Update: uMon is now booting from SD
Jarielle Catbagan jcatbagan93 at gmail.com
Thu Jul 9 16:21:50 UTC 2015
Ed,
You're absolutely right.  Will do!  I will continue focusing on the DDR init.
Thanks.
On Thu, Jul 9, 2015 at 5:07 AM, Ed Sutter <ed.sutter at alcatel-lucent.com> wrote:
> Jarielle,
> At this point, I'd suggest that you deal with DDR and the other BBB stuff.
> I'd really rather you tackle the board-specific stuff.  I'll leave it up to
> you,
> but I really think your time is better spent on the port itself.
> If you agree, then I'll look into this fdisk issue.
> Ed
>> Jarielle,
>> Sorry I didn't get back to you immediately after the push last night.
>> I had to leave and didn't get back till after midnight.
>> Anyway, yea, I guess there are different versions of fdisk because I
>> figured you had a typo in the script.  For me, the '1' is the response
>> to the 'a' command.  After issuing the 'a', it asks me what partition
>> to apply it to.  Here's part of my fdisk interaction...
>>     Command (m for help): t
>>     Selected partition 1
>>     Hex code (type L to list codes): 6
>>     Changed system type of partition 1 to 6 (FAT16)
>>     Command (m for help): a
>>     Partition number (1-4):  1 <<<<<<
>> I'm running with ubuntu 14.04.
>> I also found that the path to bash at the top of the script was different.
>> The final adjustment I made was to add a few 'sync' commands between
>> the mount/umount lines  because for me, the "rm -rf mnt" would fail
>> because
>> the device was busy (apparently not quite unumounted yet).  The sync takes
>> care of that.
>> So, not quite sure what to say about this.  The sync is not an issue;
>> harmless if not
>> needed; useful if needed so it will work for all cases.  The fdisk issue
>> may just mean we
>> need to document the possibility that there are different versions.
>> Thoughts?
>> Ed
>>> Hi Ed,
>>> Thanks for merging the patches.
>>> I just have one question about the latest commit.  The addition of the
>>> '1' in the fdisk command is actually resulting in "unknown command"
>>> being outputted when fdisk is executing from the script.  I took a
>>> screenshot of the script output and I have attached it to this email.
>>> Could I be missing something?
>>> On Wed, Jul 8, 2015 at 3:59 AM, Ed Sutter<edsutterjr at gmail.com>  wrote:
>>>> Jarielle,
>>>> Ok, great, just thought I'd save you some typing, but you beat me to it!
>>>> The files look excellent!
>>>> Ed
>>>>> Ed,
>>>>> Thank you.
>>>>> I actually already finished the next set of drafts of the files and
>>>>> modified the Makefile to build a uMon image for "raw" mode booting, as
>>>>> well as updated the script to provide the ability to setup the SD for
>>>>> either "raw" or FAT mode.
>>>>> By coincidence I also created a configuration header source file when
>>>>> I was updating the Makefile in order to build the "raw" mode image.  I
>>>>> was able to boot from an SD card using both modes that was set up
>>>>> using the script.
>>>>> The files I updated/created are as follows:
>>>>> README:
>>>>> https://github.com/jrcatbagan/umon/blob/dev/ports/beagleboneblack/README
>>>>> config_header.S:
>>>>> https://github.com/jrcatbagan/umon/blob/dev/ports/beagleboneblack/config_header.S
>>>>> sd-setup.sh:
>>>>> https://github.com/jrcatbagan/umon/blob/dev/ports/beagleboneblack/sd-setup.sh
>>>>> And these are the changes I made to the Makefile to build the image
>>>>> for "raw" mode:
>>>>> https://github.com/jrcatbagan/umon/commit/8246293254e3ce9e37cb8ed314077f35888af58c
>>>>> Let me know what you think so far about the changes/additions.  If
>>>>> they are ready, I'll be happy to send them to you as patches for
>>>>> further testing/review.
>>>>> Thanks.
>>>>> On Tue, Jul 7, 2015 at 5:40 PM, Ed Sutter<edsutterjr at gmail.com>  wrote:
>>>>>> Jarielle,
>>>>>> Since I already did it, attached is the cfg_header.S file I used for
>>>>>> raw
>>>>>> mode.
>>>>>> Ed
>>>>>> On Jul 7, 2015 4:49 AM, "Ed Sutter"<ed.sutter at alcatel-lucent.com>
>>>>>> wrote:
>>>>>>> Jarielle,
>>>>>>> Great!
>>>>>>> Two (last) minor suggestions...
>>>>>>> 1. Mention the script in the documentation file.
>>>>>>> 2. In the script you may as well include the final step that you have
>>>>>>> in
>>>>>>> the documentation
>>>>>>> for copying the MLO file to the card...
>>>>>>>      cd ~
>>>>>>>      mkdir mnt
>>>>>>>      rmdir mnt
>>>>>>> Other than that, it looks good to me.
>>>>>>> Good hunting regarding the cluster error issue!
>>>>>>> Ed
>>>>>> Thanks.  Doc and script are now updated to reflect the minor
>>>>>> suggestions.
>>>>>> I
>>>>>> added a part in the "FAT Mode" section to refer to the script and I
>>>>>> added
>>>>>> the last remaining steps in the doc to the script.  The links to the
>>>>>> files
>>>>>> are the same as before.
>>>>>> How are the doc and script so far?
>>>>>> Just for completeness, I'm going to get the raw mode image built as
>>>>>> well
>>>>>> with the Configuration Header and GP Header prepended.  I'm thinking
>>>>>> of
>>>>>> also
>>>>>> updating the script even further to allow the user to select whether
>>>>>> they
>>>>>> would want to format the SD card for "raw" or FAT mode.
>>>>>> I'll then send another draft of the files for your review.
>>>>>>>> Ed,
>>>>>>>> Thank you for your suggestions.  I have taken them into account when
>>>>>>>> improving the document.
>>>>>>>> Here is the second draft of the doc:
>>>>>>>> I have also created a script that automates the process of setting
>>>>>>>> up
>>>>>>>> the SD card.  It can be found here:
>>>>>>>> I also looked into the error regarding the situation where there is
>>>>>>>> not enough clusters and it turns out that the minimum size for the
>>>>>>>> FAT32 primary partition is around 32MB.  FAT16 on the other hand has
>>>>>>>> a
>>>>>>>> minimum size of around 3MB.  I was using this document as reference:
>>>>>>>> https://staff.washington.edu/dittrich/misc/fatgen103.pdf  .   So I
>>>>>>>> went
>>>>>>>> ahead and had the script create the primary partition as FAT16.  I
>>>>>>>> was
>>>>>>>> able to boot uMon from an SD card that was setup with this script.
>>>>>>>> Please let me know what you think about the doc and script so far.
>>>>>>>> Thanks.
>>>>>>>> On Mon, Jul 6, 2015 at 5:10 PM, Ed Sutter<edsutterjr at gmail.com>
>>>>>>>> wrote:
>>>>>>>>> Jarielle,
>>>>>>>>> Excellent!
>>>>>>>>> Couple of  comments...
>>>>>>>>> 1. Since you've got so much detail in there, you may want to
>>>>>>>>> include
>>>>>>>>> the
>>>>>>>>> names of
>>>>>>>>> the TRM chapter and sections that you reference.  I say this
>>>>>>>>> because a
>>>>>>>>> later
>>>>>>>>> revision may insert
>>>>>>>>> a chapter or a section and that will make the chapter/section
>>>>>>>>> numbers
>>>>>>>>> you
>>>>>>>>> have confusing.
>>>>>>>>> 2. For raw mode description, in the 'dd' line, change "of=/dev/sdc"
>>>>>>>>> to
>>>>>>>>> "of=<device>" (where <device> is the sd card).
>>>>>>>>> 3. For fat mode description, you may want to add a "dd if=/dev/zero
>>>>>>>>> of=<device> bs=1M count=1" as the first step just to
>>>>>>>>>         make sure there is no partition table at the base of the SD
>>>>>>>>> card.
>>>>>>>>> If
>>>>>>>>> there is, then the first 'n' in your instructions
>>>>>>>>>         may not do what you want.  I know you mention that the card
>>>>>>>>> is
>>>>>>>>> assumed
>>>>>>>>> to not be formatted.  This just
>>>>>>>>>         makes sure of that.  So, I walked through your steps, using
>>>>>>>>> this
>>>>>>>>> to
>>>>>>>>> automate:
>>>>>>>>> export SDDEV=/dev/sdc  # User should verify this device.
>>>>>>>>> sudo dd if=/dev/zero of=${SDDEV} bs=128K count=1
>>>>>>>>> echo "n\np\n1\n\n+1M\nt\nc\na\n1\np\nw\n" | fdisk ${SDDEV}
>>>>>>>>>         But when I did the mkfs line in your text, it returned an
>>>>>>>>> error:
>>>>>>>>> Not
>>>>>>>>> enough clusters for a 32bit FAT.
>>>>>>>>>         So, I just did "mkfs.vfat /dev/sdc1" and that worked fine.
>>>>>>>>> Honestly, I
>>>>>>>>> don't know the details here,
>>>>>>>>>         so if you can investigate this, that would be great.
>>>>>>>>> Suggest
>>>>>>>>> adding
>>>>>>>>> something like the script above as
>>>>>>>>>         a shortcut.
>>>>>>>>> 4. For UART boot mode, mention that the uMon image that is
>>>>>>>>> transferred
>>>>>>>>> is
>>>>>>>>> boot.bin, not the MLO.
>>>>>>>>> Some other stuff you could add:
>>>>>>>>> - To know for sure what device is your uSD card in your linux box,
>>>>>>>>> run
>>>>>>>>> "cat
>>>>>>>>> /proc/partitions" before and after
>>>>>>>>> inserting the card and note the difference.
>>>>>>>>> Good stuff,
>>>>>>>>> Ed
>>>>>>>>> Ed,
>>>>>>>>> I finished the first draft of the document.  It can be found here:
>>>>>>>>> https://github.com/jrcatbagan/umon/commit/7f751486d5ca3ba5f6449adf5561df527a5cfde1
>>>>>>>>> . Please feel free to give me any suggestions on how I can improve
>>>>>>>>> it
>>>>>>>>> or if I am missing something.  Once you give the green light, I'll
>>>>>>>>> send it to umon-devel as a patch.
>>>>>>>>> Thanks.
>>>>>>>>> On Mon, Jul 6, 2015 at 5:21 AM, Ed Sutter
>>>>>>>>> wrote:
>>>>>>>>> On 7/5/2015 6:46 PM, Chris Johns wrote:
>>>>>>>>> On 5/07/2015 4:19 am, Ed Sutter wrote:
>>>>>>>>> Ok, I managed to get it to boot using only Linux for formatting the
>>>>>>>>> card.
>>>>>>>>> It wasn't working for me until I just read your email and realized
>>>>>>>>> I
>>>>>>>>> did
>>>>>>>>> not mark
>>>>>>>>> the partition active.  After doing that it booted!
>>>>>>>>> So here are the steps I walked through
>>>>>>>>> (extracted from:
>>>>>>>>> http://forum.xda-developers.com/showthread.php?t=502095)
>>>>>>>>> 1. Verify the partition that the SD card installs as:
>>>>>>>>>          - cat /proc/paritions (without the uSD)
>>>>>>>>>          - Insert uSD card
>>>>>>>>>          - cat /proc/paritions (note the difference)
>>>>>>>>> Using /dev/sdc as our partition:
>>>>>>>>> 2. sudo fdisk /dev/sdc
>>>>>>>>>         - delete all paritions with 'd' command (d1/d2/d3/d4) as
>>>>>>>>> needed
>>>>>>>>>         - use 'n' command to create partition 1
>>>>>>>>>         - use 't' command to relabel partition 1 to 'c'
>>>>>>>>>         - use 'a' command to make the parition active
>>>>>>>>>         - use 'p' to show something like:
>>>>>>>>>        Device Boot      Start         End      Blocks   Id  System
>>>>>>>>> /dev/sdc1   *        2048     3932159     1965056    c  W95 FAT32
>>>>>>>>> (LBA)
>>>>>>>>>          - use 'w' to write to the card
>>>>>>>>> 3. Run sudo mkfs.vfat /dev/sdc1
>>>>>>>>> 4. Mount /dev/sdc1 as /media/boot (or whatever)
>>>>>>>>> 5. Copy MLO to /media/boot
>>>>>>>>> 6. Run sync; unmount /media/boot
>>>>>>>>> 7. Put card in BBB, reset with boot button depressed.
>>>>>>>>> A simple request to place in the doco early is to create a root
>>>>>>>>> partition only as large as you need and not use whole disk size in
>>>>>>>>> the
>>>>>>>>> root partition. Users should be encouraged to add other partitions
>>>>>>>>> they
>>>>>>>>> can mount as read/write to store a kernel and/or user data.
>>>>>>>>> Chris
>>>>>>>>> _______________________________________________
>>>>>>>>> Yep, for sure... my example above was lame...
>>>>>>>>> Functionally ok, but not considering the fact that the SD card will
>>>>>>>>> have
>>>>>>>>> other "stuff".  Also, Chris, IIRC, you mentioned that FAT-booting
>>>>>>>>> may
>>>>>>>>> not be
>>>>>>>>> the right way to go ultimately.  So, for now at least, it will be
>>>>>>>>> good
>>>>>>>>> to
>>>>>>>>> cover
>>>>>>>>> both modes of booting until we get a better grip on which approach
>>>>>>>>> to
>>>>>>>>> take.
>>>>>>>>> Jarielle, I can add detail on raw mode to whatever you initially
>>>>>>>>> write
>>>>>>>>> up
>>>>>>>>> if you want me to...
>>>>>>>>> Ed
>>>>>>>>> umon-devel mailing list
>>>>>>>>> umon-devel at rtems.org
>>>>>>>>> http://lists.rtems.org/mailman/listinfo/umon-devel
More information about the umon-devel mailing list
