[PATCH] BBB: sd_setup.sh: Change /bin/bash -> /bin/sh to solely adhere to POSIX shell constructs
Ed Sutter edsutterjr at gmail.com
Sun Jul 12 00:24:16 UTC 2015
Must be something strange about my environment.
I had to remove the -e to get it to run clean.
> On Jul 11, 2015 7:17 AM, "Ed Sutter" <edsutterjr at gmail.com <mailto:edsutterjr at gmail.com>> wrote:
> > Jarielle,
> > Did you try running the script with that change?
> > I applied the patch, then tried running it and it failed.
> > Apparently 'echo' in sh is different than 'echo' in bash, at least it is for my system.
> > Let me know.
> > I had to remove the -e from the echo lines for it to work on my ubuntu14.04 system.
> > You wanna test that and resubmit the patch or should I do it?
> > Ed
> Hi Ed,
> After I changed it to 'sh' I was able to run it.  Ok, I'll look into it to see what the issue might be.
> > umon-devel mailing list
> > umon-devel at rtems.org <mailto:umon-devel at rtems.org>
> > http://lists.rtems.org/mailman/listinfo/umon-devel
URL: <http://lists.rtems.org/pipermail/umon-devel/attachments/20150711/aff8a9e4/attachment.html>
More information about the umon-devel mailing list
