[PATCH] BBB: sd_setup.sh: Change /bin/bash -> /bin/sh to solely adhere to POSIX shell constructs
Ed Sutter
edsutterjr at gmail.com
Sun Jul 12 00:41:51 UTC 2015
For my system, with bash the "echo -e" is fine, but with sh, it chokes...
els:ps
PID TTY TIME CMD
3938 pts/24 00:00:00 bash
3988 pts/24 00:00:00 ps
els:echo "hello\n1\n2\n3\n"
hello\n1\n2\n3\n
els:echo -e "hello\n1\n2\n3\n"
hello
1
2
3
els:exec /bin/sh
els:ps
PID TTY TIME CMD
3938 pts/24 00:00:00 sh
3991 pts/24 00:00:00 ps
hello
1
2
3
-e hello
1
2
3
els:
Just noticed one other thing:
els:ls -l /bin/sh
lrwxrwxrwx 1 root root 4 Feb 19 2014 /bin/sh -> dash
els:ls -l /bin/bash
-rwxr-xr-x 1 root root 986672 Oct 7 2014 /bin/bash
If you guys think my system is in a strange state; hence, I'm causing this
confusion, I'll just commit it as is.
Ed
> Hi Dr. Joel,
> On Sat, Jul 11, 2015 at 8:19 AM, Joel Sherrill
> <joel.sherrill at oarcorp.com> wrote:
>> On July 11, 2015 10:06:09 AM CDT, Jarielle Catbagan <jcatbagan93 at gmail.com> wrote:
>>> Ed,
>>> Is there any indication as to why 'echo' is failing? 'echo' is not a
>>> built-in command for either shell interpreter as I was able to locate
>>> it as a separate program using both shells. The -e option is to allow
>>> interpretation of backslash characters as I was using it for newlines
>>> and tabs.
>> Do sh -x and then try the command by hand at a prompt.
> Using sh -x, I issued
> echo -e "test\t123"
> and it outputted
> + echo -e 'test\t123'
> test 123
>>> On Sat, Jul 11, 2015 at 7:51 AM, Jarielle Catbagan
>>>> On Jul 11, 2015 7:17 AM, "Ed Sutter" <edsutterjr at gmail.com> wrote:
>>>>> Jarielle,
>>>>> Did you try running the script with that change?
>>>>> I applied the patch, then tried running it and it failed.
>>>>> Apparently 'echo' in sh is different than 'echo' in bash, at least
>>> it is
>>>>> for my system.
>>>>> Let me know.
>>>>> I had to remove the -e from the echo lines for it to work on my
>>>>> ubuntu14.04 system.
>>>>> You wanna test that and resubmit the patch or should I do it?
>>>>> Ed
>>>> Hi Ed,
>>>> After I changed it to 'sh' I was able to run it. Ok, I'll look into
>>> it to
>>>> see what the issue might be.
>>>> _______________________________________________
>>>>> umon-devel mailing list
>>>>> umon-devel at rtems.org
>>>>> http://lists.rtems.org/mailman/listinfo/umon-devel
>> --joel
URL: <http://lists.rtems.org/pipermail/umon-devel/attachments/20150711/0c4d4c93/attachment-0002.html>
More information about the umon-devel
