[PATCH 5/16] Updated am335x.h
Jarielle Catbagan
jcatbagan93 at gmail.com
Wed Jun 17 17:54:49 UTC 2015
Added additional register base address, offsets, access macros, and bit defines.
ports/beagleboneblack/am335x.h | 1024 ++++++++++++++++++++-----------------
ports/beagleboneblack/rom_reset.S | 2 +-
2 files changed, 545 insertions(+), 481 deletions(-)
diff --git a/ports/beagleboneblack/am335x.h b/ports/beagleboneblack/am335x.h
index ed96dfe..10fcf1d 100644
--- a/ports/beagleboneblack/am335x.h
+++ b/ports/beagleboneblack/am335x.h
@@ -14,23 +14,342 @@
#include "bits.h"
/* AM335x device identification and feature enumeration */
#define AM335X_DEVICE_IDENTIFICATION 0x44E10600
#define AM335X_DEVICE_FEATURE 0x44E10604
/* L3 and L4 Interconnects */
-#define L3F_CFG_REG_BASE_ADDR 0x44000000
-#define L3S_CFG_REG_BASE_ADDR 0x44800000
-#define L4_WKUP_BASE_ADDR 0x44C00000
-#define L4_PER_BASE_ADDR 0x48000000
-#define L4_FAST_BASE_ADDR 0x4A000000
+#define L3F_CFG_REGS_BASE 0x44000000
+#define L3S_CFG_REGS_BASE 0x44800000
+#define L4_WKUP_BASE 0x44C00000
+#define L4_PER_BASE 0x48000000
+#define L4_FAST_BASE 0x4A000000
-/* McASPx Data Registers */
-#define MCASP0_DATA_REG_BASE_ADDR 0x46000000
-#define MCASP1_DATE_REG-BASE_ADDR 0x46400000
-/* USB Subsystem */
+/* McASPx Data Registers */
+#define MCASP0_DATA_REGS_BASE 0x46000000
+#define MCASP1_DATE_REGS_BASE 0x46400000
+ * L4_WKUP Peripherals
+/* Clock Module Peripheral Registers */
+#define CM_PER_BASE (L4_WKUP_BASE + 0x00200000)
+#define CM_PER_REG(_x_) *(vulong *)(CM_PER_BASE + _x_)
+/* Clock Module Wakeup Registers */
+#define CM_WKUP_BASE (L4_WKUP_BASE + 0x00200400)
+#define CM_WKUP_REG(_x_) *(vulong *)(CM_WKUP_BASE + _x_)
+/* Clock Module PLL Registers */
+#define CM_DPLL_BASE (L4_WKUP_BASE + 0x00200500)
+#define CM_DPLL_REG(_x_) *(vulong *)(CM_DPLL_BASE + _x_)
+/* Clock Module MPU Registers */
+#define CM_MPU_BASE (L4_WKUP_BASE + 0x00200600)
+#define CM_MPU_REG(_x_) *(vulong *)(CM_MPU_BASE + _x_)
+/* Clock Module Device Registers */
+#define CM_DEVICE_BASE (L4_WKUP_BASE + 0x00200700)
+#define CM_DEVICE_REG(_x_) *(vulong *)(CM_DEVICE_BASE + _x_)
+/* Clock Module RTC Registers */
+#define CM_RTC_BASE (L4_WKUP_BASE + 0x00200800)
+#define CM_RTC_REG(_x_) *(vulong *)(CM_RTC_BASE + _x_)
+/* Clock Module Graphics Controller Registers */
+#define CM_GFX_BASE (L4_WKUP_BASE + 0x00200900)
+#define CM_GFX_REG(_x_) *(vulong *)(CM_GFX_BASE + _x_)
+/* Clock Module Efuse Registers */
+#define CM_CEFUSE_BASE (L4_WKUP_BASE + 0x00200A00)
+#define CM_CEFUSE_REG(_x_) *(vulong *)(CM_CEFUSE_BASE + _x_)
+/* Power Reset Module Interrupt Registers */
+#define PRM_IRQ_BASE (L4_WKUP_BASE + 0x00200B00)
+#define PRM_IRQ_REG(_x_) *(vulong *)(PRM_IRQ_BASE + _x_)
+/* Power Reset Module Peripheral Registers */
+#define PRM_PER_BASE (L4_WKUP_BASE + 0x00200C00)
+#define PRM_PER_REG(_x_) *(vulong *)(PRM_PER_BASE + _x_)
+/* Power Reset Module Wakeup Registers */
+#define PRM_WKUP_BASE (L4_WKUP_BASE + 0x00200D00)
+#define PRM_WKUP_REG(_x_) *(vulong *)(PRM_WKUP_BASE + _x_)
+/* Power Reset Module MPU Registers */
+#define PRM_MPU_BASE (L4_WKUP_BASE + 0x00200E00)
+#define PRM_MPU_REG(_x_) *(vulong *)(PRM_MPU_BASE + _x_)
+/* Power Reset Module Device Registers */
+#define PRM_DEV_BASE (L4_WKUP_BASE + 0x00200F00)
+#define PRM_DEV_REG(_x_) *(vulong *)(PRM_DEV_BASE + _x_)
+/* Power Reset Module RTC Registers */
+#define PRM_RTC_BASE (L4_WKUP_BASE + 0x00201000)
+#define PRM_RTC_REG(_x_) *(vulong *)(PRM_RTC_BASE + _x_)
+/* Power Reset Module Graphics Controller Registers */
+#define PRM_GFX_BASE (L4_WKUP_BASE + 0x00201100)
+#define PRM_GFX_REG(_x_) *(vulong *)(PRM_GFX_BASE + _x_)
+/* Power Reset Module Efuse Registers */
+#define PRM_CEFUSE_BASE (L4_WKUP_BASE + 0x00201200)
+#define PRM_CEFUSE_REG(_x_) *(vulong *)(PRM_CEFUSE_BASE + _x_)
+/* DMTimer0 Registers */
+#define DMTIMER0_BASE (L4_WKUP_BASE + 0x00205000)
+#define DMTIMER0_REG(_x_) *(vulong *)(DMTIMER0_BASE + _x_)
+/* UART0 Registers */
+#define UART0_BASE (L4_WKUP_BASE + 0x00209000)
+#define UART0_REG(_x_) *(vulong *)(UART0_BASE + _x_)
+/* I2C0 Registers */
+#define I2C0_BASE (L4_WKUP_BASE + 0x0020B000)
+#define I2C0_REG(_x_) *(vulong *)(I2C0_BASE + _x_)
+/* ADC_TSC Registers */
+#define ADC_TSC_BASE (L4_WKUP_BASE + 0x0020D000)
+#define ADC_TSC_REG(_x_) *(vulong *)(ADC_TSC_BASE + _x_)
+/* Control Module */
+#define CNTL_MODULE_BASE (L4_WKUP_BASE + 0x00210000)
+#define CNTL_MODULE_REG(_x_) *(vulong *)(CNTL_MODULE_BASE + _x_)
+/* DDR2/3/mDDR PHY Registers */
+#define DDR_PHY_BASE (L4_WKUP_BASE + 0x00212000)
+#define DDR_PHY_REG(_x_) *(vulong *)(DDR_PHY_BASE + _x_)
+/* DMTimer1 1ms Registers */
+#define DMTIMER1_1MS_BASE (L4_WKUP_BASE + 0x00231000)
+#define DMTIMER1_1MS_REG(_x_) *(vulong *)(DMTIMER1_1MS_BASE + _x_)
+/* L3 Registers */
+#define SMARTREFLEX0_BASE (L4_WKUP_BASE + 0x00237000)
+#define SMARTREFLEX0_REG(_x_) *(vulong *)(SMARTREFLEX0_BASE + _x_)
+#define SMARTREFLEX1_BASE (L4_WKUP_BASE + 0x00239000)
+#define SMARTREFLEX1_REG(_x_) *(vulong *)(SMARTREFLEX1_BASE + _x_)
+/* RTC Registers */
+#define RTCSS_BASE (L4_WKUP_BASE + 0x0023E000)
+#define RTCSS_REG(_x_) *(vulong *)(RTCSS_BASE + _x_)
+/* Debug Registers */
+#define DEBUGSS_HWMASTER1_BASE (L4_WKUP_BASE + 0x00240000)
+#define DEBUGSS_HWMASTER1_REG(_x_) *(vulong *)(DEBUGSS_HWMASTER1_BASE + _x_)
+ * L4_PER Peripherals
+/* UART1 Registers */
+#define UART1_BASE (L4_PER_BASE + 0x00022000)
+#define UART1_REG(_x_) *(vulong *)(UART1_BASE + _x_)
+/* UART2 Registers */
+#define UART2_BASE (L4_PER_BASE + 0x00024000)
+#define UART2_REG(_x_) *(vulong *)(UART2_BASE + _x_)
+/* I2C1 Registers */
+#define I2C1_BASE (L4_PER_BASE + 0x0002A000)
+#define I2C1_REG(_x_) *(vulong *)(I2C1_BASE + _x_)
+/* McSPI0 Registers */
+#define MCSPI0_BASE (L4_PER_BASE + 0x00030000)
+#define MCSPI0_REG(_x_) *(vulong *)(MCSPI0_BASE + _x_)
+/* McASP0 CFG Registers */
+#define MCASP0_CFG_BASE (L4_PER_BASE + 0x00038000)
+#define MCASP0_CFG_REG(_x_) *(vulong *)(MCASP0_CFG_BASE + _x_)
+/* McASP1 CFG Registers */
+#define MCASP1_CFG_BASE (L4_PER_BASE + 0x0003C000)
+#define MCASP1_CFG_REG(_x_) *(vulong *)(MCASP1_CFG_BASE + _x_)
+/* DMTimer2 Registers */
+#define DMTIMER2_BASE (L4_PER_BASE + 0x00040000)
+#define DMTIMER2_REG(_x_) *(vulong *)(DMTIMER2_BASE + _x_)
+/* DMTimer3 Registers */
+#define DMTIMER3_BASE (L4_PER_BASE + 0x00042000)
+#define DMTIMER3_REG(_x_) *(vulong *)(DMTIMER3_BASE + _x_)
+/* DMTimer4 Registers */
+#define DMTIMER4_BASE (L4_PER_BASE + 0x00044000)
+#define DMTIMER4_REG(_x_) *(vulong *)(DMTIMER4_BASE + _x_)
+/* DMTimer5 Registers */
+#define DMTIMER5_BASE (L4_PER_BASE + 0x00046000)
+#define DMTIMER5_REG(_x_) *(vulong *)(DMTIMER5_BASE + _x_)
+/* DMTimer6 Registers */
+#define DMTIMER6_BASE (L4_PER_BASE + 0x00048000)
+#define DMTIMER6_REG(_x_) *(vulong *)(DMTIMER6_BASE + _x_)
+/* DMTimer7 Registers */
+#define DMTIMER7_BASE (L4_PER_BASE + 0x0004A000)
+#define DMTIMER7_REG(_x_) *(vulong *)(DMTIMER7_BASE + _x_)
+/* MMCHS0 Registers */
+#define MMCHS0_BASE (L4_PER_BASE + 0x00060000)
+#define MMCHS0_REG(_x_) *(vulong *)(MMCHS0_BASE + _x_)
+/* ELM Registers */
+#define ELM_BASE (L4_PER_BASE + 0x00080000)
+#define ELM_REG(_x_) *(vulong *)(ELM_BASE + _x_)
+/* Mailbox 0 Registers */
+#define MAILBOX0_BASE (L4_PER_BASE + 0x000C8000)
+#define MAILBOX0_REG(_x_) *(vulong *)(MAILBOX0_BASE + _x_)
+/* Spinlock Registers */
+#define SPINLOCK_BASE (L4_PER_BASE + 0x000CA000)
+#define SPINLOCK_REG(_x_) *(vulong *)(SPINLOCK_BASE + _x_)
+/* OCP Watchpoint Registers */
+#define OCP_WATCHPOINT_BASE (L4_PER_BASE + 0x0018C000)
+#define OCP_WATCHPOINT_REG(_x_) *(vulong *)(OCP_WATCHPOINT_BASE + _x_)
+/* I2C2 Registers */
+#define I2C2_BASE (L4_PER_BASE + 0x0019C000)
+#define I2C2_REG(_x_) *(vulong *)(I2C2_BASE + _x_)
+/* McSPI1 Registers */
+#define MCSPI1_BASE (L4_PER_BASE + 0x001A0000)
+#define MCSPI1_REG(_x_) *(vulong *)(MSCPI1_BASE + _x_)
+/* UART3 Registers */
+#define UART3_BASE (L4_PER_BASE + 0x001A6000)
+#define UART3_REG(_x_) *(vulong *)(UART3_BASE + _x_)
+/* UART4 Registers */
+#define UART4_BASE (L4_PER_BASE + 0x001A8000)
+#define UART4_REG(_x_) *(vulong *)(UART4_BASE + _x_)
+/* UART5 Registers */
+#define UART5_BASE (L4_PER_BASE + 0x001AA000)
+#define UART5_REG(_x_) *(vulong *)(UART5_BASE + _x_)
+/* DCAN0 Registers */
+#define DCAN0_BASE (L4_PER_BASE + 0x001CC000)
+#define DCAN0_REG(_x_) *(vulong *)(DCAN0_BASE + _x_)
+/* DCAN1 Registers */
+#define DCAN1_BASE (L4_PER_BASE + 0x001D0000)
+#define DCAN1_REG(_x_) *(vulong *)(DCAN1_BASE + _x_)
+/* Interrupt Controller Registers */
+#define INTCPS_BASE (L4_PER_BASE + 0x00200000)
+#define INTCPS_REG(_x_) *(vulong *)(INTCPS_BASE + _x_)
+/* MPUSS Config Register */
+#define MPUSS_BASE (L4_PER_BASE + 0x00240000)
+#define MPUSS_REG(_x_) *(vulong *)(MPUSS_BASE + _x_)
+/* PWMSS0 Configuration Registers */
+#define PWMSS0_BASE (L4_PER_BASE + 0x00300000)
+#define PWMSS0_REG(_x_) *(vulong *)(PWMSS0_BASE + _x_)
+/* PWMSS eCAP0 Registers */
+#define ECAP0_BASE (L4_PER_BASE + 0x00300100)
+#define ECAP0_REG(_x_) *(vulong *)(ECAP0_BASE + _x_)
+/* PWMSS eQEP0 Registers */
+#define EQEP0_BASE (L4_PER_BASE + 0x00300180)
+#define EQEP0_REG(_x_) *(vulong *)(EQEP0_BASE + _x_)
+/* PWMSS ePWM0 Registers */
+#define EPWM0_BASE (L4_PER_BASE + 0x00300200)
+#define EPWM0_REG(_x_) *(vulong *)(EPWM0_BASE + _x_)
+/* PWMSS1 Configuration Registers */
+#define PWMSS1_BASE (L4_PER_BASE + 0x00302000)
+#define PWMSS1_REG(_x_) *(vulong *)(PWMSS1_BASE + _x_)
+/* PWMSS eCAP1 Registers */
+#define ECAP1_BASE (L4_PER_BASE + 0x00302100)
+#define ECAP1_REG(_x_) *(vulong *)(ECAP1_BASE + _x_)
+/* PWMSS eQEP1 Registers */
+#define EQEP1_BASE (L4_PER_BASE + 0x00302180)
+#define EQEP1_REG(_x_) *(vulong *)(EQEP1_BASE + _x_)
+/* PWMSS ePWM1 Registers */
+#define EPWM1_BASE (L4_PER_BASE + 0x00302200)
+#define EPWM1_REG(_x_) *(vulong *)(EPwM_BASE + _x_)
+/* PWMSS2 Configuration Registers */
+#define PWMSS2_BASE (L4_PER_BASE + 0x00304000)
+#define PWMSS2_REG(_x_) *(vulong *)(PWMSS2_BASE + _x_)
+/* PWMSS eCAP2 Registers */
+#define ECAP2_BASE (L4_PER_BASE + 0x00304100)
+#define ECAP2_REG(_x_) *(vulong *)(ECAP2_BASE + _x_)
+/* PWMSS eQEP2 Registers */
+#define EQEP2_BASE (L4_PER_BASE + 0x00304180)
+#define EQEP2_REG(_x_) *(vulong *)(EQEP2_BASE + _x_)
+/* PWMSS ePWM2 Registers */
+#define EPWM2_BASE (L4_PER_BASE + 0x00304200)
+#define EPWM2_REG(_x_) *(vulong *)(EPWM2_BASE + _x_)
+/* LCD Contoller Registers */
+#define LCD_CNTLR_BASE (L4_PER_BASE + 0x0030E000)
+#define LCD_CNTLR_REG(_x_) *(vulong *)(LCD_CNTLR_BASE + _x_)
+ * L4_FAST Peripherals
+/* Ethernet Switch Subsystem Registers */
+#define CPSW_SS_BASE (LF_FAST_BASE + 0x00100000)
+#define CPSW_SS_REG(_x_) *(vulong *)(CPSW_SS_BASE + _x_)
+/* Ethernet Switch Port Control Registers */
+#define CPSW_PORT_BASE (LF_FAST_BASE + 0x00100100)
+#define CPSW_PORT_REG(_x_) *(vulong *)(CPSW_PORT_BASE + _x_)
+/* CPPI DMA Controller Module Registers */
+#define CPSW_CPDMA_BASE (LF_FAST_BASE + 0x00100800)
+#define CPSW_CPDMA_REG(_x_) *(vulong *)(CPSW_CPDMA_BASE + _x_)
+/* Ethernet Statistics Registers */
+#define CPSW_STATS_BASE (LF_FAST_BASE + 0x00100900)
+#define CPSW_STATS_REG(_x_) *(vulong *)(CPSW_STATS_BASE + _x_)
+/* CPPI DMA State RAM Registers */
+#define CPSW_STATERAM_BASE (LF_FAST_BASE + 0x00100A00)
+#define CPSW_STATERAM_REG(_x_) *(vulong *)(CPSW_STATERAM_BASE + _x_)
+/* Ethenet Time Sync Module Registers */
+#define CPSW_CPTS_BASE (LF_FAST_BASE + 0x00100C00)
+#define CPSW_CPTS_REG(_x_) *(vulong *)(CPSW_CPTS_BASE + _x_)
+/* Ethernet Address Lookup Engine Registers */
+#define CPSW_ALE_BASE (LF_FAST_BASE + 0x00100D00)
+#define CPSW_ALE_REG(_x_) *(vulong *)(CPSW_ALE_BASE + _x_)
+/* Ethernet Silver for Port 1 Registers */
+#define CPSW_SL1_BASE (LF_FAST_BASE + 0x00100D80)
+#define CPSW_SL1_REG(_x_) *(vulong *)(CPSW_SL1_BASE + _x_)
+/* Ethernet Silver for Port 2 Registers */
+#define CPSW_SL2_BASE (LF_FAST_BASE + 0x00100DC0)
+#define CPSW_SL2_REG(_x_) *(vulong *)(CPSW_SL2_BASE + _x_)
+/* Ethernet MDIO Controller Registers */
+#define MDIO_BASE (LF_FAST_BASE + 0x00101000)
+#define MDIO_REG(_x_) *(vulong *)(MDIO_BASE + _x_)
+/* Ethernet Subsystem Wrapper for RMII/RGMII Registers */
+#define CPSW_WR_BASE (LF_FAST_BASE + 0x00101200)
+#define CPSW_WR_REG(_x_) *(vulong *)(CPSW_WR_BASE + _x_)
+ * UART Register offsets
+#define UART_THR 0x00 // Transmit Holding Register (write only)
+#define UART_RHR 0x00 // Receive Holding Register (read only)
+#define UART_DLL 0x00 // Baud divisor lower byte (read/write)
+#define UART_IER 0x04 // Interrupt Enable Register (read/write)
+#define UART_DLH 0x04 // Baud divisor higher byte (read/write)
+#define UART_EFR 0x08 // Enhanced Feature Register
+#define UART_IIR 0x08 // Interrupt Identification Register (read only)
+#define UART_FCR 0x08 // FIFO Control Register (write only)
+#define UART_LCR 0x0C // Line Control Register (read/write)
+#define UART_MCR 0x10 // Modem Control Register (read/write)
+#define UART_XON1_ADDR1 0x10 // XON1/ADDR1 Register
+#define UART_XON2_ADDR2 0x14 // XON2/ADDR2 Register
+#define UART_LSR 0x14 // Line Status Register (read only)
+#define UART_TCR 0x18 // Transmission Control Register
+#define UART_MSR 0x18 // Modem Status Register (read only)
+#define UART_XOFF1 0x18 // XOFF1 Register
+#define UART_SPR 0x1C // Scratch Pad Register (read/write)
+#define UART_TLR 0x1C // Trigger Level Register
+#define UART_XOFF2 0x1C // XOFF2 Register
+#define UART_MDR1 0x20 // Mode Definition Register 1
+#define UART_MDR2 0x24 // Mode Definition Register 2
+#define UART_TXFLL 0x28 // Transmit Frame Length Register Low (IrDA modes only)
+#define UART_SFLSR 0x28 // Status FIFO Line Status Register (IrDA modes only)
+#define UART_RESUME 0x2C // Resume Register (IR-IrDA and IR-CIR modes only)
+#define UART_TXFLH 0x2C // Transmit Frame Length Register High (IrDA modes only
+#define UART_RXFLL 0x30 // Receive Frame Length Register Low (IrDA modes only)
+#define UART_SFREGL 0x30 // Status FIFO Register Low (IrDA modes only)
+#define UART_SFREGH 0x34 // Status FIFO Register High (IrDA modes only)
+#define UART_RXFLH 0x34 // Receive Frame Length Register High (IrDA modes only)
+#define UART_BLR 0x38 // BOF Control Register (IrDA modes only)
+#define UART_UASR 0x38 // UART Autobauding Status Register
+ // (UART autobauding mode only)
+#define UART_ACREG 0x3C // Auxiliary Control Register (IrDA-CIR modes only)
+#define UART_SCR 0x40 // Supplementary Control Register
+#define UART_SSR 0x44 // Supplementary Status Register
+#define UART_EBLR 0x48 // BOF Length Register (IR-IrDA and IR-CIR modes only)
+#define UART_MVR 0x50 // Module Version Register
+#define UART_SYSC 0x54 // System Configuration Register
+#define UART_SYSS 0x58 // System Status Register
+#define UART_WER 0x5C // Wake-up Enable Register
+#define UART_CFPS 0x60 // Carrier Frequency Prescaler Register
+#define UART_RXFIFO_LVL 0x64 // Received FIFO Level Register
+#define UART_TXFIFO_LVL 0x68 // Transmit FIFO Level Register
+#define UART_IER2 0x6C // IER2 Register
+#define UART_ISR2 0x70 // ISR2 Register
+#define UART_FREQ_SEL 0x74 // FREQ_SEL Register
+#define UART_MDR3 0x80 // Mode Definition Register 3
+#define UART_TX_DMA_THRESHOLD 0x84 // TX DMA Threshold Register
+ * USB
#define USB_SUBSYS_BASE_ADDR 0x47400000
/* USB Subsystem Registers offset */
#define USBSS_BASE_REG_OFFSET 0x0000
#define USBSS_REVREG 0x0000
@@ -75,6 +394,7 @@
#define USBSS_IRQFRAMETHOLDRX13 0x023C
#define USBSS_IRQFRAMEENABLE0 0x0240
#define USBSS_IRQFRAMEENABLE1 0x0244
/* USB Controller Registers offset */
#define USBCNTLR_USB0_BASE_REG_OFFSET 0x1000 /* USB0 */
#define USBCNTLR_USB1_BASE_REG_OFFSET 0x1800 /* USB1 */
@@ -113,6 +433,7 @@
#define USBCNTLR_UTMI 0x00E0
#define USBCNTLR_MGCUTMILB 0x00E4
#define USBCNTLR_MODE 0x00E8
/* USB PHY Registers offset */
#define USBPHY_USB0_BASE_REG_OFFSET 0x1300 /* USB0 */
#define USBPHY_USB1_BASE_REG_OFFSET 0x1B00 /* USB1 */
@@ -134,9 +455,11 @@
#define USBPHY_AD_INTERFACE_REG2 0x0048
#define USBPHY_AD_INTERFACE_REG3 0x004C
#define USBPHY_ANA_CONFIG2 0x0054
/* USB Core Registers offset */
#define USBCORE_USB0_BASE_REG_OFFSET 0x1400
#define USBCORE_USB1_BASE_REG_OFFSET 0x1C00
/* USB CPPI DMA Controller Registers offset */
#define USBCPPIDMACNTLR_BASE_REG_OFFSET 0x2000
#define USBCPPIDMACNTLR_DMAREVID 0x0000
@@ -262,9 +585,11 @@
#define USBCPPIDMACNTLR_RXGCR29 0x0BA8
#define USBCPPIDMACNTLR_RXHPCRA29 0x0BAC
#define USBCPPIDMACNTLR_RXHPCRB29 0x0BB0
/* USB CPPI DMA Scheduler Registers offset */
#define USBCPPIDMASCHED_BASE_REG_OFFSET 0x3000
#define USBCPPIDMASCHED_CNTL 0x0000
/* USB Queue Manager Registers offset */
#define USBQUEUEMNGER_BASEREG_OFFSET 0x4000
#define USBQUEUEMNGER_QMGRREVID 0x0000
@@ -301,488 +626,227 @@
#define USBQUEUEMNGER_QMEMCNTL6 0x1064
#define USBQUEUEMNGER_QMEMRBASE7 0x1070
#define USBQUEUEMNGER_QMEMCNTL7 0x1074
- * 3530 specific Section
-/* Stuff on L3 Interconnect */
-#define SMX_APE_BASE 0x68000000
-/* L3 Firewall */
-#define A_REQINFOPERM0 (SMX_APE_BASE + 0x05048)
-#define A_READPERM0 (SMX_APE_BASE + 0x05050)
-#define A_WRITEPERM0 (SMX_APE_BASE + 0x05058)
-/* GPMC */
-#define OMAP35XX_GPMC_BASE 0x6E000000
-/* SMS */
-#define OMAP35XX_SMS_BASE 0x6C000000
-/* SDRC */
-#define OMAP35XX_SDRC_BASE 0x6D000000
- * L4 Peripherals - L4 Wakeup and L4 Core now
-#define OMAP35XX_CORE_L4_IO_BASE 0x48000000
-#define OMAP35XX_WAKEUP_L4_IO_BASE 0x48300000
-#define OMAP35XX_L4_PER 0x49000000
-#define OMAP35XX_L4_IO_BASE OMAP35XX_CORE_L4_IO_BASE
-/* TAP information dont know for 3430*/
-#define OMAP35XX_TAP_BASE (0x49000000) /*giving some junk for virtio */
-/* base address for indirect vectors (internal boot mode) */
-#define SRAM_OFFSET0 0x40000000
-#define SRAM_OFFSET1 0x00200000
-#define SRAM_OFFSET2 0x0000F800
-#define SRAM_VECT_CODE (SRAM_OFFSET0|SRAM_OFFSET1|SRAM_OFFSET2)
-#define LOW_LEVEL_SRAM_STACK 0x4020FFFC
+/* SPI */
+#define MCSPI_REVISION 0x0000 // Revision Register
+#define MCSPI_SYSCONFIG 0x0110 // System Configuration Register
+#define MCSPI_SYSSTATUS 0x0114 // System Status Register
+#define MCSPI_IRQSTATUS 0x0118 // Interrupt Status Register offset
-/* UART */
+/* Interrupt Status Register bit defines */
+#define MCSPI_IRQSTATUS_RX3_FULL BIT14
+#define MCSPI_IRQSTATUS_TX3_UNDERFLOW BIT13
+#define MCSPI_IRQSTATUS_TX3_EMPTY BIT12
+#define MCSPI_IRQSTATUS_RX2_FULL BIT10
+#define MCSPI_IRQSTATUS_TX2_UNDERFLOW BIT9
+#define MCSPI_IRQSTATUS_TX2_EMPTY BIT8
+#define MCSPI_IRQSTATUS_RX1_FULL BIT6
+#define MCSPI_IRQSTATUS_TX1_UNDERFLOW BIT5
+#define MCSPI_IRQSTATUS_TX1_EMPTY BIT4
+#define MCSPI_IRQSTATUS_RX0_OVERFLOW BIT3
+#define MCSPI_IRQSTATUS_RX0_FULL BIT2
+#define MCSPI_IRQSTATUS_TX0_UNDERFLOW BIT1
+#define MCSPI_IRQSTATUS_TX0_EMPTY BIT0
+#define MCSPI_IRQENABLE 0x011C // Interrupt Enable Register offset
+#define MCSPI_SYST 0x0124 // System Register offset
+#define MCSPI_MODULCTRL 0x0128 // Module Control Register offset
-#define OMAP35XX_UART1 (OMAP35XX_L4_IO_BASE+0x6A000)
-#define OMAP35XX_UART2 (OMAP35XX_L4_IO_BASE+0x6C000)
-#define OMAP35XX_UART3 (OMAP35XX_L4_PER+0x20000)
-#define UART1_REG(_x_) *(vulong *)(OMAP35XX_UART1 + _x_)
-#define UART2_REG(_x_) *(vulong *)(OMAP35XX_UART2 + _x_)
-#define UART3_REG(_x_) *(vulong *)(OMAP35XX_UART3 + _x_)
-/* UART Register offsets */
-#define UART_RHR 0x00 // Receive Holding Register (read only)
-#define UART_THR 0x00 // Transmit Holding Register (write only)
-#define UART_DLL 0x00 // Baud divisor lower byte (read/write)
-#define UART_DLH 0x04 // Baud divisor higher byte (read/write)
-#define UART_IER 0x04 // Interrupt Enable Register (read/write)
-#define UART_IIR 0x08 // Interrupt Identification Register (read only)
-#define UART_FCR 0x08 // FIFO Control Register (write only)
-#define UART_EFR 0x08 // Enhanced Feature Register
-#define UART_LCR 0x0C // Line Control Register (read/write)
-#define UART_MCR 0x10 // Modem Control Register (read/write)
-#define UART_LSR 0x14 // Line Status Register (read only)
-#define UART_MSR 0x18 // Modem Status Register (read only)
-#define UART_TCR 0x18 //
-#define UART_TLR 0x1C //
-#define UART_SPR 0x1C // Scratch Pad Register (read/write)
-#define UART_MDR1 0x20 // Mode Definition Register 1
-#define UART_MDR2 0x24 // Mode Definition Register 2
-//#define UART_SFLSR 0x28 // Status FIFO Line Status Register (IrDA modes only)
-//#define UART_TXFLL 0x28 // Transmit Frame Length Register Low (IrDA
modes only)
-//#define UART_RESUME 0x2C // Resume Register (IR-IrDA and IR-CIR modes only)
-//#define UART_TXFLH 0x2C // Transmit Frame Length Register High
(IrDA modes only)
-//#define UART_RXFLL 0x30 // Receive Frame Length Register Low (IrDA
modes only)
-//#define UART_SFREGL 0x30 // Status FIFO Register Low (IrDA modes only)
-//#define UART_RXFLH 0x34 // Receive Frame Length Register High (IrDA
modes only)
-//#define UART_SFREGH 0x34 // Status FIFO Register High (IrDA modes only)
-//#define UART_BLR 0x38 // BOF Control Register (IrDA modes only)
-//#define UART_UASR 0x38 // UART Autobauding Status Register (UART
-//#define UART_ACREG 0x3C // Auxiliary Control Register (IrDA-CIR modes only)
-#define UART_SCR 0x40 // Supplementary Control Register
-#define UART_SSR 0x44 // Supplementary Status Register
-//#define UART_EBLR 0x48 // BOF Length Register (IR-IrDA and IR-CIR modes only)
-#define UART_SYSC 0x54 // System Configuration Register
-#define UART_SYSS 0x58 // System Status Register
-#define UART_WER 0x5C // Wake-up Enable Register
-#define UART_CFPS 0x60 // Carrier Frequency Prescaler Register
-/* SPI - Serial Peripheral Interface */
-#define SPI1_BASE_ADD (OMAP35XX_L4_IO_BASE+0x98000) // routed to I/O
sites on CSB703
-#define SPI2_BASE_ADD (OMAP35XX_L4_IO_BASE+0x9A000)
-#define SPI3_BASE_ADD (OMAP35XX_L4_IO_BASE+0xB8000) // routed to
AD7843 touch controller on CSB703
-#define SPI4_BASE_ADD (OMAP35XX_L4_IO_BASE+0xBA000)
-#define SPI1_REG(_x_) *(vulong *)(SPI1_BASE_ADD + _x_)
-#define SPI2_REG(_x_) *(vulong *)(SPI2_BASE_ADD + _x_)
-#define SPI3_REG(_x_) *(vulong *)(SPI3_BASE_ADD + _x_)
-#define SPI4_REG(_x_) *(vulong *)(SPI4_BASE_ADD + _x_)
-// SPI Register Defines
-#define SPI_SYSCONFIG 0x10 // System Configuration Register
-#define SPI_SYSSTATUS 0x14 // System Status Register
-#define SPI_IRQSTATUS 0x18 // Interrupt Status Register
-#define SPI_IRQENABLE 0x1C // Interrupt Enable/Disable Register
-#define SPI_WAKEUPENABLE 0x20 // WakeUp Enable/Disable Register
-#define SPI_SYST 0x24 // System Test Register
-#define SPI_MODULCTRL 0x28 // Serial Port Interface Configuration Register
-#define SPI_CH0_CONF 0x2C // Channel 0 Configuration Register
-#define SPI_CH1_CONF 0x40 // Channel 1 Configuration Register
-#define SPI_CH2_CONF 0x54 // Channel 2 Configuration Register
-#define SPI_CH3_CONF 0x68 // Channel 3 Configuration Register
-#define SPI_CH0_STAT 0x30 // Channel 0 Status Register
-#define SPI_CH1_STAT 0x44 // Channel 1 Status Register
-#define SPI_CH2_STAT 0x58 // Channel 2 Status Register
-#define SPI_CH3_STAT 0x6C // Channel 3 Status Register
-#define SPI_CH0_CTRL 0x34 // Channel 0 Control Register
-#define SPI_CH1_CTRL 0x48 // Channel 1 ControlRegister
-#define SPI_CH2_CTRL 0x5C // Channel 2 ControlRegister
-#define SPI_CH3_CTRL 0x70 // Channel 3 ControlRegister
-#define SPI_TXD0 0x38 // Channel 0 Transmit Data Register
-#define SPI_TXD1 0x4C // Channel 1 Transmit Data Register
-#define SPI_TXD2 0x60 // Channel 2 Transmit Data Register
-#define SPI_TXD3 0x74 // Channel 3 Transmit Data Register
-#define SPI_RXD0 0x3C // Channel 0 Receive Data Register
-#define SPI_RXD1 0x50 // Channel 1 Receive Data Register
-#define SPI_RXD2 0x64 // Channel 2 Receive Data Register
-#define SPI_RXD3 0x78 // Channel 3 Receive Data Register
-#define SPI_XFERLEVEL 0x7C // FIFO Transfer Levels Register
-// SPI Channel x Configuration Bit Defines
-#define SPI_CH_CONF_CLKG BIT29 // 1 = One clock cycle granularity
-#define SPI_CH_CONF_FFER BIT28 // 1 = FIFO buffer is used to Receive data
-#define SPI_CH_CONF_FFEW BIT27 // 1 = FIFO buffer is used to Transmit data
-#define SPI_CH_CONF_TCS_0_5 (0x00 << 25) // 0.5 clock cycles between
CS toggling and first (or last) edge of SPI clock
-#define SPI_CH_CONF_TCS_1_5 (0x01 << 25) // 1.5 clock cycles between
-#define SPI_CH_CONF_TCS_2_5 (0x02 << 25) // 2.5 clock cycles between
-#define SPI_CH_CONF_TCS_3_5 (0x03 << 25) // 3.5 clock cycles between
-#define SPI_CH_CONF_SB_POL BIT24 // 1 = Start bit polarity is held to
1 during SPI transfer
-#define SPI_CH_CONF_SBE BIT23 // 1 = Start bit added before SPI
transfer, 0 = default length specified by WL
-#define SPI_CH_CONF_SPIENSLV_0 (0x00 << 21) // Slave select detection
enabled on CS0
-#define SPI_CH_CONF_SPIENSLV_1 (0x01 << 21) // Slave select detection
enabled on CS1
-#define SPI_CH_CONF_SPIENSLV_2 (0x02 << 21) // Slave select detection
enabled on CS2
-#define SPI_CH_CONF_SPIENSLV_3 (0x03 << 21) // Slave select detection
enabled on CS3
-#define SPI_CH_CONF_FORCE BIT20 // 1 = CSx high when EPOL is 0 and
low when EPOL is 1
-#define SPI_CH_CONF_TURBO BIT19 // 1 = Turbo is activated
-#define SPI_CH_CONF_IS BIT18 // 1 = spim_simo selected for reception,
0 = spim_somi selected for reception
-#define SPI_CH_CONF_DPE1 BIT17 // 1 = no transmission on spim_simo, 0
= spim_simo selected for transmission
-#define SPI_CH_CONF_DPE0 BIT16 // 1 = no transmission on spim_somi, 0
= spim_somi selected for transmission
-#define SPI_CH_CONF_DMAR BIT15 // 1 = DMA read request enabled
-#define SPI_CH_CONF_DMAW BIT14 // 1 = DMA write request enabled
-#define SPI_CH_CONF_TRM_TR (0x00 << 12) // Transmit and receive mode
-#define SPI_CH_CONF_TRM_RO (0x01 << 12) // Receive-only mode
-#define SPI_CH_CONF_TRM_TO (0x02 << 12) // Transmit-only mode
-#define SPI_CH_CONF_WL(_x_) ((_x_ & 0x1f) << 7) // SPI word length, 0x7 = 8-bit
-#define SPI_CH_CONF_EPOL BIT6 // 1 = SPIM_CSx is low during active
state, 0 = high during active state
-#define SPI_CH_CONF_CLKD(_x_) ((_x_ & 0xf) << 2) // Frequency divider
for spim_clk
-#define SPI_CH_CONF_POL BIT1 // 1 = spim_clk is low during active
-#define SPI_CH_CONF_PHA BIT0 // 1 = data latched on even-numbered
edges, 0 = data latched on odd-numbered edges
-// SPI Interrupt Status Register Bit Defines
-#define SPI_RX3_FULL BIT14 //
-#define SPI_TX3_EMPTY BIT12 //
-#define SPI_RX2_FULL BIT10 //
-#define SPI_TX2_EMPTY BIT8 //
-#define SPI_RX1_FULL BIT14 //
-#define SPI_TX1_EMPTY BIT6 //
-#define SPI_RX0_FULL BIT2 //
-#define SPI_TX0_EMPTY BIT0 //
-// SPI Channel Status Register Bit Defines
-#define SPI_RXF_FULL BIT6 //
-#define SPI_RXF_EMPTY BIT5 //
-#define SPI_TXF_FULL BIT4 //
-#define SPI_TXF_EMPTY BIT3 //
-#define SPI_CH_EOT BIT2 //
-#define SPI_CH_TX0_EMPTY BIT1 //
-#define SPI_CH_RX0_FULL BIT0 //
+/* Configuration Registers offset */
+#define MCSPI_CH0CONF 0x012C // Channel 0 Configuration Register offset
+#define MCSPI_CH1CONF 0x0140 // Channel 1 Configuration Register offset
+#define MCSPI_CH2CONF 0x0154 // Channel 2 Configuration Register offset
+#define MCSPI_CH3CONF 0x0168 // Channel 3 Configuration Register offset
+/* Configuration Register bit defines */
+#define MCSPI_CHXCONF_CLKG BIT29 // 1 = One clock cycle granularity
+#define MCSPI_CHXCONF_FFER BIT28 // 1 = FIFO buffer is used to Receive data
+#define MCSPI_CHXCONF_FFEW BIT27 // 1 = FIFO buffer is used to Transmit data
+#define MCSPI_CHXCONF_TCS_0_5 (0x00 << 25) // 0.5 clock cycles
between CS toggling and
+ // first (or last) edge of SPI clock
+#define MCSPI_CHXCONF_TCS_1_5 (0x01 << 25) // 1.5 clock cycles
+#define MCSPI_CHXCONF_TCS_2_5 (0x02 << 25) // 2.5 clock cycles
+#define MCSPI_CHXCONF_TCS_3_5 (0x03 << 25) // 3.5 clock cycles
+#define MCSPI_CHXCONF_SBPOL BIT24 // 1 = Start bit polarity is held to 1 during
+ // SPI transfer
+#define MCSPI_CHXCONF_SBE BIT23 // 1 = Start bit added before SPI transfer,
+ // 0 = default length specified by WL
+#define MCSPI_CHXCONF_SPIENSLV_0 (0x00 << 21) // Slave select
detection enabled on CS0
+#define MCSPI_CHXCONF_SPIENSLV_1 (0x01 << 21) // Slave select
detection enabled on CS1
+#define MCSPI_CHXCONF_SPIENSLV_2 (0x02 << 21) // Slave select
detection enabled on CS2
+#define MCSPI_CHXCONF_SPIENSLV_3 (0x03 << 21) // Slave select
detection enabled on CS3
+#define MCSPI_CHXCONF_FORCE BIT20 // 1 = CSx high when EPOL is 0 and low
+ // when EPOL is 1
+#define MCSPI_CHXCONF_TURBO BIT19 // 1 = Turbo is activated
+#define MCSPI_CHXCONF_IS BIT18 // 1 = spim_simo selected for reception,
+ // 0 = spim_somi selected for reception
+#define MCSPI_CHXCONF_DPE1 BIT17 // 1 = no transmission on spim_simo,
+ // 0 = spim_simo selected for transmission
+#define MCSPI_CHXCONF_DPE0 BIT16 // 1 = no transmission on spim_somi,
+ // 0 = spim_somi selected for transmission
+#define MCSPI_CHXCONF_DMAR BIT15 // 1 = DMA read request enabled
+#define MCSPI_CHXCONF_DMAW BIT14 // 1 = DMA write request enabled
+#define MCSPI_CHXCONF_TRM_TR (0x00 << 12) // Transmit and receive mode
+#define MCSPI_CHXCONF_TRM_RO (0x01 << 12) // Receive-only mode
+#define MCSPI_CHXCONF_TRM_TO (0x02 << 12) // Transmit-only mode
+#define MCSPI_CHXCONF_WL(_x_) ((_x_ & 0x1f) << 7) // SPI word length,
0x7 = 8-bit
+#define MCSPI_CHxCONF_EPOL BIT6 // 1 = SPIM_CSx is low during active state,
+ // 0 = high during active state
+#define MCSPI_CHXCONF_CLKD(_x_) ((_x_ & 0xf) << 2) // Frequency
divider for spim_clk
+#define MCSPI_CHXCONF_POL BIT1 // 1 = spim_clk is low during active state,
+#define MCSPI_CHXCONF_PHA BIT0 // 1 = data latched on even-numbered edges,
+ // 0 = data latched on odd-numbered edges
-/* General Purpose Timers */
+/* Status Registers offset */
+#define MCSPI_CH0STAT 0x0130 // Channel 0 Status Register
+#define MCSPI_CH1STAT 0x0144 // Channel 1 Status Register
+#define MCSPI_CH2STAT 0x0158 // Channel 2 Status Register
+#define MCSPI_CH3STAT 0x016C // Channel 3 Status Register
+/* Status Register bit defines */
+#define MCSPI_CHXSAT_RXF_FULL BIT6
+#define MCSPI_CHXSAT_RXF_EMPTY BIT5
+#define MCSPI_CHXSAT_TXF_FULL BIT4
+#define MCSPI_CHXSAT_TXF_EMPTY BIT3
+#define MCSPI_CHXSAT_EOT BIT2
+#define MCSPI_CHXSAT_TX0_EMPTY BIT1
+#define MCSPI_CHXSAT_RX0_FULL BIT0
-#define OMAP35XX_GPT1 0x48318000
-#define OMAP35XX_GPT2 0x49032000
-#define OMAP35XX_GPT3 0x49034000
-#define OMAP35XX_GPT4 0x49036000
-#define OMAP35XX_GPT5 0x49038000
-#define OMAP35XX_GPT6 0x4903A000
-#define OMAP35XX_GPT7 0x4903C000
-#define OMAP35XX_GPT8 0x4903E000
-#define OMAP35XX_GPT9 0x49040000
-#define OMAP35XX_GPT10 0x48086000
-#define OMAP35XX_GPT11 0x48088000
-#define OMAP35XX_GPT12 0x48304000
+/* Control Registers offset */
+#define MCSPI_CH0CTRL 0x0134 // Channel 0 Control Register offset
+#define MCSPI_CH1CTRL 0x0148 // Channel 1 Control Register offset
+#define MCSPI_CH2CTRL 0x015C // Channel 2 Control Register offset
+#define MCSPI_CH3CTRL 0x0170 // Channel 3 Control Register offset
-/* General Purpose I/O */
+/* FIFO Buffer Registers offset */
+#define MCSPI_TX0 0x0138 // Channel 0 FIFO Transmit Buffer Register offset
+#define MCSPI_RX0 0x013C // Channel 0 FIFO Receive Buffer Register offset
+#define MCSPI_TX1 0x014C // Channel 1 FIFO Transmit Buffer Register offset
+#define MCSPI_RX1 0x0150 // Channel 1 FIFO Receive Buffer Register offset
+#define MCSPI_TX2 0x0160 // Channel 2 FIFO Transmit Buffer Register offset
+#define MCSPI_RX2 0x0164 // Channel 2 FIFO Receive Buffer Register offset
+#define MCSPI_TX3 0x0174 // Channel 3 FIFO Transmit Buffer Register offset
+#define MCSPI_RX3 0x0178 // Channel 3 FIFO Receive Buffer Register offset
-#define GPIO1_BASE_ADD 0x48310000
-#define GPIO2_BASE_ADD 0x49050000
-#define GPIO3_BASE_ADD 0x49052000
-#define GPIO4_BASE_ADD 0x49054000
-#define GPIO5_BASE_ADD 0x49056000
-#define GPIO6_BASE_ADD 0x49058000
-#define GPIO1_REG(_x_) *(vulong *)(GPIO1_BASE_ADD + _x_)
-#define GPIO2_REG(_x_) *(vulong *)(GPIO2_BASE_ADD + _x_)
-#define GPIO3_REG(_x_) *(vulong *)(GPIO3_BASE_ADD + _x_)
-#define GPIO4_REG(_x_) *(vulong *)(GPIO4_BASE_ADD + _x_)
-#define GPIO5_REG(_x_) *(vulong *)(GPIO5_BASE_ADD + _x_)
-#define GPIO6_REG(_x_) *(vulong *)(GPIO6_BASE_ADD + _x_)
+#define MCSPI_XFERLEVEL 0x017C // Transfer Levels Register
+#define MCSPI_DAFTX 0x0180 // DMA Address Aligned FIFO Transmitter Register
+#define MCSPI_DAFRX 0x01A0 // DMA Address Aligned FIFO Receiver Register
-/* GPIO Register offsets */
-#define GPIO_SYSCONFIG 0x10 //
-#define GPIO_SYSSTATUS 0x14 //
-#define GPIO_CTRL 0x30 //
-#define GPIO_OE 0x34 //
-#define GPIO_DATAIN 0x38 //
-#define GPIO_DATAOUT 0x3C //
-#define GPIO_CLEARDATAOUT 0x90 //
-#define GPIO_SETDATAOUT 0x94 //
+/* General Purpose I/O */
+/* GPIO0 Registers */
+#define GPIO0_BASE (L4_WKUP_BASE + 0x00207000)
+#define GPIO0_REG(_x_) *(vulong *)(GPIO0_BASE + _x_)
+/* GPIO1 Registers */
+#define GPIO1_BASE (L4_PER_BASE + 0x0004C000)
+#define GPIO1_REG(_x_) *(vulong *)(GPIO1_BASE + _x_)
+/* GPIO2 Registers */
+#define GPIO2_BASE (L4_PER_BASE + 0x001AC000)
+#define GPIO2_REG(_x_) *(vulong *)(GPIO2_BASE + _x_)
+/* GPIO3 Registers */
+#define GPIO3_BASE (L4_PER_BASE + 0x001AE000)
+#define GPIO3_REG(_x_) *(vulong *)(GPIO3_BASE + _x_)
-/* WatchDog Timers (1 secure, 3 GP) */
+/* GPIOx Register offsets */
+#define GPIOX_REVISION 0x0000
+#define GPIOX_SYSCONFIG 0x0010
+#define GPIOX_EOI 0x0020
+#define GPIOX_IRQSTATUS_RAW_0 0x0024
+#define GPIOX_IRQSTATUS_RAW_1 0x0028
+#define GPIOX_IRQSTATUS_0 0x002C
+#define GPIOX_IRQSTATUS_1 0x0030
+#define GPIOX_IRQSTATUS_SET_0 0x0034
+#define GPIOX_IRQSTATUS_SET_1 0x0038
+#define GPIOX_IRQSTATUS_CLR_0 0x003C
+#define GPIOX_IRQSTATUS_CLR_1 0x0040
+#define GPIOX_IRQWAKEN_0 0x0044
+#define GPIOX_IRQWAKEN_1 0x0048
+#define GPIOX_SYSSTATUS 0x0114
+#define GPIOX_CTRL 0x0130
+#define GPIOX_OE 0x0134
+#define GPIOX_DATAIN 0x0138
+#define GPIOX_DATAOUT 0x013C
+#define GPIOX_LEVELDETECT0 0x0140
+#define GPIOX_LEVELDETECT1 0x0144
+#define GPIOX_RISINGDETECT 0x0148
+#define GPIOX_FALLINGDETECT 0x014C
+#define GPIOX_DEBOUNCEENABLE 0x0150
+#define GPIOX_DEBOUNCINGTIME 0x0154
+#define GPIOX_CLEARDATAOUT 0x0190
+#define GPIOX_SETDATAOUT 0x0194
+/* Watchdog Timer */
+/* Watchdog Timer Registers offset*/
+#define WDT1_BASE (L4_WKUP_BASE + 0x00235000)
+#define WDT1_REG(_x_) *(vulong *)(WDT1_BASE + _x_)
-#define WD1_BASE_ADD 0x4830C000
-#define WD2_BASE_ADD 0x48314000
-#define WD3_BASE_ADD 0x49030000
-#define WD1_REG(_x_) *(vulong *)(WD1_BASE_ADD + _x_)
-#define WD2_REG(_x_) *(vulong *)(WD2_BASE_ADD + _x_)
-#define WD3_REG(_x_) *(vulong *)(WD3_BASE_ADD + _x_)
/* WatchDog Timer Register offsets */
-#define WD_CONFIG 0x10 // System Configuration Register
-#define WD_STATUS 0x14 // System Configuration Register
-#define WD_WISR 0x18 // System Configuration Register
-#define WD_WIER 0x1C // System Configuration Register
-#define WD_WCLR 0x24 // System Configuration Register
-#define WD_WCRR 0x28 // System Configuration Register
-#define WD_WLDR 0x2C // System Configuration Register
-#define WD_WTGR 0x30 // System Configuration Register
-#define WD_WWPS 0x34 // System Configuration Register
-#define WD_WSPR 0x48 // System Configuration Register
-/* 32KTIMER */
-#define SYNC_32KTIMER_BASE (0x48320000)
-#define S32K_CR (SYNC_32KTIMER_BASE+0x10)
+#define WDT1_WIDR 0x00 // Watchdog Identification Register
+#define WDT1_WDSC 0x10 // Watchdog System Control Register
+#define WDT1_WDST 0x14 // Watchdog Status Register
+#define WDT1_WISR 0x18 // Watchdog Interrupt Status Register
+#define WDT1_WIER 0x1C // Watchdog Interrupt Enable Register
+#define WDT1_WCLR 0x24 // Watchdog Control Register
+#define WDT1_WCRR 0x28 // Watchdog Counter Register
+#define WDT1_WLDR 0x2C // Watchdog Load Register
+#define WDT1_WTGR 0x30 // Watchdog Trigger Register
+#define WDT1_WWPS 0x34 // Watchdog Write Posting Bits Register
+#define WDT1_WDLY 0x44 // Watchdog Delay Configuration Register
+#define WDT1_WSPR 0x48 // Watchdog Start/Stop Register
+#define WDT1_WIRQSTATRAW 0x54 // Watchdog Raw Interrupt Status Register
+#define WDT1_WIRQSTAT 0x58 // Watchdog Interrupt Status Register
+#define WDT1_WIRQENSET 0x5C // Watchdog Interrupt Enable Set Register
+#define WDT1_WIRQENCLR 0x60 // Watchdog Interrupt Enable Clear Register
+/* MMC */
+/* MMC Registers offset */
+#define MMC1_BASE (L4_PER_BASE + 0x001D8000)
+#define MMC1_REG(_x_) *(vulong *)(MMC1_BASE + _x_)
-/* System Control Module */
-/* Module Name Base Address Size */
- INTERFACE 0x48002000 36 bytes
- PADCONFS 0x48002030 564 bytes
- GENERAL 0x48002270 767 bytes
- MEM_WKUP 0x48002600 1K byte
- PADCONFS_WKU 0x48002A00 80 bytes
- GENERAL_WKUP 0x48002A60 31 bytes
-#define OMAP35XX_CTRL_BASE (OMAP35XX_L4_IO_BASE+0x2000)
-#define SCM_REG(_x_) *(vulong *)(OMAP35XX_CTRL_BASE + _x_)
-/* Pad Configuration Registers */
-/* Note: Cogent is only defining the PADCONFS registers that are used
in Micromonitor */
-#define PADCONFS_GPMC_NCS3 0xB4 // NCS3[15:0], NCS4[31:16]
-#define PADCONFS_GPMC_NCS5 0xB8 // NCS5[15:0], EXP_INTX[31:16]
-#define PADCONFS_GPMC_NCS7 0xBC // LCD_BKL_X[15:0], LCLK[31:16]
-#define PADCONFS_GPMC_NADV_ALE 0xC0 // NADV_ALE[15:0], NOE[31:16]
-#define PADCONFS_GPMC_NWE 0xC4 // NWE[15:0], NBE0_CLE[31:16]
-#define PADCONFS_DSS_PCLK 0xD4 // LCD_PCLK_X[15:0], LCD_HS_X[31:16]
-#define PADCONFS_DSS_VSYNC 0xD8 // LCD_VS_X[15:0], LCD_OE_X[31:16]
-#define PADCONFS_DSS_DATA0 0xDC // LCD_B0_X[15:0], LCD_B1_X[31:16]
-#define PADCONFS_DSS_DATA2 0xE0 // LCD_B2_X[15:0], LCD_B3_X[31:16]
-#define PADCONFS_DSS_DATA4 0xE4 // LCD_B4_X[15:0], LCD_B5_X[31:16]
-#define PADCONFS_DSS_DATA6 0xE8 // LCD_G0_X[15:0], LCD_G1_X[31:16]
-#define PADCONFS_DSS_DATA8 0xEC // LCD_G2_X[15:0], LCD_G3_X[31:16]
-#define PADCONFS_DSS_DATA10 0xF0 // LCD_G4_X[15:0], LCD_G5_X[31:16]
-#define PADCONFS_DSS_DATA12 0xF4 // LCD_R0_X[15:0], LCD_R1_X[31:16]
-#define PADCONFS_DSS_DATA14 0xF8 // LCD_R2_X[15:0], LCD_R3_X[31:16]
-#define PADCONFS_DSS_DATA16 0xFC // LCD_R4_X[15:0], LCD_R5_X[31:16]
-#define PADCONFS_DSS_DATA18 0x100 // SPI1_CLK_X[15:0], SPI1_MOSI_X[31:16]
-#define PADCONFS_DSS_DATA20 0x104 // SPI1_MISO_X[15:0], *SPI1_CS0_X[31:16]
-#define PADCONFS_DSS_DATA22 0x108 // GPIO7_X[15:0], NC[31:16]
-#define PADCONFS_MMC1_DAT4 0x150 // *I2C_INT_X[15:0], *PIRQ_X[31:16]
-#define PADCONFS_MMC1_DAT6 0x154 // GPIO0_X[15:0], GPIO1_X[31:16]
-#define PADCONFS_MCBSP3_CLKX 0x170 // D_TXD[15:0], D_RXD[31:16]
-#define PADCONFS_SYS_NIRQ 0x1E0 // FIQ[15:0], SYS_CLK2[31:16]
-#define PADCONFS_SYS_OFF_MODE 0xA18 // OFF_MODE_X[15:0], USB_CLK[31:16]
-#define PADCONFS_GPMC_WAIT2 0xD0 // NA[15:0], E_INTX[31:16]
-#define PADCONFS_MMC1_CLK 0x144 // MMC1_CLK[15:0], MMC1_CMD[31:16]
-#define PADCONFS_MMC1_DAT0 0x148 // MMC1_DAT0[15:0], MMC1_DAT1[31:16]
-#define PADCONFS_MMC1_DAT2 0x14C // MMC1_DAT2[15:0], MMC1_DAT3[31:16]
-#define CM_REV_REG 0x48004800
-#define PRM_REV_REG 0x48306804
-#define CM_REV_MAJ() ((*(volatile unsigned long *)CM_REV_REG & 0xf0)>>4)
-#define CM_REV_MIN() (*(volatile unsigned long *)CM_REV_REG & 0x0f)
-#define PRM_REV_MAJ() ((*(volatile unsigned long *)PRM_REV_REG & 0xf0)>>4)
-#define PRM_REV_MIN() (*(volatile unsigned long *)PRM_REV_REG & 0x0f)
-/* MMC registers...
-#define CM_FCLKEN1_CORE 0x48004a00
-#define CM_ICLKEN1_CORE 0x48004a10
-#define CM_IDLEST1_CORE 0x48004a20
-#define CM_AUTOIDLE1_CORE 0x48004a30
-#define PM_WKEN1_CORE 0x48306aa0
-#define PM_MPUGRPSEL1_CORE 0x48306aa4
-#define PM_IVA2GRPSEL1_CORE 0x48306aa8
-#define PM_WKST1_CORE 0x48306ab0
-#define CONTROL_DEVCONF0 0x48002274
-#define MMC1_BASE_ADD 0x4809c000
-#define MMC2_BASE_ADD 0x480ad000
-#define MMC3_BASE_ADD 0x480b4000
-#define MMC1_REG(_x_) *(vulong *)(MMC1_BASE_ADD + _x_)
-#define MMC2_REG(_x_) *(vulong *)(MMC2_BASE_ADD + _x_)
-#define MMC3_REG(_x_) *(vulong *)(MMC3_BASE_ADD + _x_)
-#define MMCHS_SYSCONFIG 0x10
-#define MMCHS_SYSSTATUS 0x14
-#define MMCHS_CSRE 0x24
-#define MMCHS_SYSTEST 0x28
-#define MMCHS_CON 0x2C
-#define MMCHS_PWCNT 0x30
-#define MMCHS_BLK 0x104
-#define MMCHS_ARG 0x108
-#define MMCHS_CMD 0x10C
-#define MMCHS_RSP10 0x110
-#define MMCHS_RSP32 0x114
-#define MMCHS_RSP54 0x118
-#define MMCHS_RSP76 0x11C
-#define MMCHS_DATA 0x120
-#define MMCHS_PSTATE 0x124
-#define MMCHS_HCTL 0x128
-#define MMCHS_SYSCTL 0x12C
-#define MMCHS_STAT 0x130
-#define MMCHS_IE 0x134
-#define MMCHS_ISE 0x138
-#define MMCHS_AC12 0x13C
-#define MMCHS_CAPA 0x140
-#define MMCHS_CUR_CAPA 0x148
-#define MMCHS_REV 0x1FC
-/* Miscellaneous MMC register bits...
- * (only specified the ones I use)
-#define EN_MMC1 (1 << 24)
-#define ST_MMC1 (1 << 24)
-#define AUTO_MMC1 (1 << 24)
-#define GRPSEL_MMC1 (1 << 24)
-#define VS18 0x04000000
-#define VS30 0x02000000
-#define VS33 0x01000000
-#define MMCINIT 0x00000002
-#define ODE 0x00000001
-#define SVDS 0x00000e00
-#define SVDS18 (5 << 9)
-#define SVDS30 (6 << 9)
-#define SVDS33 (7 << 9)
-#define SDBP 0x00000100
-#define ICE 0x00000001
-#define ICS 0x00000002
-#define CEN 0x00000004
-#define CLKD(v) ((v & 0x3ff) << 6)
-#define CLKDMSK (0x3ff << 6)
-#define CLKACTIVITYMSK (3 << 8)
-#define CLKACTIVITY(n) ((n & 3) << 8)
-#define SIDLEMODEMSK (3 << 3)
-#define SIDLEMODE(n) ((n & 3) << 3)
-#define ENWAKEUP (1 << 2)
-#define IWE (1 << 24)
-#define AUTOIDLE 1
-#define CLKEXTFREE (1 << 16)
-#define SRESET 0x00000002
-#define CC 0x00000001
-#define RESETDONE 0x00000001
-#define IE_ALL 0x317f8337
-#define CDP (1 << 7)
-#define CMD(v) ((v & 0x3f) << 24)
-#define CMDMSK (0x3f << 24)
-#define CMDI 0x00000001
-#define DEBOUNCE (3 << 16)
-#define CCRC (1 << 17)
-#define DCRC (1 << 21)
-#define CERR (1 << 28)
-#define CTO (1 << 16)
-#define DP (1 << 21)
-#define RSPTYPE_NONE 0x00000000
-#define RSPTYPE_136 0x00010000
-#define RSPTYPE_48 0x00020000
-#define RSPTYPE_48BSY 0x00030000
-#define RSPTYPE 0x00030000
-#define SRD (1 << 26)
-#define SRC (1 << 25)
-#define SRA (1 << 24)
-#define DTOMSK (0xf<<16)
-#define DTO(a) ((a&0xf) << 16)
-#define NBLK(a) ((a&0xffff) << 16)
-#define BLEN(a) (a&0x7ff)
-#define MMCSDIO1ADPCLKISEL (1 << 24)
-/* PBIAS...
-#define CONTROL_PBIAS_LITE 0x48002520
-#define PBIAS_LITE_VMMC1_3V (0x0101)
-#define MMC_PWR_STABLE (0x0202)
-#define PBIAS_LITE_VMMC1_52MHZ (0x0404)
-#define PBIAS_LITE_MMC1_ERROR (0x0808)
-#define PBIAS_LITE_MMC1_HIGH (0x8080)
-/* Control status...
-#define CONTROL_STATUS 0x480022f0
-#define SYSBOOT 0x3f
-#define DEVICETYPE (0x3 << 8)
-/* 16 bit access CONTROL */
-#define MUX_VAL(OFFSET,VALUE)\
- *(unsigned short *) (OMAP35XX_CTRL_BASE + (OFFSET)) = VALUE;
-#define CP(x) (CONTROL_PADCONF_##x)
-#define CONTROL_PADCONF_DSS_DATA18 0x0100
-#define CONTROL_PADCONF_DSS_DATA19 0x0102
-#define CONTROL_PADCONF_DSS_DATA20 0x0104
-#define CONTROL_PADCONF_DSS_DATA21 0x0106
-#define CONTROL_PADCONF_MMC1_CLK 0x0144
-#define CONTROL_PADCONF_MMC1_CMD 0x0146
-#define CONTROL_PADCONF_MMC1_DAT0 0x0148
-#define CONTROL_PADCONF_MMC1_DAT1 0x014A
-#define CONTROL_PADCONF_MMC1_DAT2 0x014C
-#define CONTROL_PADCONF_MMC1_DAT3 0x014E
-#define CONTROL_PADCONF_HSUSB0_CLK 0x01A2
-#define CONTROL_PADCONF_HSUSB0_STP 0x01A4
-#define CONTROL_PADCONF_HSUSB0_DIR 0x01A6
-#define CONTROL_PADCONF_HSUSB0_NXT 0x01A8
-#define CONTROL_PADCONF_HSUSB0_DATA0 0x01AA
-#define CONTROL_PADCONF_HSUSB0_DATA1 0x01AC
-#define CONTROL_PADCONF_HSUSB0_DATA2 0x01AE
-#define CONTROL_PADCONF_HSUSB0_DATA3 0x01B0
-#define CONTROL_PADCONF_HSUSB0_DATA4 0x01B2
-#define CONTROL_PADCONF_HSUSB0_DATA5 0x01B4
-#define CONTROL_PADCONF_HSUSB0_DATA6 0x01B6
-#define CONTROL_PADCONF_HSUSB0_DATA7 0x01B8
-#define CONTROL_PADCONF_I2C1_SCL 0x01BA
-#define CONTROL_PADCONF_I2C1_SDA 0x01BC
-#define CONTROL_PADCONF_McBSP3_DX 0x016C
-/* bits used in control reg's above
- * IEN - Input Enable
- * IDIS - Input Disable
- * PTD - Pull type Down
- * PTU - Pull type Up
- * DIS - Pull type selection is inactive
- * EN - Pull type selection is active
- * M0 - Mode 0
-#define IEN (1 << 8)
-#define IDIS (0 << 8)
-#define PTU (1 << 4)
-#define PTD (0 << 4)
-#define EN (1 << 3)
-#define DIS (0 << 3)
-#define M0 0 /* modes */
-#define M1 1
-#define M2 2
-#define M3 3
-#define M4 4
-#define M5 5
-#define M6 6
-#define M7 7
+/* MMC Register offsets */
+#define SD_SYSCONFIG 0x0110 // System Configuration
+#define SD_SYSSTATUS 0x0114 // System Status
+#define SD_CSRE 0x0124 // Card Status Response Error
+#define SD_SYSTEST 0x0128 // System Test
+#define SD_CON 0x012C // Configuration
+#define SD_PWCNT 0x0130 // Power Counter
+#define SD_SDMASA 0x0200 // SDMA System Address
+#define SD_BLK 0x0204 // Transfer Length Configuration
+#define SD_ARG 0x0208 // Command Argument
+#define SD_CMD 0x020C // Command and Transfer Mode
+#define SD_RSP10 0x0210 // Command Response 0 and 1
+#define SD_RSP32 0x0214 // Command Response 2 and 3
+#define SD_RSP54 0x0218 // Command Response 4 and 5
+#define SD_RSP76 0x021C // Command Response 6 and 7
+#define SD_DATA 0x0220 // Data
+#define SD_PSTATE 0x0224 // Present State
+#define SD_HCTL 0x0228 // Host Control
+#define SD_SYSCTL 0x022C // SD System Control
+#define SD_STAT 0x0230 // SD Interrupt Status
+#define SD_IE 0x0234 // SD Interrupt Enable
+#define SD_ISE 0x0238 // SD Interrupt Enable Set
+#define SD_AC12 0x023C // Auto CMD12 Error Status
+#define SD_CAPA 0x0240 // Capabilities
+#define SD_CUR_CAPA 0x0148 // Maximum Current Capabilities
+#define SD_FE 0x0250 // Force Event
+#define SD_ADMAES 0x0254 // ADMA Error Status
+#define SD_ADMASAL 0x0258 // ADMA System Address Low bits
+#define SD_ADMASAH 0x025C // ADMA System Address High bits
+#define SD_REV 0x02FC // Versions
diff --git a/ports/beagleboneblack/rom_reset.S
b/ports/beagleboneblack/rom_reset.S
index 8fb396f..686296c 100644
--- a/ports/beagleboneblack/rom_reset.S
+++ b/ports/beagleboneblack/rom_reset.S
@@ -21,7 +21,7 @@
#include "warmstart.h"
-#include "beagleboneblack"
+#include "am335x.h"
#include "config.h"
2.3.3
More information about the umon-devel
