Umon command line reached in BBB
Fri Jun 19 02:35:54 UTC 2015
On 19/06/2015 12:17 pm, Ed Sutter wrote:
> Is this all explained through the patches you've submitted?  If yes,
> spoon feed me
> a bit regarding how I can pull in your changes, because as of right now
> I'm confused.
> I apologize for not syncing up on this sooner; I tend to just go off on
> my own and
> do things in a corner, so I haven't really been paying enough attention
> to the stuff
> now in git.
No need to apologize. Once you get a suitable work flow git is really
helpful in helping maintain open source projects. Here is a full run
done for you play with. The first command is the best one to get back to
a sane state if everything seems to appear broken. Also work on a branch
and then just delete it if you think it is broken.
First sync a clone back to the master:
 $ git reset --hard
Then create a branch. Branches in git are cheap and very helpful.
 $ git checkout -b jc-1
Here I have made a branch called 'jc-1' so his first round of patches
can be applied and tested.
Save the email from the list in a plain text format.
Apply the email patches:
 $ git am < 0001-blah-blah
where '0001-blah-blah' is the save file name. Apply in order.
Once this is done a status should show nothing outstanding.
 $ git status
A review of the log should show the commits.
 $ git log
You can now build and test the patches.
[*** this bit is extra and can be ignored ***]
You could leave those patches and do something else. For example:
 $ git checkout master
 $ git checkout -b play-ground-1
    [ edit, commit etc ]
I might now commit a change to the master and you would pick it up with:
 $ git pull
Note, this assumes you have no uncommitted or stashed changes.
This also means the commits on jc-1 are out of sync with master:
 [*** end the extra bits ***]
Sync out with master:
 $ git checkout jc-1
 $ git rebase master
Merge the patches into the master:
 $ git merge jc-1
If you are happy push (needs an ssh cloned repo):
 $ git push
If this fails because someone else has pushed changes, try:
 $ git pull --rebase
 $ git push
If there are conflicts you need to resolve those and commit the changes.
Once you are happy delete the jc-1 branch. For the next set of patches
create jc-2 or what ever you like.
I hope this help and is not too confusing. Feel free to ask any specific
questions.
More information about the umon-devel mailing list
