other stuff...
    Jarielle Catbagan
    jcatbagan93 at gmail.com
    Tue Jul 14 14:50:32 UTC 2015
On Tue, Jul 14, 2015 at 5:24 AM, Ed Sutter <ed.sutter at alcatel-lucent.com> wrote:
> Jarielle,
> After pushing the GPIO/LED stuff last night, I realized that one other
> feature that is handy to have initialized is a hardware based timer.
That would be great to have!
> I'll look into this (since its simple! :-) ), and hook it in. You're making
> great progress, now moving on to eMMC, so just stay that course.
Will do! :-)
> Then, after eMMC and Ethernet comes TFS...
> TFS was written for use on NOR flash (the power-safe defragmentation
> assumes that); however, in general it can also be used in RAM
> (pumped from some other non-volatile source at startup); so its
> reasonable to run TFS with SPI-flash or MMC as well (minus the
> power-safe defragmentation).   Once you have the MMC interface
> working, this should be relatively easy to pull in.
> I think at that point, things are almost wrapped up!  Cool!
> Ed
I think so too!  Getting TFS to work should be interesting.  It's nice
to see everything coming together step-by-step.
Thanks!
> umon-devel mailing list
> umon-devel at rtems.org
> http://lists.rtems.org/mailman/listinfo/umon-devel
More information about the umon-devel
