[PATCH 3/16] Renamed BBB template linker scripts, updated architecture header file, Makefile, config.h
Jarielle Catbagan
jcatbagan93 at gmail.com
Wed Jun 17 08:51:46 UTC 2015
Please excuse me if I might have caused any confusion regarding the
order of the patches. The first two submitted, with the first patch
still waiting for approval to be submitted into this mailing list at
the time of this patch's submission, are [PATCH 1/16] and [PATCH
2/16].
The template linker scripts were renamed to correspond to the PLATFORM
variable in the BBB Makefile. The architecture header file was
renamed to relate to the BBB platform.
Modified the CPU type supplied to the -mcpu compiler switch to cortex-a8.
Updated the ROM length that can be potentially allocated to Umon
during the initial boot. This is done through the modification of
BOOTROMLEN in the Makefile. The value assigned reflects the fact that
there are 109KB that can be used by Umon during the initial boot
procedures.
Modified the DEFAULT_ETHERADD in config.h to match the MAC addresses
associated with the MAC address of the BBB's that I have. This value
should be updated on a user-by-user basis.
ports/beagleboneblack/BEAGLEBONEBLACK_boot.ldt | 63 +++
ports/beagleboneblack/BEAGLEBONEBLACK_ramtst.ldt | 59 +++
ports/beagleboneblack/CSB740_boot.ldt | 63 ---
ports/beagleboneblack/CSB740_ramtst.ldt | 59 ---
ports/beagleboneblack/Makefile | 9 +-
ports/beagleboneblack/beagleboneblack.h | 498 +++++++++++++++++++++++
ports/beagleboneblack/config.h | 8 +-
ports/beagleboneblack/omap3530.h | 497 ----------------------
ports/beagleboneblack/rom_reset.S | 8 +-
9 files changed, 635 insertions(+), 629 deletions(-)
create mode 100644 ports/beagleboneblack/BEAGLEBONEBLACK_boot.ldt
create mode 100644 ports/beagleboneblack/BEAGLEBONEBLACK_ramtst.ldt
delete mode 100644 ports/beagleboneblack/CSB740_boot.ldt
delete mode 100644 ports/beagleboneblack/CSB740_ramtst.ldt
create mode 100644 ports/beagleboneblack/beagleboneblack.h
delete mode 100644 ports/beagleboneblack/omap3530.h
diff --git a/ports/beagleboneblack/BEAGLEBONEBLACK_boot.ldt
b/ports/beagleboneblack/BEAGLEBONEBLACK_boot.ldt
new file mode 100644
index 0000000..4ece406
--- /dev/null
+++ b/ports/beagleboneblack/BEAGLEBONEBLACK_boot.ldt
@@ -0,0 +1,63 @@
+/* BEAGLEBONEBLACK_boot.ld
+ * This is the memory map file used for the boot-flash based version
+ * of MicroMonitor. The only value that should be considered adjustable
+ * here is the base address of the 'dram' memory block.
+MEMORY
+ rom : org = ROMBASE, len = ROMLEN
+ dram : org = DRAMBASE, len = DRAMLEN
+SECTIONS
+ .text :
+ boot_base = .;
+ rom_reset.o(.text)
+ *(.glue_7t)
+ *(.glue_7)
+ } >rom
+ .data :
+ *(.data)
+ } >rom
+ .sdata :
+ *(.sdata)
+ } >rom
+ .sdata2 :
+ *(.sdata2)
+ } >rom
+ .rodata :
+ *(.rodata)
+ *(.rodata.str1.4)
+ } >rom
+ .got :
+ *(.got)
+ } >rom
+ .bss :
+ bss_start = .;
+ atag_space = .;
+ . += ATAGSIZE;
+ end_atag_space = .;
+ *(.bss) *(COMMON)
+ } >dram
+ .sbss :
+ *(.sbss)
+ bss_end = .;
+ } >dram
diff --git a/ports/beagleboneblack/BEAGLEBONEBLACK_ramtst.ldt
b/ports/beagleboneblack/BEAGLEBONEBLACK_ramtst.ldt
index 0000000..76fbce4
--- /dev/null
+++ b/ports/beagleboneblack/BEAGLEBONEBLACK_ramtst.ldt
@@ -0,0 +1,59 @@
+etheraddr = MACADDRBASE;
+alt_tfsdevtbl_base = ALTTFSDEVTBLBASE;
+MEMORY
+ rom : org = RAMTSTROMBASE, len = RAMTSTROMLEN
+SECTIONS
+ .text :
+ boot_base = .;
+ ram_reset.o(.text)
+ *(.glue_7t)
+ *(.glue_7)
+ } >rom
+ .data :
+ *(.data)
+ } >rom
+ .sdata :
+ *(.sdata)
+ } >rom
+ .sdata2 :
+ *(.sdata2)
+ } >rom
+ .rodata :
+ *(.rodata)
+ *(.rodata.str1.4)
+ } >rom
+ .got :
+ *(.got)
+ } >rom
+ .bss :
+ bss_start = .;
+ atag_space = .;
+ . += ATAGSIZE;
+ *(.bss) *(COMMON)
+ } >rom
+ .sbss :
+ *(.sbss)
+ bss_end = .;
+ } >rom
diff --git a/ports/beagleboneblack/CSB740_boot.ldt
b/ports/beagleboneblack/CSB740_boot.ldt
deleted file mode 100644
index c8bc089..0000000
--- a/ports/beagleboneblack/CSB740_boot.ldt
+++ /dev/null
@@ -1,63 +0,0 @@
-/* CSB740_boot.ld:
- * This is the memory map file used for the boot-flash based version
- * of MicroMonitor. The only value that should be considered adjustable
- * here is the base address of the 'dram' memory block.
-MEMORY
- rom : org = ROMBASE, len = ROMLEN
- dram : org = DRAMBASE, len = DRAMLEN
-SECTIONS
- .text :
- boot_base = .;
- rom_reset.o(.text)
- *(.glue_7t)
- *(.glue_7)
- } >rom
- .data :
- *(.data)
- } >rom
- .sdata :
- *(.sdata)
- } >rom
- .sdata2 :
- *(.sdata2)
- } >rom
- .rodata :
- *(.rodata)
- *(.rodata.str1.4)
- } >rom
- .got :
- *(.got)
- } >rom
- .bss :
- bss_start = .;
- atag_space = .;
- . += ATAGSIZE;
- end_atag_space = .;
- *(.bss) *(COMMON)
- } >dram
- .sbss :
- *(.sbss)
- bss_end = .;
- } >dram
diff --git a/ports/beagleboneblack/CSB740_ramtst.ldt
b/ports/beagleboneblack/CSB740_ramtst.ldt
index 76fbce4..0000000
--- a/ports/beagleboneblack/CSB740_ramtst.ldt
+++ /dev/null
@@ -1,59 +0,0 @@
-etheraddr = MACADDRBASE;
-alt_tfsdevtbl_base = ALTTFSDEVTBLBASE;
-MEMORY
- rom : org = RAMTSTROMBASE, len = RAMTSTROMLEN
-SECTIONS
- .text :
- boot_base = .;
- ram_reset.o(.text)
- *(.glue_7t)
- *(.glue_7)
- } >rom
- .data :
- *(.data)
- } >rom
- .sdata :
- *(.sdata)
- } >rom
- .sdata2 :
- *(.sdata2)
- } >rom
- .rodata :
- *(.rodata)
- *(.rodata.str1.4)
- } >rom
- .got :
- *(.got)
- } >rom
- .bss :
- bss_start = .;
- atag_space = .;
- . += ATAGSIZE;
- *(.bss) *(COMMON)
- } >rom
- .sbss :
- *(.sbss)
- bss_end = .;
- } >rom
diff --git a/ports/beagleboneblack/Makefile b/ports/beagleboneblack/Makefile
index 61f2df6..29f53c5 100644
--- a/ports/beagleboneblack/Makefile
+++ b/ports/beagleboneblack/Makefile
@@ -4,18 +4,20 @@
PLATFORM = BEAGLEBONEBLACK
+# From the perspective of this file, UMONTOP is ../../umon_main
TOPDIR = $(UMONTOP)
TGTDIR = beagleboneblack
CPUTYPE = arm
FILETYPE = elf
-# Using tools installed by "sudo apt-get install gcc-arm-none-eabi"...
+# Using tools installed in Arch Linux using "sudo pacman --sync
arm-none-eabi-gcc"
+# ABIDIR contains a directory to be also searched for libraries
ABIDIR = /usr/lib/gcc/arm-none-eabi/4.9.2
LIBABIDIR = -L $(ABIDIR)
TOOL_PREFIX = /usr/bin/arm-none-eabi
COMMON_AFLAGS = -c -D PLATFORM_$(PLATFORM)=1 -D ASSEMBLY_ONLY
-CUSTOM_CFLAGS = -mcpu=arm1136j-s -O2 -isystem $(ABIDIR)/include
-Wno-char-subscripts
+CUSTOM_CFLAGS = -mcpu=cortex-a8 -O2 -isystem $(ABIDIR)/include
@@ -24,7 +26,8 @@ CUSTOM_CFLAGS = -mcpu=arm1136j-s -O2 -isystem
$(ABIDIR)/include -Wno-char-subscr
# The following variables are used to establish the system's memory map.
BOOTROMBASE=0x402F0400
-BOOTROMLEN=0x100000
+# Max size of internal SRAM of AM335x is 109Kb = 0x1B400
+BOOTROMLEN=0x1B400
BOOTRAMBASE=0x80000000
BOOTRAMLEN=0x100000
RAMTSTROMBASE=0x80100000
diff --git a/ports/beagleboneblack/beagleboneblack.h
b/ports/beagleboneblack/beagleboneblack.h
index 0000000..f6ba5b9
--- /dev/null
+++ b/ports/beagleboneblack/beagleboneblack.h
@@ -0,0 +1,498 @@
+// beagleboneblack.h
+// Author(s): Luis Torrico, Cogent Computer Systems, Inc.
+// Contributors: Jarielle Catbagan
+// Date: 05/02/2008
+// Description: This file was modified from omap3530.h. This file containes
+// register base addresses and offsets as well as access macros
+// for the AM335x/Beaglebone Black on-chip peripherals.
+// Peripherals not used by UMON have not been tested (and
+// may not be defined). Use these defines with caution!!
+#include "bits.h"
+ * 3530 specific Section
+/* Stuff on L3 Interconnect */
+#define SMX_APE_BASE 0x68000000
+/* L3 Firewall */
+#define A_REQINFOPERM0 (SMX_APE_BASE + 0x05048)
+#define A_READPERM0 (SMX_APE_BASE + 0x05050)
+#define A_WRITEPERM0 (SMX_APE_BASE + 0x05058)
+/* GPMC */
+#define OMAP35XX_GPMC_BASE 0x6E000000
+/* SMS */
+#define OMAP35XX_SMS_BASE 0x6C000000
+/* SDRC */
+#define OMAP35XX_SDRC_BASE 0x6D000000
+ * L4 Peripherals - L4 Wakeup and L4 Core now
+#define OMAP35XX_CORE_L4_IO_BASE 0x48000000
+#define OMAP35XX_WAKEUP_L4_IO_BASE 0x48300000
+#define OMAP35XX_L4_PER 0x49000000
+#define OMAP35XX_L4_IO_BASE OMAP35XX_CORE_L4_IO_BASE
+/* TAP information dont know for 3430*/
+#define OMAP35XX_TAP_BASE (0x49000000) /*giving some junk for virtio */
+/* base address for indirect vectors (internal boot mode) */
+#define SRAM_OFFSET0 0x40000000
+#define SRAM_OFFSET1 0x00200000
+#define SRAM_OFFSET2 0x0000F800
+#define SRAM_VECT_CODE (SRAM_OFFSET0|SRAM_OFFSET1|SRAM_OFFSET2)
+#define LOW_LEVEL_SRAM_STACK 0x4020FFFC
+/* UART */
+#define OMAP35XX_UART1 (OMAP35XX_L4_IO_BASE+0x6A000)
+#define OMAP35XX_UART2 (OMAP35XX_L4_IO_BASE+0x6C000)
+#define OMAP35XX_UART3 (OMAP35XX_L4_PER+0x20000)
+#define UART1_REG(_x_) *(vulong *)(OMAP35XX_UART1 + _x_)
+#define UART2_REG(_x_) *(vulong *)(OMAP35XX_UART2 + _x_)
+#define UART3_REG(_x_) *(vulong *)(OMAP35XX_UART3 + _x_)
+/* UART Register offsets */
+#define UART_RHR 0x00 // Receive Holding Register (read only)
+#define UART_THR 0x00 // Transmit Holding Register (write only)
+#define UART_DLL 0x00 // Baud divisor lower byte (read/write)
+#define UART_DLH 0x04 // Baud divisor higher byte (read/write)
+#define UART_IER 0x04 // Interrupt Enable Register (read/write)
+#define UART_IIR 0x08 // Interrupt Identification Register (read only)
+#define UART_FCR 0x08 // FIFO Control Register (write only)
+#define UART_EFR 0x08 // Enhanced Feature Register
+#define UART_LCR 0x0C // Line Control Register (read/write)
+#define UART_MCR 0x10 // Modem Control Register (read/write)
+#define UART_LSR 0x14 // Line Status Register (read only)
+#define UART_MSR 0x18 // Modem Status Register (read only)
+#define UART_TCR 0x18 //
+#define UART_TLR 0x1C //
+#define UART_SPR 0x1C // Scratch Pad Register (read/write)
+#define UART_MDR1 0x20 // Mode Definition Register 1
+#define UART_MDR2 0x24 // Mode Definition Register 2
+//#define UART_SFLSR 0x28 // Status FIFO Line Status Register (IrDA modes only)
+//#define UART_TXFLL 0x28 // Transmit Frame Length Register Low (IrDA
modes only)
+//#define UART_RESUME 0x2C // Resume Register (IR-IrDA and IR-CIR modes only)
+//#define UART_TXFLH 0x2C // Transmit Frame Length Register High
(IrDA modes only)
+//#define UART_RXFLL 0x30 // Receive Frame Length Register Low (IrDA
modes only)
+//#define UART_SFREGL 0x30 // Status FIFO Register Low (IrDA modes only)
+//#define UART_RXFLH 0x34 // Receive Frame Length Register High (IrDA
modes only)
+//#define UART_SFREGH 0x34 // Status FIFO Register High (IrDA modes only)
+//#define UART_BLR 0x38 // BOF Control Register (IrDA modes only)
+//#define UART_UASR 0x38 // UART Autobauding Status Register (UART
autobauding mode only)
+//#define UART_ACREG 0x3C // Auxiliary Control Register (IrDA-CIR modes only)
+#define UART_SCR 0x40 // Supplementary Control Register
+#define UART_SSR 0x44 // Supplementary Status Register
+//#define UART_EBLR 0x48 // BOF Length Register (IR-IrDA and IR-CIR modes only)
+#define UART_SYSC 0x54 // System Configuration Register
+#define UART_SYSS 0x58 // System Status Register
+#define UART_WER 0x5C // Wake-up Enable Register
+#define UART_CFPS 0x60 // Carrier Frequency Prescaler Register
+/* SPI - Serial Peripheral Interface */
+#define SPI1_BASE_ADD (OMAP35XX_L4_IO_BASE+0x98000) // routed to I/O
sites on CSB703
+#define SPI2_BASE_ADD (OMAP35XX_L4_IO_BASE+0x9A000)
+#define SPI3_BASE_ADD (OMAP35XX_L4_IO_BASE+0xB8000) // routed to
AD7843 touch controller on CSB703
+#define SPI4_BASE_ADD (OMAP35XX_L4_IO_BASE+0xBA000)
+#define SPI1_REG(_x_) *(vulong *)(SPI1_BASE_ADD + _x_)
+#define SPI2_REG(_x_) *(vulong *)(SPI2_BASE_ADD + _x_)
+#define SPI3_REG(_x_) *(vulong *)(SPI3_BASE_ADD + _x_)
+#define SPI4_REG(_x_) *(vulong *)(SPI4_BASE_ADD + _x_)
+// SPI Register Defines
+#define SPI_SYSCONFIG 0x10 // System Configuration Register
+#define SPI_SYSSTATUS 0x14 // System Status Register
+#define SPI_IRQSTATUS 0x18 // Interrupt Status Register
+#define SPI_IRQENABLE 0x1C // Interrupt Enable/Disable Register
+#define SPI_WAKEUPENABLE 0x20 // WakeUp Enable/Disable Register
+#define SPI_SYST 0x24 // System Test Register
+#define SPI_MODULCTRL 0x28 // Serial Port Interface Configuration Register
+#define SPI_CH0_CONF 0x2C // Channel 0 Configuration Register
+#define SPI_CH1_CONF 0x40 // Channel 1 Configuration Register
+#define SPI_CH2_CONF 0x54 // Channel 2 Configuration Register
+#define SPI_CH3_CONF 0x68 // Channel 3 Configuration Register
+#define SPI_CH0_STAT 0x30 // Channel 0 Status Register
+#define SPI_CH1_STAT 0x44 // Channel 1 Status Register
+#define SPI_CH2_STAT 0x58 // Channel 2 Status Register
+#define SPI_CH3_STAT 0x6C // Channel 3 Status Register
+#define SPI_CH0_CTRL 0x34 // Channel 0 Control Register
+#define SPI_CH1_CTRL 0x48 // Channel 1 ControlRegister
+#define SPI_CH2_CTRL 0x5C // Channel 2 ControlRegister
+#define SPI_CH3_CTRL 0x70 // Channel 3 ControlRegister
+#define SPI_TXD0 0x38 // Channel 0 Transmit Data Register
+#define SPI_TXD1 0x4C // Channel 1 Transmit Data Register
+#define SPI_TXD2 0x60 // Channel 2 Transmit Data Register
+#define SPI_TXD3 0x74 // Channel 3 Transmit Data Register
+#define SPI_RXD0 0x3C // Channel 0 Receive Data Register
+#define SPI_RXD1 0x50 // Channel 1 Receive Data Register
+#define SPI_RXD2 0x64 // Channel 2 Receive Data Register
+#define SPI_RXD3 0x78 // Channel 3 Receive Data Register
+#define SPI_XFERLEVEL 0x7C // FIFO Transfer Levels Register
+// SPI Channel x Configuration Bit Defines
+#define SPI_CH_CONF_CLKG BIT29 // 1 = One clock cycle granularity
+#define SPI_CH_CONF_FFER BIT28 // 1 = FIFO buffer is used to Receive data
+#define SPI_CH_CONF_FFEW BIT27 // 1 = FIFO buffer is used to Transmit data
+#define SPI_CH_CONF_TCS_0_5 (0x00 << 25) // 0.5 clock cycles between
CS toggling and first (or last) edge of SPI clock
+#define SPI_CH_CONF_TCS_1_5 (0x01 << 25) // 1.5 clock cycles between
+#define SPI_CH_CONF_TCS_2_5 (0x02 << 25) // 2.5 clock cycles between
+#define SPI_CH_CONF_TCS_3_5 (0x03 << 25) // 3.5 clock cycles between
+#define SPI_CH_CONF_SB_POL BIT24 // 1 = Start bit polarity is held to
1 during SPI transfer
+#define SPI_CH_CONF_SBE BIT23 // 1 = Start bit added before SPI
transfer, 0 = default length specified by WL
+#define SPI_CH_CONF_SPIENSLV_0 (0x00 << 21) // Slave select detection
enabled on CS0
+#define SPI_CH_CONF_SPIENSLV_1 (0x01 << 21) // Slave select detection
enabled on CS1
+#define SPI_CH_CONF_SPIENSLV_2 (0x02 << 21) // Slave select detection
enabled on CS2
+#define SPI_CH_CONF_SPIENSLV_3 (0x03 << 21) // Slave select detection
enabled on CS3
+#define SPI_CH_CONF_FORCE BIT20 // 1 = CSx high when EPOL is 0 and
low when EPOL is 1
+#define SPI_CH_CONF_TURBO BIT19 // 1 = Turbo is activated
+#define SPI_CH_CONF_IS BIT18 // 1 = spim_simo selected for reception,
0 = spim_somi selected for reception
+#define SPI_CH_CONF_DPE1 BIT17 // 1 = no transmission on spim_simo, 0
= spim_simo selected for transmission
+#define SPI_CH_CONF_DPE0 BIT16 // 1 = no transmission on spim_somi, 0
= spim_somi selected for transmission
+#define SPI_CH_CONF_DMAR BIT15 // 1 = DMA read request enabled
+#define SPI_CH_CONF_DMAW BIT14 // 1 = DMA write request enabled
+#define SPI_CH_CONF_TRM_TR (0x00 << 12) // Transmit and receive mode
+#define SPI_CH_CONF_TRM_RO (0x01 << 12) // Receive-only mode
+#define SPI_CH_CONF_TRM_TO (0x02 << 12) // Transmit-only mode
+#define SPI_CH_CONF_WL(_x_) ((_x_ & 0x1f) << 7) // SPI word length, 0x7 = 8-bit
+#define SPI_CH_CONF_EPOL BIT6 // 1 = SPIM_CSx is low during active
state, 0 = high during active state
+#define SPI_CH_CONF_CLKD(_x_) ((_x_ & 0xf) << 2) // Frequency divider
for spim_clk
+#define SPI_CH_CONF_POL BIT1 // 1 = spim_clk is low during active
+#define SPI_CH_CONF_PHA BIT0 // 1 = data latched on even-numbered
edges, 0 = data latched on odd-numbered edges
+// SPI Interrupt Status Register Bit Defines
+#define SPI_RX3_FULL BIT14 //
+#define SPI_TX3_EMPTY BIT12 //
+#define SPI_RX2_FULL BIT10 //
+#define SPI_TX2_EMPTY BIT8 //
+#define SPI_RX1_FULL BIT14 //
+#define SPI_TX1_EMPTY BIT6 //
+#define SPI_RX0_FULL BIT2 //
+#define SPI_TX0_EMPTY BIT0 //
+// SPI Channel Status Register Bit Defines
+#define SPI_RXF_FULL BIT6 //
+#define SPI_RXF_EMPTY BIT5 //
+#define SPI_TXF_FULL BIT4 //
+#define SPI_TXF_EMPTY BIT3 //
+#define SPI_CH_EOT BIT2 //
+#define SPI_CH_TX0_EMPTY BIT1 //
+#define SPI_CH_RX0_FULL BIT0 //
+/* General Purpose Timers */
+#define OMAP35XX_GPT1 0x48318000
+#define OMAP35XX_GPT2 0x49032000
+#define OMAP35XX_GPT3 0x49034000
+#define OMAP35XX_GPT4 0x49036000
+#define OMAP35XX_GPT5 0x49038000
+#define OMAP35XX_GPT6 0x4903A000
+#define OMAP35XX_GPT7 0x4903C000
+#define OMAP35XX_GPT8 0x4903E000
+#define OMAP35XX_GPT9 0x49040000
+#define OMAP35XX_GPT10 0x48086000
+#define OMAP35XX_GPT11 0x48088000
+#define OMAP35XX_GPT12 0x48304000
+/* General Purpose I/O */
+#define GPIO1_BASE_ADD 0x48310000
+#define GPIO2_BASE_ADD 0x49050000
+#define GPIO3_BASE_ADD 0x49052000
+#define GPIO4_BASE_ADD 0x49054000
+#define GPIO5_BASE_ADD 0x49056000
+#define GPIO6_BASE_ADD 0x49058000
+#define GPIO1_REG(_x_) *(vulong *)(GPIO1_BASE_ADD + _x_)
+#define GPIO2_REG(_x_) *(vulong *)(GPIO2_BASE_ADD + _x_)
+#define GPIO3_REG(_x_) *(vulong *)(GPIO3_BASE_ADD + _x_)
+#define GPIO4_REG(_x_) *(vulong *)(GPIO4_BASE_ADD + _x_)
+#define GPIO5_REG(_x_) *(vulong *)(GPIO5_BASE_ADD + _x_)
+#define GPIO6_REG(_x_) *(vulong *)(GPIO6_BASE_ADD + _x_)
+/* GPIO Register offsets */
+#define GPIO_SYSCONFIG 0x10 //
+#define GPIO_SYSSTATUS 0x14 //
+#define GPIO_CTRL 0x30 //
+#define GPIO_OE 0x34 //
+#define GPIO_DATAIN 0x38 //
+#define GPIO_DATAOUT 0x3C //
+#define GPIO_CLEARDATAOUT 0x90 //
+#define GPIO_SETDATAOUT 0x94 //
+/* WatchDog Timers (1 secure, 3 GP) */
+#define WD1_BASE_ADD 0x4830C000
+#define WD2_BASE_ADD 0x48314000
+#define WD3_BASE_ADD 0x49030000
+#define WD1_REG(_x_) *(vulong *)(WD1_BASE_ADD + _x_)
+#define WD2_REG(_x_) *(vulong *)(WD2_BASE_ADD + _x_)
+#define WD3_REG(_x_) *(vulong *)(WD3_BASE_ADD + _x_)
+/* WatchDog Timer Register offsets */
+#define WD_CONFIG 0x10 // System Configuration Register
+#define WD_STATUS 0x14 // System Configuration Register
+#define WD_WISR 0x18 // System Configuration Register
+#define WD_WIER 0x1C // System Configuration Register
+#define WD_WCLR 0x24 // System Configuration Register
+#define WD_WCRR 0x28 // System Configuration Register
+#define WD_WLDR 0x2C // System Configuration Register
+#define WD_WTGR 0x30 // System Configuration Register
+#define WD_WWPS 0x34 // System Configuration Register
+#define WD_WSPR 0x48 // System Configuration Register
+/* 32KTIMER */
+#define SYNC_32KTIMER_BASE (0x48320000)
+#define S32K_CR (SYNC_32KTIMER_BASE+0x10)
+/* System Control Module */
+/* Module Name Base Address Size */
+ INTERFACE 0x48002000 36 bytes
+ PADCONFS 0x48002030 564 bytes
+ GENERAL 0x48002270 767 bytes
+ MEM_WKUP 0x48002600 1K byte
+ PADCONFS_WKU 0x48002A00 80 bytes
+ GENERAL_WKUP 0x48002A60 31 bytes
+#define OMAP35XX_CTRL_BASE (OMAP35XX_L4_IO_BASE+0x2000)
+#define SCM_REG(_x_) *(vulong *)(OMAP35XX_CTRL_BASE + _x_)
+/* Pad Configuration Registers */
+/* Note: Cogent is only defining the PADCONFS registers that are used
in Micromonitor */
+#define PADCONFS_GPMC_NCS3 0xB4 // NCS3[15:0], NCS4[31:16]
+#define PADCONFS_GPMC_NCS5 0xB8 // NCS5[15:0], EXP_INTX[31:16]
+#define PADCONFS_GPMC_NCS7 0xBC // LCD_BKL_X[15:0], LCLK[31:16]
+#define PADCONFS_GPMC_NADV_ALE 0xC0 // NADV_ALE[15:0], NOE[31:16]
+#define PADCONFS_GPMC_NWE 0xC4 // NWE[15:0], NBE0_CLE[31:16]
+#define PADCONFS_DSS_PCLK 0xD4 // LCD_PCLK_X[15:0], LCD_HS_X[31:16]
+#define PADCONFS_DSS_VSYNC 0xD8 // LCD_VS_X[15:0], LCD_OE_X[31:16]
+#define PADCONFS_DSS_DATA0 0xDC // LCD_B0_X[15:0], LCD_B1_X[31:16]
+#define PADCONFS_DSS_DATA2 0xE0 // LCD_B2_X[15:0], LCD_B3_X[31:16]
+#define PADCONFS_DSS_DATA4 0xE4 // LCD_B4_X[15:0], LCD_B5_X[31:16]
+#define PADCONFS_DSS_DATA6 0xE8 // LCD_G0_X[15:0], LCD_G1_X[31:16]
+#define PADCONFS_DSS_DATA8 0xEC // LCD_G2_X[15:0], LCD_G3_X[31:16]
+#define PADCONFS_DSS_DATA10 0xF0 // LCD_G4_X[15:0], LCD_G5_X[31:16]
+#define PADCONFS_DSS_DATA12 0xF4 // LCD_R0_X[15:0], LCD_R1_X[31:16]
+#define PADCONFS_DSS_DATA14 0xF8 // LCD_R2_X[15:0], LCD_R3_X[31:16]
+#define PADCONFS_DSS_DATA16 0xFC // LCD_R4_X[15:0], LCD_R5_X[31:16]
+#define PADCONFS_DSS_DATA18 0x100 // SPI1_CLK_X[15:0], SPI1_MOSI_X[31:16]
+#define PADCONFS_DSS_DATA20 0x104 // SPI1_MISO_X[15:0], *SPI1_CS0_X[31:16]
+#define PADCONFS_DSS_DATA22 0x108 // GPIO7_X[15:0], NC[31:16]
+#define PADCONFS_MMC1_DAT4 0x150 // *I2C_INT_X[15:0], *PIRQ_X[31:16]
+#define PADCONFS_MMC1_DAT6 0x154 // GPIO0_X[15:0], GPIO1_X[31:16]
+#define PADCONFS_MCBSP3_CLKX 0x170 // D_TXD[15:0], D_RXD[31:16]
+#define PADCONFS_SYS_NIRQ 0x1E0 // FIQ[15:0], SYS_CLK2[31:16]
+#define PADCONFS_SYS_OFF_MODE 0xA18 // OFF_MODE_X[15:0], USB_CLK[31:16]
+#define PADCONFS_GPMC_WAIT2 0xD0 // NA[15:0], E_INTX[31:16]
+#define PADCONFS_MMC1_CLK 0x144 // MMC1_CLK[15:0], MMC1_CMD[31:16]
+#define PADCONFS_MMC1_DAT0 0x148 // MMC1_DAT0[15:0], MMC1_DAT1[31:16]
+#define PADCONFS_MMC1_DAT2 0x14C // MMC1_DAT2[15:0], MMC1_DAT3[31:16]
+#define CM_REV_REG 0x48004800
+#define PRM_REV_REG 0x48306804
+#define CM_REV_MAJ() ((*(volatile unsigned long *)CM_REV_REG & 0xf0)>>4)
+#define CM_REV_MIN() (*(volatile unsigned long *)CM_REV_REG & 0x0f)
+#define PRM_REV_MAJ() ((*(volatile unsigned long *)PRM_REV_REG & 0xf0)>>4)
+#define PRM_REV_MIN() (*(volatile unsigned long *)PRM_REV_REG & 0x0f)
+/* MMC registers...
+#define CM_FCLKEN1_CORE 0x48004a00
+#define CM_ICLKEN1_CORE 0x48004a10
+#define CM_IDLEST1_CORE 0x48004a20
+#define CM_AUTOIDLE1_CORE 0x48004a30
+#define PM_WKEN1_CORE 0x48306aa0
+#define PM_MPUGRPSEL1_CORE 0x48306aa4
+#define PM_IVA2GRPSEL1_CORE 0x48306aa8
+#define PM_WKST1_CORE 0x48306ab0
+#define CONTROL_DEVCONF0 0x48002274
+#define MMC1_BASE_ADD 0x4809c000
+#define MMC2_BASE_ADD 0x480ad000
+#define MMC3_BASE_ADD 0x480b4000
+#define MMC1_REG(_x_) *(vulong *)(MMC1_BASE_ADD + _x_)
+#define MMC2_REG(_x_) *(vulong *)(MMC2_BASE_ADD + _x_)
+#define MMC3_REG(_x_) *(vulong *)(MMC3_BASE_ADD + _x_)
+#define MMCHS_SYSCONFIG 0x10
+#define MMCHS_SYSSTATUS 0x14
+#define MMCHS_CSRE 0x24
+#define MMCHS_SYSTEST 0x28
+#define MMCHS_CON 0x2C
+#define MMCHS_PWCNT 0x30
+#define MMCHS_BLK 0x104
+#define MMCHS_ARG 0x108
+#define MMCHS_CMD 0x10C
+#define MMCHS_RSP10 0x110
+#define MMCHS_RSP32 0x114
+#define MMCHS_RSP54 0x118
+#define MMCHS_RSP76 0x11C
+#define MMCHS_DATA 0x120
+#define MMCHS_PSTATE 0x124
+#define MMCHS_HCTL 0x128
+#define MMCHS_SYSCTL 0x12C
+#define MMCHS_STAT 0x130
+#define MMCHS_IE 0x134
+#define MMCHS_ISE 0x138
+#define MMCHS_AC12 0x13C
+#define MMCHS_CAPA 0x140
+#define MMCHS_CUR_CAPA 0x148
+#define MMCHS_REV 0x1FC
+/* Miscellaneous MMC register bits...
+ * (only specified the ones I use)
+#define EN_MMC1 (1 << 24)
+#define ST_MMC1 (1 << 24)
+#define AUTO_MMC1 (1 << 24)
+#define GRPSEL_MMC1 (1 << 24)
+#define VS18 0x04000000
+#define VS30 0x02000000
+#define VS33 0x01000000
+#define MMCINIT 0x00000002
+#define ODE 0x00000001
+#define SVDS 0x00000e00
+#define SVDS18 (5 << 9)
+#define SVDS30 (6 << 9)
+#define SVDS33 (7 << 9)
+#define SDBP 0x00000100
+#define ICE 0x00000001
+#define ICS 0x00000002
+#define CEN 0x00000004
+#define CLKD(v) ((v & 0x3ff) << 6)
+#define CLKDMSK (0x3ff << 6)
+#define CLKACTIVITYMSK (3 << 8)
+#define CLKACTIVITY(n) ((n & 3) << 8)
+#define SIDLEMODEMSK (3 << 3)
+#define SIDLEMODE(n) ((n & 3) << 3)
+#define ENWAKEUP (1 << 2)
+#define IWE (1 << 24)
+#define AUTOIDLE 1
+#define CLKEXTFREE (1 << 16)
+#define SRESET 0x00000002
+#define CC 0x00000001
+#define RESETDONE 0x00000001
+#define IE_ALL 0x317f8337
+#define CDP (1 << 7)
+#define CMD(v) ((v & 0x3f) << 24)
+#define CMDMSK (0x3f << 24)
+#define CMDI 0x00000001
+#define DEBOUNCE (3 << 16)
+#define CCRC (1 << 17)
+#define DCRC (1 << 21)
+#define CERR (1 << 28)
+#define CTO (1 << 16)
+#define DP (1 << 21)
+#define RSPTYPE_NONE 0x00000000
+#define RSPTYPE_136 0x00010000
+#define RSPTYPE_48 0x00020000
+#define RSPTYPE_48BSY 0x00030000
+#define RSPTYPE 0x00030000
+#define SRD (1 << 26)
+#define SRC (1 << 25)
+#define SRA (1 << 24)
+#define DTOMSK (0xf<<16)
+#define DTO(a) ((a&0xf) << 16)
+#define NBLK(a) ((a&0xffff) << 16)
+#define BLEN(a) (a&0x7ff)
+#define MMCSDIO1ADPCLKISEL (1 << 24)
+/* PBIAS...
+#define CONTROL_PBIAS_LITE 0x48002520
+#define PBIAS_LITE_VMMC1_3V (0x0101)
+#define MMC_PWR_STABLE (0x0202)
+#define PBIAS_LITE_VMMC1_52MHZ (0x0404)
+#define PBIAS_LITE_MMC1_ERROR (0x0808)
+#define PBIAS_LITE_MMC1_HIGH (0x8080)
+/* Control status...
+#define CONTROL_STATUS 0x480022f0
+#define SYSBOOT 0x3f
+#define DEVICETYPE (0x3 << 8)
+/* 16 bit access CONTROL */
+#define MUX_VAL(OFFSET,VALUE)\
+ *(unsigned short *) (OMAP35XX_CTRL_BASE + (OFFSET)) = VALUE;
+#define CP(x) (CONTROL_PADCONF_##x)
+#define CONTROL_PADCONF_DSS_DATA18 0x0100
+#define CONTROL_PADCONF_DSS_DATA19 0x0102
+#define CONTROL_PADCONF_DSS_DATA20 0x0104
+#define CONTROL_PADCONF_DSS_DATA21 0x0106
+#define CONTROL_PADCONF_MMC1_CLK 0x0144
+#define CONTROL_PADCONF_MMC1_CMD 0x0146
+#define CONTROL_PADCONF_MMC1_DAT0 0x0148
+#define CONTROL_PADCONF_MMC1_DAT1 0x014A
+#define CONTROL_PADCONF_MMC1_DAT2 0x014C
+#define CONTROL_PADCONF_MMC1_DAT3 0x014E
+#define CONTROL_PADCONF_HSUSB0_CLK 0x01A2
+#define CONTROL_PADCONF_HSUSB0_STP 0x01A4
+#define CONTROL_PADCONF_HSUSB0_DIR 0x01A6
+#define CONTROL_PADCONF_HSUSB0_NXT 0x01A8
+#define CONTROL_PADCONF_HSUSB0_DATA0 0x01AA
+#define CONTROL_PADCONF_HSUSB0_DATA1 0x01AC
+#define CONTROL_PADCONF_HSUSB0_DATA2 0x01AE
+#define CONTROL_PADCONF_HSUSB0_DATA3 0x01B0
+#define CONTROL_PADCONF_HSUSB0_DATA4 0x01B2
+#define CONTROL_PADCONF_HSUSB0_DATA5 0x01B4
+#define CONTROL_PADCONF_HSUSB0_DATA6 0x01B6
+#define CONTROL_PADCONF_HSUSB0_DATA7 0x01B8
+#define CONTROL_PADCONF_I2C1_SCL 0x01BA
+#define CONTROL_PADCONF_I2C1_SDA 0x01BC
+#define CONTROL_PADCONF_McBSP3_DX 0x016C
+/* bits used in control reg's above
+ * IEN - Input Enable
+ * IDIS - Input Disable
+ * PTD - Pull type Down
+ * PTU - Pull type Up
+ * DIS - Pull type selection is inactive
+ * EN - Pull type selection is active
+ * M0 - Mode 0
+#define IEN (1 << 8)
+#define IDIS (0 << 8)
+#define PTU (1 << 4)
+#define PTD (0 << 4)
+#define EN (1 << 3)
+#define DIS (0 << 3)
+#define M0 0 /* modes */
+#define M1 1
+#define M2 2
+#define M3 3
+#define M4 4
+#define M5 5
+#define M6 6
+#define M7 7
diff --git a/ports/beagleboneblack/config.h b/ports/beagleboneblack/config.h
index be92801..9cb7a9b 100644
--- a/ports/beagleboneblack/config.h
+++ b/ports/beagleboneblack/config.h
@@ -1,8 +1,8 @@
* Monitor configuration file for the Beaglebone Black
- * Adapted by Luis Torrico, Cogent Computer Systems, Inc.
- * email: luis at cogcomp.com
+ * Adapted by Jarielle Catbagan
+ * email: jcatbagan93 at gmail.com | jrcatbagan at ca.rr.com
* General notice:
@@ -32,7 +32,9 @@
* regarding the use of these definitions.
* DEFAULT_IPADD could be set to "DHCP" or "BOOTP" as well.
-#define DEFAULT_ETHERADD "00:30:23:40:00:" // Cogent Block
+#define DEFAULT_ETHERADD "D0:39:72:4B:89:21"
+//#define DEFAULT_ETHERADD "1C:BA:BC:E2:2E:39"
+//#define DEFAULT_ETHERADD "1C:BA:BC:E2:3C:B8"
#define DEFAULT_IPADD "192.168.1.137"
#define CPU_LE
diff --git a/ports/beagleboneblack/omap3530.h b/ports/beagleboneblack/omap3530.h
index 7b16ffc..0000000
--- a/ports/beagleboneblack/omap3530.h
+++ /dev/null
@@ -1,497 +0,0 @@
-// omap3530.h
-// Author(s): Luis Torrico, Cogent Computer Systems, Inc.
-// Contributors:
-// Date: 05/02/2008
-// Description: This file contains register base addresses and offsets
-// and access macros for the OMAP3530 on-chip peripherals
-// Peripherals not used by UMON have not been tested (and
-// may not be defined). Use these defines with caution!!
-#include "bits.h"
- * 3530 specific Section
-/* Stuff on L3 Interconnect */
-#define SMX_APE_BASE 0x68000000
-/* L3 Firewall */
-#define A_REQINFOPERM0 (SMX_APE_BASE + 0x05048)
-#define A_READPERM0 (SMX_APE_BASE + 0x05050)
-#define A_WRITEPERM0 (SMX_APE_BASE + 0x05058)
-/* GPMC */
-#define OMAP35XX_GPMC_BASE 0x6E000000
-/* SMS */
-#define OMAP35XX_SMS_BASE 0x6C000000
-/* SDRC */
-#define OMAP35XX_SDRC_BASE 0x6D000000
- * L4 Peripherals - L4 Wakeup and L4 Core now
-#define OMAP35XX_CORE_L4_IO_BASE 0x48000000
-#define OMAP35XX_WAKEUP_L4_IO_BASE 0x48300000
-#define OMAP35XX_L4_PER 0x49000000
-#define OMAP35XX_L4_IO_BASE OMAP35XX_CORE_L4_IO_BASE
-/* TAP information dont know for 3430*/
-#define OMAP35XX_TAP_BASE (0x49000000) /*giving some junk for virtio */
-/* base address for indirect vectors (internal boot mode) */
-#define SRAM_OFFSET0 0x40000000
-#define SRAM_OFFSET1 0x00200000
-#define SRAM_OFFSET2 0x0000F800
-#define SRAM_VECT_CODE (SRAM_OFFSET0|SRAM_OFFSET1|SRAM_OFFSET2)
-#define LOW_LEVEL_SRAM_STACK 0x4020FFFC
-/* UART */
-#define OMAP35XX_UART1 (OMAP35XX_L4_IO_BASE+0x6A000)
-#define OMAP35XX_UART2 (OMAP35XX_L4_IO_BASE+0x6C000)
-#define OMAP35XX_UART3 (OMAP35XX_L4_PER+0x20000)
-#define UART1_REG(_x_) *(vulong *)(OMAP35XX_UART1 + _x_)
-#define UART2_REG(_x_) *(vulong *)(OMAP35XX_UART2 + _x_)
-#define UART3_REG(_x_) *(vulong *)(OMAP35XX_UART3 + _x_)
-/* UART Register offsets */
-#define UART_RHR 0x00 // Receive Holding Register (read only)
-#define UART_THR 0x00 // Transmit Holding Register (write only)
-#define UART_DLL 0x00 // Baud divisor lower byte (read/write)
-#define UART_DLH 0x04 // Baud divisor higher byte (read/write)
-#define UART_IER 0x04 // Interrupt Enable Register (read/write)
-#define UART_IIR 0x08 // Interrupt Identification Register (read only)
-#define UART_FCR 0x08 // FIFO Control Register (write only)
-#define UART_EFR 0x08 // Enhanced Feature Register
-#define UART_LCR 0x0C // Line Control Register (read/write)
-#define UART_MCR 0x10 // Modem Control Register (read/write)
-#define UART_LSR 0x14 // Line Status Register (read only)
-#define UART_MSR 0x18 // Modem Status Register (read only)
-#define UART_TCR 0x18 //
-#define UART_TLR 0x1C //
-#define UART_SPR 0x1C // Scratch Pad Register (read/write)
-#define UART_MDR1 0x20 // Mode Definition Register 1
-#define UART_MDR2 0x24 // Mode Definition Register 2
-//#define UART_SFLSR 0x28 // Status FIFO Line Status Register (IrDA modes only)
-//#define UART_TXFLL 0x28 // Transmit Frame Length Register Low (IrDA
modes only)
-//#define UART_RESUME 0x2C // Resume Register (IR-IrDA and IR-CIR modes only)
-//#define UART_TXFLH 0x2C // Transmit Frame Length Register High
(IrDA modes only)
-//#define UART_RXFLL 0x30 // Receive Frame Length Register Low (IrDA
modes only)
-//#define UART_SFREGL 0x30 // Status FIFO Register Low (IrDA modes only)
-//#define UART_RXFLH 0x34 // Receive Frame Length Register High (IrDA
modes only)
-//#define UART_SFREGH 0x34 // Status FIFO Register High (IrDA modes only)
-//#define UART_BLR 0x38 // BOF Control Register (IrDA modes only)
-//#define UART_UASR 0x38 // UART Autobauding Status Register (UART
-//#define UART_ACREG 0x3C // Auxiliary Control Register (IrDA-CIR modes only)
-#define UART_SCR 0x40 // Supplementary Control Register
-#define UART_SSR 0x44 // Supplementary Status Register
-//#define UART_EBLR 0x48 // BOF Length Register (IR-IrDA and IR-CIR modes only)
-#define UART_SYSC 0x54 // System Configuration Register
-#define UART_SYSS 0x58 // System Status Register
-#define UART_WER 0x5C // Wake-up Enable Register
-#define UART_CFPS 0x60 // Carrier Frequency Prescaler Register
-/* SPI - Serial Peripheral Interface */
-#define SPI1_BASE_ADD (OMAP35XX_L4_IO_BASE+0x98000) // routed to I/O
sites on CSB703
-#define SPI2_BASE_ADD (OMAP35XX_L4_IO_BASE+0x9A000)
-#define SPI3_BASE_ADD (OMAP35XX_L4_IO_BASE+0xB8000) // routed to
-#define SPI4_BASE_ADD (OMAP35XX_L4_IO_BASE+0xBA000)
-#define SPI1_REG(_x_) *(vulong *)(SPI1_BASE_ADD + _x_)
-#define SPI2_REG(_x_) *(vulong *)(SPI2_BASE_ADD + _x_)
-#define SPI3_REG(_x_) *(vulong *)(SPI3_BASE_ADD + _x_)
-#define SPI4_REG(_x_) *(vulong *)(SPI4_BASE_ADD + _x_)
-// SPI Register Defines
-#define SPI_SYSCONFIG 0x10 // System Configuration Register
-#define SPI_SYSSTATUS 0x14 // System Status Register
-#define SPI_IRQSTATUS 0x18 // Interrupt Status Register
-#define SPI_IRQENABLE 0x1C // Interrupt Enable/Disable Register
-#define SPI_WAKEUPENABLE 0x20 // WakeUp Enable/Disable Register
-#define SPI_SYST 0x24 // System Test Register
-#define SPI_MODULCTRL 0x28 // Serial Port Interface Configuration Register
-#define SPI_CH0_CONF 0x2C // Channel 0 Configuration Register
-#define SPI_CH1_CONF 0x40 // Channel 1 Configuration Register
-#define SPI_CH2_CONF 0x54 // Channel 2 Configuration Register
-#define SPI_CH3_CONF 0x68 // Channel 3 Configuration Register
-#define SPI_CH0_STAT 0x30 // Channel 0 Status Register
-#define SPI_CH1_STAT 0x44 // Channel 1 Status Register
-#define SPI_CH2_STAT 0x58 // Channel 2 Status Register
-#define SPI_CH3_STAT 0x6C // Channel 3 Status Register
-#define SPI_CH0_CTRL 0x34 // Channel 0 Control Register
-#define SPI_CH1_CTRL 0x48 // Channel 1 ControlRegister
-#define SPI_CH2_CTRL 0x5C // Channel 2 ControlRegister
-#define SPI_CH3_CTRL 0x70 // Channel 3 ControlRegister
-#define SPI_TXD0 0x38 // Channel 0 Transmit Data Register
-#define SPI_TXD1 0x4C // Channel 1 Transmit Data Register
-#define SPI_TXD2 0x60 // Channel 2 Transmit Data Register
-#define SPI_TXD3 0x74 // Channel 3 Transmit Data Register
-#define SPI_RXD0 0x3C // Channel 0 Receive Data Register
-#define SPI_RXD1 0x50 // Channel 1 Receive Data Register
-#define SPI_RXD2 0x64 // Channel 2 Receive Data Register
-#define SPI_RXD3 0x78 // Channel 3 Receive Data Register
-#define SPI_XFERLEVEL 0x7C // FIFO Transfer Levels Register
-// SPI Channel x Configuration Bit Defines
-#define SPI_CH_CONF_CLKG BIT29 // 1 = One clock cycle granularity
-#define SPI_CH_CONF_FFER BIT28 // 1 = FIFO buffer is used to Receive data
-#define SPI_CH_CONF_FFEW BIT27 // 1 = FIFO buffer is used to Transmit data
-#define SPI_CH_CONF_TCS_0_5 (0x00 << 25) // 0.5 clock cycles between
-#define SPI_CH_CONF_TCS_1_5 (0x01 << 25) // 1.5 clock cycles between
-#define SPI_CH_CONF_TCS_2_5 (0x02 << 25) // 2.5 clock cycles between
-#define SPI_CH_CONF_TCS_3_5 (0x03 << 25) // 3.5 clock cycles between
-#define SPI_CH_CONF_SB_POL BIT24 // 1 = Start bit polarity is held to
-#define SPI_CH_CONF_SBE BIT23 // 1 = Start bit added before SPI
-#define SPI_CH_CONF_SPIENSLV_0 (0x00 << 21) // Slave select detection
enabled on CS0
-#define SPI_CH_CONF_SPIENSLV_1 (0x01 << 21) // Slave select detection
enabled on CS1
-#define SPI_CH_CONF_SPIENSLV_2 (0x02 << 21) // Slave select detection
enabled on CS2
-#define SPI_CH_CONF_SPIENSLV_3 (0x03 << 21) // Slave select detection
enabled on CS3
-#define SPI_CH_CONF_FORCE BIT20 // 1 = CSx high when EPOL is 0 and
low when EPOL is 1
-#define SPI_CH_CONF_TURBO BIT19 // 1 = Turbo is activated
-#define SPI_CH_CONF_IS BIT18 // 1 = spim_simo selected for reception,
-#define SPI_CH_CONF_DPE1 BIT17 // 1 = no transmission on spim_simo, 0
-#define SPI_CH_CONF_DPE0 BIT16 // 1 = no transmission on spim_somi, 0
-#define SPI_CH_CONF_DMAR BIT15 // 1 = DMA read request enabled
-#define SPI_CH_CONF_DMAW BIT14 // 1 = DMA write request enabled
-#define SPI_CH_CONF_TRM_TR (0x00 << 12) // Transmit and receive mode
-#define SPI_CH_CONF_TRM_RO (0x01 << 12) // Receive-only mode
-#define SPI_CH_CONF_TRM_TO (0x02 << 12) // Transmit-only mode
-#define SPI_CH_CONF_WL(_x_) ((_x_ & 0x1f) << 7) // SPI word length, 0x7 = 8-bit
-#define SPI_CH_CONF_EPOL BIT6 // 1 = SPIM_CSx is low during active
-#define SPI_CH_CONF_CLKD(_x_) ((_x_ & 0xf) << 2) // Frequency divider
for spim_clk
-#define SPI_CH_CONF_POL BIT1 // 1 = spim_clk is low during active
-#define SPI_CH_CONF_PHA BIT0 // 1 = data latched on even-numbered
-// SPI Interrupt Status Register Bit Defines
-#define SPI_RX3_FULL BIT14 //
-#define SPI_TX3_EMPTY BIT12 //
-#define SPI_RX2_FULL BIT10 //
-#define SPI_TX2_EMPTY BIT8 //
-#define SPI_RX1_FULL BIT14 //
-#define SPI_TX1_EMPTY BIT6 //
-#define SPI_RX0_FULL BIT2 //
-#define SPI_TX0_EMPTY BIT0 //
-// SPI Channel Status Register Bit Defines
-#define SPI_RXF_FULL BIT6 //
-#define SPI_RXF_EMPTY BIT5 //
-#define SPI_TXF_FULL BIT4 //
-#define SPI_TXF_EMPTY BIT3 //
-#define SPI_CH_EOT BIT2 //
-#define SPI_CH_TX0_EMPTY BIT1 //
-#define SPI_CH_RX0_FULL BIT0 //
-/* General Purpose Timers */
-#define OMAP35XX_GPT1 0x48318000
-#define OMAP35XX_GPT2 0x49032000
-#define OMAP35XX_GPT3 0x49034000
-#define OMAP35XX_GPT4 0x49036000
-#define OMAP35XX_GPT5 0x49038000
-#define OMAP35XX_GPT6 0x4903A000
-#define OMAP35XX_GPT7 0x4903C000
-#define OMAP35XX_GPT8 0x4903E000
-#define OMAP35XX_GPT9 0x49040000
-#define OMAP35XX_GPT10 0x48086000
-#define OMAP35XX_GPT11 0x48088000
-#define OMAP35XX_GPT12 0x48304000
-/* General Purpose I/O */
-#define GPIO1_BASE_ADD 0x48310000
-#define GPIO2_BASE_ADD 0x49050000
-#define GPIO3_BASE_ADD 0x49052000
-#define GPIO4_BASE_ADD 0x49054000
-#define GPIO5_BASE_ADD 0x49056000
-#define GPIO6_BASE_ADD 0x49058000
-#define GPIO1_REG(_x_) *(vulong *)(GPIO1_BASE_ADD + _x_)
-#define GPIO2_REG(_x_) *(vulong *)(GPIO2_BASE_ADD + _x_)
-#define GPIO3_REG(_x_) *(vulong *)(GPIO3_BASE_ADD + _x_)
-#define GPIO4_REG(_x_) *(vulong *)(GPIO4_BASE_ADD + _x_)
-#define GPIO5_REG(_x_) *(vulong *)(GPIO5_BASE_ADD + _x_)
-#define GPIO6_REG(_x_) *(vulong *)(GPIO6_BASE_ADD + _x_)
-/* GPIO Register offsets */
-#define GPIO_SYSCONFIG 0x10 //
-#define GPIO_SYSSTATUS 0x14 //
-#define GPIO_CTRL 0x30 //
-#define GPIO_OE 0x34 //
-#define GPIO_DATAIN 0x38 //
-#define GPIO_DATAOUT 0x3C //
-#define GPIO_CLEARDATAOUT 0x90 //
-#define GPIO_SETDATAOUT 0x94 //
-/* WatchDog Timers (1 secure, 3 GP) */
-#define WD1_BASE_ADD 0x4830C000
-#define WD2_BASE_ADD 0x48314000
-#define WD3_BASE_ADD 0x49030000
-#define WD1_REG(_x_) *(vulong *)(WD1_BASE_ADD + _x_)
-#define WD2_REG(_x_) *(vulong *)(WD2_BASE_ADD + _x_)
-#define WD3_REG(_x_) *(vulong *)(WD3_BASE_ADD + _x_)
-/* WatchDog Timer Register offsets */
-#define WD_CONFIG 0x10 // System Configuration Register
-#define WD_STATUS 0x14 // System Configuration Register
-#define WD_WISR 0x18 // System Configuration Register
-#define WD_WIER 0x1C // System Configuration Register
-#define WD_WCLR 0x24 // System Configuration Register
-#define WD_WCRR 0x28 // System Configuration Register
-#define WD_WLDR 0x2C // System Configuration Register
-#define WD_WTGR 0x30 // System Configuration Register
-#define WD_WWPS 0x34 // System Configuration Register
-#define WD_WSPR 0x48 // System Configuration Register
-/* 32KTIMER */
-#define SYNC_32KTIMER_BASE (0x48320000)
-#define S32K_CR (SYNC_32KTIMER_BASE+0x10)
-/* System Control Module */
-/* Module Name Base Address Size */
- INTERFACE 0x48002000 36 bytes
- PADCONFS 0x48002030 564 bytes
- GENERAL 0x48002270 767 bytes
- MEM_WKUP 0x48002600 1K byte
- PADCONFS_WKU 0x48002A00 80 bytes
- GENERAL_WKUP 0x48002A60 31 bytes
-#define OMAP35XX_CTRL_BASE (OMAP35XX_L4_IO_BASE+0x2000)
-#define SCM_REG(_x_) *(vulong *)(OMAP35XX_CTRL_BASE + _x_)
-/* Pad Configuration Registers */
-/* Note: Cogent is only defining the PADCONFS registers that are used
in Micromonitor */
-#define PADCONFS_GPMC_NCS3 0xB4 // NCS3[15:0], NCS4[31:16]
-#define PADCONFS_GPMC_NCS5 0xB8 // NCS5[15:0], EXP_INTX[31:16]
-#define PADCONFS_GPMC_NCS7 0xBC // LCD_BKL_X[15:0], LCLK[31:16]
-#define PADCONFS_GPMC_NADV_ALE 0xC0 // NADV_ALE[15:0], NOE[31:16]
-#define PADCONFS_GPMC_NWE 0xC4 // NWE[15:0], NBE0_CLE[31:16]
-#define PADCONFS_DSS_PCLK 0xD4 // LCD_PCLK_X[15:0], LCD_HS_X[31:16]
-#define PADCONFS_DSS_VSYNC 0xD8 // LCD_VS_X[15:0], LCD_OE_X[31:16]
-#define PADCONFS_DSS_DATA0 0xDC // LCD_B0_X[15:0], LCD_B1_X[31:16]
-#define PADCONFS_DSS_DATA2 0xE0 // LCD_B2_X[15:0], LCD_B3_X[31:16]
-#define PADCONFS_DSS_DATA4 0xE4 // LCD_B4_X[15:0], LCD_B5_X[31:16]
-#define PADCONFS_DSS_DATA6 0xE8 // LCD_G0_X[15:0], LCD_G1_X[31:16]
-#define PADCONFS_DSS_DATA8 0xEC // LCD_G2_X[15:0], LCD_G3_X[31:16]
-#define PADCONFS_DSS_DATA10 0xF0 // LCD_G4_X[15:0], LCD_G5_X[31:16]
-#define PADCONFS_DSS_DATA12 0xF4 // LCD_R0_X[15:0], LCD_R1_X[31:16]
-#define PADCONFS_DSS_DATA14 0xF8 // LCD_R2_X[15:0], LCD_R3_X[31:16]
-#define PADCONFS_DSS_DATA16 0xFC // LCD_R4_X[15:0], LCD_R5_X[31:16]
-#define PADCONFS_DSS_DATA18 0x100 // SPI1_CLK_X[15:0], SPI1_MOSI_X[31:16]
-#define PADCONFS_DSS_DATA20 0x104 // SPI1_MISO_X[15:0], *SPI1_CS0_X[31:16]
-#define PADCONFS_DSS_DATA22 0x108 // GPIO7_X[15:0], NC[31:16]
-#define PADCONFS_MMC1_DAT4 0x150 // *I2C_INT_X[15:0], *PIRQ_X[31:16]
-#define PADCONFS_MMC1_DAT6 0x154 // GPIO0_X[15:0], GPIO1_X[31:16]
-#define PADCONFS_MCBSP3_CLKX 0x170 // D_TXD[15:0], D_RXD[31:16]
-#define PADCONFS_SYS_NIRQ 0x1E0 // FIQ[15:0], SYS_CLK2[31:16]
-#define PADCONFS_SYS_OFF_MODE 0xA18 // OFF_MODE_X[15:0], USB_CLK[31:16]
-#define PADCONFS_GPMC_WAIT2 0xD0 // NA[15:0], E_INTX[31:16]
-#define PADCONFS_MMC1_CLK 0x144 // MMC1_CLK[15:0], MMC1_CMD[31:16]
-#define PADCONFS_MMC1_DAT0 0x148 // MMC1_DAT0[15:0], MMC1_DAT1[31:16]
-#define PADCONFS_MMC1_DAT2 0x14C // MMC1_DAT2[15:0], MMC1_DAT3[31:16]
-#define CM_REV_REG 0x48004800
-#define PRM_REV_REG 0x48306804
-#define CM_REV_MAJ() ((*(volatile unsigned long *)CM_REV_REG & 0xf0)>>4)
-#define CM_REV_MIN() (*(volatile unsigned long *)CM_REV_REG & 0x0f)
-#define PRM_REV_MAJ() ((*(volatile unsigned long *)PRM_REV_REG & 0xf0)>>4)
-#define PRM_REV_MIN() (*(volatile unsigned long *)PRM_REV_REG & 0x0f)
-/* MMC registers...
-#define CM_FCLKEN1_CORE 0x48004a00
-#define CM_ICLKEN1_CORE 0x48004a10
-#define CM_IDLEST1_CORE 0x48004a20
-#define CM_AUTOIDLE1_CORE 0x48004a30
-#define PM_WKEN1_CORE 0x48306aa0
-#define PM_MPUGRPSEL1_CORE 0x48306aa4
-#define PM_IVA2GRPSEL1_CORE 0x48306aa8
-#define PM_WKST1_CORE 0x48306ab0
-#define CONTROL_DEVCONF0 0x48002274
-#define MMC1_BASE_ADD 0x4809c000
-#define MMC2_BASE_ADD 0x480ad000
-#define MMC3_BASE_ADD 0x480b4000
-#define MMC1_REG(_x_) *(vulong *)(MMC1_BASE_ADD + _x_)
-#define MMC2_REG(_x_) *(vulong *)(MMC2_BASE_ADD + _x_)
-#define MMC3_REG(_x_) *(vulong *)(MMC3_BASE_ADD + _x_)
-#define MMCHS_SYSCONFIG 0x10
-#define MMCHS_SYSSTATUS 0x14
-#define MMCHS_CSRE 0x24
-#define MMCHS_SYSTEST 0x28
-#define MMCHS_CON 0x2C
-#define MMCHS_PWCNT 0x30
-#define MMCHS_BLK 0x104
-#define MMCHS_ARG 0x108
-#define MMCHS_CMD 0x10C
-#define MMCHS_RSP10 0x110
-#define MMCHS_RSP32 0x114
-#define MMCHS_RSP54 0x118
-#define MMCHS_RSP76 0x11C
-#define MMCHS_DATA 0x120
-#define MMCHS_PSTATE 0x124
-#define MMCHS_HCTL 0x128
-#define MMCHS_SYSCTL 0x12C
-#define MMCHS_STAT 0x130
-#define MMCHS_IE 0x134
-#define MMCHS_ISE 0x138
-#define MMCHS_AC12 0x13C
-#define MMCHS_CAPA 0x140
-#define MMCHS_CUR_CAPA 0x148
-#define MMCHS_REV 0x1FC
-/* Miscellaneous MMC register bits...
- * (only specified the ones I use)
-#define EN_MMC1 (1 << 24)
-#define ST_MMC1 (1 << 24)
-#define AUTO_MMC1 (1 << 24)
-#define GRPSEL_MMC1 (1 << 24)
-#define VS18 0x04000000
-#define VS30 0x02000000
-#define VS33 0x01000000
-#define MMCINIT 0x00000002
-#define ODE 0x00000001
-#define SVDS 0x00000e00
-#define SVDS18 (5 << 9)
-#define SVDS30 (6 << 9)
-#define SVDS33 (7 << 9)
-#define SDBP 0x00000100
-#define ICE 0x00000001
-#define ICS 0x00000002
-#define CEN 0x00000004
-#define CLKD(v) ((v & 0x3ff) << 6)
-#define CLKDMSK (0x3ff << 6)
-#define CLKACTIVITYMSK (3 << 8)
-#define CLKACTIVITY(n) ((n & 3) << 8)
-#define SIDLEMODEMSK (3 << 3)
-#define SIDLEMODE(n) ((n & 3) << 3)
-#define ENWAKEUP (1 << 2)
-#define IWE (1 << 24)
-#define AUTOIDLE 1
-#define CLKEXTFREE (1 << 16)
-#define SRESET 0x00000002
-#define CC 0x00000001
-#define RESETDONE 0x00000001
-#define IE_ALL 0x317f8337
-#define CDP (1 << 7)
-#define CMD(v) ((v & 0x3f) << 24)
-#define CMDMSK (0x3f << 24)
-#define CMDI 0x00000001
-#define DEBOUNCE (3 << 16)
-#define CCRC (1 << 17)
-#define DCRC (1 << 21)
-#define CERR (1 << 28)
-#define CTO (1 << 16)
-#define DP (1 << 21)
-#define RSPTYPE_NONE 0x00000000
-#define RSPTYPE_136 0x00010000
-#define RSPTYPE_48 0x00020000
-#define RSPTYPE_48BSY 0x00030000
-#define RSPTYPE 0x00030000
-#define SRD (1 << 26)
-#define SRC (1 << 25)
-#define SRA (1 << 24)
-#define DTOMSK (0xf<<16)
-#define DTO(a) ((a&0xf) << 16)
-#define NBLK(a) ((a&0xffff) << 16)
-#define BLEN(a) (a&0x7ff)
-#define MMCSDIO1ADPCLKISEL (1 << 24)
-/* PBIAS...
-#define CONTROL_PBIAS_LITE 0x48002520
-#define PBIAS_LITE_VMMC1_3V (0x0101)
-#define MMC_PWR_STABLE (0x0202)
-#define PBIAS_LITE_VMMC1_52MHZ (0x0404)
-#define PBIAS_LITE_MMC1_ERROR (0x0808)
-#define PBIAS_LITE_MMC1_HIGH (0x8080)
-/* Control status...
-#define CONTROL_STATUS 0x480022f0
-#define SYSBOOT 0x3f
-#define DEVICETYPE (0x3 << 8)
-/* 16 bit access CONTROL */
-#define MUX_VAL(OFFSET,VALUE)\
- *(unsigned short *) (OMAP35XX_CTRL_BASE + (OFFSET)) = VALUE;
-#define CP(x) (CONTROL_PADCONF_##x)
-#define CONTROL_PADCONF_DSS_DATA18 0x0100
-#define CONTROL_PADCONF_DSS_DATA19 0x0102
-#define CONTROL_PADCONF_DSS_DATA20 0x0104
-#define CONTROL_PADCONF_DSS_DATA21 0x0106
-#define CONTROL_PADCONF_MMC1_CLK 0x0144
-#define CONTROL_PADCONF_MMC1_CMD 0x0146
-#define CONTROL_PADCONF_MMC1_DAT0 0x0148
-#define CONTROL_PADCONF_MMC1_DAT1 0x014A
-#define CONTROL_PADCONF_MMC1_DAT2 0x014C
-#define CONTROL_PADCONF_MMC1_DAT3 0x014E
-#define CONTROL_PADCONF_HSUSB0_CLK 0x01A2
-#define CONTROL_PADCONF_HSUSB0_STP 0x01A4
-#define CONTROL_PADCONF_HSUSB0_DIR 0x01A6
-#define CONTROL_PADCONF_HSUSB0_NXT 0x01A8
-#define CONTROL_PADCONF_HSUSB0_DATA0 0x01AA
-#define CONTROL_PADCONF_HSUSB0_DATA1 0x01AC
-#define CONTROL_PADCONF_HSUSB0_DATA2 0x01AE
-#define CONTROL_PADCONF_HSUSB0_DATA3 0x01B0
-#define CONTROL_PADCONF_HSUSB0_DATA4 0x01B2
-#define CONTROL_PADCONF_HSUSB0_DATA5 0x01B4
-#define CONTROL_PADCONF_HSUSB0_DATA6 0x01B6
-#define CONTROL_PADCONF_HSUSB0_DATA7 0x01B8
-#define CONTROL_PADCONF_I2C1_SCL 0x01BA
-#define CONTROL_PADCONF_I2C1_SDA 0x01BC
-#define CONTROL_PADCONF_McBSP3_DX 0x016C
-/* bits used in control reg's above
- * IEN - Input Enable
- * IDIS - Input Disable
- * PTD - Pull type Down
- * PTU - Pull type Up
- * DIS - Pull type selection is inactive
- * EN - Pull type selection is active
- * M0 - Mode 0
-#define IEN (1 << 8)
-#define IDIS (0 << 8)
-#define PTU (1 << 4)
-#define PTD (0 << 4)
-#define EN (1 << 3)
-#define DIS (0 << 3)
-#define M0 0 /* modes */
-#define M1 1
-#define M2 2
-#define M3 3
-#define M4 4
-#define M5 5
-#define M6 6
-#define M7 7
diff --git a/ports/beagleboneblack/rom_reset.S
b/ports/beagleboneblack/rom_reset.S
index d2c9cfb..8fb396f 100644
--- a/ports/beagleboneblack/rom_reset.S
+++ b/ports/beagleboneblack/rom_reset.S
@@ -15,13 +15,13 @@
* phone: 908-582-2351
- * Modified for the CSB740 - OMAP3530 Single Board
+ * Modified for the Beaglebone Black
- * rom_reset.s:
+ * rom_reset.S:
#include "warmstart.h"
-#include "omap3530.h"
+#include "beagleboneblack"
#include "config.h"
2.3.3
More information about the umon-devel
