[PATCH 1/6] BBB: am335x.h: Add defines for MMC0 interface, AM335x MMC/SD registers, and CMD/responses
Jarielle Catbagan jcatbagan93 at gmail.com
Mon Aug 3 04:16:38 UTC 2015
 ports/beagleboneblack/am335x.h | 256 ++++++++++++++++++++++++++++++++++++++++-
 1 file changed, 252 insertions(+), 4 deletions(-)
diff --git a/ports/beagleboneblack/am335x.h b/ports/beagleboneblack/am335x.h
index 55a4d2a..8b85b4b 100644
--- a/ports/beagleboneblack/am335x.h
+++ b/ports/beagleboneblack/am335x.h
@@ -266,6 +266,9 @@
 #define CM_PER_L3_CLKSTCTRL		0x0C
 #define CM_PER_EMIF_CLKCTRL		0x28
+#define CM_PER_MMC0_CLKCTRL		0x3C
+#define CM_PER_MMC0_CLKCTRL_MODULEMODE_ENABLE	0x02
+#define CM_PER_MMC0_CLKCTRL_IDLEST	0x00030000
 #define CM_PER_GPIO1_CLKCTRL		0xAC
@@ -344,6 +347,13 @@
 #define CONF_GPMC_A6                    0x0858
 #define CONF_GPMC_A7                    0x085c
 #define CONF_GPMC_A8                    0x0860
+#define CONF_MMC0_DAT3			0x08F0
+#define CONF_MMC0_DAT2			0x08F4
+#define CONF_MMC0_DAT1			0x08F8
+#define CONF_MMC0_DAT0			0x08FC
+#define CONF_MMC0_CLK			0x0900
+#define CONF_MMC0_CMD			0x0904
+#define CONF_SPI0_CS1			0x0960
 #define CONF_UART0_RXD                  0x0970
 #define CONF_UART0_TXD                  0x0974
 #define DDR_IO_CTRL			0x0E04
@@ -456,9 +466,6 @@
 /* DMTimer7 Registers */
 #define DMTIMER7_BASE			(L4_PER_BASE + 0x0004A000)
 #define DMTIMER7_REG(_x_)		*(vulong *)(DMTIMER7_BASE + _x_)
-/* MMCHS0 Registers */
-#define MMCHS0_BASE			(L4_PER_BASE + 0x00060000)
-#define MMCHS0_REG(_x_)			*(vulong *)(MMCHS0_BASE + _x_)
 /* ELM Registers */
 #define ELM_BASE			(L4_PER_BASE + 0x00080000)
 #define ELM_REG(_x_)			*(vulong *)(ELM_BASE + _x_)
@@ -1221,7 +1228,10 @@
 /* MMC */
-/* MMC Registers offset */
+/* MMCHS0 Registers base */
+#define MMCHS0_BASE			(L4_PER_BASE + 0x00060000)
+#define MMCHS0_REG(_x_)			*(vulong *)(MMCHS0_BASE + _x_)
+/* MMC Registers base */
 #define MMC1_BASE			(L4_PER_BASE + 0x001D8000)
 #define MMC1_REG(_x_)			*(vulong *)(MMC1_BASE + _x_)
@@ -1229,26 +1239,181 @@
 	/* System Configuration */
 #define SD_SYSCONFIG			0x0110
+#define SD_SYSCONFIG_CLOCKACTIVITY	0x00000300
+#define SD_SYSCONFIG_SIDLEMODE		0x00000018
+#define SD_SYSCONFIG_SIDLEMODE_IDLE	0x00000000
+#define SD_SYSCONFIG_SIDLEMODE_IGNORE	0x00000008
+#define SD_SYSCONFIG_SIDLEMODE_WKUP	0x00000010
+#define SD_SYSCONFIG_ENAWAKEUP		0x00000004
+#define SD_SYSCONFIG_ENAWAKEUP_DISABLE	0x00000000
+#define SD_SYSCONFIG_ENAWAKEUP_ENABLE	0x00000004
+#define SD_SYSCONFIG_SOFTRESET		0x00000002
+#define SD_SYSCONFIG_AUTOIDLE		0x00000001
+#define SD_SYSCONFIG_AUTOIDLE_AUTOGATE	0x00000001
 	/* System Status */
 #define SD_SYSSTATUS			0x0114
+#define SD_SYSSTATUS_RESETDONE		0x00000001
 	/* Card Status Response Error */
 #define SD_CSRE				0x0124
 	/* System Test */
 #define SD_SYSTEST			0x0128
 	/* Configuration */
 #define SD_CON				0x012C
+#define SD_CON_SDMA_LNE			0x00200000
+#define SD_CON_DMA_MNS			0x00100000
+#define SD_CON_DDR			0x00080000
+#define SD_CON_BOOT_CF0			0x00040000
+#define SD_CON_BOOT_ACK			0x00020000
+#define SD_CON_CLKEXTFREE		0x00010000
+#define SD_CON_PADEN			0x00008000
+#define SD_CON_CEATA			0x00001000
+#define SD_CON_CTPL			0x00000800
+#define SD_CON_DVAL			0x00000600
+#define SD_CON_DVAL_33US		0x00000000
+#define SD_CON_DVAL_231US		0x00000200
+#define SD_CON_DVAL_1MS			0x00000400
+#define SD_CON_DVAL_840US		0x00000600
+#define SD_CON_WPP			0x00000100
+#define SD_CON_CDP			0x00000080
+#define SD_CON_CDP_ACTIVE_LOW		0x00000080
+#define SD_CON_CDP_ACTIVE_HIGH		0x00000000
+#define SD_CON_MIT			0x00000040
+#define SD_CON_DW8			0x00000020
+#define SD_CON_DW8_1BIT_OR_4BIT		0x00000000
+#define SD_CON_DW8_8BIT			0x00000020
+#define SD_CON_MODE			0x00000010
+#define SD_CON_MODE_SYSTEST		0x00000010
+#define SD_CON_MODE_NORMAL		0x00000000
+#define SD_CON_STR			0x00000008
+#define SD_CON_HR			0x00000004
+#define SD_CON_INIT			0x00000002
+#define SD_CON_INIT_START		0x00000002
+#define SD_CON_INIT_END			0x00000000
+#define SD_CON_OD			0x00000001
+#define SD_CON_OD_ENABLE		0x00000001
+#define SD_CON_OD_DISABLE		0x00000000
 	/* Power Counter */
 #define SD_PWCNT			0x0130
 	/* SDMA System Address */
 #define SD_SDMASA			0x0200
 	/* Transfer Length Configuration */
 #define SD_BLK				0x0204
+#define SD_BLK_512_BYTES		0x00000200
 	/* Command Argument */
 #define SD_ARG				0x0208
 	/* Command and Transfer Mode */
 #define SD_CMD				0x020C
+#define SD_CMD_CMD0_GO_IDLE_STATE		0x00000000
+#define SD_CMD_CMD0_GO_PRE_IDLE_STATE		0x00000000
+#define SD_CMD_CMD0_BOOT_INITIATION		0x00000000
+#define SD_CMD_CMD1_SEND_OP_COND		0x01000000
+#define SD_CMD_CMD2_ALL_SEND_CID		0x02000000
+#define SD_CMD_CMD3_SEND_RELATIVE_ADDR		0x03000000
+#define SD_CMD_CMD3_SET_RELATIVE_ADDR		0x03000000
+#define SD_CMD_CMD4_SET_DSR			0x04000000
+#define SD_CMD_CMD5_SLEEP_AWAKE			0x05000000
+#define SD_CMD_CMD6_SWITCH_FUNC			0x06000000
+#define SD_CMD_CMD6_SWITCH			0x06000000
+#define SD_CMD_CMD7_SELECT_DESELECT_CARD	0x07000000
+#define SD_CMD_CMD8_SEND_IF_COND		0x08000000
+#define SD_CMD_CMD8_SEND_EXT_CSD		0x08000000
+#define SD_CMD_CMD9_SEND_CSD			0x09000000
+#define SD_CMD_CMD10_SEND_CID			0x0A000000
+#define SD_CMD_CMD11_READ_DAT			0x0B000000
+#define SD_CMD_CMD12_STOP_TRANSMISSION		0x0C000000
+#define SD_CMD_CMD13_SEND_STATUS		0x0D000000
+#define SD_CMD_CMD14_BUSTEST_R			0x0E000000
+#define SD_CMD_CMD15_GO_INACTIVE_STATE		0x0F000000
+#define SD_CMD_CMD16_SET_BLOCKLEN		0x10000000
+#define SD_CMD_CMD17_READ_SINGLE_BLOCK		0x11000000
+#define SD_CMD_CMD18_READ_MULTIPLE_BLOCK	0x12000000
+#define SD_CMD_CMD19_BUSTEST_W			0x13000000
+#define SD_CMD_CMD20_WRITE_DAT_UNTIL_STOP	0x14000000
+#define SD_CMD_CMD24_WRITE_BLOCK		0x18000000
+#define SD_CMD_CMD25_WRITE_MULTIPLE_BLOCK	0x19000000
+#define SD_CMD_CMD26_PROGRAM_CID		0x1A000000
+#define SD_CMD_CMD27_PROGRAM_CSD		0x1B000000
+#define SD_CMD_CMD28_SET_WRITE_PROT		0x1C000000
+#define SD_CMD_CMD29_CLR_WRITE_PROT		0x1D000000
+#define SD_CMD_CMD30_SEND_WRITE_PROT		0x1E000000
+#define SD_CMD_CMD31_SEND_WRITE_PROT_TYPE	0x1F000000
+#define SD_CMD_CMD32_ERASE_WR_BLK_START		0x20000000
+#define SD_CMD_CMD33_ERASE_WR_BLK_END		0x21000000
+#define SD_CMD_CMD35_ERASE_GROUP_START		0x23000000
+#define SD_CMD_CMD36_ERASE_GROUP_END		0x24000000
+#define SD_CMD_CMD38_ERASE			0x26000000
+#define SD_CMD_CMD39_FAST_IO			0x27000000
+#define SD_CMD_CMD40_GO_IRQ_STATE		0x28000000
+#define SD_CMD_CMD42_LOCK_UNLOCK		0x2A000000
+#define SD_CMD_CMD55_APP_CMD			0x37000000
+#define SD_CMD_CMD56_GEN_CMD			0x38000000
+#define SD_CMD_ACMD6_SET_BUS_WIDTH		0x06000000
+#define SD_CMD_ACMD13_SD_STATUS			0x0D000000
+#define SD_CMD_ACMD22_SEND_NUM_WR_BLOCKS	0x16000000
+#define SD_CMD_ACMD23_SET_WR_BLK_ERASE_COUNT	0x17000000
+#define SD_CMD_ACMD41_SD_SEND_OP_COND		0x29000000
+#define SD_CMD_ACMD42_SET_CLR_CARD_DETECT	0x2A000000
+#define SD_CMD_ACMD51_SEND_SCR			0x33000000
+#define SD_CMD_CMD_TYPE_NORMAL			0x00000000
+#define SD_CMD_CMD_TYPE_SUSPEND			0x00400000
+#define SD_CMD_CMD_TYPE_RESUME			0x00800000
+#define SD_CMD_CMD_TYPE_ABORT			0x00C00000
+#define SD_CMD_DP_NO_DATA_PRESENT		0x00000000
+#define SD_CMD_DP_DATA_PRESENT			0x00200000
+#define SD_CMD_CICE_DISABLE			0x00000000
+#define SD_CMD_CICE_ENABLE			0x00100000
+#define SD_CMD_CCCE_DISABLE			0x00000000
+#define SD_CMD_CCCE_ENABLE			0x00080000
+#define RSP_TYPE_NO_RESPONSE		0x00000000
+#define RSP_TYPE_136			0x00010000
+#define RSP_TYPE_48			0x00020000
+#define RSP_TYPE_48_WITH_BUSY		0x00030000
+#define SD_CMD_RSP_TYPE_NO_RESPONSE	RSP_TYPE_NO_RESPONSE
+#define SD_CMD_RSP_TYPE_R1		RSP_TYPE_48
+#define SD_CMD_RSP_TYPE_R1B		RSP_TYPE_48_WITH_BUSY
+#define SD_CMD_RSP_TYPE_R2		RSP_TYPE_136
+#define SD_CMD_RSP_TYPE_R3		RSP_TYPE_48
+#define SD_CMD_RSP_TYPE_R4		RSP_TYPE_48
+#define SD_CMD_RSP_TYPE_R5		RSP_TYPE_48
+#define SD_CMD_RSP_TYPE_R5B		RSP_TYPE_48_WITH_BUSY
+#define SD_CMD_RSP_TYPE_R6		RSP_TYPE_48
+#define SD_CMD_RSP_TYPE_R7		RSP_TYPE_48
+#define SD_CMD_MSBS_SINGLE		0x00000000
+#define SD_CMD_MSBS_MULTIPLE		0x00000020
+#define SD_CMD_DDIR_WRITE		0x00000000
+#define SD_CMD_DDIR_READ		0x00000010
+#define SD_CMD_ACEN_DISABLE		0x00000000
+#define SD_CMD_ACEN_CMD12_ENABLE	0x00000004
+#define SD_CMD_BCE_DISABLE		0x00000000
+#define SD_CMD_BCE_ENABLE		0x00000002
+#define SD_CMD_DE_DISABLE		0x00000000
+#define SD_CMD_DE_ENABLE		0x00000001
 	/* Command Response 0 and 1 */
 #define SD_RSP10			0x0210
+#define SD_RSP10_R1_CURRENT_STATE			0x00001E00
+#define SD_RSP10_R1_CURRENT_STATE_IDLE			0x00000000
+#define SD_RSP10_R1_CURRENT_STATE_READY			0x00000200
+#define SD_RSP10_R1_CURRENT_STATE_IDENTIFICATION	0x00000400
+#define SD_RSP10_R1_CURRENT_STATE_STANDBY		0x00000600
+#define SD_RSP10_R1_CURRENT_STATE_TRANSFER		0x00000800
+#define SD_RSP10_R1_CURRENT_STATE_SENDING_DATA		0x00000A00
+#define SD_RSP10_R1_CURRENT_STATE_RECEIVE_DATA		0x00000C00
+#define SD_RSP10_R1_CURRENT_STATE_PROGRAMMING		0x00000E00
+#define SD_RSP10_R1_CURRENT_STATE_DISCONNECT		0x00001000
+#define SD_RSP10_R3_CARD_CAPACITY_STATUS		0x40000000
+#define SD_RSP10_R3_CARD_POWER_UP_STATUS		0x80000000
 	/* Command Response 2 and 3 */
 #define SD_RSP32			0x0214
 	/* Command Response 4 and 5 */
@@ -1259,20 +1424,103 @@
 #define SD_DATA				0x0220
 	/* Present State */
 #define SD_PSTATE			0x0224
+#define SD_PSTATE_CLEV			0x01000000
+#define SD_PSTATE_DLEV			0x00F00000
+#define SD_PSTATE_WP			0x00080000
+#define SD_PSTATE_CDPL			0x00040000
+#define SD_PSTATE_CSS			0x00020000
+#define SD_PSTATE_CINS			0x00010000
+#define SD_PSTATE_BRE			0x00000800
+#define SD_PSTATE_BWE			0x00000400
+#define SD_PSTATE_RTA			0x00000200
+#define SD_PSTATE_WTA			0x00000100
+#define SD_PSTATE_DLA			0x00000004
+#define SD_PSTATE_DATI			0x00000002
+#define SD_PSTATE_CMDI			0x00000001
 	/* Host Control */
 #define SD_HCTL				0x0228
+#define SD_HCTL_SDVS			0x00000E00
+#define SD_HCTL_SDVS_VS18		0x00000A00
+#define SD_HCTL_SDVS_VS30		0x00000C00
+#define SD_HCTL_SDVS_VS33		0x00000E00
+#define SD_HCTL_SDBP			0x00000100
+#define SD_HCTL_DMAS			0x00000180
+#define SD_HCTL_DMAS_32BIT_ADDR_ADMA2	0x00000010
+#define SD_HCTL_DTW			0x00000002
+#define SD_HCTL_DTW_1BIT		0x00000000
+#define SD_HCTL_DTW_4BIT		0x00000002
 	/* SD System Control */
 #define SD_SYSCTL			0x022C
+#define SD_SYSCTL_SRC			0x02000000
+#define SD_SYSCTL_SRA			0x01000000
+#define SD_SYSCTL_DTO			0x000F0000
+#define SD_SYSCTL_DTO_TCF_2_13		0x00000000
+#define SD_SYSCTL_DTO_TCF_2_14		0x00010000
+#define SD_SYSCTL_DTO_TCF_2_27		0x000E0000
+#define SD_SYSCTL_CLKD			0x0000FFC0
+#define SD_SYSCTL_CEN			0x00000004
+#define SD_SYSCTL_CEN_ENABLE		0x00000004
+#define SD_SYSCTL_ICS			0x00000002
+#define SD_SYSCTL_ICE			0x00000001
+#define SD_SYSCTL_ICE_ENABLE		0x00000001
 	/* SD Interrupt Status */
 #define SD_STAT				0x0230
+#define SD_STAT_BADA			0x20000000
+#define SD_STAT_CERR			0x10000000
+#define SD_STAT_ADMAE			0x02000000
+#define SD_STAT_ACE			0x01000000
+#define SD_STAT_DEB			0x00400000
+#define SD_STAT_DCRC			0x00200000
+#define SD_STAT_DTO			0x00100000
+#define SD_STAT_CIE			0x00080000
+#define SD_STAT_CEB			0x00040000
+#define SD_STAT_CCRC			0x00020000
+#define SD_STAT_CTO			0x00010000
+#define SD_STAT_ERRI			0x00008000
+#define SD_STAT_BSR			0x00000400
+#define SD_STAT_OBI			0x00000200
+#define SD_STAT_CIRQ			0x00000100
+#define SD_STAT_CREM			0x00000080
+#define SD_STAT_CINS			0x00000040
+#define SD_STAT_BRR			0x00000020
+#define SD_STAT_BWR			0x00000010
+#define SD_STAT_DMA			0x00000008
+#define SD_STAT_BGE			0x00000004
+#define SD_STAT_TC			0x00000002
+#define SD_STAT_CC			0x00000001
 	/* SD Interrupt Enable */
 #define SD_IE				0x0234
+#define SD_IE_BADA_ENABLE		0x20000000
+#define SD_IE_CERR_ENABLE		0x10000000
+#define SD_IE_ADMA_ENABLE		0x02000000
+#define SD_IE_ACE_ENABLE		0x01000000
+#define SD_IE_DEB_ENABLE		0x00400000
+#define SD_IE_DCRC_ENABLE		0x00200000
+#define SD_IE_DTO_ENABLE		0x00100000
+#define SD_IE_CIE_ENABLE		0x00080000
+#define SD_IE_CEB_ENABLE		0x00040000
+#define SD_IE_CCRC_ENABLE		0x00020000
+#define SD_IE_CTO_ENABLE		0x00010000
+#define SD_IE_BSR_ENABLE		0x00000400
+#define SD_IE_OBI_ENABLE		0x00000200
+#define SD_IE_CIRQ_ENABLE		0x00000100
+#define SD_IE_CREM_ENABLE		0x00000080
+#define SD_IE_CINS_ENABLE		0x00000040
+#define SD_IE_BRR_ENABLE		0x00000020
+#define SD_IE_BWR_ENABLE		0x00000010
+#define SD_IE_DMA_ENABLE		0x00000008
+#define SD_IE_BGE_ENABLE		0x00000004
+#define SD_IE_TC_ENABLE			0x00000002
+#define SD_IE_CC_ENABLE			0x00000001
 	/* SD Interrupt Enable Set */
 #define SD_ISE				0x0238
 	/* Auto CMD12 Error Status */
 #define SD_AC12				0x023C
 	/* Capabilities */
 #define SD_CAPA				0x0240
+#define SD_CAPA_VS18			0x04000000
+#define SD_CAPA_VS30			0x02000000
+#define SD_CAPA_VS33			0x01000000
 	/* Maximum Current Capabilities */
 #define SD_CUR_CAPA			0x0148
 	/* Force Event */
2.5.0
More information about the umon-devel mailing list
