[PATCH 2/8] BBB: Migrate MMC0 clock enable from am335x_sd.c:sdInit() to cpuio.c:initCPUio()
Jarielle Catbagan jcatbagan93 at gmail.com
Tue Aug 4 18:03:22 UTC 2015
The reason why the MMC0 clock enable has to be executed much earlier is a result of the invocation
of sdInstalled() in sd.h before sdInit().  Without this migration, an exception occurs since the
MMC0 interface has not been enabled before it is accessed by sdInstalled().
 ports/beagleboneblack/am335x_sd.c | 4 ----
 ports/beagleboneblack/cpuio.c     | 4 ++++
 2 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/ports/beagleboneblack/am335x_sd.c b/ports/beagleboneblack/am335x_sd.c
index ac2392c..7eb0180 100644
--- a/ports/beagleboneblack/am335x_sd.c
+++ b/ports/beagleboneblack/am335x_sd.c
@@ -47,10 +47,6 @@ sdInit(int interface, int verbosity)
 	uint32_t cmd, arg, resp[4];
-	/* Enable MMC0 clocks */
-	CM_PER_REG(CM_PER_MMC0_CLKCTRL) |= CM_PER_MMC0_CLKCTRL_MODULEMODE_ENABLE;
-	while (CM_PER_REG(CM_PER_MMC0_CLKCTRL) & CM_PER_MMC0_CLKCTRL_IDLEST);
 	/* Reset the MMC/SD controller */
 	MMCHS0_REG(SD_SYSCONFIG) = SD_SYSCONFIG_SOFTRESET;
 	while (!(MMCHS0_REG(SD_SYSSTATUS) & SD_SYSSTATUS_RESETDONE));
diff --git a/ports/beagleboneblack/cpuio.c b/ports/beagleboneblack/cpuio.c
index eab0a00..a1ca3aa 100644
--- a/ports/beagleboneblack/cpuio.c
+++ b/ports/beagleboneblack/cpuio.c
@@ -205,6 +205,10 @@ initCPUio(void)
 	// Enable clock for GPIO1:
 	CM_PER_REG(CM_PER_GPIO1_CLKCTRL) |= 2;
+	/* Enable MMC0 clocks */
+	CM_PER_REG(CM_PER_MMC0_CLKCTRL) |= CM_PER_MMC0_CLKCTRL_MODULEMODE_ENABLE;
+	while (CM_PER_REG(CM_PER_MMC0_CLKCTRL) & CM_PER_MMC0_CLKCTRL_IDLEST);
 	pinMuxInit();
 	InitUART(DEFAULT_BAUD_RATE);
2.5.0
More information about the umon-devel mailing list
