[PATCH 4/16] Renamed BBB platform file to am335x.h, initial version of am335x.h
Jarielle Catbagan
jcatbagan93 at gmail.com
Wed Jun 17 17:52:58 UTC 2015
Renamed beagleboneblack.h -> am335x.h
Initial version of am335x.h includes a subset of the regsiter base
addresses and offsets specific to the AM335x architecture.
main/common/warmstart.h | 2 +-
main/make/common.make | 0
ports/beagleboneblack/am335x.h | 788 ++++++++++++++++++++++++++++++++
ports/beagleboneblack/beagleboneblack.h | 498 --------------------
4 files changed, 789 insertions(+), 499 deletions(-)
mode change 100755 => 100644 main/make/common.make
create mode 100644 ports/beagleboneblack/am335x.h
delete mode 100644 ports/beagleboneblack/beagleboneblack.h
diff --git a/main/common/warmstart.h b/main/common/warmstart.h
index 50300eb..a3037ad 100644
--- a/main/common/warmstart.h
+++ b/main/common/warmstart.h
@@ -31,4 +31,4 @@
#define APPLICATION (5<<4)
#define APP_EXIT (9<<4)
-#endif
+#endif /* _WARMSTART_H_ */
diff --git a/main/make/common.make b/main/make/common.make
old mode 100755
new mode 100644
diff --git a/ports/beagleboneblack/am335x.h b/ports/beagleboneblack/am335x.h
new file mode 100644
index 0000000..ed96dfe
--- /dev/null
+++ b/ports/beagleboneblack/am335x.h
@@ -0,0 +1,788 @@
+// am335x.h
+// Author(s): Luis Torrico, Cogent Computer Systems, Inc.
+// Contributors: Jarielle Catbagan
+// Date: 05/02/2008
+// Description: This file was modified from omap3530.h. This file containes
+// register base addresses and offsets as well as access macros
+// for the AM335x/Beaglebone Black on-chip peripherals.
+// Peripherals not used by UMON have not been tested (and
+// may not be defined). Use these defines with caution!!
+#include "bits.h"
+/* AM335x device identification and feature enumeration */
+#define AM335X_DEVICE_IDENTIFICATION 0x44E10600
+#define AM335X_DEVICE_FEATURE 0x44E10604
+/* L3 and L4 Interconnects */
+#define L3F_CFG_REG_BASE_ADDR 0x44000000
+#define L3S_CFG_REG_BASE_ADDR 0x44800000
+#define L4_WKUP_BASE_ADDR 0x44C00000
+#define L4_PER_BASE_ADDR 0x48000000
+#define L4_FAST_BASE_ADDR 0x4A000000
+/* McASPx Data Registers */
+#define MCASP0_DATA_REG_BASE_ADDR 0x46000000
+#define MCASP1_DATE_REG-BASE_ADDR 0x46400000
+/* USB Subsystem */
+#define USB_SUBSYS_BASE_ADDR 0x47400000
+/* USB Subsystem Registers offset */
+#define USBSS_BASE_REG_OFFSET 0x0000
+#define USBSS_REVREG 0x0000
+#define USBSS_SYSCONFIG 0x0010
+#define USBSS_IRQSTATRAW 0x0024
+#define USBSS_IRQSTAT 0x0028
+#define USBSS_IRQENABLER 0x002C
+#define USBSS_IRQCLEARR 0x0030
+#define USBSS_IRQDMATHOLDTX00 0x0100
+#define USBSS_IRQDMATHOLDTX01 0x0104
+#define USBSS_IRQDMATHOLDTX02 0x0108
+#define USBSS_IRQDMATHOLDTX03 0x010C
+#define USBSS_IRQDMATHOLDRX00 0x0110
+#define USBSS_IRQDMATHOLDRX01 0x0114
+#define USBSS_IRQDMATHOLDRX02 0x0118
+#define USBSS_IRQDMATHOLDRX03 0x011C
+#define USBSS_IRQDMATHOLDTX10 0x0120
+#define USBSS_IRQDMATHOLDTX11 0x0124
+#define USBSS_IRQDMATHOLDTX12 0x0128
+#define USBSS_IRQDMATHOLDTX13 0x012C
+#define USBSS_IRQDMATHOLDRX10 0x0130
+#define USBSS_IRQDMATHOLDRX11 0x0134
+#define USBSS_IRQDMATHOLDRX12 0x0138
+#define USBSS_IRQDMATHOLDRX13 0x013C
+#define USBSS_IRQDMAENABLE0 0x0140
+#define USBSS_IRQDMAENABLE1 0x0144
+#define USBSS_IRQFRAMETHOLDTX00 0x0200
+#define USBSS_IRQFRAMETHOLDTX01 0x0204
+#define USBSS_IRQFRAMETHOLDTX02 0x0208
+#define USBSS_IRQFRAMETHOLDTX03 0x020C
+#define USBSS_IRQFRAMETHOLDRX00 0x0210
+#define USBSS_IRQFRAMETHOLDRX01 0x0214
+#define USBSS_IRQFRAMETHOLDRX02 0x0218
+#define USBSS_IRQFRAMETHOLDRX03 0x021C
+#define USBSS_IRQFRAMETHOLDTX10 0x0220
+#define USBSS_IRQFRAMETHOLDTX11 0x0224
+#define USBSS_IRQFRAMETHOLDTX12 0x0228
+#define USBSS_IRQFRAMETHOLDTX13 0x022C
+#define USBSS_IRQFRAMETHOLDRX10 0x0230
+#define USBSS_IRQFRAMETHOLDRX11 0x0234
+#define USBSS_IRQFRAMETHOLDRX12 0x0238
+#define USBSS_IRQFRAMETHOLDRX13 0x023C
+#define USBSS_IRQFRAMEENABLE0 0x0240
+#define USBSS_IRQFRAMEENABLE1 0x0244
+/* USB Controller Registers offset */
+#define USBCNTLR_USB0_BASE_REG_OFFSET 0x1000 /* USB0 */
+#define USBCNTLR_USB1_BASE_REG_OFFSET 0x1800 /* USB1 */
+#define USBCNTLR_REV 0x0000
+#define USBCNTLR_CTRL 0x0014
+#define USBCNTLR_STAT 0x0018
+#define USBCNTLR_IRQMSTAT 0x0020
+#define USBCNTLR_IRQSTATRAW0 0x0028
+#define USBCNTLR_IRQSTATRAW1 0x002C
+#define USBCNTLR_IRQSTAT0 0x0030
+#define USBCNTLR_IRQSTAT1 0x0034
+#define USBCNTLR_IRQENABLESET0 0x0038
+#define USBCNTLR_IRQENABLESET1 0x003C
+#define USBCNTLR_IRQENABLECLR0 0x0040
+#define USBCNTLR_IRQENABLECLR1 0x0044
+#define USBCNTLR_TXMODE 0x0070
+#define USBCNTLR_RXMODE 0x0074
+#define USBCNTLR_GENRNDISEP1 0x0080
+#define USBCNTLR_GENRNDISEP2 0x0084
+#define USBCNTLR_GENRNDISEP3 0x0088
+#define USBCNTLR_GENRNDISEP4 0x008C
+#define USBCNTLR_GENRNDISEP5 0x0090
+#define USBCNTLR_GENRNDISEP6 0x0094
+#define USBCNTLR_GENRNDISEP7 0x0098
+#define USBCNTLR_GENRNDISEP8 0x009C
+#define USBCNTLR_GENRNDISEP9 0x00A0
+#define USBCNTLR_GENRNDISEP10 0x00A4
+#define USBCNTLR_GENRNDISEP11 0x00A8
+#define USBCNTLR_GENRNDISEP12 0x00AC
+#define USBCNTLR_GENRNDISEP13 0x00B0
+#define USBCNTLR_GENRNDISEP14 0x00B4
+#define USBCNTLR_GENRNDISEP15 0x00B8
+#define USBCNTLR_AUTOREQ 0x00D0
+#define USBCNTLR_SRPFIXTIME 0x00D4
+#define USBCNTLR_TDOWN 0x00D8
+#define USBCNTLR_UTMI 0x00E0
+#define USBCNTLR_MGCUTMILB 0x00E4
+#define USBCNTLR_MODE 0x00E8
+/* USB PHY Registers offset */
+#define USBPHY_USB0_BASE_REG_OFFSET 0x1300 /* USB0 */
+#define USBPHY_USB1_BASE_REG_OFFSET 0x1B00 /* USB1 */
+#define USBPHY_TERMINATION_CNTL 0x0000
+#define USBPHY_RX_CALIB 0x0004
+#define USBPHY_DLLHS_2 0x0008
+#define USBPHY_RX_TEST_2 0x000C
+#define USBPHY_CHRG_DET 0x0014
+#define USBPHY_PWR_CNTL 0x0018
+#define USBPHY_UTMI_INTERFACE_CNTL_1 0x001C
+#define USBPHY_UTMI_INTERFACE_CNTL_2 0x0020
+#define USBPHY_BIST 0x0024
+#define USBPHY_BIST_CRC 0x0028
+#define USBPHY_CDR_BIST2 0x002C
+#define USBPHY_GPIO 0x0030
+#define USBPHY_DLLHS 0x0034
+#define USBPHY_USB2PHYCM_CONFIG 0x003C
+#define USBPHY_AD_INTERFACE_REG1 0x0044
+#define USBPHY_AD_INTERFACE_REG2 0x0048
+#define USBPHY_AD_INTERFACE_REG3 0x004C
+#define USBPHY_ANA_CONFIG2 0x0054
+/* USB Core Registers offset */
+#define USBCORE_USB0_BASE_REG_OFFSET 0x1400
+#define USBCORE_USB1_BASE_REG_OFFSET 0x1C00
+/* USB CPPI DMA Controller Registers offset */
+#define USBCPPIDMACNTLR_BASE_REG_OFFSET 0x2000
+#define USBCPPIDMACNTLR_DMAREVID 0x0000
+#define USBCPPIDMACNTLR_TDFDQ 0x0004
+#define USBCPPIDMACNTLR_DMAEMU 0x0008
+#define USBCPPIDMACNTLR_TXGCR0 0x0800
+#define USBCPPIDMACNTLR_RXGCR0 0x0808
+#define USBCPPIDMACNTLR_RXHPCRA0 0x080C
+#define USBCPPIDMACNTLR_RXHPCRB0 0x0810
+#define USBCPPIDMACNTLR_TXGCR1 0x0820
+#define USBCPPIDMACNTLR_RXGCR1 0x0828
+#define USBCPPIDMACNTLR_RXHPCRA1 0x082C
+#define USBCPPIDMACNTLR_RXHPCRB1 0x0830
+#define USBCPPIDMACNTLR_TXGCR2 0x0840
+#define USBCPPIDMACNTLR_RXGCR2 0x0848
+#define USBCPPIDMACNTLR_RXHPCRA2 0x084C
+#define USBCPPIDMACNTLR_RXHPCRB2 0x0850
+#define USBCPPIDMACNTLR_TXGCR3 0x0860
+#define USBCPPIDMACNTLR_RXGCR3 0x0868
+#define USBCPPIDMACNTLR_RXHPCRA3 0x086C
+#define USBCPPIDMACNTLR_RXHPCRB3 0x0870
+#define USBCPPIDMACNTLR_TXGCR4 0x0880
+#define USBCPPIDMACNTLR_RXGCR4 0x0888
+#define USBCPPIDMACNTLR_RXHPCRA4 0x088C
+#define USBCPPIDMACNTLR_RXHPCRB4 0x0890
+#define USBCPPIDMACNTLR_TXGCR5 0x08A0
+#define USBCPPIDMACNTLR_RXGCR5 0x08A8
+#define USBCPPIDMACNTLR_RXHPCRA5 0x08AC
+#define USBCPPIDMACNTLR_RXHPCRB5 0x08B0
+#define USBCPPIDMACNTLR_TXGCR6 0x08C0
+#define USBCPPIDMACNTLR_RXGCR6 0x08C8
+#define USBCPPIDMACNTLR_RXHPCRA6 0x08CC
+#define USBCPPIDMACNTLR_RXHPCRB6 0x08D0
+#define USBCPPIDMACNTLR_TXGCR7 0x08E0
+#define USBCPPIDMACNTLR_RXGCR7 0x08E8
+#define USBCPPIDMACNTLR_RXHPCRA7 0x08EC
+#define USBCPPIDMACNTLR_RXHPCRB7 0x08F0
+#define USBCPPIDMACNTLR_TXGCR8 0x0900
+#define USBCPPIDMACNTLR_RXGCR8 0x0908
+#define USBCPPIDMACNTLR_RXHPCRA8 0x090C
+#define USBCPPIDMACNTLR_RXHPCRB8 0x0910
+#define USBCPPIDMACNTLR_TXGCR9 0x0920
+#define USBCPPIDMACNTLR_RXGCR9 0x0928
+#define USBCPPIDMACNTLR_RXHPCRA9 0x092C
+#define USBCPPIDMACNTLR_RXHPCRB9 0x0930
+#define USBCPPIDMACNTLR_TXGCR10 0x0940
+#define USBCPPIDMACNTLR_RXGCR10 0x0948
+#define USBCPPIDMACNTLR_RXHPCRA10 0x094C
+#define USBCPPIDMACNTLR_RXHPCRB10 0x0950
+#define USBCPPIDMACNTLR_TXGCR11 0x0960
+#define USBCPPIDMACNTLR_RXGCR11 0x0968
+#define USBCPPIDMACNTLR_RXHPCRA11 0x096C
+#define USBCPPIDMACNTLR_RXHPCRB11 0x0970
+#define USBCPPIDMACNTLR_TXGCR12 0x0980
+#define USBCPPIDMACNTLR_RXGCR12 0x0988
+#define USBCPPIDMACNTLR_RXHPCRA12 0x098C
+#define USBCPPIDMACNTLR_RXHPCRB12 0x0990
+#define USBCPPIDMACNTLR_TXGCR13 0x09A0
+#define USBCPPIDMACNTLR_RXGCR13 0x09A8
+#define USBCPPIDMACNTLR_RXHPCRA13 0x09AC
+#define USBCPPIDMACNTLR_RXHPCRB13 0x09B0
+#define USBCPPIDMACNTLR_TXGCR14 0x09C0
+#define USBCPPIDMACNTLR_RXGCR14 0x09C8
+#define USBCPPIDMACNTLR_RXHPCRA14 0x09CC
+#define USBCPPIDMACNTLR_RXHPCRB14 0x09D0
+#define USBCPPIDMACNTLR_TXGCR15 0x09E0
+#define USBCPPIDMACNTLR_RXGCR15 0x09E8
+#define USBCPPIDMACNTLR_RXHPCRA15 0x09EC
+#define USBCPPIDMACNTLR_RXHPCRB15 0x09F0
+#define USBCPPIDMACNTLR_TXGCR16 0x0A00
+#define USBCPPIDMACNTLR_RXGCR16 0x0A08
+#define USBCPPIDMACNTLR_RXHPCRA16 0x0A0C
+#define USBCPPIDMACNTLR_RXHPCRB16 0x0A10
+#define USBCPPIDMACNTLR_TXGCR17 0x0A20
+#define USBCPPIDMACNTLR_RXGCR17 0x0A28
+#define USBCPPIDMACNTLR_RXHPCRA17 0x0A2C
+#define USBCPPIDMACNTLR_RXHPCRB17 0x0A30
+#define USBCPPIDMACNTLR_TXGCR18 0x0A40
+#define USBCPPIDMACNTLR_RXGCR18 0x0A48
+#define USBCPPIDMACNTLR_RXHPCRA18 0x0A4C
+#define USBCPPIDMACNTLR_RXHPCRB18 0x0A50
+#define USBCPPIDMACNTLR_TXGCR19 0x0A60
+#define USBCPPIDMACNTLR_RXGCR19 0x0A68
+#define USBCPPIDMACNTLR_RXHPCRA19 0x0A6C
+#define USBCPPIDMACNTLR_RXHPCRB19 0x0A70
+#define USBCPPIDMACNTLR_TXGCR20 0x0A80
+#define USBCPPIDMACNTLR_RXGCR20 0x0A88
+#define USBCPPIDMACNTLR_RXHPCRA20 0x0A8C
+#define USBCPPIDMACNTLR_RXHPCRB20 0x0A90
+#define USBCPPIDMACNTLR_TXGCR21 0x0AA0
+#define USBCPPIDMACNTLR_RXGCR21 0x0AA8
+#define USBCPPIDMACNTLR_RXHPCRA21 0x0AAC
+#define USBCPPIDMACNTLR_RXHPCRB21 0x0AB0
+#define USBCPPIDMACNTLR_TXGCR22 0x0AC0
+#define USBCPPIDMACNTLR_RXGCR22 0x0AC8
+#define USBCPPIDMACNTLR_RXHPCRA22 0x0ACC
+#define USBCPPIDMACNTLR_RXHPCRB22 0x0AD0
+#define USBCPPIDMACNTLR_TXGCR23 0x0AE0
+#define USBCPPIDMACNTLR_RXGCR23 0x0AE8
+#define USBCPPIDMACNTLR_RXHPCRA23 0x0AEC
+#define USBCPPIDMACNTLR_RXHPCRB23 0x0AF0
+#define USBCPPIDMACNTLR_TXGCR24 0x0B00
+#define USBCPPIDMACNTLR_RXGCR24 0x0B08
+#define USBCPPIDMACNTLR_RXHPCRA24 0x0B0C
+#define USBCPPIDMACNTLR_RXHPCRB24 0x0B10
+#define USBCPPIDMACNTLR_TXGCR25 0x0B20
+#define USBCPPIDMACNTLR_RXGCR25 0x0B28
+#define USBCPPIDMACNTLR_RXHPCRA25 0x0B2C
+#define USBCPPIDMACNTLR_RXHPCRB25 0x0B30
+#define USBCPPIDMACNTLR_TXGCR26 0x0B40
+#define USBCPPIDMACNTLR_RXGCR26 0x0B48
+#define USBCPPIDMACNTLR_RXHPCRA26 0x0B4C
+#define USBCPPIDMACNTLR_RXHPCRB26 0x0B50
+#define USBCPPIDMACNTLR_TXGCR27 0x0B60
+#define USBCPPIDMACNTLR_RXGCR27 0x0B68
+#define USBCPPIDMACNTLR_RXHPCRA27 0x0B6C
+#define USBCPPIDMACNTLR_RXHPCRB27 0x0B70
+#define USBCPPIDMACNTLR_TXGCR28 0x0B80
+#define USBCPPIDMACNTLR_RXGCR28 0x0B88
+#define USBCPPIDMACNTLR_RXHPCRA28 0x0B8C
+#define USBCPPIDMACNTLR_RXHPCRB28 0x0B90
+#define USBCPPIDMACNTLR_TXGCR29 0x0BA0
+#define USBCPPIDMACNTLR_RXGCR29 0x0BA8
+#define USBCPPIDMACNTLR_RXHPCRA29 0x0BAC
+#define USBCPPIDMACNTLR_RXHPCRB29 0x0BB0
+/* USB CPPI DMA Scheduler Registers offset */
+#define USBCPPIDMASCHED_BASE_REG_OFFSET 0x3000
+#define USBCPPIDMASCHED_CNTL 0x0000
+/* USB Queue Manager Registers offset */
+#define USBQUEUEMNGER_BASEREG_OFFSET 0x4000
+#define USBQUEUEMNGER_QMGRREVID 0x0000
+#define USBQUEUEMNGER_QMGRRST 0x0008
+#define USBQUEUEMNGER_FDNSCO 0x0020
+#define USBQUEUEMNGER_FDNSC1 0x0024
+#define USBQUEUEMNGER_FDNSC2 0x0028
+#define USBQUEUEMNGER_FDNSC3 0x002C
+#define USBQUEUEMNGER_FDNSC4 0x0030
+#define USBQUEUEMNGER_FDNSC5 0x0034
+#define USBQUEUEMNGER_FDNSC6 0x0038
+#define USBQUEUEMNGER_FDNSC7 0x003C
+#define USBQUEUEMNGER_LRAM0BASE 0x0080
+#define USBQUEUEMNGER_LRAM0SIZE 0x0084
+#define USBQUEUEMNGER_LRAM1BASE 0x0088
+#define USBQUEUEMNGER_PEND0 0x0090
+#define USBQUEUEMNGER_PEND1 0x0094
+#define USBQUEUEMNGER_PEND2 0x0098
+#define USBQUEUEMNGER_PEND3 0x009C
+#define USBQUEUEMNGER_PEND4 0x00A0
+#define USBQUEUEMNGER_QMEMRBASE0 0x1000
+#define USBQUEUEMNGER_QMEMCNTL0 0x1004
+#define USBQUEUEMNGER_QMEMRBASE1 0x1010
+#define USBQUEUEMNGER_QMEMCNTL1 0x1014
+#define USBQUEUEMNGER_QMEMRBASE2 0x1020
+#define USBQUEUEMNGER_QMEMCNTL2 0x1024
+#define USBQUEUEMNGER_QMEMRBASE3 0x1030
+#define USBQUEUEMNGER_QMEMCNTL3 0x1034
+#define USBQUEUEMNGER_QMEMRBASE4 0x1040
+#define USBQUEUEMNGER_QMEMCNTL4 0x1044
+#define USBQUEUEMNGER_QMEMRBASE5 0x1050
+#define USBQUEUEMNGER_QMEMCNTL5 0x1054
+#define USBQUEUEMNGER_QMEMRBASE6 0x1060
+#define USBQUEUEMNGER_QMEMCNTL6 0x1064
+#define USBQUEUEMNGER_QMEMRBASE7 0x1070
+#define USBQUEUEMNGER_QMEMCNTL7 0x1074
+ * 3530 specific Section
+/* Stuff on L3 Interconnect */
+#define SMX_APE_BASE 0x68000000
+/* L3 Firewall */
+#define A_REQINFOPERM0 (SMX_APE_BASE + 0x05048)
+#define A_READPERM0 (SMX_APE_BASE + 0x05050)
+#define A_WRITEPERM0 (SMX_APE_BASE + 0x05058)
+/* GPMC */
+#define OMAP35XX_GPMC_BASE 0x6E000000
+/* SMS */
+#define OMAP35XX_SMS_BASE 0x6C000000
+/* SDRC */
+#define OMAP35XX_SDRC_BASE 0x6D000000
+ * L4 Peripherals - L4 Wakeup and L4 Core now
+#define OMAP35XX_CORE_L4_IO_BASE 0x48000000
+#define OMAP35XX_WAKEUP_L4_IO_BASE 0x48300000
+#define OMAP35XX_L4_PER 0x49000000
+#define OMAP35XX_L4_IO_BASE OMAP35XX_CORE_L4_IO_BASE
+/* TAP information dont know for 3430*/
+#define OMAP35XX_TAP_BASE (0x49000000) /*giving some junk for virtio */
+/* base address for indirect vectors (internal boot mode) */
+#define SRAM_OFFSET0 0x40000000
+#define SRAM_OFFSET1 0x00200000
+#define SRAM_OFFSET2 0x0000F800
+#define SRAM_VECT_CODE (SRAM_OFFSET0|SRAM_OFFSET1|SRAM_OFFSET2)
+#define LOW_LEVEL_SRAM_STACK 0x4020FFFC
+/* UART */
+#define OMAP35XX_UART1 (OMAP35XX_L4_IO_BASE+0x6A000)
+#define OMAP35XX_UART2 (OMAP35XX_L4_IO_BASE+0x6C000)
+#define OMAP35XX_UART3 (OMAP35XX_L4_PER+0x20000)
+#define UART1_REG(_x_) *(vulong *)(OMAP35XX_UART1 + _x_)
+#define UART2_REG(_x_) *(vulong *)(OMAP35XX_UART2 + _x_)
+#define UART3_REG(_x_) *(vulong *)(OMAP35XX_UART3 + _x_)
+/* UART Register offsets */
+#define UART_RHR 0x00 // Receive Holding Register (read only)
+#define UART_THR 0x00 // Transmit Holding Register (write only)
+#define UART_DLL 0x00 // Baud divisor lower byte (read/write)
+#define UART_DLH 0x04 // Baud divisor higher byte (read/write)
+#define UART_IER 0x04 // Interrupt Enable Register (read/write)
+#define UART_IIR 0x08 // Interrupt Identification Register (read only)
+#define UART_FCR 0x08 // FIFO Control Register (write only)
+#define UART_EFR 0x08 // Enhanced Feature Register
+#define UART_LCR 0x0C // Line Control Register (read/write)
+#define UART_MCR 0x10 // Modem Control Register (read/write)
+#define UART_LSR 0x14 // Line Status Register (read only)
+#define UART_MSR 0x18 // Modem Status Register (read only)
+#define UART_TCR 0x18 //
+#define UART_TLR 0x1C //
+#define UART_SPR 0x1C // Scratch Pad Register (read/write)
+#define UART_MDR1 0x20 // Mode Definition Register 1
+#define UART_MDR2 0x24 // Mode Definition Register 2
+//#define UART_SFLSR 0x28 // Status FIFO Line Status Register (IrDA modes only)
+//#define UART_TXFLL 0x28 // Transmit Frame Length Register Low (IrDA
modes only)
+//#define UART_RESUME 0x2C // Resume Register (IR-IrDA and IR-CIR modes only)
+//#define UART_TXFLH 0x2C // Transmit Frame Length Register High
(IrDA modes only)
+//#define UART_RXFLL 0x30 // Receive Frame Length Register Low (IrDA
modes only)
+//#define UART_SFREGL 0x30 // Status FIFO Register Low (IrDA modes only)
+//#define UART_RXFLH 0x34 // Receive Frame Length Register High (IrDA
modes only)
+//#define UART_SFREGH 0x34 // Status FIFO Register High (IrDA modes only)
+//#define UART_BLR 0x38 // BOF Control Register (IrDA modes only)
+//#define UART_UASR 0x38 // UART Autobauding Status Register (UART
autobauding mode only)
+//#define UART_ACREG 0x3C // Auxiliary Control Register (IrDA-CIR modes only)
+#define UART_SCR 0x40 // Supplementary Control Register
+#define UART_SSR 0x44 // Supplementary Status Register
+//#define UART_EBLR 0x48 // BOF Length Register (IR-IrDA and IR-CIR modes only)
+#define UART_SYSC 0x54 // System Configuration Register
+#define UART_SYSS 0x58 // System Status Register
+#define UART_WER 0x5C // Wake-up Enable Register
+#define UART_CFPS 0x60 // Carrier Frequency Prescaler Register
+/* SPI - Serial Peripheral Interface */
+#define SPI1_BASE_ADD (OMAP35XX_L4_IO_BASE+0x98000) // routed to I/O
sites on CSB703
+#define SPI2_BASE_ADD (OMAP35XX_L4_IO_BASE+0x9A000)
+#define SPI3_BASE_ADD (OMAP35XX_L4_IO_BASE+0xB8000) // routed to
AD7843 touch controller on CSB703
+#define SPI4_BASE_ADD (OMAP35XX_L4_IO_BASE+0xBA000)
+#define SPI1_REG(_x_) *(vulong *)(SPI1_BASE_ADD + _x_)
+#define SPI2_REG(_x_) *(vulong *)(SPI2_BASE_ADD + _x_)
+#define SPI3_REG(_x_) *(vulong *)(SPI3_BASE_ADD + _x_)
+#define SPI4_REG(_x_) *(vulong *)(SPI4_BASE_ADD + _x_)
+// SPI Register Defines
+#define SPI_SYSCONFIG 0x10 // System Configuration Register
+#define SPI_SYSSTATUS 0x14 // System Status Register
+#define SPI_IRQSTATUS 0x18 // Interrupt Status Register
+#define SPI_IRQENABLE 0x1C // Interrupt Enable/Disable Register
+#define SPI_WAKEUPENABLE 0x20 // WakeUp Enable/Disable Register
+#define SPI_SYST 0x24 // System Test Register
+#define SPI_MODULCTRL 0x28 // Serial Port Interface Configuration Register
+#define SPI_CH0_CONF 0x2C // Channel 0 Configuration Register
+#define SPI_CH1_CONF 0x40 // Channel 1 Configuration Register
+#define SPI_CH2_CONF 0x54 // Channel 2 Configuration Register
+#define SPI_CH3_CONF 0x68 // Channel 3 Configuration Register
+#define SPI_CH0_STAT 0x30 // Channel 0 Status Register
+#define SPI_CH1_STAT 0x44 // Channel 1 Status Register
+#define SPI_CH2_STAT 0x58 // Channel 2 Status Register
+#define SPI_CH3_STAT 0x6C // Channel 3 Status Register
+#define SPI_CH0_CTRL 0x34 // Channel 0 Control Register
+#define SPI_CH1_CTRL 0x48 // Channel 1 ControlRegister
+#define SPI_CH2_CTRL 0x5C // Channel 2 ControlRegister
+#define SPI_CH3_CTRL 0x70 // Channel 3 ControlRegister
+#define SPI_TXD0 0x38 // Channel 0 Transmit Data Register
+#define SPI_TXD1 0x4C // Channel 1 Transmit Data Register
+#define SPI_TXD2 0x60 // Channel 2 Transmit Data Register
+#define SPI_TXD3 0x74 // Channel 3 Transmit Data Register
+#define SPI_RXD0 0x3C // Channel 0 Receive Data Register
+#define SPI_RXD1 0x50 // Channel 1 Receive Data Register
+#define SPI_RXD2 0x64 // Channel 2 Receive Data Register
+#define SPI_RXD3 0x78 // Channel 3 Receive Data Register
+#define SPI_XFERLEVEL 0x7C // FIFO Transfer Levels Register
+// SPI Channel x Configuration Bit Defines
+#define SPI_CH_CONF_CLKG BIT29 // 1 = One clock cycle granularity
+#define SPI_CH_CONF_FFER BIT28 // 1 = FIFO buffer is used to Receive data
+#define SPI_CH_CONF_FFEW BIT27 // 1 = FIFO buffer is used to Transmit data
+#define SPI_CH_CONF_TCS_0_5 (0x00 << 25) // 0.5 clock cycles between
CS toggling and first (or last) edge of SPI clock
+#define SPI_CH_CONF_TCS_1_5 (0x01 << 25) // 1.5 clock cycles between
+#define SPI_CH_CONF_TCS_2_5 (0x02 << 25) // 2.5 clock cycles between
+#define SPI_CH_CONF_TCS_3_5 (0x03 << 25) // 3.5 clock cycles between
+#define SPI_CH_CONF_SB_POL BIT24 // 1 = Start bit polarity is held to
1 during SPI transfer
+#define SPI_CH_CONF_SBE BIT23 // 1 = Start bit added before SPI
transfer, 0 = default length specified by WL
+#define SPI_CH_CONF_SPIENSLV_0 (0x00 << 21) // Slave select detection
enabled on CS0
+#define SPI_CH_CONF_SPIENSLV_1 (0x01 << 21) // Slave select detection
enabled on CS1
+#define SPI_CH_CONF_SPIENSLV_2 (0x02 << 21) // Slave select detection
enabled on CS2
+#define SPI_CH_CONF_SPIENSLV_3 (0x03 << 21) // Slave select detection
enabled on CS3
+#define SPI_CH_CONF_FORCE BIT20 // 1 = CSx high when EPOL is 0 and
low when EPOL is 1
+#define SPI_CH_CONF_TURBO BIT19 // 1 = Turbo is activated
+#define SPI_CH_CONF_IS BIT18 // 1 = spim_simo selected for reception,
0 = spim_somi selected for reception
+#define SPI_CH_CONF_DPE1 BIT17 // 1 = no transmission on spim_simo, 0
= spim_simo selected for transmission
+#define SPI_CH_CONF_DPE0 BIT16 // 1 = no transmission on spim_somi, 0
= spim_somi selected for transmission
+#define SPI_CH_CONF_DMAR BIT15 // 1 = DMA read request enabled
+#define SPI_CH_CONF_DMAW BIT14 // 1 = DMA write request enabled
+#define SPI_CH_CONF_TRM_TR (0x00 << 12) // Transmit and receive mode
+#define SPI_CH_CONF_TRM_RO (0x01 << 12) // Receive-only mode
+#define SPI_CH_CONF_TRM_TO (0x02 << 12) // Transmit-only mode
+#define SPI_CH_CONF_WL(_x_) ((_x_ & 0x1f) << 7) // SPI word length, 0x7 = 8-bit
+#define SPI_CH_CONF_EPOL BIT6 // 1 = SPIM_CSx is low during active
state, 0 = high during active state
+#define SPI_CH_CONF_CLKD(_x_) ((_x_ & 0xf) << 2) // Frequency divider
for spim_clk
+#define SPI_CH_CONF_POL BIT1 // 1 = spim_clk is low during active
+#define SPI_CH_CONF_PHA BIT0 // 1 = data latched on even-numbered
edges, 0 = data latched on odd-numbered edges
+// SPI Interrupt Status Register Bit Defines
+#define SPI_RX3_FULL BIT14 //
+#define SPI_TX3_EMPTY BIT12 //
+#define SPI_RX2_FULL BIT10 //
+#define SPI_TX2_EMPTY BIT8 //
+#define SPI_RX1_FULL BIT14 //
+#define SPI_TX1_EMPTY BIT6 //
+#define SPI_RX0_FULL BIT2 //
+#define SPI_TX0_EMPTY BIT0 //
+// SPI Channel Status Register Bit Defines
+#define SPI_RXF_FULL BIT6 //
+#define SPI_RXF_EMPTY BIT5 //
+#define SPI_TXF_FULL BIT4 //
+#define SPI_TXF_EMPTY BIT3 //
+#define SPI_CH_EOT BIT2 //
+#define SPI_CH_TX0_EMPTY BIT1 //
+#define SPI_CH_RX0_FULL BIT0 //
+/* General Purpose Timers */
+#define OMAP35XX_GPT1 0x48318000
+#define OMAP35XX_GPT2 0x49032000
+#define OMAP35XX_GPT3 0x49034000
+#define OMAP35XX_GPT4 0x49036000
+#define OMAP35XX_GPT5 0x49038000
+#define OMAP35XX_GPT6 0x4903A000
+#define OMAP35XX_GPT7 0x4903C000
+#define OMAP35XX_GPT8 0x4903E000
+#define OMAP35XX_GPT9 0x49040000
+#define OMAP35XX_GPT10 0x48086000
+#define OMAP35XX_GPT11 0x48088000
+#define OMAP35XX_GPT12 0x48304000
+/* General Purpose I/O */
+#define GPIO1_BASE_ADD 0x48310000
+#define GPIO2_BASE_ADD 0x49050000
+#define GPIO3_BASE_ADD 0x49052000
+#define GPIO4_BASE_ADD 0x49054000
+#define GPIO5_BASE_ADD 0x49056000
+#define GPIO6_BASE_ADD 0x49058000
+#define GPIO1_REG(_x_) *(vulong *)(GPIO1_BASE_ADD + _x_)
+#define GPIO2_REG(_x_) *(vulong *)(GPIO2_BASE_ADD + _x_)
+#define GPIO3_REG(_x_) *(vulong *)(GPIO3_BASE_ADD + _x_)
+#define GPIO4_REG(_x_) *(vulong *)(GPIO4_BASE_ADD + _x_)
+#define GPIO5_REG(_x_) *(vulong *)(GPIO5_BASE_ADD + _x_)
+#define GPIO6_REG(_x_) *(vulong *)(GPIO6_BASE_ADD + _x_)
+/* GPIO Register offsets */
+#define GPIO_SYSCONFIG 0x10 //
+#define GPIO_SYSSTATUS 0x14 //
+#define GPIO_CTRL 0x30 //
+#define GPIO_OE 0x34 //
+#define GPIO_DATAIN 0x38 //
+#define GPIO_DATAOUT 0x3C //
+#define GPIO_CLEARDATAOUT 0x90 //
+#define GPIO_SETDATAOUT 0x94 //
+/* WatchDog Timers (1 secure, 3 GP) */
+#define WD1_BASE_ADD 0x4830C000
+#define WD2_BASE_ADD 0x48314000
+#define WD3_BASE_ADD 0x49030000
+#define WD1_REG(_x_) *(vulong *)(WD1_BASE_ADD + _x_)
+#define WD2_REG(_x_) *(vulong *)(WD2_BASE_ADD + _x_)
+#define WD3_REG(_x_) *(vulong *)(WD3_BASE_ADD + _x_)
+/* WatchDog Timer Register offsets */
+#define WD_CONFIG 0x10 // System Configuration Register
+#define WD_STATUS 0x14 // System Configuration Register
+#define WD_WISR 0x18 // System Configuration Register
+#define WD_WIER 0x1C // System Configuration Register
+#define WD_WCLR 0x24 // System Configuration Register
+#define WD_WCRR 0x28 // System Configuration Register
+#define WD_WLDR 0x2C // System Configuration Register
+#define WD_WTGR 0x30 // System Configuration Register
+#define WD_WWPS 0x34 // System Configuration Register
+#define WD_WSPR 0x48 // System Configuration Register
+/* 32KTIMER */
+#define SYNC_32KTIMER_BASE (0x48320000)
+#define S32K_CR (SYNC_32KTIMER_BASE+0x10)
+/* System Control Module */
+/* Module Name Base Address Size */
+ INTERFACE 0x48002000 36 bytes
+ PADCONFS 0x48002030 564 bytes
+ GENERAL 0x48002270 767 bytes
+ MEM_WKUP 0x48002600 1K byte
+ PADCONFS_WKU 0x48002A00 80 bytes
+ GENERAL_WKUP 0x48002A60 31 bytes
+#define OMAP35XX_CTRL_BASE (OMAP35XX_L4_IO_BASE+0x2000)
+#define SCM_REG(_x_) *(vulong *)(OMAP35XX_CTRL_BASE + _x_)
+/* Pad Configuration Registers */
+/* Note: Cogent is only defining the PADCONFS registers that are used
in Micromonitor */
+#define PADCONFS_GPMC_NCS3 0xB4 // NCS3[15:0], NCS4[31:16]
+#define PADCONFS_GPMC_NCS5 0xB8 // NCS5[15:0], EXP_INTX[31:16]
+#define PADCONFS_GPMC_NCS7 0xBC // LCD_BKL_X[15:0], LCLK[31:16]
+#define PADCONFS_GPMC_NADV_ALE 0xC0 // NADV_ALE[15:0], NOE[31:16]
+#define PADCONFS_GPMC_NWE 0xC4 // NWE[15:0], NBE0_CLE[31:16]
+#define PADCONFS_DSS_PCLK 0xD4 // LCD_PCLK_X[15:0], LCD_HS_X[31:16]
+#define PADCONFS_DSS_VSYNC 0xD8 // LCD_VS_X[15:0], LCD_OE_X[31:16]
+#define PADCONFS_DSS_DATA0 0xDC // LCD_B0_X[15:0], LCD_B1_X[31:16]
+#define PADCONFS_DSS_DATA2 0xE0 // LCD_B2_X[15:0], LCD_B3_X[31:16]
+#define PADCONFS_DSS_DATA4 0xE4 // LCD_B4_X[15:0], LCD_B5_X[31:16]
+#define PADCONFS_DSS_DATA6 0xE8 // LCD_G0_X[15:0], LCD_G1_X[31:16]
+#define PADCONFS_DSS_DATA8 0xEC // LCD_G2_X[15:0], LCD_G3_X[31:16]
+#define PADCONFS_DSS_DATA10 0xF0 // LCD_G4_X[15:0], LCD_G5_X[31:16]
+#define PADCONFS_DSS_DATA12 0xF4 // LCD_R0_X[15:0], LCD_R1_X[31:16]
+#define PADCONFS_DSS_DATA14 0xF8 // LCD_R2_X[15:0], LCD_R3_X[31:16]
+#define PADCONFS_DSS_DATA16 0xFC // LCD_R4_X[15:0], LCD_R5_X[31:16]
+#define PADCONFS_DSS_DATA18 0x100 // SPI1_CLK_X[15:0], SPI1_MOSI_X[31:16]
+#define PADCONFS_DSS_DATA20 0x104 // SPI1_MISO_X[15:0], *SPI1_CS0_X[31:16]
+#define PADCONFS_DSS_DATA22 0x108 // GPIO7_X[15:0], NC[31:16]
+#define PADCONFS_MMC1_DAT4 0x150 // *I2C_INT_X[15:0], *PIRQ_X[31:16]
+#define PADCONFS_MMC1_DAT6 0x154 // GPIO0_X[15:0], GPIO1_X[31:16]
+#define PADCONFS_MCBSP3_CLKX 0x170 // D_TXD[15:0], D_RXD[31:16]
+#define PADCONFS_SYS_NIRQ 0x1E0 // FIQ[15:0], SYS_CLK2[31:16]
+#define PADCONFS_SYS_OFF_MODE 0xA18 // OFF_MODE_X[15:0], USB_CLK[31:16]
+#define PADCONFS_GPMC_WAIT2 0xD0 // NA[15:0], E_INTX[31:16]
+#define PADCONFS_MMC1_CLK 0x144 // MMC1_CLK[15:0], MMC1_CMD[31:16]
+#define PADCONFS_MMC1_DAT0 0x148 // MMC1_DAT0[15:0], MMC1_DAT1[31:16]
+#define PADCONFS_MMC1_DAT2 0x14C // MMC1_DAT2[15:0], MMC1_DAT3[31:16]
+#define CM_REV_REG 0x48004800
+#define PRM_REV_REG 0x48306804
+#define CM_REV_MAJ() ((*(volatile unsigned long *)CM_REV_REG & 0xf0)>>4)
+#define CM_REV_MIN() (*(volatile unsigned long *)CM_REV_REG & 0x0f)
+#define PRM_REV_MAJ() ((*(volatile unsigned long *)PRM_REV_REG & 0xf0)>>4)
+#define PRM_REV_MIN() (*(volatile unsigned long *)PRM_REV_REG & 0x0f)
+/* MMC registers...
+#define CM_FCLKEN1_CORE 0x48004a00
+#define CM_ICLKEN1_CORE 0x48004a10
+#define CM_IDLEST1_CORE 0x48004a20
+#define CM_AUTOIDLE1_CORE 0x48004a30
+#define PM_WKEN1_CORE 0x48306aa0
+#define PM_MPUGRPSEL1_CORE 0x48306aa4
+#define PM_IVA2GRPSEL1_CORE 0x48306aa8
+#define PM_WKST1_CORE 0x48306ab0
+#define CONTROL_DEVCONF0 0x48002274
+#define MMC1_BASE_ADD 0x4809c000
+#define MMC2_BASE_ADD 0x480ad000
+#define MMC3_BASE_ADD 0x480b4000
+#define MMC1_REG(_x_) *(vulong *)(MMC1_BASE_ADD + _x_)
+#define MMC2_REG(_x_) *(vulong *)(MMC2_BASE_ADD + _x_)
+#define MMC3_REG(_x_) *(vulong *)(MMC3_BASE_ADD + _x_)
+#define MMCHS_SYSCONFIG 0x10
+#define MMCHS_SYSSTATUS 0x14
+#define MMCHS_CSRE 0x24
+#define MMCHS_SYSTEST 0x28
+#define MMCHS_CON 0x2C
+#define MMCHS_PWCNT 0x30
+#define MMCHS_BLK 0x104
+#define MMCHS_ARG 0x108
+#define MMCHS_CMD 0x10C
+#define MMCHS_RSP10 0x110
+#define MMCHS_RSP32 0x114
+#define MMCHS_RSP54 0x118
+#define MMCHS_RSP76 0x11C
+#define MMCHS_DATA 0x120
+#define MMCHS_PSTATE 0x124
+#define MMCHS_HCTL 0x128
+#define MMCHS_SYSCTL 0x12C
+#define MMCHS_STAT 0x130
+#define MMCHS_IE 0x134
+#define MMCHS_ISE 0x138
+#define MMCHS_AC12 0x13C
+#define MMCHS_CAPA 0x140
+#define MMCHS_CUR_CAPA 0x148
+#define MMCHS_REV 0x1FC
+/* Miscellaneous MMC register bits...
+ * (only specified the ones I use)
+#define EN_MMC1 (1 << 24)
+#define ST_MMC1 (1 << 24)
+#define AUTO_MMC1 (1 << 24)
+#define GRPSEL_MMC1 (1 << 24)
+#define VS18 0x04000000
+#define VS30 0x02000000
+#define VS33 0x01000000
+#define MMCINIT 0x00000002
+#define ODE 0x00000001
+#define SVDS 0x00000e00
+#define SVDS18 (5 << 9)
+#define SVDS30 (6 << 9)
+#define SVDS33 (7 << 9)
+#define SDBP 0x00000100
+#define ICE 0x00000001
+#define ICS 0x00000002
+#define CEN 0x00000004
+#define CLKD(v) ((v & 0x3ff) << 6)
+#define CLKDMSK (0x3ff << 6)
+#define CLKACTIVITYMSK (3 << 8)
+#define CLKACTIVITY(n) ((n & 3) << 8)
+#define SIDLEMODEMSK (3 << 3)
+#define SIDLEMODE(n) ((n & 3) << 3)
+#define ENWAKEUP (1 << 2)
+#define IWE (1 << 24)
+#define AUTOIDLE 1
+#define CLKEXTFREE (1 << 16)
+#define SRESET 0x00000002
+#define CC 0x00000001
+#define RESETDONE 0x00000001
+#define IE_ALL 0x317f8337
+#define CDP (1 << 7)
+#define CMD(v) ((v & 0x3f) << 24)
+#define CMDMSK (0x3f << 24)
+#define CMDI 0x00000001
+#define DEBOUNCE (3 << 16)
+#define CCRC (1 << 17)
+#define DCRC (1 << 21)
+#define CERR (1 << 28)
+#define CTO (1 << 16)
+#define DP (1 << 21)
+#define RSPTYPE_NONE 0x00000000
+#define RSPTYPE_136 0x00010000
+#define RSPTYPE_48 0x00020000
+#define RSPTYPE_48BSY 0x00030000
+#define RSPTYPE 0x00030000
+#define SRD (1 << 26)
+#define SRC (1 << 25)
+#define SRA (1 << 24)
+#define DTOMSK (0xf<<16)
+#define DTO(a) ((a&0xf) << 16)
+#define NBLK(a) ((a&0xffff) << 16)
+#define BLEN(a) (a&0x7ff)
+#define MMCSDIO1ADPCLKISEL (1 << 24)
+/* PBIAS...
+#define CONTROL_PBIAS_LITE 0x48002520
+#define PBIAS_LITE_VMMC1_3V (0x0101)
+#define MMC_PWR_STABLE (0x0202)
+#define PBIAS_LITE_VMMC1_52MHZ (0x0404)
+#define PBIAS_LITE_MMC1_ERROR (0x0808)
+#define PBIAS_LITE_MMC1_HIGH (0x8080)
+/* Control status...
+#define CONTROL_STATUS 0x480022f0
+#define SYSBOOT 0x3f
+#define DEVICETYPE (0x3 << 8)
+/* 16 bit access CONTROL */
+#define MUX_VAL(OFFSET,VALUE)\
+ *(unsigned short *) (OMAP35XX_CTRL_BASE + (OFFSET)) = VALUE;
+#define CP(x) (CONTROL_PADCONF_##x)
+#define CONTROL_PADCONF_DSS_DATA18 0x0100
+#define CONTROL_PADCONF_DSS_DATA19 0x0102
+#define CONTROL_PADCONF_DSS_DATA20 0x0104
+#define CONTROL_PADCONF_DSS_DATA21 0x0106
+#define CONTROL_PADCONF_MMC1_CLK 0x0144
+#define CONTROL_PADCONF_MMC1_CMD 0x0146
+#define CONTROL_PADCONF_MMC1_DAT0 0x0148
+#define CONTROL_PADCONF_MMC1_DAT1 0x014A
+#define CONTROL_PADCONF_MMC1_DAT2 0x014C
+#define CONTROL_PADCONF_MMC1_DAT3 0x014E
+#define CONTROL_PADCONF_HSUSB0_CLK 0x01A2
+#define CONTROL_PADCONF_HSUSB0_STP 0x01A4
+#define CONTROL_PADCONF_HSUSB0_DIR 0x01A6
+#define CONTROL_PADCONF_HSUSB0_NXT 0x01A8
+#define CONTROL_PADCONF_HSUSB0_DATA0 0x01AA
+#define CONTROL_PADCONF_HSUSB0_DATA1 0x01AC
+#define CONTROL_PADCONF_HSUSB0_DATA2 0x01AE
+#define CONTROL_PADCONF_HSUSB0_DATA3 0x01B0
+#define CONTROL_PADCONF_HSUSB0_DATA4 0x01B2
+#define CONTROL_PADCONF_HSUSB0_DATA5 0x01B4
+#define CONTROL_PADCONF_HSUSB0_DATA6 0x01B6
+#define CONTROL_PADCONF_HSUSB0_DATA7 0x01B8
+#define CONTROL_PADCONF_I2C1_SCL 0x01BA
+#define CONTROL_PADCONF_I2C1_SDA 0x01BC
+#define CONTROL_PADCONF_McBSP3_DX 0x016C
+/* bits used in control reg's above
+ * IEN - Input Enable
+ * IDIS - Input Disable
+ * PTD - Pull type Down
+ * PTU - Pull type Up
+ * DIS - Pull type selection is inactive
+ * EN - Pull type selection is active
+ * M0 - Mode 0
+#define IEN (1 << 8)
+#define IDIS (0 << 8)
+#define PTU (1 << 4)
+#define PTD (0 << 4)
+#define EN (1 << 3)
+#define DIS (0 << 3)
+#define M0 0 /* modes */
+#define M1 1
+#define M2 2
+#define M3 3
+#define M4 4
+#define M5 5
+#define M6 6
+#define M7 7
diff --git a/ports/beagleboneblack/beagleboneblack.h
b/ports/beagleboneblack/beagleboneblack.h
deleted file mode 100644
index f6ba5b9..0000000
--- a/ports/beagleboneblack/beagleboneblack.h
+++ /dev/null
@@ -1,498 +0,0 @@
-// beagleboneblack.h
-// Author(s): Luis Torrico, Cogent Computer Systems, Inc.
-// Contributors: Jarielle Catbagan
-// Date: 05/02/2008
-// Description: This file was modified from omap3530.h. This file containes
-// register base addresses and offsets as well as access macros
-// for the AM335x/Beaglebone Black on-chip peripherals.
-// Peripherals not used by UMON have not been tested (and
-// may not be defined). Use these defines with caution!!
-#include "bits.h"
- * 3530 specific Section
-/* Stuff on L3 Interconnect */
-#define SMX_APE_BASE 0x68000000
-/* L3 Firewall */
-#define A_REQINFOPERM0 (SMX_APE_BASE + 0x05048)
-#define A_READPERM0 (SMX_APE_BASE + 0x05050)
-#define A_WRITEPERM0 (SMX_APE_BASE + 0x05058)
-/* GPMC */
-#define OMAP35XX_GPMC_BASE 0x6E000000
-/* SMS */
-#define OMAP35XX_SMS_BASE 0x6C000000
-/* SDRC */
-#define OMAP35XX_SDRC_BASE 0x6D000000
- * L4 Peripherals - L4 Wakeup and L4 Core now
-#define OMAP35XX_CORE_L4_IO_BASE 0x48000000
-#define OMAP35XX_WAKEUP_L4_IO_BASE 0x48300000
-#define OMAP35XX_L4_PER 0x49000000
-#define OMAP35XX_L4_IO_BASE OMAP35XX_CORE_L4_IO_BASE
-/* TAP information dont know for 3430*/
-#define OMAP35XX_TAP_BASE (0x49000000) /*giving some junk for virtio */
-/* base address for indirect vectors (internal boot mode) */
-#define SRAM_OFFSET0 0x40000000
-#define SRAM_OFFSET1 0x00200000
-#define SRAM_OFFSET2 0x0000F800
-#define SRAM_VECT_CODE (SRAM_OFFSET0|SRAM_OFFSET1|SRAM_OFFSET2)
-#define LOW_LEVEL_SRAM_STACK 0x4020FFFC
-/* UART */
-#define OMAP35XX_UART1 (OMAP35XX_L4_IO_BASE+0x6A000)
-#define OMAP35XX_UART2 (OMAP35XX_L4_IO_BASE+0x6C000)
-#define OMAP35XX_UART3 (OMAP35XX_L4_PER+0x20000)
-#define UART1_REG(_x_) *(vulong *)(OMAP35XX_UART1 + _x_)
-#define UART2_REG(_x_) *(vulong *)(OMAP35XX_UART2 + _x_)
-#define UART3_REG(_x_) *(vulong *)(OMAP35XX_UART3 + _x_)
-/* UART Register offsets */
-#define UART_RHR 0x00 // Receive Holding Register (read only)
-#define UART_THR 0x00 // Transmit Holding Register (write only)
-#define UART_DLL 0x00 // Baud divisor lower byte (read/write)
-#define UART_DLH 0x04 // Baud divisor higher byte (read/write)
-#define UART_IER 0x04 // Interrupt Enable Register (read/write)
-#define UART_IIR 0x08 // Interrupt Identification Register (read only)
-#define UART_FCR 0x08 // FIFO Control Register (write only)
-#define UART_EFR 0x08 // Enhanced Feature Register
-#define UART_LCR 0x0C // Line Control Register (read/write)
-#define UART_MCR 0x10 // Modem Control Register (read/write)
-#define UART_LSR 0x14 // Line Status Register (read only)
-#define UART_MSR 0x18 // Modem Status Register (read only)
-#define UART_TCR 0x18 //
-#define UART_TLR 0x1C //
-#define UART_SPR 0x1C // Scratch Pad Register (read/write)
-#define UART_MDR1 0x20 // Mode Definition Register 1
-#define UART_MDR2 0x24 // Mode Definition Register 2
-//#define UART_SFLSR 0x28 // Status FIFO Line Status Register (IrDA modes only)
-//#define UART_TXFLL 0x28 // Transmit Frame Length Register Low (IrDA
modes only)
-//#define UART_RESUME 0x2C // Resume Register (IR-IrDA and IR-CIR modes only)
-//#define UART_TXFLH 0x2C // Transmit Frame Length Register High
(IrDA modes only)
-//#define UART_RXFLL 0x30 // Receive Frame Length Register Low (IrDA
modes only)
-//#define UART_SFREGL 0x30 // Status FIFO Register Low (IrDA modes only)
-//#define UART_RXFLH 0x34 // Receive Frame Length Register High (IrDA
modes only)
-//#define UART_SFREGH 0x34 // Status FIFO Register High (IrDA modes only)
-//#define UART_BLR 0x38 // BOF Control Register (IrDA modes only)
-//#define UART_UASR 0x38 // UART Autobauding Status Register (UART
-//#define UART_ACREG 0x3C // Auxiliary Control Register (IrDA-CIR modes only)
-#define UART_SCR 0x40 // Supplementary Control Register
-#define UART_SSR 0x44 // Supplementary Status Register
-//#define UART_EBLR 0x48 // BOF Length Register (IR-IrDA and IR-CIR modes only)
-#define UART_SYSC 0x54 // System Configuration Register
-#define UART_SYSS 0x58 // System Status Register
-#define UART_WER 0x5C // Wake-up Enable Register
-#define UART_CFPS 0x60 // Carrier Frequency Prescaler Register
-/* SPI - Serial Peripheral Interface */
-#define SPI1_BASE_ADD (OMAP35XX_L4_IO_BASE+0x98000) // routed to I/O
sites on CSB703
-#define SPI2_BASE_ADD (OMAP35XX_L4_IO_BASE+0x9A000)
-#define SPI3_BASE_ADD (OMAP35XX_L4_IO_BASE+0xB8000) // routed to
-#define SPI4_BASE_ADD (OMAP35XX_L4_IO_BASE+0xBA000)
-#define SPI1_REG(_x_) *(vulong *)(SPI1_BASE_ADD + _x_)
-#define SPI2_REG(_x_) *(vulong *)(SPI2_BASE_ADD + _x_)
-#define SPI3_REG(_x_) *(vulong *)(SPI3_BASE_ADD + _x_)
-#define SPI4_REG(_x_) *(vulong *)(SPI4_BASE_ADD + _x_)
-// SPI Register Defines
-#define SPI_SYSCONFIG 0x10 // System Configuration Register
-#define SPI_SYSSTATUS 0x14 // System Status Register
-#define SPI_IRQSTATUS 0x18 // Interrupt Status Register
-#define SPI_IRQENABLE 0x1C // Interrupt Enable/Disable Register
-#define SPI_WAKEUPENABLE 0x20 // WakeUp Enable/Disable Register
-#define SPI_SYST 0x24 // System Test Register
-#define SPI_MODULCTRL 0x28 // Serial Port Interface Configuration Register
-#define SPI_CH0_CONF 0x2C // Channel 0 Configuration Register
-#define SPI_CH1_CONF 0x40 // Channel 1 Configuration Register
-#define SPI_CH2_CONF 0x54 // Channel 2 Configuration Register
-#define SPI_CH3_CONF 0x68 // Channel 3 Configuration Register
-#define SPI_CH0_STAT 0x30 // Channel 0 Status Register
-#define SPI_CH1_STAT 0x44 // Channel 1 Status Register
-#define SPI_CH2_STAT 0x58 // Channel 2 Status Register
-#define SPI_CH3_STAT 0x6C // Channel 3 Status Register
-#define SPI_CH0_CTRL 0x34 // Channel 0 Control Register
-#define SPI_CH1_CTRL 0x48 // Channel 1 ControlRegister
-#define SPI_CH2_CTRL 0x5C // Channel 2 ControlRegister
-#define SPI_CH3_CTRL 0x70 // Channel 3 ControlRegister
-#define SPI_TXD0 0x38 // Channel 0 Transmit Data Register
-#define SPI_TXD1 0x4C // Channel 1 Transmit Data Register
-#define SPI_TXD2 0x60 // Channel 2 Transmit Data Register
-#define SPI_TXD3 0x74 // Channel 3 Transmit Data Register
-#define SPI_RXD0 0x3C // Channel 0 Receive Data Register
-#define SPI_RXD1 0x50 // Channel 1 Receive Data Register
-#define SPI_RXD2 0x64 // Channel 2 Receive Data Register
-#define SPI_RXD3 0x78 // Channel 3 Receive Data Register
-#define SPI_XFERLEVEL 0x7C // FIFO Transfer Levels Register
-// SPI Channel x Configuration Bit Defines
-#define SPI_CH_CONF_CLKG BIT29 // 1 = One clock cycle granularity
-#define SPI_CH_CONF_FFER BIT28 // 1 = FIFO buffer is used to Receive data
-#define SPI_CH_CONF_FFEW BIT27 // 1 = FIFO buffer is used to Transmit data
-#define SPI_CH_CONF_TCS_0_5 (0x00 << 25) // 0.5 clock cycles between
-#define SPI_CH_CONF_TCS_1_5 (0x01 << 25) // 1.5 clock cycles between
-#define SPI_CH_CONF_TCS_2_5 (0x02 << 25) // 2.5 clock cycles between
-#define SPI_CH_CONF_TCS_3_5 (0x03 << 25) // 3.5 clock cycles between
-#define SPI_CH_CONF_SB_POL BIT24 // 1 = Start bit polarity is held to
-#define SPI_CH_CONF_SBE BIT23 // 1 = Start bit added before SPI
-#define SPI_CH_CONF_SPIENSLV_0 (0x00 << 21) // Slave select detection
enabled on CS0
-#define SPI_CH_CONF_SPIENSLV_1 (0x01 << 21) // Slave select detection
enabled on CS1
-#define SPI_CH_CONF_SPIENSLV_2 (0x02 << 21) // Slave select detection
enabled on CS2
-#define SPI_CH_CONF_SPIENSLV_3 (0x03 << 21) // Slave select detection
enabled on CS3
-#define SPI_CH_CONF_FORCE BIT20 // 1 = CSx high when EPOL is 0 and
low when EPOL is 1
-#define SPI_CH_CONF_TURBO BIT19 // 1 = Turbo is activated
-#define SPI_CH_CONF_IS BIT18 // 1 = spim_simo selected for reception,
-#define SPI_CH_CONF_DPE1 BIT17 // 1 = no transmission on spim_simo, 0
-#define SPI_CH_CONF_DPE0 BIT16 // 1 = no transmission on spim_somi, 0
-#define SPI_CH_CONF_DMAR BIT15 // 1 = DMA read request enabled
-#define SPI_CH_CONF_DMAW BIT14 // 1 = DMA write request enabled
-#define SPI_CH_CONF_TRM_TR (0x00 << 12) // Transmit and receive mode
-#define SPI_CH_CONF_TRM_RO (0x01 << 12) // Receive-only mode
-#define SPI_CH_CONF_TRM_TO (0x02 << 12) // Transmit-only mode
-#define SPI_CH_CONF_WL(_x_) ((_x_ & 0x1f) << 7) // SPI word length, 0x7 = 8-bit
-#define SPI_CH_CONF_EPOL BIT6 // 1 = SPIM_CSx is low during active
-#define SPI_CH_CONF_CLKD(_x_) ((_x_ & 0xf) << 2) // Frequency divider
for spim_clk
-#define SPI_CH_CONF_POL BIT1 // 1 = spim_clk is low during active
-#define SPI_CH_CONF_PHA BIT0 // 1 = data latched on even-numbered
-// SPI Interrupt Status Register Bit Defines
-#define SPI_RX3_FULL BIT14 //
-#define SPI_TX3_EMPTY BIT12 //
-#define SPI_RX2_FULL BIT10 //
-#define SPI_TX2_EMPTY BIT8 //
-#define SPI_RX1_FULL BIT14 //
-#define SPI_TX1_EMPTY BIT6 //
-#define SPI_RX0_FULL BIT2 //
-#define SPI_TX0_EMPTY BIT0 //
-// SPI Channel Status Register Bit Defines
-#define SPI_RXF_FULL BIT6 //
-#define SPI_RXF_EMPTY BIT5 //
-#define SPI_TXF_FULL BIT4 //
-#define SPI_TXF_EMPTY BIT3 //
-#define SPI_CH_EOT BIT2 //
-#define SPI_CH_TX0_EMPTY BIT1 //
-#define SPI_CH_RX0_FULL BIT0 //
-/* General Purpose Timers */
-#define OMAP35XX_GPT1 0x48318000
-#define OMAP35XX_GPT2 0x49032000
-#define OMAP35XX_GPT3 0x49034000
-#define OMAP35XX_GPT4 0x49036000
-#define OMAP35XX_GPT5 0x49038000
-#define OMAP35XX_GPT6 0x4903A000
-#define OMAP35XX_GPT7 0x4903C000
-#define OMAP35XX_GPT8 0x4903E000
-#define OMAP35XX_GPT9 0x49040000
-#define OMAP35XX_GPT10 0x48086000
-#define OMAP35XX_GPT11 0x48088000
-#define OMAP35XX_GPT12 0x48304000
-/* General Purpose I/O */
-#define GPIO1_BASE_ADD 0x48310000
-#define GPIO2_BASE_ADD 0x49050000
-#define GPIO3_BASE_ADD 0x49052000
-#define GPIO4_BASE_ADD 0x49054000
-#define GPIO5_BASE_ADD 0x49056000
-#define GPIO6_BASE_ADD 0x49058000
-#define GPIO1_REG(_x_) *(vulong *)(GPIO1_BASE_ADD + _x_)
-#define GPIO2_REG(_x_) *(vulong *)(GPIO2_BASE_ADD + _x_)
-#define GPIO3_REG(_x_) *(vulong *)(GPIO3_BASE_ADD + _x_)
-#define GPIO4_REG(_x_) *(vulong *)(GPIO4_BASE_ADD + _x_)
-#define GPIO5_REG(_x_) *(vulong *)(GPIO5_BASE_ADD + _x_)
-#define GPIO6_REG(_x_) *(vulong *)(GPIO6_BASE_ADD + _x_)
-/* GPIO Register offsets */
-#define GPIO_SYSCONFIG 0x10 //
-#define GPIO_SYSSTATUS 0x14 //
-#define GPIO_CTRL 0x30 //
-#define GPIO_OE 0x34 //
-#define GPIO_DATAIN 0x38 //
-#define GPIO_DATAOUT 0x3C //
-#define GPIO_CLEARDATAOUT 0x90 //
-#define GPIO_SETDATAOUT 0x94 //
-/* WatchDog Timers (1 secure, 3 GP) */
-#define WD1_BASE_ADD 0x4830C000
-#define WD2_BASE_ADD 0x48314000
-#define WD3_BASE_ADD 0x49030000
-#define WD1_REG(_x_) *(vulong *)(WD1_BASE_ADD + _x_)
-#define WD2_REG(_x_) *(vulong *)(WD2_BASE_ADD + _x_)
-#define WD3_REG(_x_) *(vulong *)(WD3_BASE_ADD + _x_)
-/* WatchDog Timer Register offsets */
-#define WD_CONFIG 0x10 // System Configuration Register
-#define WD_STATUS 0x14 // System Configuration Register
-#define WD_WISR 0x18 // System Configuration Register
-#define WD_WIER 0x1C // System Configuration Register
-#define WD_WCLR 0x24 // System Configuration Register
-#define WD_WCRR 0x28 // System Configuration Register
-#define WD_WLDR 0x2C // System Configuration Register
-#define WD_WTGR 0x30 // System Configuration Register
-#define WD_WWPS 0x34 // System Configuration Register
-#define WD_WSPR 0x48 // System Configuration Register
-/* 32KTIMER */
-#define SYNC_32KTIMER_BASE (0x48320000)
-#define S32K_CR (SYNC_32KTIMER_BASE+0x10)
-/* System Control Module */
-/* Module Name Base Address Size */
- INTERFACE 0x48002000 36 bytes
- PADCONFS 0x48002030 564 bytes
- GENERAL 0x48002270 767 bytes
- MEM_WKUP 0x48002600 1K byte
- PADCONFS_WKU 0x48002A00 80 bytes
- GENERAL_WKUP 0x48002A60 31 bytes
-#define OMAP35XX_CTRL_BASE (OMAP35XX_L4_IO_BASE+0x2000)
-#define SCM_REG(_x_) *(vulong *)(OMAP35XX_CTRL_BASE + _x_)
-/* Pad Configuration Registers */
-/* Note: Cogent is only defining the PADCONFS registers that are used
in Micromonitor */
-#define PADCONFS_GPMC_NCS3 0xB4 // NCS3[15:0], NCS4[31:16]
-#define PADCONFS_GPMC_NCS5 0xB8 // NCS5[15:0], EXP_INTX[31:16]
-#define PADCONFS_GPMC_NCS7 0xBC // LCD_BKL_X[15:0], LCLK[31:16]
-#define PADCONFS_GPMC_NADV_ALE 0xC0 // NADV_ALE[15:0], NOE[31:16]
-#define PADCONFS_GPMC_NWE 0xC4 // NWE[15:0], NBE0_CLE[31:16]
-#define PADCONFS_DSS_PCLK 0xD4 // LCD_PCLK_X[15:0], LCD_HS_X[31:16]
-#define PADCONFS_DSS_VSYNC 0xD8 // LCD_VS_X[15:0], LCD_OE_X[31:16]
-#define PADCONFS_DSS_DATA0 0xDC // LCD_B0_X[15:0], LCD_B1_X[31:16]
-#define PADCONFS_DSS_DATA2 0xE0 // LCD_B2_X[15:0], LCD_B3_X[31:16]
-#define PADCONFS_DSS_DATA4 0xE4 // LCD_B4_X[15:0], LCD_B5_X[31:16]
-#define PADCONFS_DSS_DATA6 0xE8 // LCD_G0_X[15:0], LCD_G1_X[31:16]
-#define PADCONFS_DSS_DATA8 0xEC // LCD_G2_X[15:0], LCD_G3_X[31:16]
-#define PADCONFS_DSS_DATA10 0xF0 // LCD_G4_X[15:0], LCD_G5_X[31:16]
-#define PADCONFS_DSS_DATA12 0xF4 // LCD_R0_X[15:0], LCD_R1_X[31:16]
-#define PADCONFS_DSS_DATA14 0xF8 // LCD_R2_X[15:0], LCD_R3_X[31:16]
-#define PADCONFS_DSS_DATA16 0xFC // LCD_R4_X[15:0], LCD_R5_X[31:16]
-#define PADCONFS_DSS_DATA18 0x100 // SPI1_CLK_X[15:0], SPI1_MOSI_X[31:16]
-#define PADCONFS_DSS_DATA20 0x104 // SPI1_MISO_X[15:0], *SPI1_CS0_X[31:16]
-#define PADCONFS_DSS_DATA22 0x108 // GPIO7_X[15:0], NC[31:16]
-#define PADCONFS_MMC1_DAT4 0x150 // *I2C_INT_X[15:0], *PIRQ_X[31:16]
-#define PADCONFS_MMC1_DAT6 0x154 // GPIO0_X[15:0], GPIO1_X[31:16]
-#define PADCONFS_MCBSP3_CLKX 0x170 // D_TXD[15:0], D_RXD[31:16]
-#define PADCONFS_SYS_NIRQ 0x1E0 // FIQ[15:0], SYS_CLK2[31:16]
-#define PADCONFS_SYS_OFF_MODE 0xA18 // OFF_MODE_X[15:0], USB_CLK[31:16]
-#define PADCONFS_GPMC_WAIT2 0xD0 // NA[15:0], E_INTX[31:16]
-#define PADCONFS_MMC1_CLK 0x144 // MMC1_CLK[15:0], MMC1_CMD[31:16]
-#define PADCONFS_MMC1_DAT0 0x148 // MMC1_DAT0[15:0], MMC1_DAT1[31:16]
-#define PADCONFS_MMC1_DAT2 0x14C // MMC1_DAT2[15:0], MMC1_DAT3[31:16]
-#define CM_REV_REG 0x48004800
-#define PRM_REV_REG 0x48306804
-#define CM_REV_MAJ() ((*(volatile unsigned long *)CM_REV_REG & 0xf0)>>4)
-#define CM_REV_MIN() (*(volatile unsigned long *)CM_REV_REG & 0x0f)
-#define PRM_REV_MAJ() ((*(volatile unsigned long *)PRM_REV_REG & 0xf0)>>4)
-#define PRM_REV_MIN() (*(volatile unsigned long *)PRM_REV_REG & 0x0f)
-/* MMC registers...
-#define CM_FCLKEN1_CORE 0x48004a00
-#define CM_ICLKEN1_CORE 0x48004a10
-#define CM_IDLEST1_CORE 0x48004a20
-#define CM_AUTOIDLE1_CORE 0x48004a30
-#define PM_WKEN1_CORE 0x48306aa0
-#define PM_MPUGRPSEL1_CORE 0x48306aa4
-#define PM_IVA2GRPSEL1_CORE 0x48306aa8
-#define PM_WKST1_CORE 0x48306ab0
-#define CONTROL_DEVCONF0 0x48002274
-#define MMC1_BASE_ADD 0x4809c000
-#define MMC2_BASE_ADD 0x480ad000
-#define MMC3_BASE_ADD 0x480b4000
-#define MMC1_REG(_x_) *(vulong *)(MMC1_BASE_ADD + _x_)
-#define MMC2_REG(_x_) *(vulong *)(MMC2_BASE_ADD + _x_)
-#define MMC3_REG(_x_) *(vulong *)(MMC3_BASE_ADD + _x_)
-#define MMCHS_SYSCONFIG 0x10
-#define MMCHS_SYSSTATUS 0x14
-#define MMCHS_CSRE 0x24
-#define MMCHS_SYSTEST 0x28
-#define MMCHS_CON 0x2C
-#define MMCHS_PWCNT 0x30
-#define MMCHS_BLK 0x104
-#define MMCHS_ARG 0x108
-#define MMCHS_CMD 0x10C
-#define MMCHS_RSP10 0x110
-#define MMCHS_RSP32 0x114
-#define MMCHS_RSP54 0x118
-#define MMCHS_RSP76 0x11C
-#define MMCHS_DATA 0x120
-#define MMCHS_PSTATE 0x124
-#define MMCHS_HCTL 0x128
-#define MMCHS_SYSCTL 0x12C
-#define MMCHS_STAT 0x130
-#define MMCHS_IE 0x134
-#define MMCHS_ISE 0x138
-#define MMCHS_AC12 0x13C
-#define MMCHS_CAPA 0x140
-#define MMCHS_CUR_CAPA 0x148
-#define MMCHS_REV 0x1FC
-/* Miscellaneous MMC register bits...
- * (only specified the ones I use)
-#define EN_MMC1 (1 << 24)
-#define ST_MMC1 (1 << 24)
-#define AUTO_MMC1 (1 << 24)
-#define GRPSEL_MMC1 (1 << 24)
-#define VS18 0x04000000
-#define VS30 0x02000000
-#define VS33 0x01000000
-#define MMCINIT 0x00000002
-#define ODE 0x00000001
-#define SVDS 0x00000e00
-#define SVDS18 (5 << 9)
-#define SVDS30 (6 << 9)
-#define SVDS33 (7 << 9)
-#define SDBP 0x00000100
-#define ICE 0x00000001
-#define ICS 0x00000002
-#define CEN 0x00000004
-#define CLKD(v) ((v & 0x3ff) << 6)
-#define CLKDMSK (0x3ff << 6)
-#define CLKACTIVITYMSK (3 << 8)
-#define CLKACTIVITY(n) ((n & 3) << 8)
-#define SIDLEMODEMSK (3 << 3)
-#define SIDLEMODE(n) ((n & 3) << 3)
-#define ENWAKEUP (1 << 2)
-#define IWE (1 << 24)
-#define AUTOIDLE 1
-#define CLKEXTFREE (1 << 16)
-#define SRESET 0x00000002
-#define CC 0x00000001
-#define RESETDONE 0x00000001
-#define IE_ALL 0x317f8337
-#define CDP (1 << 7)
-#define CMD(v) ((v & 0x3f) << 24)
-#define CMDMSK (0x3f << 24)
-#define CMDI 0x00000001
-#define DEBOUNCE (3 << 16)
-#define CCRC (1 << 17)
-#define DCRC (1 << 21)
-#define CERR (1 << 28)
-#define CTO (1 << 16)
-#define DP (1 << 21)
-#define RSPTYPE_NONE 0x00000000
-#define RSPTYPE_136 0x00010000
-#define RSPTYPE_48 0x00020000
-#define RSPTYPE_48BSY 0x00030000
-#define RSPTYPE 0x00030000
-#define SRD (1 << 26)
-#define SRC (1 << 25)
-#define SRA (1 << 24)
-#define DTOMSK (0xf<<16)
-#define DTO(a) ((a&0xf) << 16)
-#define NBLK(a) ((a&0xffff) << 16)
-#define BLEN(a) (a&0x7ff)
-#define MMCSDIO1ADPCLKISEL (1 << 24)
-/* PBIAS...
-#define CONTROL_PBIAS_LITE 0x48002520
-#define PBIAS_LITE_VMMC1_3V (0x0101)
-#define MMC_PWR_STABLE (0x0202)
-#define PBIAS_LITE_VMMC1_52MHZ (0x0404)
-#define PBIAS_LITE_MMC1_ERROR (0x0808)
-#define PBIAS_LITE_MMC1_HIGH (0x8080)
-/* Control status...
-#define CONTROL_STATUS 0x480022f0
-#define SYSBOOT 0x3f
-#define DEVICETYPE (0x3 << 8)
-/* 16 bit access CONTROL */
-#define MUX_VAL(OFFSET,VALUE)\
- *(unsigned short *) (OMAP35XX_CTRL_BASE + (OFFSET)) = VALUE;
-#define CP(x) (CONTROL_PADCONF_##x)
-#define CONTROL_PADCONF_DSS_DATA18 0x0100
-#define CONTROL_PADCONF_DSS_DATA19 0x0102
-#define CONTROL_PADCONF_DSS_DATA20 0x0104
-#define CONTROL_PADCONF_DSS_DATA21 0x0106
-#define CONTROL_PADCONF_MMC1_CLK 0x0144
-#define CONTROL_PADCONF_MMC1_CMD 0x0146
-#define CONTROL_PADCONF_MMC1_DAT0 0x0148
-#define CONTROL_PADCONF_MMC1_DAT1 0x014A
-#define CONTROL_PADCONF_MMC1_DAT2 0x014C
-#define CONTROL_PADCONF_MMC1_DAT3 0x014E
-#define CONTROL_PADCONF_HSUSB0_CLK 0x01A2
-#define CONTROL_PADCONF_HSUSB0_STP 0x01A4
-#define CONTROL_PADCONF_HSUSB0_DIR 0x01A6
-#define CONTROL_PADCONF_HSUSB0_NXT 0x01A8
-#define CONTROL_PADCONF_HSUSB0_DATA0 0x01AA
-#define CONTROL_PADCONF_HSUSB0_DATA1 0x01AC
-#define CONTROL_PADCONF_HSUSB0_DATA2 0x01AE
-#define CONTROL_PADCONF_HSUSB0_DATA3 0x01B0
-#define CONTROL_PADCONF_HSUSB0_DATA4 0x01B2
-#define CONTROL_PADCONF_HSUSB0_DATA5 0x01B4
-#define CONTROL_PADCONF_HSUSB0_DATA6 0x01B6
-#define CONTROL_PADCONF_HSUSB0_DATA7 0x01B8
-#define CONTROL_PADCONF_I2C1_SCL 0x01BA
-#define CONTROL_PADCONF_I2C1_SDA 0x01BC
-#define CONTROL_PADCONF_McBSP3_DX 0x016C
-/* bits used in control reg's above
- * IEN - Input Enable
- * IDIS - Input Disable
- * PTD - Pull type Down
- * PTU - Pull type Up
- * DIS - Pull type selection is inactive
- * EN - Pull type selection is active
- * M0 - Mode 0
-#define IEN (1 << 8)
-#define IDIS (0 << 8)
-#define PTU (1 << 4)
-#define PTD (0 << 4)
-#define EN (1 << 3)
-#define DIS (0 << 3)
-#define M0 0 /* modes */
-#define M1 1
-#define M2 2
-#define M3 3
-#define M4 4
-#define M5 5
-#define M6 6
-#define M7 7
2.3.3
More information about the umon-devel
