[PATCH] BBB: sd_setup.sh: Change /bin/bash -> /bin/sh to solely adhere to POSIX shell constructs
Joel Sherrill
joel.sherrill at oarcorp.com
Sat Jul 11 14:28:06 UTC 2015
On July 11, 2015 9:18:01 AM CDT, Ed Sutter <edsutterjr at gmail.com> wrote:
>Jarielle,
>Did you try running the script with that change?
>I applied the patch, then tried running it and it failed.
>Apparently 'echo' in sh is different than 'echo' in bash, at least it
>is for my system.
>Let me know.
>I had to remove the -e from the echo lines for it to work on my
>ubuntu14.04 system.
>You wanna test that and resubmit the patch or should I do it?
What happened?
>Ed
>_______________________________________________
>umon-devel mailing list
>umon-devel at rtems.org
>http://lists.rtems.org/mailman/listinfo/umon-devel
--joel
More information about the umon-devel
