughts?
--joel
On Wed, Oct 14, 2026 at 5:13 PM Miroslaw Dach <miroslaw.dach at gmail.com>
wrote:
> Hi Gedare,
> The issue with RTEMS on RPi 3B+ was solved.
> The problem was in the Raspberry Pi BSP interrupt dispatcher that makes
> the whole system stop under interrupt load. We hit it on a Raspberry Pi 3
> Model B+ running an EPICS 7.0.10 IOC with rtems-libbsd (USB Ethernet) on
> RTEMS 6.2;
> Symptom
> With network traffic on the LAN7800 USB Ethernet the board froze after
> 30 s to 3 min, idle after a few minutes: console dead, no task runs, an
> externally visible "heartbeat" stops. It looked like a bus or CPU lockup
> and we spent months on USB controller theories. Earlier reports of
> "RTEMS hangs on Raspberry Pi with USB/network" on the lists may be the
> same issue.
> Root cause
> bsp_interrupt_dispatch() in bsps/arm/raspberrypi/irq/irq.c reads
> BCM2835_IRQ_BASIC and, when any "speed-up" bit is set, calls ffs() on
> the UNMASKED value:
>     pend = BCM2835_REG(BCM2835_IRQ_BASIC);
>     if ( pend & BCM2835_IRQ_BASIC_SPEEDUP_USED_BITS ) {
>       pend_bit = ffs(pend) - 1;
>       vector = bcm2835_irq_speedup_table[pend_bit];
> Bit 8 of IRQ_BASIC ("one or more bits set in pending register 1") is set
> whenever a bank-1 interrupt without a speed-up bit is pending, for
> example the system timer compare 3 used for the clock tick (GPU IRQ 3).
> If such an interrupt is pending at the same time as a speed-up one, for
> example USB (GPU IRQ 9, speed-up bit 11), the register reads 0x900.
> ffs(0x900) - 1 = 8, bcm2835_irq_speedup_table[8] is -1, vector becomes
> 0xffffffff, the check "vector < 255" fails, no handler is called, the
> interrupt stays asserted and the CPU re-enters the dispatcher forever.
> We confirmed this with a RAM trace that survives a watchdog reset: the
> last 600 entries of every frozen run were the IRQ_BASIC read returning
> 0x900, about 1.3 million times per second, with no handler call in
> between. The probability per interrupt is small, so the failure rate
> scales with the interrupt rate; with ~40000 USB interrupts/s and a 2 kHz
> tick it took about 30 s.
> Fix
> Mask the value before the bit scan. With 0x900 the USB interrupt is then
> dispatched first; the immediate re-entry sees 0x100, takes the
> IRQ_PENDING1 path and dispatches the tick.
> Tested on Raspberry Pi 3B+ (raspberrypi2 BSP, RTEMS 6.2 be446b02d0,
> rtems-libbsd 6-freebsd-14, EPICS 7.0.10): 15.5 hours of continuous
> operation with 450 million USB transfers and 1.8 billion interrupts,
> versus a freeze within a minute before the change.
> The patch could be found in the attachment.
> Best Regards
> Mirek
> czw., 21 maj 2026 o 14:41 Miroslaw Dach <miroslaw.dach at gmail.com>
> napisał(a):
>> Hi Gedare,
>> Thanks for the good news about the RPi4. Please let me know when you have
>> some results and working RPi4 with RTEMS.
>> Did anybody try the lwIP network stack for RTEMS?
>> Best Regards
>> Mirek
>> wt., 19 maj 2026 o 15:18 Gedare Bloom <gedare at rtems.org> napisał(a):
>>> Just a quick note that the preferred venue for community engagement is
>>> shifting toward https://users.rtems.org
>>> I think the RPi4 is maturing quite rapidly. We have a GSoC project
>>> focused on it as well.
>>> lwIP might also be an option to consider.
>>> On Fri, May 8, 2026 at 4:00 PM Miroslaw Dach <miroslaw.dach at gmail.com>
>>> wrote:
>>> > Hi John,
>>> > Many Thanks for your reply and all of the hints. It looks like that at
>>> present there is no good solution to use RTEMS on RPi 3 b+ due to the issue
>>> with the
>>> > usb-Network bridge. The most promising approach would be to use the
>>> PRi v4 or v5  since the network chip is directly connected to the system
>>> but the BSP is not yet complete for RTEMS so maybe in the future.
>>> > Best Regards
>>> > Mirek
>>> > sob., 25 kwi 2026 o 10:37 John Howard <echosoft.llc at gmail.com>
>>> napisał(a):
>>> >> Hi Mirek,
>>> >> I don't know what to tell you about this issue. You know more about
>>> the details than I do.
>>> >> (I don't know what EPICS IOC does.)
>>> >> I knew RTEMS didn't use FIQ, but I assumed a 32/64-bit FreeBSD for
>>> Raspberry Pi didn't either. Why not a continuing FIQ issue on their mailing
>>> list after all this time? I haven't used FreeBSD for RPi (too many security
>>> holes to me). I use Debian Bullseye for my 3B+ and I am not happy with
>>> Linux.
>>> >> I don't expect this to occur on RPi Zero 2 W because it lacks the
>>> Ethernet subsystem and has a newer revision of the 3B+ subsystem. (I will
>>> deal with it later during my app testing phase.)
>>> >> I am not the CODEOWNER at RTEMS.org for that Dynaware/Synopsis driver.
>>> >> I do know that Synopsis released it unlicensed AS IS but is willing
>>> to license it under obligation for their customers.
>>> >> I recently looked at an alternative kernel memory map document where
>>> FIQ stacks are present for RPi 3B+ when Aarch32, but I can't find them when
>>> Aarch64 which standardized calling conventions.
>>> >> Sorry I couldn't be of much help to you on this issue. Dealing with
>>> FIQ handling is as idiosyncratic as it gets on Raspberry Pi and is a
>>> deal-breaker to me.
>>> >> -- John
>>> >> On Apr 22, 2026, at 10:28 PM, Miroslaw Dach <miroslaw.dach at gmail.com>
>>> wrote:
>>> >> Hi John,
>>> >> Thanks for your e-mail and your suggestion.
>>> >> Follow-up to my earlier report about the DWC OTG USB hang on RPi 3B+
>>> >> with RTEMS 6. I've done extensive instrumentation and applied BCM2835-
>>> >> specific errata workarounds from the Linux dwc2 driver. Here are the
>>> >> complete findings:
>>> >> I added diagnostic counters (#ifdef __rtems__) to the FreeBSD dwc_otg
>>> >> driver, printed every 1 second from the 10ms timer callback:
>>> >> - yld:   times dwc_otg_interrupt_poll_locked() hit its 16-iteration
>>> cap
>>> >> - afail: times dwc_otg_host_channel_alloc() failed (no free channels)
>>> >> - hok:   successful halt completions processed
>>> >> - rxd:   RX data discarded (no active endpoint listening)
>>> >> - stuck: channels with wait_halted=1 but allocated=0 (leaked channels)
>>> >> - filt:  filter ISR entry/exit count (to detect stuck ISR)
>>> >> - thr:   thread handler entry/exit count
>>> >> - gi:    last GINTSTS register value
>>> >> Results: channel exhaustion theory DISPROVED
>>> >> Across all tests, every counter remained perfectly healthy right up to
>>> >> the instant of the freeze:
>>> >>   DWC_OTG t=17500: yld=0 afail=0 hok=180038 rxd=0 ch=8/16
>>> >>       alloc=0 wh=0 stuck=0 filt=738178/738178 thr=7280/7280
>>> >>       gi=0x04000031
>>> >> - yld=0:     the 16-iteration poll loop cap was NEVER hit
>>> >> - afail=0:   channel allocation NEVER failed
>>> >> - stuck=0:   NO channels ever leaked (wait_halted was always cleared)
>>> >> - filt balanced: filter ISR entered and exited the same number of
>>> times
>>> >> - thr balanced:  thread handler entered and exited the same number of
>>> times
>>> >> - gi=0x04000031: benign (host mode + TX FIFOs empty + RX FIFO
>>> non-empty)
>>> >> The ~1054 halt completions/second were steady with no degradation.
>>> >> Results: total CPU freeze, not software deadlock
>>> >> I also tried an independent RTEMS timer (rtems_timer_fire_after) as a
>>> >> heartbeat, firing outside the USB bus lock. Both the USB timer and the
>>> >> independent heartbeat stopped simultaneously, confirming the entire
>>> ARM
>>> >> core freezes — not just the USB subsystem.
>>> >> No RTEMS fatal error handler was triggered (I installed one via
>>> >> CONFIGURE_INITIAL_EXTENSIONS). This means it is NOT a standard ARM
>>> >> data abort — the CPU simply stops executing, likely due to an AHB bus
>>> >> lockup caused by the DWC OTG controller hardware.
>>> >> BCM2835 errata workarounds applied
>>> >> Based on the Linux dwc2 driver (params.c, core.c) and the Ultibo
>>> >> project documentation, I applied three workarounds:
>>> >> 1. FIFO size cap: BCM2835 hardware reports 4096 words but only 4080
>>> >>    exist. Cap sc_fifo_size to 4080*4 bytes to prevent FIFO overrun.
>>> >>    (In practice, the hardware on my board reported <= 4080, so this
>>> >>    cap was NOT triggered.)
>>> >> 2. GAHBCFG AHB burst configuration: Broadcom redefined bits [4:1] of
>>> >>    GAHBCFG for AXI burst control. Linux dwc2 sets ahbcfg=0x10 for
>>> >>    BCM2835. Changed from GAHBCFG_GLBLINTRMSK (0x01) to 0x11.
>>> >> 3. AHB idle wait after core reset: Added a loop waiting for
>>> >>    GRSTCTL_AHBIDLE after GRSTCTL_CSFTRST, plus 250ms settling delay
>>> >>    (Linux dwc2 uses 100+ ms).
>>> >> Results with workarounds:
>>> >> - Before: hangs after ~86 seconds (2 kHz tick)
>>> >> - After:  hangs after ~175 seconds (2 kHz tick)
>>> >> The workarounds approximately doubled the time-to-hang but did NOT
>>> >> eliminate it. All software counters remained healthy throughout.
>>> >> The hang is caused most probably by a combination of factors:
>>> >> 1. The DWC OTG controller on BCM2835/BCM2837 requires sub-125µs
>>> >>    interrupt response times for USB split transaction phases (Start
>>> >>    Split → Complete Split through the USB hub). The RPi 3B+ Ethernet
>>> >>    goes through a USB hub (LAN7515), making every packet a split
>>> >>    transaction.
>>> >> 2. The Linux kernel addresses this with a dedicated FIQ (Fast
>>> Interrupt
>>> >>    Request) handler (dwc_otg_fiq_fsm.c) that executes complete split
>>> >>    transactions in FIQ context, bypassing the normal interrupt stack.
>>> >>    Without FIQ, "certain USB devices become completely unusable."
>>> >> 3 The FreeBSD dwc_otg driver used by RTEMS handles all split
>>> >>    transactions in normal interrupt context. On RTEMS, the interrupt
>>> >>    filter and thread handler run back-to-back in the interrupt server
>>> >>    task (nexus_intr_with_filter in rtems-kernel-nexus.c), with no
>>> >>    preemption point between them.
>>> >> 4 When the controller's split transaction timing is violated, it
>>> >>    enters an unrecoverable state that locks the AHB bus, freezing the
>>> >>    entire ARM core including UART and system timers.
>>> >> The timing correlation with tick rate confirms this: higher tick rate
>>> >> = more frequent scheduling = more interrupt latency jitter = faster
>>> >> timing violation.
>>> >> A proper fix requires most probably implementing FIQ-based split
>>> transaction handling
>>> >> in the RTEMS BSP for BCM2835/BCM2837, similar to what Linux does in
>>> >> dwc_otg_fiq_fsm.c. This is a significant undertaking but is essential
>>> >> for reliable USB operation on RPi 3B+ (and RPi Zero 2 W, which uses
>>> >> the same SoC).
>>> >> The GAHBCFG and reset sequence workarounds should also be applied as
>>> >> they improve stability.
>>> >> Please give me your thoughts on that. Maybe it is easier to finalise
>>> the BSP for RPi 4 and 5?
>>> >> Best Regards
>>> >> Mirek
>>> >> śr., 22 kwi 2026 o 13:17 John Howard <echosoft.llc at gmail.com>
>>> napisał(a):
>>> >>> Fascinating. Thanks for that detailed report.
>>> >>> You indicated USB enumerating continues running in the background.
>>> >>> I am educated-guessing that a counter maximum is reached, and then
>>> mistakenly breached. I would look for a test of that counter and correct it
>>> from allowing greater-than comparing.
>>> >>> Let us know how it turns out.
>>> >>> I am developing an app for Raspberry Pi Zero 2 W (stripped-down
>>> 3B+). I wasn't expecting any potential problem like this.
>>> >>> -- John
>>> >>> > On Apr 22, 2026, at 1:25 PM, Miroslaw Dach <
>>> miroslaw.dach at gmail.com> wrote:
>>> >>> > Hi All,
>>> >>> > I'm running an EPICS ioc server (EPICS 7.0.10)  with RTEMS 6.2 on
>>> a Raspberry Pi 3B+ with rtems-libbsd  (6-freebsd-14) and
>>> >>> > encountering a reproducible system hang after several minutes of
>>> operation.
>>> >>> > Through systematic elimination testing I've narrowed the root
>>> cause to the
>>> >>> > DWC OTG USB controller driver. I'd appreciate any recommendations
>>> on how
>>> >>> > to address this. I can of course use the EPICS ioc server under
>>> linux on RPi but just tried to have the RTEMS - Hard real time system which
>>> is much more deterministic.
>>> >>> > The boot time for the RPi with EPICS/RTEMS is around 7 sec which
>>> is extremely fast!
>>> >>> > Environment
>>> >>> > - Board: Raspberry Pi 3B+ (BCM2837, boardrev a020d3)
>>> >>> > - RTEMS: rtems-6.2 (ARM/ARMv4/raspberrypi2)
>>> >>> > - Network stack: rtems-libbsd (RTEMS_BSD_CONFIG_BSP_CONFIG +
>>> RTEMS_BSD_CONFIG_INIT)
>>> >>> > - Ethernet: LAN7515 USB Ethernet (muge driver, via DWC OTG)
>>> >>> > - Application: EPICS IOC (but hang occurs with minimal/empty IOC
>>> as well)
>>> >>> > - Console: UART serial (/dev/ttyS0)
>>> >>> > Symptom
>>> >>> > The system boots and runs normally, then the entire system freezes
>>> >>> > including the UART serial console (which is not USB-dependent). No
>>> crash
>>> >>> > message, no stack dump — a hard hang requiring power cycle.
>>> >>> > The time-to-hang depends on the system tick rate:
>>> >>> > - CONFIGURE_MICROSECONDS_PER_TICK=500  (2 kHz): hangs after ~2
>>> minutes
>>> >>> > - CONFIGURE_MICROSECONDS_PER_TICK=10000 (100 Hz): hangs after ~5-6
>>> minutes
>>> >>> > During the hang, the UART becomes completely unresponsive,
>>> suggesting a
>>> >>> > kernel-level deadlock or interrupt handler issue rather than an
>>> >>> > application-level problem.
>>> >>> > Elimination testing performed
>>> >>> > I systematically disabled components to isolate the cause. All
>>> tests below
>>> >>> > used CONFIGURE_MICROSECONDS_PER_TICK=10000 (100 Hz):
>>> >>> > 1. Disabled all EPICS database records (no record processing) ->
>>> still hangs
>>> >>> > 2. Disabled periodic NTP sync (no socket operations) -> still hangs
>>> >>> > 3. Disabled IP configuration (no ifconfig, no route, no network
>>> traffic,
>>> >>> >    but USB/DWC OTG still initialised via
>>> RTEMS_BSD_CONFIG_BSP_CONFIG)
>>> >>> >    -> still hangs (~5-6 min), USB hub enumeration continues in
>>> background:
>>> >>> >       ugen1.2: <vendor 0x0424 product 0x2514> at usbus1
>>> >>> >       uhub1 on uhub0
>>> >>> >    Console output is garbled by concurrent USB enumeration
>>> messages,
>>> >>> >    suggesting interrupt contention.
>>> >>> > 4. Commented out RTEMS_BSD_CONFIG_BSP_CONFIG and the
>>> >>> >    #include <bsp/nexus-devices.h> to prevent DWC OTG initialisation
>>> >>> >    -> STABLE, ran for 14+ minutes with no hang (test stopped
>>> manually)
>>> >>> > The libbsd software stack (loopback, sockets, telnetd) continues to
>>> >>> > function in test 4 — only the hardware BSP devices (DWC OTG, muge,
>>> >>> > uhub, ukphy) are excluded.
>>> >>> > Minimal reproduction
>>> >>> > Build an RTEMS 6.2 application for raspberrypi2 BSP with:
>>> >>> >   #define RTEMS_BSD_CONFIG_BSP_CONFIG
>>> >>> >   #define RTEMS_BSD_CONFIG_INIT
>>> >>> >   #include <machine/rtems-bsd-config.h>
>>> >>> >   #include <bsp/nexus-devices.h>     /* in one translation unit */
>>> >>> >   #define CONFIGURE_MICROSECONDS_PER_TICK 10000
>>> >>> > The application does not need to configure any network interface or
>>> >>> > perform any USB transfers — the DWC OTG hub polling alone triggers
>>> >>> > the hang after ~5-6 minutes.
>>> >>> > Commenting out RTEMS_BSD_CONFIG_BSP_CONFIG and the nexus-devices.h
>>> >>> > include eliminates the hang.
>>> >>> > Boot log (abbreviated, from hanging configuration)
>>> >>> > RTEMS RPi 3B+ 1.3 (1GB) [00a020d3]
>>> >>> > nexus0: <RTEMS Nexus device>
>>> >>> > dwcotg0: <DWC OTG 2.0 integrated USB controller> on nexus0
>>> >>> > usbus1 on dwcotg0
>>> >>> > usbus1: 480Mbps High Speed USB v2.0
>>> >>> > ugen1.1: <DWCOTG OTG Root HUB> at usbus1
>>> >>> > uhub0 on usbus1
>>> >>> > uhub0: <DWCOTG OTG Root HUB, class 9/0, rev 2.00/1.00, addr 1> on
>>> usbus1
>>> >>> > uhub0: 1 port with 1 removable, self powered
>>> >>> > uhub1 on uhub0
>>> >>> > uhub1: <vendor 0x0424 product 0x2514, class 9/0, rev 2.00/b.b3,
>>> addr 2> on usbus1
>>> >>> > uhub1: 4 ports with 3 removable, self powered
>>> >>> > ugen1.3: <vendor 0x0424 product 0x2514> at usbus1
>>> >>> > uhub2 on uhub1
>>> >>> > uhub2: <vendor 0x0424 product 0x2514, class 9/0, rev 2.00/b.b3,
>>> addr 3> on usbus1
>>> >>> > uhub2: 3 ports with 2 removable, self powered
>>> >>> > ugen1.4: <vendor 0x0424 product 0x7800> at usbus1
>>> >>> > muge0: <vendor 0x0424 product 0x7800, rev 2.10/3.00, addr 4> on
>>> usbus1
>>> >>> > muge0: Chip ID 0x7800 rev 0002
>>> >>> > miibus0: <MII bus> on muge0
>>> >>> > ukphy0: <Generic IEEE 802.3u media interface> PHY 1 on miibus0
>>> >>> > info: ue0: <USB Ethernet> on muge0
>>> >>> > [system hangs after ~5-6 minutes, UART unresponsive]
>>> >>> > Questions
>>> >>> > 1. Is this a known issue with the DWC OTG driver on RPi 3B+?
>>> >>> > 2. Are there any configuration options (hub polling interval,
>>> interrupt
>>> >>> >    coalescing, DMA settings) that might work around the problem?
>>> >>> > 3. Would a newer version of rtems-libbsd contain fixes for this?
>>> >>> > 4. Is there an alternative Ethernet driver approach for RPi 3B+
>>> that
>>> >>> >    avoids the DWC OTG USB path?
>>> >>> > 5. Is there any known project which uses RPi with RTEMS?
>>> >>> > (it looks like that the option to run RTEMS on RPi4 or RPi 5 can
>>> not be considered since the BSP in RTEMS kernel  is not yet finalised.
>>> >>> > The RPi4 or RPi 5 would be much better candidates vs RPi 3 B+
>>> since they use direct connection to Ethernet instead of the USB-Ethernet)
>>> >>> > Thank you for any guidance.
>>> >>> > Mirek
>>> >>> > _______________________________________________
>>> >>> > users mailing list
>>> >>> > users at rtems.org
>>> >>> > http://lists.rtems.org/mailman/listinfo/users
>>> > users mailing list
>>> > users at rtems.org
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20261014/774c1d69/attachment-0001.htm>
