Update: uMon is now booting from SD
Ed Sutter ed.sutter at alcatel-lucent.com
Tue Jul 7 19:14:15 UTC 2015
Looks good...
> On Jul 7, 2015 4:49 AM, "Ed Sutter" <ed.sutter at alcatel-lucent.com
> <mailto:ed.sutter at alcatel-lucent.com>> wrote:
> > Jarielle,
> > Great!
> > Two (last) minor suggestions...
> > 1. Mention the script in the documentation file.
> > 2. In the script you may as well include the final step that you
> have in the documentation
> > for copying the MLO file to the card...
> >    cd ~
> >    mkdir mnt
> >    rmdir mnt
> > Other than that, it looks good to me.
> > Good hunting regarding the cluster error issue!
> > Ed
> Thanks.  Doc and script are now updated to reflect the minor
> suggestions.  I added a part in the "FAT Mode" section to refer to the
> script and I added the last remaining steps in the doc to the script.
> The links to the files are the same as before.
> How are the doc and script so far?
> Just for completeness, I'm going to get the raw mode image built as
> well with the Configuration Header and GP Header prepended.  I'm
> thinking of also updating the script even further to allow the user to
> select whether they would want to format the SD card for "raw" or FAT
> mode.
> I'll then send another draft of the files for your review.
> >> Ed,
> >> Thank you for your suggestions.  I have taken them into account when
> >> improving the document.
> >> Here is the second draft of the doc:
> https://github.com/jrcatbagan/umon/blob/dev/ports/beagleboneblack/README
> >> I have also created a script that automates the process of setting up
> >> the SD card.  It can be found here:
> https://github.com/jrcatbagan/umon/blob/dev/ports/beagleboneblack/sd-setup.sh
> >> I also looked into the error regarding the situation where there is
> >> not enough clusters and it turns out that the minimum size for the
> >> FAT32 primary partition is around 32MB.  FAT16 on the other hand has a
> >> minimum size of around 3MB.  I was using this document as reference:
> >> https://staff.washington.edu/dittrich/misc/fatgen103.pdf .   So I went
> >> ahead and had the script create the primary partition as FAT16.  I was
> >> able to boot uMon from an SD card that was setup with this script.
> >> Please let me know what you think about the doc and script so far.
> >> Thanks.
> >> On Mon, Jul 6, 2015 at 5:10 PM, Ed Sutter <edsutterjr at gmail.com
> <mailto:edsutterjr at gmail.com>> wrote:
> >>> Jarielle,
> >>> Excellent!
> >>> Couple of  comments...
> >>> 1. Since you've got so much detail in there, you may want to
> include the
> >>> names of
> >>> the TRM chapter and sections that you reference.  I say this
> because a later
> >>> revision may insert
> >>> a chapter or a section and that will make the chapter/section
> numbers you
> >>> have confusing.
> >>> 2. For raw mode description, in the 'dd' line, change "of=/dev/sdc" to
> >>> "of=<device>" (where <device> is the sd card).
> >>> 3. For fat mode description, you may want to add a "dd if=/dev/zero
> >>> of=<device> bs=1M count=1" as the first step just to
> >>>       make sure there is no partition table at the base of the SD
> card.  If
> >>> there is, then the first 'n' in your instructions
> >>>       may not do what you want.  I know you mention that the card
> is assumed
> >>> to not be formatted.  This just
> >>>       makes sure of that.  So, I walked through your steps, using
> this to
> >>> automate:
> >>> export SDDEV=/dev/sdc  # User should verify this device.
> >>> sudo dd if=/dev/zero of=${SDDEV} bs=128K count=1
> >>> echo "n\np\n1\n\n+1M\nt\nc\na\n1\np\nw\n" | fdisk ${SDDEV}
> >>>       But when I did the mkfs line in your text, it returned an
> error: Not
> >>> enough clusters for a 32bit FAT.
> >>>       So, I just did "mkfs.vfat /dev/sdc1" and that worked fine.
> Honestly, I
> >>> don't know the details here,
> >>>       so if you can investigate this, that would be great.
> Suggest adding
> >>> something like the script above as
> >>>       a shortcut.
> >>> 4. For UART boot mode, mention that the uMon image that is
> transferred is
> >>> boot.bin, not the MLO.
> >>> Some other stuff you could add:
> >>> - To know for sure what device is your uSD card in your linux box,
> run "cat
> >>> /proc/partitions" before and after
> >>> inserting the card and note the difference.
> >>> Good stuff,
> >>> Ed
> >>> Ed,
> >>> I finished the first draft of the document.  It can be found here:
> https://github.com/jrcatbagan/umon/commit/7f751486d5ca3ba5f6449adf5561df527a5cfde1
> >>> . Please feel free to give me any suggestions on how I can improve it
> >>> or if I am missing something.  Once you give the green light, I'll
> >>> send it to umon-devel as a patch.
> >>> Thanks.
> >>> On Mon, Jul 6, 2015 at 5:21 AM, Ed Sutter
> <ed.sutter at alcatel-lucent.com <mailto:ed.sutter at alcatel-lucent.com>>
> >>> wrote:
> >>> On 7/5/2015 6:46 PM, Chris Johns wrote:
> >>> On 5/07/2015 4:19 am, Ed Sutter wrote:
> >>> Ok, I managed to get it to boot using only Linux for formatting
> the card.
> >>> It wasn't working for me until I just read your email and realized
> I did
> >>> not mark
> >>> the partition active.  After doing that it booted!
> >>> So here are the steps I walked through
> >>> (extracted from:
> http://forum.xda-developers.com/showthread.php?t=502095)
> >>> 1. Verify the partition that the SD card installs as:
> >>>        - cat /proc/paritions (without the uSD)
> >>>        - Insert uSD card
> >>>        - cat /proc/paritions (note the difference)
> >>> Using /dev/sdc as our partition:
> >>> 2. sudo fdisk /dev/sdc
> >>>       - delete all paritions with 'd' command (d1/d2/d3/d4) as needed
> >>>       - use 'n' command to create partition 1
> >>>       - use 't' command to relabel partition 1 to 'c'
> >>>       - use 'a' command to make the parition active
> >>>       - use 'p' to show something like:
> >>>      Device Boot      Start         End Blocks   Id  System
> >>> /dev/sdc1   *        2048     3932159     1965056   c  W95 FAT32 (LBA)
> >>>        - use 'w' to write to the card
> >>> 3. Run sudo mkfs.vfat /dev/sdc1
> >>> 4. Mount /dev/sdc1 as /media/boot (or whatever)
> >>> 5. Copy MLO to /media/boot
> >>> 6. Run sync; unmount /media/boot
> >>> 7. Put card in BBB, reset with boot button depressed.
> >>> A simple request to place in the doco early is to create a root
> >>> partition only as large as you need and not use whole disk size in the
> >>> root partition. Users should be encouraged to add other partitions
> they
> >>> can mount as read/write to store a kernel and/or user data.
> >>> Chris
> >>> _______________________________________________
> >>> Yep, for sure... my example above was lame...
> >>> Functionally ok, but not considering the fact that the SD card
> will have
> >>> other "stuff".  Also, Chris, IIRC, you mentioned that FAT-booting
> may not be
> >>> the right way to go ultimately.  So, for now at least, it will be
> good to
> >>> cover
> >>> both modes of booting until we get a better grip on which approach to
> >>> take.
> >>> Jarielle, I can add detail on raw mode to whatever you initially
> write up
> >>> if you want me to...
> >>> Ed
> >>> umon-devel mailing list
> >>> umon-devel at rtems.org <mailto:umon-devel at rtems.org>
> >>> http://lists.rtems.org/mailman/listinfo/umon-devel
More information about the umon-devel mailing list
