[PATCH 4/16] Renamed BBB platform file to am335x.h, initial version of am335x.h
Ed Sutter ed.sutter at alcatel-lucent.com
Thu Jun 18 14:15:36 UTC 2015
On 6/18/2015 10:14 AM, Gedare Bloom wrote:
> On Thu, Jun 18, 2015 at 9:49 AM, Ed Sutter <ed.sutter at alcatel-lucent.com> wrote:
>> On 6/18/2015 9:36 AM, Gedare Bloom wrote:
>>> On Wed, Jun 17, 2015 at 1:52 PM, Jarielle Catbagan
>>> <jcatbagan93 at gmail.com> wrote:
>>>> Renamed beagleboneblack.h -> am335x.h
>>>> Initial version of am335x.h includes a subset of the regsiter base
>>>> addresses and offsets specific to the AM335x architecture.
>>>>    main/common/warmstart.h                 |   2 +-
>>>>    main/make/common.make                   |   0
>>>>    ports/beagleboneblack/am335x.h          | 788
>>>>    ports/beagleboneblack/beagleboneblack.h | 498 --------------------
>>>>    4 files changed, 789 insertions(+), 499 deletions(-)
>>>>    mode change 100755 => 100644 main/make/common.make
>>>>    create mode 100644 ports/beagleboneblack/am335x.h
>>>>    delete mode 100644 ports/beagleboneblack/beagleboneblack.h
>>>> diff --git a/main/common/warmstart.h b/main/common/warmstart.h
>>>> index 50300eb..a3037ad 100644
>>>> --- a/main/common/warmstart.h
>>>> +++ b/main/common/warmstart.h
>>>> @@ -31,4 +31,4 @@
>>>>    #define APPLICATION (5<<4)
>>>>    #define APP_EXIT (9<<4)
>>>> -#endif
>>>> +#endif /* _WARMSTART_H_ */
>>>> diff --git a/main/make/common.make b/main/make/common.make
>>>> old mode 100755
>>>> new mode 100644
>>>> diff --git a/ports/beagleboneblack/am335x.h
>>>> b/ports/beagleboneblack/am335x.h
>>>> new file mode 100644
>>>> index 0000000..ed96dfe
>>>> --- /dev/null
>>>> +++ b/ports/beagleboneblack/am335x.h
>>>> @@ -0,0 +1,788 @@
>>>> +// am335x.h
>>>> +// Author(s):    Luis Torrico, Cogent Computer Systems, Inc.
>>>> +// Contributors: Jarielle Catbagan
>>>> +// Date:         05/02/2008
>>> You should probably list yourself as the author, and I'd get rid of
>>> these Date entries, the git log contains sufficient information.
>>> Is there a documented umon coding style?
>>> Would it be of interest to generate doxygen for umon (headers)?
>>> Gedare
>> No there isn't.  :-(
>> I generally just use 4-space tabs and comment with...
>>    * comment here
>> but I know I'm not real consistent through the code.
>> At various points I started attempting a doxygen format, but never got it
>> rolling.  I'm certainly up for converting it though (over time of course).
> No time to start like the present. I'd suggest defining the style with
> something close to what you have got, that you want a consistent
> look-and-feel, and if you find particular rules are desired as you
> move forward that you add to them. A simple text document in the repo
> will be sufficient to document the style rules for now, since they're
> pretty simple.
> RTEMS has a fairly comprehensive set of coding conventions that have
> grown over years that includes style and doxygen use.
> https://devel.rtems.org/wiki/Developer/Coding/Conventions
> You don't need so much now, but it really helps to make code review
> easier if all the code looks the same.
Ok, I'm up to my neck today, so I'll look at this tonight.
Tx
Ed Sutter
Alcatel-Lucent Technologies -- Bell Laboratories
Phone: 908-582-2351
Email: ed.sutter at alcatel-lucent.com
More information about the umon-devel mailing list
