Update: uMon is now booting from SD
Jarielle Catbagan jcatbagan93 at gmail.com
Thu Jul 9 17:24:16 UTC 2015
On Thu, Jul 9, 2015 at 10:05 AM, Ed Sutter <ed.sutter at alcatel-lucent.com> wrote:
> Jarielle,
> Great!  Meanwhile, I may push a few changes just to clean up a few
> non-obvious things
> that are still hanging around in the port/beagleboneblack directory from the
> CSB740 port;
> so you may see a few patches over the next few days.
> Ed
Sounds good!  I will pull in the changes to my local branch once they
are available.
Thanks.
>> Ed,
>> You're absolutely right.  Will do!  I will continue focusing on the DDR
>> init.
>> Thanks.
>> On Thu, Jul 9, 2015 at 5:07 AM, Ed Sutter <ed.sutter at alcatel-lucent.com>
>> wrote:
>>> Jarielle,
>>> At this point, I'd suggest that you deal with DDR and the other BBB
>>> stuff.
>>> I'd really rather you tackle the board-specific stuff.  I'll leave it up
>>> to
>>> you,
>>> but I really think your time is better spent on the port itself.
>>> If you agree, then I'll look into this fdisk issue.
>>> Ed
>>>> Jarielle,
>>>> Sorry I didn't get back to you immediately after the push last night.
>>>> I had to leave and didn't get back till after midnight.
>>>> Anyway, yea, I guess there are different versions of fdisk because I
>>>> figured you had a typo in the script.  For me, the '1' is the response
>>>> to the 'a' command.  After issuing the 'a', it asks me what partition
>>>> to apply it to.  Here's part of my fdisk interaction...
>>>>      Command (m for help): t
>>>>      Selected partition 1
>>>>      Hex code (type L to list codes): 6
>>>>      Changed system type of partition 1 to 6 (FAT16)
>>>>      Command (m for help): a
>>>>      Partition number (1-4):  1 <<<<<<
>>>> I'm running with ubuntu 14.04.
>>>> I also found that the path to bash at the top of the script was
>>>> different.
>>>> The final adjustment I made was to add a few 'sync' commands between
>>>> the mount/umount lines  because for me, the "rm -rf mnt" would fail
>>>> because
>>>> the device was busy (apparently not quite unumounted yet).  The sync
>>>> takes
>>>> care of that.
>>>> So, not quite sure what to say about this.  The sync is not an issue;
>>>> harmless if not
>>>> needed; useful if needed so it will work for all cases.  The fdisk issue
>>>> may just mean we
>>>> need to document the possibility that there are different versions.
>>>> Thoughts?
>>>> Ed
>>>>> Hi Ed,
>>>>> Thanks for merging the patches.
>>>>> I just have one question about the latest commit.  The addition of the
>>>>> '1' in the fdisk command is actually resulting in "unknown command"
>>>>> being outputted when fdisk is executing from the script.  I took a
>>>>> screenshot of the script output and I have attached it to this email.
>>>>> Could I be missing something?
>>>>> On Wed, Jul 8, 2015 at 3:59 AM, Ed Sutter<edsutterjr at gmail.com>  wrote:
>>>>>> Jarielle,
>>>>>> Ok, great, just thought I'd save you some typing, but you beat me to
>>>>>> it!
>>>>>> The files look excellent!
>>>>>> Ed
>>>>>>> Ed,
>>>>>>> Thank you.
>>>>>>> I actually already finished the next set of drafts of the files and
>>>>>>> modified the Makefile to build a uMon image for "raw" mode booting,
>>>>>>> as
>>>>>>> well as updated the script to provide the ability to setup the SD for
>>>>>>> either "raw" or FAT mode.
>>>>>>> By coincidence I also created a configuration header source file when
>>>>>>> I was updating the Makefile in order to build the "raw" mode image.
>>>>>>> I
>>>>>>> was able to boot from an SD card using both modes that was set up
>>>>>>> using the script.
>>>>>>> The files I updated/created are as follows:
>>>>>>> README:
>>>>>>> https://github.com/jrcatbagan/umon/blob/dev/ports/beagleboneblack/README
>>>>>>> config_header.S:
>>>>>>> https://github.com/jrcatbagan/umon/blob/dev/ports/beagleboneblack/config_header.S
>>>>>>> sd-setup.sh:
>>>>>>> https://github.com/jrcatbagan/umon/blob/dev/ports/beagleboneblack/sd-setup.sh
>>>>>>> And these are the changes I made to the Makefile to build the image
>>>>>>> for "raw" mode:
>>>>>>> https://github.com/jrcatbagan/umon/commit/8246293254e3ce9e37cb8ed314077f35888af58c
>>>>>>> Let me know what you think so far about the changes/additions.  If
>>>>>>> they are ready, I'll be happy to send them to you as patches for
>>>>>>> further testing/review.
>>>>>>> Thanks.
>>>>>>> On Tue, Jul 7, 2015 at 5:40 PM, Ed Sutter<edsutterjr at gmail.com>
>>>>>>> wrote:
>>>>>>>> Jarielle,
>>>>>>>> Since I already did it, attached is the cfg_header.S file I used for
>>>>>>>> raw
>>>>>>>> mode.
>>>>>>>> Ed
>>>>>>>> On Jul 7, 2015 4:49 AM, "Ed Sutter"<ed.sutter at alcatel-lucent.com>
>>>>>>>> wrote:
>>>>>>>>> Jarielle,
>>>>>>>>> Great!
>>>>>>>>> Two (last) minor suggestions...
>>>>>>>>> 1. Mention the script in the documentation file.
>>>>>>>>> 2. In the script you may as well include the final step that you
>>>>>>>>> have
>>>>>>>>> in
>>>>>>>>> the documentation
>>>>>>>>> for copying the MLO file to the card...
>>>>>>>>>       cd ~
>>>>>>>>>       mkdir mnt
>>>>>>>>>       rmdir mnt
>>>>>>>>> Other than that, it looks good to me.
>>>>>>>>> Good hunting regarding the cluster error issue!
>>>>>>>>> Ed
>>>>>>>> Thanks.  Doc and script are now updated to reflect the minor
>>>>>>>> suggestions.
>>>>>>>> I
>>>>>>>> added a part in the "FAT Mode" section to refer to the script and I
>>>>>>>> added
>>>>>>>> the last remaining steps in the doc to the script.  The links to the
>>>>>>>> files
>>>>>>>> are the same as before.
>>>>>>>> How are the doc and script so far?
>>>>>>>> Just for completeness, I'm going to get the raw mode image built as
>>>>>>>> well
>>>>>>>> with the Configuration Header and GP Header prepended.  I'm thinking
>>>>>>>> of
>>>>>>>> also
>>>>>>>> updating the script even further to allow the user to select whether
>>>>>>>> they
>>>>>>>> would want to format the SD card for "raw" or FAT mode.
>>>>>>>> I'll then send another draft of the files for your review.
>>>>>>>>>> Ed,
>>>>>>>>>> Thank you for your suggestions.  I have taken them into account
>>>>>>>>>> when
>>>>>>>>>> improving the document.
>>>>>>>>>> Here is the second draft of the doc:
>>>>>>>>>> I have also created a script that automates the process of setting
>>>>>>>>>> up
>>>>>>>>>> the SD card.  It can be found here:
>>>>>>>>>> I also looked into the error regarding the situation where there
>>>>>>>>>> is
>>>>>>>>>> not enough clusters and it turns out that the minimum size for the
>>>>>>>>>> FAT32 primary partition is around 32MB.  FAT16 on the other hand
>>>>>>>>>> has
>>>>>>>>>> a
>>>>>>>>>> minimum size of around 3MB.  I was using this document as
>>>>>>>>>> reference:
>>>>>>>>>> https://staff.washington.edu/dittrich/misc/fatgen103.pdf  .   So I
>>>>>>>>>> went
>>>>>>>>>> ahead and had the script create the primary partition as FAT16.  I
>>>>>>>>>> was
>>>>>>>>>> able to boot uMon from an SD card that was setup with this script.
>>>>>>>>>> Please let me know what you think about the doc and script so far.
>>>>>>>>>> Thanks.
>>>>>>>>>> On Mon, Jul 6, 2015 at 5:10 PM, Ed Sutter<edsutterjr at gmail.com>
>>>>>>>>>> wrote:
>>>>>>>>>>> Jarielle,
>>>>>>>>>>> Excellent!
>>>>>>>>>>> Couple of  comments...
>>>>>>>>>>> 1. Since you've got so much detail in there, you may want to
>>>>>>>>>>> include
>>>>>>>>>>> the
>>>>>>>>>>> names of
>>>>>>>>>>> the TRM chapter and sections that you reference.  I say this
>>>>>>>>>>> because a
>>>>>>>>>>> later
>>>>>>>>>>> revision may insert
>>>>>>>>>>> a chapter or a section and that will make the chapter/section
>>>>>>>>>>> numbers
>>>>>>>>>>> you
>>>>>>>>>>> have confusing.
>>>>>>>>>>> 2. For raw mode description, in the 'dd' line, change
>>>>>>>>>>> "of=/dev/sdc"
>>>>>>>>>>> to
>>>>>>>>>>> "of=<device>" (where <device> is the sd card).
>>>>>>>>>>> 3. For fat mode description, you may want to add a "dd
>>>>>>>>>>> if=/dev/zero
>>>>>>>>>>> of=<device> bs=1M count=1" as the first step just to
>>>>>>>>>>>          make sure there is no partition table at the base of the
>>>>>>>>>>> SD
>>>>>>>>>>> card.
>>>>>>>>>>> If
>>>>>>>>>>> there is, then the first 'n' in your instructions
>>>>>>>>>>>          may not do what you want.  I know you mention that the
>>>>>>>>>>> card
>>>>>>>>>>> is
>>>>>>>>>>> assumed
>>>>>>>>>>> to not be formatted.  This just
>>>>>>>>>>>          makes sure of that.  So, I walked through your steps,
>>>>>>>>>>> using
>>>>>>>>>>> this
>>>>>>>>>>> to
>>>>>>>>>>> automate:
>>>>>>>>>>> export SDDEV=/dev/sdc  # User should verify this device.
>>>>>>>>>>> sudo dd if=/dev/zero of=${SDDEV} bs=128K count=1
>>>>>>>>>>> echo "n\np\n1\n\n+1M\nt\nc\na\n1\np\nw\n" | fdisk ${SDDEV}
>>>>>>>>>>>          But when I did the mkfs line in your text, it returned
>>>>>>>>>>> an
>>>>>>>>>>> error:
>>>>>>>>>>> Not
>>>>>>>>>>> enough clusters for a 32bit FAT.
>>>>>>>>>>>          So, I just did "mkfs.vfat /dev/sdc1" and that worked
>>>>>>>>>>> fine.
>>>>>>>>>>> Honestly, I
>>>>>>>>>>> don't know the details here,
>>>>>>>>>>>          so if you can investigate this, that would be great.
>>>>>>>>>>> Suggest
>>>>>>>>>>> adding
>>>>>>>>>>> something like the script above as
>>>>>>>>>>>          a shortcut.
>>>>>>>>>>> 4. For UART boot mode, mention that the uMon image that is
>>>>>>>>>>> transferred
>>>>>>>>>>> is
>>>>>>>>>>> boot.bin, not the MLO.
>>>>>>>>>>> Some other stuff you could add:
>>>>>>>>>>> - To know for sure what device is your uSD card in your linux
>>>>>>>>>>> box,
>>>>>>>>>>> run
>>>>>>>>>>> "cat
>>>>>>>>>>> /proc/partitions" before and after
>>>>>>>>>>> inserting the card and note the difference.
>>>>>>>>>>> Good stuff,
>>>>>>>>>>> Ed
>>>>>>>>>>> Ed,
>>>>>>>>>>> I finished the first draft of the document.  It can be found
>>>>>>>>>>> here:
>>>>>>>>>>> https://github.com/jrcatbagan/umon/commit/7f751486d5ca3ba5f6449adf5561df527a5cfde1
>>>>>>>>>>> . Please feel free to give me any suggestions on how I can
>>>>>>>>>>> improve
>>>>>>>>>>> it
>>>>>>>>>>> or if I am missing something.  Once you give the green light,
>>>>>>>>>>> I'll
>>>>>>>>>>> send it to umon-devel as a patch.
>>>>>>>>>>> Thanks.
>>>>>>>>>>> On Mon, Jul 6, 2015 at 5:21 AM, Ed Sutter
>>>>>>>>>>> wrote:
>>>>>>>>>>> On 7/5/2015 6:46 PM, Chris Johns wrote:
>>>>>>>>>>> On 5/07/2015 4:19 am, Ed Sutter wrote:
>>>>>>>>>>> Ok, I managed to get it to boot using only Linux for formatting
>>>>>>>>>>> the
>>>>>>>>>>> card.
>>>>>>>>>>> It wasn't working for me until I just read your email and
>>>>>>>>>>> realized
>>>>>>>>>>> I
>>>>>>>>>>> did
>>>>>>>>>>> not mark
>>>>>>>>>>> the partition active.  After doing that it booted!
>>>>>>>>>>> So here are the steps I walked through
>>>>>>>>>>> (extracted from:
>>>>>>>>>>> http://forum.xda-developers.com/showthread.php?t=502095)
>>>>>>>>>>> 1. Verify the partition that the SD card installs as:
>>>>>>>>>>>           - cat /proc/paritions (without the uSD)
>>>>>>>>>>>           - Insert uSD card
>>>>>>>>>>>           - cat /proc/paritions (note the difference)
>>>>>>>>>>> Using /dev/sdc as our partition:
>>>>>>>>>>> 2. sudo fdisk /dev/sdc
>>>>>>>>>>>          - delete all paritions with 'd' command (d1/d2/d3/d4) as
>>>>>>>>>>> needed
>>>>>>>>>>>          - use 'n' command to create partition 1
>>>>>>>>>>>          - use 't' command to relabel partition 1 to 'c'
>>>>>>>>>>>          - use 'a' command to make the parition active
>>>>>>>>>>>          - use 'p' to show something like:
>>>>>>>>>>>         Device Boot      Start         End      Blocks   Id
>>>>>>>>>>> System
>>>>>>>>>>> /dev/sdc1   *        2048     3932159     1965056    c  W95 FAT32
>>>>>>>>>>> (LBA)
>>>>>>>>>>>           - use 'w' to write to the card
>>>>>>>>>>> 3. Run sudo mkfs.vfat /dev/sdc1
>>>>>>>>>>> 4. Mount /dev/sdc1 as /media/boot (or whatever)
>>>>>>>>>>> 5. Copy MLO to /media/boot
>>>>>>>>>>> 6. Run sync; unmount /media/boot
>>>>>>>>>>> 7. Put card in BBB, reset with boot button depressed.
>>>>>>>>>>> A simple request to place in the doco early is to create a root
>>>>>>>>>>> partition only as large as you need and not use whole disk size
>>>>>>>>>>> in
>>>>>>>>>>> the
>>>>>>>>>>> root partition. Users should be encouraged to add other
>>>>>>>>>>> partitions
>>>>>>>>>>> they
>>>>>>>>>>> can mount as read/write to store a kernel and/or user data.
>>>>>>>>>>> Chris
>>>>>>>>>>> _______________________________________________
>>>>>>>>>>> Yep, for sure... my example above was lame...
>>>>>>>>>>> Functionally ok, but not considering the fact that the SD card
>>>>>>>>>>> will
>>>>>>>>>>> have
>>>>>>>>>>> other "stuff".  Also, Chris, IIRC, you mentioned that FAT-booting
>>>>>>>>>>> may
>>>>>>>>>>> not be
>>>>>>>>>>> the right way to go ultimately.  So, for now at least, it will be
>>>>>>>>>>> good
>>>>>>>>>>> to
>>>>>>>>>>> cover
>>>>>>>>>>> both modes of booting until we get a better grip on which
>>>>>>>>>>> approach
>>>>>>>>>>> to
>>>>>>>>>>> take.
>>>>>>>>>>> Jarielle, I can add detail on raw mode to whatever you initially
>>>>>>>>>>> write
>>>>>>>>>>> up
>>>>>>>>>>> if you want me to...
>>>>>>>>>>> Ed
>>>>>>>>>>> umon-devel mailing list
>>>>>>>>>>> umon-devel at rtems.org
>>>>>>>>>>> http://lists.rtems.org/mailman/listinfo/umon-devel
More information about the umon-devel mailing list
