[PATCH 2/3] BBB: Add proper attributions to the files modified
Jarielle Catbagan jcatbagan93 at gmail.com
Fri Aug 21 17:05:59 UTC 2015
 ports/beagleboneblack/config.h        | 10 ++++----
 ports/beagleboneblack/config_header.S | 10 +++++++-
 ports/beagleboneblack/cpuio.c         | 19 ++++++++++++++++
 ports/beagleboneblack/cpuio.h         | 15 ++++++++++++
 ports/beagleboneblack/gp_header.S     | 11 ++++++++-
 ports/beagleboneblack/rom_reset.S     |  7 +++---
 ports/beagleboneblack/xcmddcl.h       | 43 ++++++++++++++++++++++++-----------
 ports/beagleboneblack/xcmdtbl.h       | 39 +++++++++++++++++++++++--------
 8 files changed, 120 insertions(+), 34 deletions(-)
diff --git a/ports/beagleboneblack/config.h b/ports/beagleboneblack/config.h
index 1475a8e..2592fdf 100644
--- a/ports/beagleboneblack/config.h
+++ b/ports/beagleboneblack/config.h
@@ -1,9 +1,5 @@
- * Monitor configuration file for the Beaglebone Black
- * Adapted by Jarielle Catbagan
- * email: jcatbagan93 at gmail.com
+ * Monitor configuration file
  * General notice:
  * This code is part of a boot-monitor package developed as a generic base
@@ -17,6 +13,10 @@
  * Author:  Ed Sutter
  * email:   esutter at lucent.com
  * phone:   908-582-2351
+ * Adapted by Jarielle Catbagan for the Beaglebone Black
+ * email: jcatbagan93 at gmail.com
 #include "am335x.h"
diff --git a/ports/beagleboneblack/config_header.S b/ports/beagleboneblack/config_header.S
index dbf6ff0..79da601 100644
--- a/ports/beagleboneblack/config_header.S
+++ b/ports/beagleboneblack/config_header.S
@@ -1,6 +1,14 @@
 	.file "config_header.S"
-/* This is the Configuration Header TOC Structure that must be prepended to a GP Header followed
+ * Copyright (c) 2015 Jarielle Catbagan <jcatbagan93 at gmail.com>
+ * http://www.apache.org/licenses/LICENSE-2.0
+ * This is the Configuration Header TOC Structure that must be prepended to a GP Header followed
  * by the uMon image in order to boot from non-XIP devices such as an SD card using "raw" mode.
  * Please refer to the AM335x TRM, Section 26.1.7.5.5.1 "Configuration Header" for more information.
diff --git a/ports/beagleboneblack/cpuio.c b/ports/beagleboneblack/cpuio.c
index 22afb37..f6289fe 100644
--- a/ports/beagleboneblack/cpuio.c
+++ b/ports/beagleboneblack/cpuio.c
@@ -1,3 +1,22 @@
+ * General notice:
+ * This code is part of a boot-monitor package developed as a generic base
+ * platform for embedded system designs.  As such, it is likely to be
+ * distributed to various projects beyond the control of the original
+ * author.  Please notify the author of any enhancements made or bugs found
+ * so that all may benefit from the changes.  In addition, notification back
+ * to the author will allow the new user to pick up changes that may have
+ * been made by other users after this version of the code was distributed.
+ * Author:  Ed Sutter
+ * email:   esutter at lucent.com
+ * phone:   908-582-2351
 #include "config.h"
 #include "stddefs.h"
 #include "cpuio.h"
diff --git a/ports/beagleboneblack/cpuio.h b/ports/beagleboneblack/cpuio.h
index 0e64a09..d18d19d 100644
--- a/ports/beagleboneblack/cpuio.h
+++ b/ports/beagleboneblack/cpuio.h
@@ -1,3 +1,18 @@
+ * General notice:
 #define DEFAULT_BAUD_RATE 115200
 #define HWREAD32(a) *(volatile unsigned long *)(a)
diff --git a/ports/beagleboneblack/gp_header.S b/ports/beagleboneblack/gp_header.S
index 3efceae..fd463b5 100644
--- a/ports/beagleboneblack/gp_header.S
+++ b/ports/beagleboneblack/gp_header.S
@@ -1,7 +1,16 @@
 	.file "gp_header.S"
-/* This GP header is prepended to uMon images when booting from non-XIP devices (e.g. SD).
+ * This GP header is prepended to uMon images when booting from non-XIP devices (e.g. SD).
  * Refer to the AM335x TRM, Section 26.1.9 for more information.
 	.word BIN_SIZE + 8
 	.word 0x402f0400
diff --git a/ports/beagleboneblack/rom_reset.S b/ports/beagleboneblack/rom_reset.S
index 98701a4..10c0ce2 100644
--- a/ports/beagleboneblack/rom_reset.S
+++ b/ports/beagleboneblack/rom_reset.S
@@ -15,10 +15,9 @@
- * Modified for the CSB740 - OMAP3530 Single Board
- * rom_reset.s:
 #include "warmstart.h"
 #include "am335x.h"
diff --git a/ports/beagleboneblack/xcmddcl.h b/ports/beagleboneblack/xcmddcl.h
index 771e1da..9670fef 100644
--- a/ports/beagleboneblack/xcmddcl.h
+++ b/ports/beagleboneblack/xcmddcl.h
@@ -1,16 +1,33 @@
-/* xcmddcl.h: */
-/* This file must exist even if it is empty because it is #included in the */
-/* common file cmdtbl.c.  The purpose is to keep the common comand table   */
-/* file (common/cmdtbl.c) from being corrupted with non-generic commands   */
-/* that may be target specific. */
-/* It is the declaration portion of the code that must be at the top of    */
-/* the cmdtbl[] array. */
-/* For example:
-extern  int dummycmd();         Function declaration.
-extern  char *dummyHelp[];      Command help array declaration.
+ * xcmddcl.h
+ * This file must exist even if it is empty because it is #included in the
+ * common file cmdtbl.c.  The purpose is to keep the common comand table
+ * file (common/cmdtbl.c) from being corrupted with non-generic commands
+ * that may be target specific.
+ * It is the declaration portion of the code that must be at the top of
+ * the cmdtbl[] array.
+ * For example:
+ *      extern  int dummycmd();         Function declaration.
+ *      extern  char *dummyHelp[];      Command help array declaration.
+ * General notice:
 extern int mmc();
 extern char *mmcHelp[];
diff --git a/ports/beagleboneblack/xcmdtbl.h b/ports/beagleboneblack/xcmdtbl.h
index 70cc54f..6f74586 100644
--- a/ports/beagleboneblack/xcmdtbl.h
+++ b/ports/beagleboneblack/xcmdtbl.h
@@ -1,12 +1,31 @@
-/* xcmdtbl.h: */
-/* It is the entry in the command table representing the new command being */
-/* added to the cmdtbl[] array. */
-/* For example:
-    { "dummy",    dummycmd,   dummyHelp,    0 },
+ * xcmdtbl.h
+ * It is the entry in the command table representing the new command being
+ * added to the cmdtbl[] array.
+ * For example:
+ *      { "dummy",    dummycmd,   dummyHelp,    0 },
+ * General notice:
 {"mmc",     mmc,        mmcHelp,    0},
2.3.1
More information about the umon-devel mailing list
