[PATCH 7/8] BBB: xcmddcl.h/xcmdtbl.h: Remove irrelevant commands
Jarielle Catbagan jcatbagan93 at gmail.com
Fri Jul 3 17:54:54 UTC 2015
 ports/beagleboneblack/xcmddcl.h | 20 +-------------------
 ports/beagleboneblack/xcmdtbl.h | 10 +---------
 2 files changed, 2 insertions(+), 28 deletions(-)
diff --git a/ports/beagleboneblack/xcmddcl.h b/ports/beagleboneblack/xcmddcl.h
index 76d5cca..644b074 100644
--- a/ports/beagleboneblack/xcmddcl.h
+++ b/ports/beagleboneblack/xcmddcl.h
@@ -1,5 +1,4 @@
-/* extcmddcl.h: */
+/* xcmddcl.h: */
 /* This file must exist even if it is empty because it is #included in the */
 /* common file cmdtbl.c.  The purpose is to keep the common comand table   */
 /* file (common/cmdtbl.c) from being corrupted with non-generic commands   */
@@ -12,20 +11,3 @@ extern  int dummycmd();         Function declaration.
 extern  char *dummyHelp[];      Command help array declaration.
-extern int date();
-extern char *dateHelp[];
-#if INCLUDE_LCD
-extern int lcd_tst();
-extern char *lcd_tstHelp[];
-#endif
-//extern int i2c();
-//extern char *i2cHelp[];
-extern int nandCmd();
-extern char *nandHelp[];
-extern int ldatags();
-extern char *ldatagsHelp[];
diff --git a/ports/beagleboneblack/xcmdtbl.h b/ports/beagleboneblack/xcmdtbl.h
index 7fb337f..120957e 100644
--- a/ports/beagleboneblack/xcmdtbl.h
+++ b/ports/beagleboneblack/xcmdtbl.h
@@ -1,4 +1,4 @@
-/* extcmdtbl.h: */
+/* xcmdtbl.h: */
@@ -8,11 +8,3 @@
 /* For example:
     "dummy",    dummycmd,   dummyHelp,
-//{"i2c",			i2c,		i2cHelp,},
-#if INCLUDE_LCD
-{"lcd_tst",		lcd_tst,	lcd_tstHelp,},
-#endif
-{"ldatags",		ldatags,	ldatagsHelp,},
-#if INCLUDE_NANDCMD
-{"nand",		nandCmd,	nandHelp,},
-#endif
2.3.3
More information about the umon-devel mailing list
