Update: uMon is now booting from SD
Ed Sutter
edsutterjr at gmail.com
Thu Jul 9 11:09:04 UTC 2015
Jarielle,
Sorry I didn't get back to you immediately after the push last night.
I had to leave and didn't get back till after midnight.
Anyway, yea, I guess there are different versions of fdisk because I
figured you had a typo in the script. For me, the '1' is the response
to the 'a' command. After issuing the 'a', it asks me what partition
to apply it to. Here's part of my fdisk interaction...
Command (m for help): t
Selected partition 1
Hex code (type L to list codes): 6
Changed system type of partition 1 to 6 (FAT16)
Command (m for help): a
Partition number (1-4): 1 <<<<<<
I'm running with ubuntu 14.04.
I also found that the path to bash at the top of the script was different.
The final adjustment I made was to add a few 'sync' commands between
the mount/umount lines because for me, the "rm -rf mnt" would fail because
the device was busy (apparently not quite unumounted yet). The sync takes
care of that.
So, not quite sure what to say about this. The sync is not an issue; harmless if not
needed; useful if needed so it will work for all cases. The fdisk issue may just mean we
need to document the possibility that there are different versions.
Thoughts?
Ed
> Hi Ed,
> Thanks for merging the patches.
> I just have one question about the latest commit. The addition of the
> '1' in the fdisk command is actually resulting in "unknown command"
> being outputted when fdisk is executing from the script. I took a
> screenshot of the script output and I have attached it to this email.
> Could I be missing something?
> On Wed, Jul 8, 2015 at 3:59 AM, Ed Sutter <edsutterjr at gmail.com> wrote:
>> Jarielle,
>> Ok, great, just thought I'd save you some typing, but you beat me to it!
>> The files look excellent!
>> Ed
>>> Ed,
>>> Thank you.
>>> I actually already finished the next set of drafts of the files and
>>> modified the Makefile to build a uMon image for "raw" mode booting, as
>>> well as updated the script to provide the ability to setup the SD for
>>> either "raw" or FAT mode.
>>> By coincidence I also created a configuration header source file when
>>> I was updating the Makefile in order to build the "raw" mode image. I
>>> was able to boot from an SD card using both modes that was set up
>>> using the script.
>>> The files I updated/created are as follows:
>>> README:
>>> https://github.com/jrcatbagan/umon/blob/dev/ports/beagleboneblack/README
>>> config_header.S:
>>> https://github.com/jrcatbagan/umon/blob/dev/ports/beagleboneblack/config_header.S
>>> sd-setup.sh:
>>> https://github.com/jrcatbagan/umon/blob/dev/ports/beagleboneblack/sd-setup.sh
>>> And these are the changes I made to the Makefile to build the image
>>> for "raw" mode:
>>> https://github.com/jrcatbagan/umon/commit/8246293254e3ce9e37cb8ed314077f35888af58c
>>> Let me know what you think so far about the changes/additions. If
>>> they are ready, I'll be happy to send them to you as patches for
>>> further testing/review.
>>> Thanks.
>>> On Tue, Jul 7, 2015 at 5:40 PM, Ed Sutter <edsutterjr at gmail.com> wrote:
>>>> Jarielle,
>>>> Since I already did it, attached is the cfg_header.S file I used for raw
>>>> mode.
>>>> Ed
>>>> On Jul 7, 2015 4:49 AM, "Ed Sutter" <ed.sutter at alcatel-lucent.com> wrote:
>>>>> Jarielle,
>>>>> Great!
>>>>> Two (last) minor suggestions...
>>>>> 1. Mention the script in the documentation file.
>>>>> 2. In the script you may as well include the final step that you have in
>>>>> the documentation
>>>>> for copying the MLO file to the card...
>>>>> cd ~
>>>>> mkdir mnt
>>>>> rmdir mnt
>>>>> Other than that, it looks good to me.
>>>>> Good hunting regarding the cluster error issue!
>>>>> Ed
>>>> Thanks. Doc and script are now updated to reflect the minor suggestions.
>>>> I
>>>> added a part in the "FAT Mode" section to refer to the script and I added
>>>> the last remaining steps in the doc to the script. The links to the
>>>> files
>>>> are the same as before.
>>>> How are the doc and script so far?
>>>> Just for completeness, I'm going to get the raw mode image built as well
>>>> with the Configuration Header and GP Header prepended. I'm thinking of
>>>> also
>>>> updating the script even further to allow the user to select whether they
>>>> would want to format the SD card for "raw" or FAT mode.
>>>> I'll then send another draft of the files for your review.
>>>>>> Ed,
>>>>>> Thank you for your suggestions. I have taken them into account when
>>>>>> improving the document.
>>>>>> Here is the second draft of the doc:
>>>>>> I have also created a script that automates the process of setting up
>>>>>> the SD card. It can be found here:
>>>>>> I also looked into the error regarding the situation where there is
>>>>>> not enough clusters and it turns out that the minimum size for the
>>>>>> FAT32 primary partition is around 32MB. FAT16 on the other hand has a
>>>>>> minimum size of around 3MB. I was using this document as reference:
>>>>>> https://staff.washington.edu/dittrich/misc/fatgen103.pdf . So I went
>>>>>> ahead and had the script create the primary partition as FAT16. I was
>>>>>> able to boot uMon from an SD card that was setup with this script.
>>>>>> Please let me know what you think about the doc and script so far.
>>>>>> Thanks.
>>>>>> On Mon, Jul 6, 2015 at 5:10 PM, Ed Sutter <edsutterjr at gmail.com> wrote:
>>>>>>> Jarielle,
>>>>>>> Excellent!
>>>>>>> Couple of comments...
>>>>>>> 1. Since you've got so much detail in there, you may want to include
>>>>>>> the
>>>>>>> names of
>>>>>>> the TRM chapter and sections that you reference. I say this because a
>>>>>>> later
>>>>>>> revision may insert
>>>>>>> a chapter or a section and that will make the chapter/section numbers
>>>>>>> you
>>>>>>> have confusing.
>>>>>>> 2. For raw mode description, in the 'dd' line, change "of=/dev/sdc" to
>>>>>>> "of=<device>" (where <device> is the sd card).
>>>>>>> 3. For fat mode description, you may want to add a "dd if=/dev/zero
>>>>>>> of=<device> bs=1M count=1" as the first step just to
>>>>>>> make sure there is no partition table at the base of the SD
>>>>>>> card.
>>>>>>> If
>>>>>>> there is, then the first 'n' in your instructions
>>>>>>> may not do what you want. I know you mention that the card is
>>>>>>> assumed
>>>>>>> to not be formatted. This just
>>>>>>> makes sure of that. So, I walked through your steps, using
>>>>>>> this
>>>>>>> to
>>>>>>> automate:
>>>>>>> export SDDEV=/dev/sdc # User should verify this device.
>>>>>>> sudo dd if=/dev/zero of=${SDDEV} bs=128K count=1
>>>>>>> echo "n\np\n1\n\n+1M\nt\nc\na\n1\np\nw\n" | fdisk ${SDDEV}
>>>>>>> But when I did the mkfs line in your text, it returned an
>>>>>>> error:
>>>>>>> Not
>>>>>>> enough clusters for a 32bit FAT.
>>>>>>> So, I just did "mkfs.vfat /dev/sdc1" and that worked fine.
>>>>>>> Honestly, I
>>>>>>> don't know the details here,
>>>>>>> so if you can investigate this, that would be great. Suggest
>>>>>>> adding
>>>>>>> something like the script above as
>>>>>>> a shortcut.
>>>>>>> 4. For UART boot mode, mention that the uMon image that is transferred
>>>>>>> is
>>>>>>> boot.bin, not the MLO.
>>>>>>> Some other stuff you could add:
>>>>>>> - To know for sure what device is your uSD card in your linux box, run
>>>>>>> "cat
>>>>>>> /proc/partitions" before and after
>>>>>>> inserting the card and note the difference.
>>>>>>> Good stuff,
>>>>>>> Ed
>>>>>>> Ed,
>>>>>>> I finished the first draft of the document. It can be found here:
>>>>>>> https://github.com/jrcatbagan/umon/commit/7f751486d5ca3ba5f6449adf5561df527a5cfde1
>>>>>>> . Please feel free to give me any suggestions on how I can improve it
>>>>>>> or if I am missing something. Once you give the green light, I'll
>>>>>>> send it to umon-devel as a patch.
>>>>>>> Thanks.
>>>>>>> On Mon, Jul 6, 2015 at 5:21 AM, Ed Sutter
>>>>>>> wrote:
>>>>>>> On 7/5/2015 6:46 PM, Chris Johns wrote:
>>>>>>> On 5/07/2015 4:19 am, Ed Sutter wrote:
>>>>>>> Ok, I managed to get it to boot using only Linux for formatting the
>>>>>>> card.
>>>>>>> It wasn't working for me until I just read your email and realized I
>>>>>>> did
>>>>>>> not mark
>>>>>>> the partition active. After doing that it booted!
>>>>>>> So here are the steps I walked through
>>>>>>> (extracted from:
>>>>>>> http://forum.xda-developers.com/showthread.php?t=502095)
>>>>>>> 1. Verify the partition that the SD card installs as:
>>>>>>> - cat /proc/paritions (without the uSD)
>>>>>>> - Insert uSD card
>>>>>>> - cat /proc/paritions (note the difference)
>>>>>>> Using /dev/sdc as our partition:
>>>>>>> 2. sudo fdisk /dev/sdc
>>>>>>> - delete all paritions with 'd' command (d1/d2/d3/d4) as needed
>>>>>>> - use 'n' command to create partition 1
>>>>>>> - use 't' command to relabel partition 1 to 'c'
>>>>>>> - use 'a' command to make the parition active
>>>>>>> - use 'p' to show something like:
>>>>>>> Device Boot Start End Blocks Id System
>>>>>>> /dev/sdc1 * 2048 3932159 1965056 c W95 FAT32
>>>>>>> (LBA)
>>>>>>> - use 'w' to write to the card
>>>>>>> 3. Run sudo mkfs.vfat /dev/sdc1
>>>>>>> 4. Mount /dev/sdc1 as /media/boot (or whatever)
>>>>>>> 5. Copy MLO to /media/boot
>>>>>>> 6. Run sync; unmount /media/boot
>>>>>>> 7. Put card in BBB, reset with boot button depressed.
>>>>>>> A simple request to place in the doco early is to create a root
>>>>>>> partition only as large as you need and not use whole disk size in the
>>>>>>> root partition. Users should be encouraged to add other partitions
>>>>>>> they
>>>>>>> can mount as read/write to store a kernel and/or user data.
>>>>>>> Chris
>>>>>>> _______________________________________________
>>>>>>> Yep, for sure... my example above was lame...
>>>>>>> Functionally ok, but not considering the fact that the SD card will
>>>>>>> have
>>>>>>> other "stuff". Also, Chris, IIRC, you mentioned that FAT-booting may
>>>>>>> not be
>>>>>>> the right way to go ultimately. So, for now at least, it will be good
>>>>>>> to
>>>>>>> cover
>>>>>>> both modes of booting until we get a better grip on which approach to
>>>>>>> take.
>>>>>>> Jarielle, I can add detail on raw mode to whatever you initially write
>>>>>>> up
>>>>>>> if you want me to...
>>>>>>> Ed
>>>>>>> umon-devel mailing list
>>>>>>> umon-devel at rtems.org
>>>>>>> http://lists.rtems.org/mailman/listinfo/umon-devel
URL: <http://lists.rtems.org/pipermail/umon-devel/attachments/20150709/8fe2cdfe/attachment-0001.html>
More information about the umon-devel
