[PATCH 2/8] BBB: Migrate custom exception handler mapping from rom_reset.S to ram_vector_install() in cpuio.c
Jarielle Catbagan
jcatbagan93 at gmail.com
Fri Jul 3 17:54:49 UTC 2015
ports/beagleboneblack/cpuio.c | 25 ++++++++++++++++++++++++-
ports/beagleboneblack/rom_reset.S | 37 -------------------------------------
2 files changed, 24 insertions(+), 38 deletions(-)
diff --git a/ports/beagleboneblack/cpuio.c b/ports/beagleboneblack/cpuio.c
index 3be316b..ffa076d 100644
--- a/ports/beagleboneblack/cpuio.c
+++ b/ports/beagleboneblack/cpuio.c
@@ -109,11 +109,34 @@ target_reset(void)
monrestart(INITIALIZE);
+/* Override the default exception handlers provided by the AM335x
+ * internal ROM code with uMon's custom exception handlers
+void
+ram_vector_install(void)
+ extern unsigned long abort_data;
+ extern unsigned long abort_prefetch;
+ extern unsigned long undefined_instruction;
+ extern unsigned long software_interrupt;
+ extern unsigned long interrupt_request;
+ extern unsigned long fast_interrupt_request;
+ extern unsigned long not_assigned;
+ *(ulong **)0x4030ce24 = &undefined_instruction;
+ *(ulong **)0x4030ce28 = &software_interrupt;
+ *(ulong **)0x4030ce2c = &abort_prefetch;
+ *(ulong **)0x4030ce30 = &abort_data;
+ *(ulong **)0x4030ce34 = ¬_assigned;
+ *(ulong **)0x4030ce38 = &interrupt_request;
+ *(ulong **)0x4030ce3c = &fast_interrupt_request;
/* If any CPU IO wasn't initialized in reset.S, do it here...
* This just provides a "C-level" IO init opportunity.
void
initCPUio(void)
- /* ADD_CODE_HERE */
+ ram_vector_install();
diff --git a/ports/beagleboneblack/rom_reset.S b/ports/beagleboneblack/rom_reset.S
index 83d79df..176f3a7 100644
--- a/ports/beagleboneblack/rom_reset.S
+++ b/ports/beagleboneblack/rom_reset.S
@@ -93,43 +93,6 @@ coldstart_1:
orr r0,r0,#0xd3 // Set mode to supervisor, IRQ FIQ disabled.
msr cpsr,r0
- /* store the address of the custom exception handlers in the exception vector space
- of the AM335x Public RAM */
- ldr r1, =undefined_instruction
- movw r2, #0xce24
- movt r2, #0x4030
- str r1, [r2]
- ldr r1, =software_interrupt
- movw r2, #0xce28
- movt r2, #0x4030
- str r1, [r2]
- ldr r1, =abort_prefetch
- movw r2, #0xce2c
- movt r2, #0x4030
- str r1, [r2]
- ldr r1, =abort_data
- movw r2, #0xce30
- movt r2, #0x4030
- str r1, [r2]
- ldr r1, =not_assigned
- movw r2, #0xce34
- movt r2, #0x4030
- str r1, [r2]
- ldr r1, =interrupt_request
- movw r2, #0xce38
- movt r2, #0x4030
- str r1, [r2]
- ldr r1, =fast_interrupt_request
- movw r2, #0xce3c
- movt r2, #0x4030
- str r1, [r2]
// bl cache_init
2.3.3
More information about the umon-devel
