[PATCH 10/13] Removed ads7846.* from BBB port
Jarielle Catbagan jcatbagan93 at gmail.com
Sat Jun 20 02:58:00 UTC 2015
The ADS7846 Interface routines are not relevant to the BBB port, therefore it is removed.
Unlike the previously existing ad7843.c, ads7846.c does not have to be removed from the
compilation process as it is not included.
 ports/beagleboneblack/ads7846.c | 180 ----------------------------------------
 ports/beagleboneblack/ads7846.h |  56 -------------
 2 files changed, 236 deletions(-)
 delete mode 100644 ports/beagleboneblack/ads7846.c
 delete mode 100644 ports/beagleboneblack/ads7846.h
diff --git a/ports/beagleboneblack/ads7846.c b/ports/beagleboneblack/ads7846.c
deleted file mode 100644
index e3b2a68..0000000
--- a/ports/beagleboneblack/ads7846.c
+++ /dev/null
@@ -1,180 +0,0 @@
-//      ads7846.c
-// Author(s):   Michael Kelly - Cogent Computer Systems, Inc.
-// Date:        03/06/03
-// Description:	ADS7846 Interface routines for CSB740
-//				Modified from MC9328mxl version to use SPI1
-#include "config.h"
-#include "cpuio.h"
-#include "genlib.h"
-#include "stddefs.h"
-#include "omap3530.h"
-#include "cpu_gpio.h"
-#include "ads7846.h"
-#include "cli.h"
-#include "umongpio.h"
-// function prototypes
-int ads_init(void);
-int ads_rd(uchar ads_ctl);
-extern void udelay(int delay);
-// ads_init()
-// This routine sets up the OMAP3530 SPI3 port in Microwire mode
-// (8 bit control, 16 bit data, 24 bit total).  It also turns on
-// the ADS7843 pen interrupt via a dummy read.  Note that we assume
-// that PERCLK2 is 12Mhz (HCLK/4). We are using CS0 on SPI3.
-int ads_init()
-	volatile uchar temp;
-	SPI3_REG(SPI_CH0_CTRL) = 0x00;				// Disable SPI3 Channel 0
-	SPI3_REG(SPI_CH0_CONF) = SPI_CH_CONF_CLKG
-					   | SPI_CH_CONF_DPE0	// no transmission on SPI3_MISO
-					   | SPI_CH_CONF_WL(7)	 	// 8-bit data mode
-					   | SPI_CH_CONF_EPOL	  	// CS is active low
-//					   | SPI_CH_CONF_SB_POL	  	//
-//					   | SPI_CH_CONF_SBE	  	//
-					   | SPI_CH_CONF_CLKD(9);	// divide by 512 = 93Khz
-//					   | SPI_CH_CONF_PHA;		// Data is latched on even numbered edges
-//					   | SPI_CH_CONF_POL;	  	// SPI clock is active low
-	SPI3_REG(SPI_MODULCTRL) = 0x0;				// Functional mode, Master, and auto CS generation
-	SPI3_REG(SPI_CH0_CTRL) = 0x01;				// Enable SPI3 Channel 0
-	// enable the ADS7846 so it can generate a touch interrupt.
-	// this consists of reading any channel, but setting the
-	// power down mode in the control byte to 00b.  note we
-	// flush the returned data
-	//ads_rd(ADS7846E_S | ADS7846E_PD_ADC | ADS7846E_ADD_DFR_X);
-	ads_rd(ADS7846E_S | ADS7846E_PD_ADC | ADS7846E_8BIT | ADS7846E_ADD_DFR_Y);
-//	ads_rd(ADS7846E_S | ADS7846E_PD_ADC | ADS7846E_ADD_DFR_Y);
-	temp = SPI3_REG(SPI_RXD0);
-	return 0;
-	int timeout = 100;
-	volatile uchar temp0, temp1;
-	// the OMAP3530 only handles up to 16-bits per transfer
-	// so we send 8-bits at a time to get our total of 24
-//	SPI3_REG(SPI_TXD0) = ads_ctl;
-//	udelay(10);
-//	while (!(SPI3_REG(SPI_IRQSTATUS) & SPI_TX0_EMPTY));
-//	while (!(SPI3_REG(SPI_IRQSTATUS) & SPI_RX0_FULL));
-//	temp0 = SPI3_REG(SPI_RXD0);
-//	SPI3_REG(SPI_TXD0) = 0;
-//	udelay(10);
-//	udelay(10);
-//	temp1 = SPI3_REG(SPI_RXD0);
-	SPI3_REG(SPI_TXD0) = ads_ctl;
-	udelay(10);
-	while (!(SPI3_REG(SPI_CH0_STAT) & SPI_CH_TX0_EMPTY));
-	while (!(SPI3_REG(SPI_CH0_STAT) & SPI_CH_RX0_FULL));
-	temp0 = SPI3_REG(SPI_RXD0);
-	SPI3_REG(SPI_TXD0) = 0;
-	udelay(10);
-//	udelay(10);
-//	while (!(SPI3_REG(SPI_CH0_STAT) & SPI_CH_TX0_EMPTY));
-//	while (!(SPI3_REG(SPI_CH0_STAT) & SPI_CH_RX0_FULL));
-	temp1 = 0;
-	return ((temp0 << 8) | temp1);
-char *adsHelp[] = {
-	"Screen touch demo using ADS7846 and OMAP3530 SPI port.",
-	0
-int ads(int argc, char *argv[])
-	uchar c;
-	int pen, i;
-	int average_x, average_y;
-	// init the SPI and ADS7846
-	if (ads_init() == -1)
-		printf("Error intializing ADS7846!\n");
-		return (CMD_FAILURE);
-	printf("Waiting for Touch (Press \'X\' to end test)...\n");
-	pen = 0;
-	while (1)
-		if (gotachar())
-			c = getchar();
-			if ((c == 'X') || (c == 'x')) goto done;
-		if (GPIO_tst(PIRQ) == 0)
-			printf("Pen Down....\n");
-			pen = 1;
-			while(GPIO_tst(PIRQ) == 0) // keep reading until touch goes away
-				average_x = 0;
-				average_y = 0;
-				// display every 256 samples (less if pen is down a short time)
-				for (i = 0; i < 256 ; i++)
-//					average_x += ads_rd(ADS7846E_S | ADS7846E_PD_ADC | ADS7846E_ADD_DFR_X);
-//					average_y += ads_rd(ADS7846E_S | ADS7846E_PD_ADC | ADS7846E_ADD_DFR_Y);
-					average_x += ads_rd(ADS7846E_S | ADS7846E_PD_ADC | ADS7846E_8BIT | ADS7846E_ADD_DFR_X);
-					average_y += ads_rd(ADS7846E_S | ADS7846E_PD_ADC | ADS7846E_8BIT | ADS7846E_ADD_DFR_Y);
-				printf("X = %04d, Y = %04d\n", average_x/i, average_y/i);
-			} // while pen is down
-		if (pen)
-			printf("Pen Up....\n");
-			pen = 0;
-done:
-	return(CMD_SUCCESS);
diff --git a/ports/beagleboneblack/ads7846.h b/ports/beagleboneblack/ads7846.h
index 9ee33dc..0000000
--- a/ports/beagleboneblack/ads7846.h
+++ /dev/null
@@ -1,56 +0,0 @@
-// ads7846.h
-// Author(s):    Michael Kelly, Cogent Computer Systems, Inc.
-// Contributors:
-// Date:         03/06/03
-// Description:  This file contains register offsets and bit defines
-//				 for the TI ADS7846 Touch Screen Controller
-// Bit positions for ADS7846E Control byte
-#define ADS7846E_S				0x80	    // Start bit, always 1
-#define ADS7846E_8BIT			0x08	    // 0 = 12-bit conversion, 1 = 8-bits
-#define ADS7846E_SER			0x04	    // 0 = Differential, 1 = Single ended
-// Address select defines for single ended mode (or'ed with the single ended select bit)
-// USE FOR ADS7846
-//#define ADS7846E_ADD_SER_TEMP0	(ADS7846E_SER | (0x0 << 4))	// temperature measurement 1
-//#define ADS7846E_ADD_SER_Y		(ADS7846E_SER | (0x1 << 4))	// Y position measurement
-//#define ADS7846E_ADD_SER_BAT	(ADS7846E_SER | (0x2 << 4))	// battery input measurement
-//#define ADS7846E_ADD_SER_Z1		(ADS7846E_SER | (0x3 << 4))	// pressure measurement 1
-//#define ADS7846E_ADD_SER_Z2		(ADS7846E_SER | (0x4 << 4))	// pressure measurement 2
-//#define ADS7846E_ADD_SER_X		(ADS7846E_SER | (0x5 << 4))	// X position measurement
-//#define ADS7846E_ADD_SER_AUX	(ADS7846E_SER | (0x6 << 4))	// auxillary input measurement
-//#define ADS7846E_ADD_SER_TEMP1	(ADS7846E_SER | (0x7 << 4))	// temperature measurement 2
-// USE FOR ADS7843
-#define ADS7846E_ADD_SER_Y		(ADS7846E_SER | (0x1 << 4))	// Y position measurement
-//#define ADS7846E_ADD_SER_Z1		(ADS7846E_SER | (0x2 << 4))	// pressure measurement 1
-//#define ADS7846E_ADD_SER_Z2		(ADS7846E_SER | (0x6 << 4))	// pressure measurement 2
-#define ADS7846E_ADD_SER_X		(ADS7846E_SER | (0x5 << 4))	// X position measurement
-// Address select defines for differential mode
-#define ADS7846E_ADD_DFR_X		(0x1 << 4)	// Y position measurement
-//#define ADS7846E_ADD_DFR_Z1		(0x2 << 4)	// pressure measurement 1
-//#define ADS7846E_ADD_DFR_Z2		(0x6 << 4)	// pressure measurement 2
-#define ADS7846E_ADD_DFR_Y		(0x5 << 4)	// X position measurement
-// Power Down Modes
-#define ADS7846E_PD_LPWR		0x0			// low-power mode, no power-up delay, *IRQ is enabled
-#define ADS7846E_PD_REF			0x1			// 2.5V reference off, ADC on, requires delay before conversion
-#define ADS7846E_PD_ADC			0x2			// ADC off, REF on, no delay required
-#define ADS7846E_PD_IRQ			0x3			// device on, but *IRQ is disabled
2.3.3
More information about the umon-devel mailing list
