Update: uMon is now booting from SD
Jarielle Catbagan jcatbagan93 at gmail.com
Mon Jul 6 01:22:44 UTC 2015
On Sun, Jul 5, 2015 at 3:46 PM, Chris Johns <chrisj at rtems.org> wrote:
> On 5/07/2015 4:19 am, Ed Sutter wrote:
>> Ok, I managed to get it to boot using only Linux for formatting the card.
>> It wasn't working for me until I just read your email and realized I did
>> not mark
>> the partition active.  After doing that it booted!
>> So here are the steps I walked through
>> (extracted from: http://forum.xda-developers.com/showthread.php?t=502095) :
>> 1. Verify the partition that the SD card installs as:
>>      - cat /proc/paritions (without the uSD)
>>      - Insert uSD card
>>      - cat /proc/paritions (note the difference)
>> Using /dev/sdc as our partition:
>> 2. sudo fdisk /dev/sdc
>>     - delete all paritions with 'd' command (d1/d2/d3/d4) as needed
>>     - use 'n' command to create partition 1
>>     - use 't' command to relabel partition 1 to 'c'
>>     - use 'a' command to make the parition active
>>     - use 'p' to show something like:
>>    Device Boot      Start         End      Blocks   Id  System
>> /dev/sdc1   *        2048     3932159     1965056    c  W95 FAT32 (LBA)
>>      - use 'w' to write to the card
>> 3. Run sudo mkfs.vfat /dev/sdc1
>> 4. Mount /dev/sdc1 as /media/boot (or whatever)
>> 5. Copy MLO to /media/boot
>> 6. Run sync; unmount /media/boot
>> 7. Put card in BBB, reset with boot button depressed.
> A simple request to place in the doco early is to create a root
> partition only as large as you need and not use whole disk size in the
> root partition. Users should be encouraged to add other partitions they
> can mount as read/write to store a kernel and/or user data.
Definitely, I will be including that remark in the documentation as well.
Thanks.
> Chris
> umon-devel mailing list
> umon-devel at rtems.org
> http://lists.rtems.org/mailman/listinfo/umon-devel
More information about the umon-devel mailing list
