[PATCH] BBB: sd_setup.sh: Change /bin/bash -> /bin/sh to solely adhere to POSIX shell constructs
Ed Sutter edsutterjr at gmail.com
Mon Jul 13 23:34:27 UTC 2015
Jarielle,
Its pushed to the master.
Thanks!
Ed
> Ok, I just sent a version 2 of the patch that included the change from
> the previous version as well as changing all 'echo' invocations to
> 'printf'.  I tested the script both in bash/sh as well as dash, as
> apparently sh can be a symbolic link to both on different platforms,
> and things seem to be working.
> Here is the link to the patch:
> https://lists.rtems.org/pipermail/umon-devel/2015-July/000233.html
> Let me know if there are still any issues or if we should look for an
> alternative solution.
> Thanks.
> On Sat, Jul 11, 2015 at 6:48 PM, Jarielle Catbagan
> <jcatbagan93 at gmail.com> wrote:
>> Interesting. On my machine /bin/sh is a symbolic link to /bin/bash.  I
>> went ahead and tried /bin/dash and the 'echo' command can interpret
>> backslash characters whereas echo on sh/bash, -e has to be specified
>> otherwise the characters are outputted as is.
>> I tried printf in bash/sh and dash, and the command seems to be more
>> compatible in both shells.  I think this would be the solution in that
>> all 'echo' commands are replaced with 'printf'.  What do you think?
>> On Sat, Jul 11, 2015 at 5:41 PM, Ed Sutter <edsutterjr at gmail.com> wrote:
>>> For my system, with bash the "echo -e" is fine, but with sh, it chokes...
>>> els:ps
>>>    PID TTY          TIME CMD
>>>   3938 pts/24   00:00:00 bash
>>>   3988 pts/24   00:00:00 ps
>>> els:echo "hello\n1\n2\n3\n"
>>> hello\n1\n2\n3\n
>>> els:echo -e "hello\n1\n2\n3\n"
>>> hello
>>> 1
>>> 2
>>> 3
>>> els:exec /bin/sh
>>> els:ps
>>>    PID TTY          TIME CMD
>>>   3938 pts/24   00:00:00 sh
>>>   3991 pts/24   00:00:00 ps
>>> hello
>>> 1
>>> 2
>>> 3
>>> -e hello
>>> 1
>>> 2
>>> 3
>>> els:
>>> Just noticed one other thing:
>>> els:ls -l /bin/sh
>>> lrwxrwxrwx 1 root root 4 Feb 19  2014 /bin/sh -> dash
>>> els:ls -l /bin/bash
>>> -rwxr-xr-x 1 root root 986672 Oct  7  2014 /bin/bash
>>> If you guys think my system is in a strange state; hence, I'm causing this
>>> confusion, I'll just commit it as is.
>>> Ed
>>> Hi Dr. Joel,
>>> On Sat, Jul 11, 2015 at 8:19 AM, Joel Sherrill
>>> <joel.sherrill at oarcorp.com> wrote:
>>> On July 11, 2015 10:06:09 AM CDT, Jarielle Catbagan <jcatbagan93 at gmail.com>
>>> wrote:
>>> Ed,
>>> Is there any indication as to why 'echo' is failing?  'echo' is not a
>>> built-in command for either shell interpreter as I was able to locate
>>> it as a separate program using both shells.  The -e option is to allow
>>> interpretation of backslash characters as I was using it for newlines
>>> and tabs.
>>> Do  sh -x and then try the command by hand at a prompt.
>>> Using sh -x, I issued
>>>          echo -e "test\t123"
>>> and it outputted
>>>          + echo -e 'test\t123'
>>>          test        123
>>> On Sat, Jul 11, 2015 at 7:51 AM, Jarielle Catbagan
>>> On Jul 11, 2015 7:17 AM, "Ed Sutter" <edsutterjr at gmail.com> wrote:
>>> Jarielle,
>>> Did you try running the script with that change?
>>> I applied the patch, then tried running it and it failed.
>>> Apparently 'echo' in sh is different than 'echo' in bash, at least
>>> it is
>>> for my system.
>>> Let me know.
>>> I had to remove the -e from the echo lines for it to work on my
>>> ubuntu14.04 system.
>>> You wanna test that and resubmit the patch or should I do it?
>>> Ed
>>> Hi Ed,
>>> After I changed it to 'sh' I was able to run it.  Ok, I'll look into
>>> it to
>>> see what the issue might be.
>>> umon-devel mailing list
>>> umon-devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/umon-devel
>>> --joel
More information about the umon-devel mailing list
