patches...
Jarielle Catbagan jcatbagan93 at gmail.com
Tue Jul 14 05:42:21 UTC 2015
Awesome!  I will merge the changes to my local branch.
Thanks!
On Mon, Jul 13, 2015 at 7:22 PM, Ed Sutter <edsutterjr at gmail.com> wrote:
> I pushed a few patches tonight...
> 1. Removed a few files from ports/beagleboneblack that were leftovers from
> csb740.
> 2. Added the code that initializes GPIO associated with the four LEDs and
> incorporated
>   the uMon code that blinks a status led.
> #2 was done primarily because I had done this when we were still debugging
> the boot-from-SD
> code, and I figured it should be incorporated in.
> Jarielle, if you decide later that the blinking LED is annoying, then just
> set
> INCLUDE_BLINKLED to zero in config.h.
> Ed
> umon-devel mailing list
> umon-devel at rtems.org
> http://lists.rtems.org/mailman/listinfo/umon-devel
More information about the umon-devel mailing list
