[PATCH 2/8] BBB: Migrate custom exception handler mapping from rom_reset.S to ram_vector_install() in cpuio.c
Jarielle Catbagan jcatbagan93 at gmail.com
Fri Jul 3 17:54:49 UTC 2015
 ports/beagleboneblack/cpuio.c     | 25 ++++++++++++++++++++++++-
 ports/beagleboneblack/rom_reset.S | 37 -------------------------------------
 2 files changed, 24 insertions(+), 38 deletions(-)
diff --git a/ports/beagleboneblack/cpuio.c b/ports/beagleboneblack/cpuio.c
index 3be316b..ffa076d 100644
--- a/ports/beagleboneblack/cpuio.c
+++ b/ports/beagleboneblack/cpuio.c
@@ -109,11 +109,34 @@ target_reset(void)
 	monrestart(INITIALIZE);
+/* Override the default exception handlers provided by the AM335x
+ * internal ROM code with uMon's custom exception handlers
+void
+ram_vector_install(void)
+	extern unsigned long abort_data;
+	extern unsigned long abort_prefetch;
+	extern unsigned long undefined_instruction;
+	extern unsigned long software_interrupt;
+	extern unsigned long interrupt_request;
+	extern unsigned long fast_interrupt_request;
+	extern unsigned long not_assigned;
+	*(ulong **)0x4030ce24 = &undefined_instruction;
+	*(ulong **)0x4030ce28 = &software_interrupt;
+	*(ulong **)0x4030ce2c = &abort_prefetch;
+	*(ulong **)0x4030ce30 = &abort_data;
+	*(ulong **)0x4030ce34 = &not_assigned;
+	*(ulong **)0x4030ce38 = &interrupt_request;
+	*(ulong **)0x4030ce3c = &fast_interrupt_request;
 /* If any CPU IO wasn't initialized in reset.S, do it here...
  * This just provides a "C-level" IO init opportunity.
 void
 initCPUio(void)
-	/* ADD_CODE_HERE */
+	ram_vector_install();
diff --git a/ports/beagleboneblack/rom_reset.S b/ports/beagleboneblack/rom_reset.S
index 83d79df..176f3a7 100644
--- a/ports/beagleboneblack/rom_reset.S
+++ b/ports/beagleboneblack/rom_reset.S
@@ -93,43 +93,6 @@ coldstart_1:
 	orr	r0,r0,#0xd3			// Set mode to supervisor, IRQ FIQ disabled.
 	msr	cpsr,r0
-	/* store the address of the custom exception handlers in the exception vector space
-	   of the AM335x Public RAM */
-	ldr r1, =undefined_instruction
-	movw r2, #0xce24
-	movt r2, #0x4030
-	str r1, [r2]
-	ldr r1, =software_interrupt
-	movw r2, #0xce28
-	movt r2, #0x4030
-	str r1, [r2]
-	ldr r1, =abort_prefetch
-	movw r2, #0xce2c
-	movt r2, #0x4030
-	str r1, [r2]
-	ldr r1, =abort_data
-	movw r2, #0xce30
-	movt r2, #0x4030
-	str r1, [r2]
-	ldr r1, =not_assigned
-	movw r2, #0xce34
-	movt r2, #0x4030
-	str r1, [r2]
-	ldr r1, =interrupt_request
-	movw r2, #0xce38
-	movt r2, #0x4030
-	str r1, [r2]
-	ldr r1, =fast_interrupt_request
-	movw r2, #0xce3c
-	movt r2, #0x4030
-	str r1, [r2]
 //	bl cache_init
2.3.3
More information about the umon-devel mailing list
