[PATCH 2/7] Duplicated csb740 directory to beagleboneblack directory for BBB port
Jarielle Catbagan
jcatbagan93 at gmail.com
Fri Jun 19 22:05:32 UTC 2015
[PATCH 2/7] was too large. It is attached in gzipped form.
On Fri, Jun 19, 2015 at 2:32 PM, Jarielle Catbagan
<jcatbagan93 at gmail.com> wrote:
> I wasn't entirely satisfied with the previous patches I submitted. I went ahead and redid the
> patches by breaking down the commits into the smallest logical change from one commit to another.
> The main intention of these first set of patches is to simply create a copy of the "csb740" port
> directory which will serve as the basis for porting Umon to the Beaglebone Black. Next, the
> newly created BBB port directory as well as the paths to the necessary files required when
> building Umon were fixed. As a result, these set of patches allow the initial version of Umon
> in the BBB port to build successfully.
> The next set of patches that will be submitted will start to remove the CSB740 specifics and
> replacing it with those that match the AM335x/BBB.
Type: application/x-gzip
Desc: not available
URL: <http://lists.rtems.org/pipermail/umon-devel/attachments/20150619/d7aaabd0/attachment-0001.bin>
More information about the umon-devel
