[PATCH 8/8] BBB: Migrate MMC1 clock enable from am335x_mmc.c:mmcInit() to cpuio.c:initCPUio()
Jarielle Catbagan jcatbagan93 at gmail.com
Tue Aug 4 18:03:28 UTC 2015
 ports/beagleboneblack/am335x_mmc.c | 4 ----
 ports/beagleboneblack/cpuio.c      | 4 ++++
 2 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/ports/beagleboneblack/am335x_mmc.c b/ports/beagleboneblack/am335x_mmc.c
index 10aef23..bba60a2 100644
--- a/ports/beagleboneblack/am335x_mmc.c
+++ b/ports/beagleboneblack/am335x_mmc.c
@@ -135,10 +135,6 @@ mmcInit(int interface, int verbose)
 	uint32_t cmd, arg, resp[4];
-	/* Enable MMC1 clocks */
-	CM_PER_REG(CM_PER_MMC1_CLKCTRL) |= CM_PER_MMC1_CLKCTRL_MODULEMODE_ENABLE;
-	while (CM_PER_REG(CM_PER_MMC1_CLKCTRL) & CM_PER_MMC0_CLKCTRL_IDLEST);
 	/* Reset the MMC1 Controller */
 	MMC1_REG(SD_SYSCONFIG) = SD_SYSCONFIG_SOFTRESET;
 	while (!(MMC1_REG(SD_SYSSTATUS) & SD_SYSSTATUS_RESETDONE));
diff --git a/ports/beagleboneblack/cpuio.c b/ports/beagleboneblack/cpuio.c
index 1579fb0..a8a901d 100644
--- a/ports/beagleboneblack/cpuio.c
+++ b/ports/beagleboneblack/cpuio.c
@@ -241,6 +241,10 @@ initCPUio(void)
 	CM_PER_REG(CM_PER_MMC0_CLKCTRL) |= CM_PER_MMC0_CLKCTRL_MODULEMODE_ENABLE;
 	while (CM_PER_REG(CM_PER_MMC0_CLKCTRL) & CM_PER_MMC0_CLKCTRL_IDLEST);
+	/* Enable MMC1 clocks */
+	CM_PER_REG(CM_PER_MMC1_CLKCTRL) |= CM_PER_MMC1_CLKCTRL_MODULEMODE_ENABLE;
+	while (CM_PER_REG(CM_PER_MMC1_CLKCTRL) & CM_PER_MMC0_CLKCTRL_IDLEST);
 	pinMuxInit();
 	InitUART(DEFAULT_BAUD_RATE);
2.5.0
More information about the umon-devel mailing list
