[PATCH 1/7] Removed execution mode file attribute from all ASCII text files
Jarielle Catbagan jcatbagan93 at gmail.com
Fri Jun 19 21:32:43 UTC 2015
 apps/common/timer.h            | 0
 main/common/dns.c              | 0
 main/common/env.c              | 0
 main/common/fbi.c              | 0
 main/common/fbi.h              | 0
 main/common/flash.c            | 0
 main/common/flash.h            | 0
 main/common/font.c             | 0
 main/common/font.h             | 0
 main/common/if.c               | 0
 main/common/nand.c             | 0
 main/common/tfsclean1.c        | 0
 main/common/time.h             | 0
 main/common/timestuff.c        | 0
 main/common/tsi.c              | 0
 main/glib/getglib              | 0
 main/glib/inrange.c            | 0
 main/glib/pollconsole.c        | 0
 main/glib/prascii.c            | 0
 main/glib/printmem.c           | 0
 main/glib/smemcpy.c            | 0
 main/glib/smemset.c            | 0
 main/glib/strtolower.c         | 0
 main/glib/swap.c               | 0
 main/glib/ticktock.c           | 0
 main/make/common.make          | 0
 ports/csb740/CSB740_boot.ldt   | 0
 ports/csb740/CSB740_ramtst.ldt | 0
 ports/csb740/Makefile          | 0
 ports/csb740/_vimrc            | 0
 ports/csb740/ad7843.c          | 0
 ports/csb740/ad7843.h          | 0
 ports/csb740/ads7846.c         | 0
 ports/csb740/ads7846.h         | 0
 ports/csb740/bashrc            | 0
 ports/csb740/bdi2000.cfg       | 0
 ports/csb740/config.h          | 0
 ports/csb740/cpu.h             | 0
 ports/csb740/cpu_gpio.h        | 0
 ports/csb740/cpu_i2c.c         | 0
 ports/csb740/cpu_i2c.h         | 0
 ports/csb740/cpuio.c           | 0
 ports/csb740/cpuio.h           | 0
 ports/csb740/etherdev.c        | 0
 ports/csb740/fbidemo           | 0
 ports/csb740/font8x16.h        | 0
 ports/csb740/gdbregs.c         | 0
 ports/csb740/lcd_lut.h         | 0
 ports/csb740/omap3530.h        | 0
 ports/csb740/omap3530_gpio.c   | 0
 ports/csb740/omap3530_iomux.c  | 0
 ports/csb740/omap3530_iomux.h  | 0
 ports/csb740/omap3530_lcd.c    | 0
 ports/csb740/omap3530_lcd.h    | 0
 ports/csb740/omap3530_mem.h    | 0
 ports/csb740/omap3530_sdmmc.c  | 0
 ports/csb740/ram_reset.S       | 0
 ports/csb740/regnames.c        | 0
 ports/csb740/rom_reset.S       | 0
 ports/csb740/target_version.h  | 0
 ports/csb740/tfsdev.h          | 0
 ports/csb740/xcmddcl.h         | 0
 ports/csb740/xcmdtbl.h         | 0
 ports/template/flashtest.scr   | 0
 64 files changed, 0 insertions(+), 0 deletions(-)
 mode change 100755 => 100644 apps/common/timer.h
 mode change 100755 => 100644 main/common/dns.c
 mode change 100755 => 100644 main/common/env.c
 mode change 100755 => 100644 main/common/fbi.c
 mode change 100755 => 100644 main/common/fbi.h
 mode change 100755 => 100644 main/common/flash.c
 mode change 100755 => 100644 main/common/flash.h
 mode change 100755 => 100644 main/common/font.c
 mode change 100755 => 100644 main/common/font.h
 mode change 100755 => 100644 main/common/if.c
 mode change 100755 => 100644 main/common/nand.c
 mode change 100755 => 100644 main/common/tfsclean1.c
 mode change 100755 => 100644 main/common/time.h
 mode change 100755 => 100644 main/common/timestuff.c
 mode change 100755 => 100644 main/common/tsi.c
 mode change 100755 => 100644 main/glib/getglib
 mode change 100755 => 100644 main/glib/inrange.c
 mode change 100755 => 100644 main/glib/pollconsole.c
 mode change 100755 => 100644 main/glib/prascii.c
 mode change 100755 => 100644 main/glib/printmem.c
 mode change 100755 => 100644 main/glib/smemcpy.c
 mode change 100755 => 100644 main/glib/smemset.c
 mode change 100755 => 100644 main/glib/strtolower.c
 mode change 100755 => 100644 main/glib/swap.c
 mode change 100755 => 100644 main/glib/ticktock.c
 mode change 100755 => 100644 main/make/common.make
 mode change 100755 => 100644 ports/csb740/CSB740_boot.ldt
 mode change 100755 => 100644 ports/csb740/CSB740_ramtst.ldt
 mode change 100755 => 100644 ports/csb740/Makefile
 mode change 100755 => 100644 ports/csb740/_vimrc
 mode change 100755 => 100644 ports/csb740/ad7843.c
 mode change 100755 => 100644 ports/csb740/ad7843.h
 mode change 100755 => 100644 ports/csb740/ads7846.c
 mode change 100755 => 100644 ports/csb740/ads7846.h
 mode change 100755 => 100644 ports/csb740/bashrc
 mode change 100755 => 100644 ports/csb740/bdi2000.cfg
 mode change 100755 => 100644 ports/csb740/config.h
 mode change 100755 => 100644 ports/csb740/cpu.h
 mode change 100755 => 100644 ports/csb740/cpu_gpio.h
 mode change 100755 => 100644 ports/csb740/cpu_i2c.c
 mode change 100755 => 100644 ports/csb740/cpu_i2c.h
 mode change 100755 => 100644 ports/csb740/cpuio.c
 mode change 100755 => 100644 ports/csb740/cpuio.h
 mode change 100755 => 100644 ports/csb740/etherdev.c
 mode change 100755 => 100644 ports/csb740/fbidemo
 mode change 100755 => 100644 ports/csb740/font8x16.h
 mode change 100755 => 100644 ports/csb740/gdbregs.c
 mode change 100755 => 100644 ports/csb740/lcd_lut.h
 mode change 100755 => 100644 ports/csb740/omap3530.h
 mode change 100755 => 100644 ports/csb740/omap3530_gpio.c
 mode change 100755 => 100644 ports/csb740/omap3530_iomux.c
 mode change 100755 => 100644 ports/csb740/omap3530_iomux.h
 mode change 100755 => 100644 ports/csb740/omap3530_lcd.c
 mode change 100755 => 100644 ports/csb740/omap3530_lcd.h
 mode change 100755 => 100644 ports/csb740/omap3530_mem.h
 mode change 100755 => 100644 ports/csb740/omap3530_sdmmc.c
 mode change 100755 => 100644 ports/csb740/ram_reset.S
 mode change 100755 => 100644 ports/csb740/regnames.c
 mode change 100755 => 100644 ports/csb740/rom_reset.S
 mode change 100755 => 100644 ports/csb740/target_version.h
 mode change 100755 => 100644 ports/csb740/tfsdev.h
 mode change 100755 => 100644 ports/csb740/xcmddcl.h
 mode change 100755 => 100644 ports/csb740/xcmdtbl.h
 mode change 100755 => 100644 ports/template/flashtest.scr
diff --git a/apps/common/timer.h b/apps/common/timer.h
old mode 100755
new mode 100644
diff --git a/main/common/dns.c b/main/common/dns.c
old mode 100755
new mode 100644
diff --git a/main/common/env.c b/main/common/env.c
old mode 100755
new mode 100644
diff --git a/main/common/fbi.c b/main/common/fbi.c
old mode 100755
new mode 100644
diff --git a/main/common/fbi.h b/main/common/fbi.h
old mode 100755
new mode 100644
diff --git a/main/common/flash.c b/main/common/flash.c
old mode 100755
new mode 100644
diff --git a/main/common/flash.h b/main/common/flash.h
old mode 100755
new mode 100644
diff --git a/main/common/font.c b/main/common/font.c
old mode 100755
new mode 100644
diff --git a/main/common/font.h b/main/common/font.h
old mode 100755
new mode 100644
diff --git a/main/common/if.c b/main/common/if.c
old mode 100755
new mode 100644
diff --git a/main/common/nand.c b/main/common/nand.c
old mode 100755
new mode 100644
diff --git a/main/common/tfsclean1.c b/main/common/tfsclean1.c
old mode 100755
new mode 100644
diff --git a/main/common/time.h b/main/common/time.h
old mode 100755
new mode 100644
diff --git a/main/common/timestuff.c b/main/common/timestuff.c
old mode 100755
new mode 100644
diff --git a/main/common/tsi.c b/main/common/tsi.c
old mode 100755
new mode 100644
diff --git a/main/glib/getglib b/main/glib/getglib
old mode 100755
new mode 100644
diff --git a/main/glib/inrange.c b/main/glib/inrange.c
old mode 100755
new mode 100644
diff --git a/main/glib/pollconsole.c b/main/glib/pollconsole.c
old mode 100755
new mode 100644
diff --git a/main/glib/prascii.c b/main/glib/prascii.c
old mode 100755
new mode 100644
diff --git a/main/glib/printmem.c b/main/glib/printmem.c
old mode 100755
new mode 100644
diff --git a/main/glib/smemcpy.c b/main/glib/smemcpy.c
old mode 100755
new mode 100644
diff --git a/main/glib/smemset.c b/main/glib/smemset.c
old mode 100755
new mode 100644
diff --git a/main/glib/strtolower.c b/main/glib/strtolower.c
old mode 100755
new mode 100644
diff --git a/main/glib/swap.c b/main/glib/swap.c
old mode 100755
new mode 100644
diff --git a/main/glib/ticktock.c b/main/glib/ticktock.c
old mode 100755
new mode 100644
diff --git a/main/make/common.make b/main/make/common.make
old mode 100755
new mode 100644
diff --git a/ports/csb740/CSB740_boot.ldt b/ports/csb740/CSB740_boot.ldt
old mode 100755
new mode 100644
diff --git a/ports/csb740/CSB740_ramtst.ldt b/ports/csb740/CSB740_ramtst.ldt
old mode 100755
new mode 100644
diff --git a/ports/csb740/Makefile b/ports/csb740/Makefile
old mode 100755
new mode 100644
diff --git a/ports/csb740/_vimrc b/ports/csb740/_vimrc
old mode 100755
new mode 100644
diff --git a/ports/csb740/ad7843.c b/ports/csb740/ad7843.c
old mode 100755
new mode 100644
diff --git a/ports/csb740/ad7843.h b/ports/csb740/ad7843.h
old mode 100755
new mode 100644
diff --git a/ports/csb740/ads7846.c b/ports/csb740/ads7846.c
old mode 100755
new mode 100644
diff --git a/ports/csb740/ads7846.h b/ports/csb740/ads7846.h
old mode 100755
new mode 100644
diff --git a/ports/csb740/bashrc b/ports/csb740/bashrc
old mode 100755
new mode 100644
diff --git a/ports/csb740/bdi2000.cfg b/ports/csb740/bdi2000.cfg
old mode 100755
new mode 100644
diff --git a/ports/csb740/config.h b/ports/csb740/config.h
old mode 100755
new mode 100644
diff --git a/ports/csb740/cpu.h b/ports/csb740/cpu.h
old mode 100755
new mode 100644
diff --git a/ports/csb740/cpu_gpio.h b/ports/csb740/cpu_gpio.h
old mode 100755
new mode 100644
diff --git a/ports/csb740/cpu_i2c.c b/ports/csb740/cpu_i2c.c
old mode 100755
new mode 100644
diff --git a/ports/csb740/cpu_i2c.h b/ports/csb740/cpu_i2c.h
old mode 100755
new mode 100644
diff --git a/ports/csb740/cpuio.c b/ports/csb740/cpuio.c
old mode 100755
new mode 100644
diff --git a/ports/csb740/cpuio.h b/ports/csb740/cpuio.h
old mode 100755
new mode 100644
diff --git a/ports/csb740/etherdev.c b/ports/csb740/etherdev.c
old mode 100755
new mode 100644
diff --git a/ports/csb740/fbidemo b/ports/csb740/fbidemo
old mode 100755
new mode 100644
diff --git a/ports/csb740/font8x16.h b/ports/csb740/font8x16.h
old mode 100755
new mode 100644
diff --git a/ports/csb740/gdbregs.c b/ports/csb740/gdbregs.c
old mode 100755
new mode 100644
diff --git a/ports/csb740/lcd_lut.h b/ports/csb740/lcd_lut.h
old mode 100755
new mode 100644
diff --git a/ports/csb740/omap3530.h b/ports/csb740/omap3530.h
old mode 100755
new mode 100644
diff --git a/ports/csb740/omap3530_gpio.c b/ports/csb740/omap3530_gpio.c
old mode 100755
new mode 100644
diff --git a/ports/csb740/omap3530_iomux.c b/ports/csb740/omap3530_iomux.c
old mode 100755
new mode 100644
diff --git a/ports/csb740/omap3530_iomux.h b/ports/csb740/omap3530_iomux.h
old mode 100755
new mode 100644
diff --git a/ports/csb740/omap3530_lcd.c b/ports/csb740/omap3530_lcd.c
old mode 100755
new mode 100644
diff --git a/ports/csb740/omap3530_lcd.h b/ports/csb740/omap3530_lcd.h
old mode 100755
new mode 100644
diff --git a/ports/csb740/omap3530_mem.h b/ports/csb740/omap3530_mem.h
old mode 100755
new mode 100644
diff --git a/ports/csb740/omap3530_sdmmc.c b/ports/csb740/omap3530_sdmmc.c
old mode 100755
new mode 100644
diff --git a/ports/csb740/ram_reset.S b/ports/csb740/ram_reset.S
old mode 100755
new mode 100644
diff --git a/ports/csb740/regnames.c b/ports/csb740/regnames.c
old mode 100755
new mode 100644
diff --git a/ports/csb740/rom_reset.S b/ports/csb740/rom_reset.S
old mode 100755
new mode 100644
diff --git a/ports/csb740/target_version.h b/ports/csb740/target_version.h
old mode 100755
new mode 100644
diff --git a/ports/csb740/tfsdev.h b/ports/csb740/tfsdev.h
old mode 100755
new mode 100644
diff --git a/ports/csb740/xcmddcl.h b/ports/csb740/xcmddcl.h
old mode 100755
new mode 100644
diff --git a/ports/csb740/xcmdtbl.h b/ports/csb740/xcmdtbl.h
old mode 100755
new mode 100644
diff --git a/ports/template/flashtest.scr b/ports/template/flashtest.scr
old mode 100755
new mode 100644
2.3.3
More information about the umon-devel mailing list
