Fwd: BBB/AM335x: isspace() results in data abort exception in strtol() in strtol.c and strtoul() in strtoul.c
Jarielle Catbagan
jcatbagan93 at gmail.com
Sun Jun 21 16:27:06 UTC 2015
I was testing the "help", "dm" and "pm" commands on the Umon command
line and they resulted in what appears to cause the program to hang.
I captured the result and it can be found here
https://drive.google.com/file/d/0B_44Dkqbmn75TjQwZjJaczNJYk0/view?usp=sharing.
After doing some debugging, I was able to pinpoint the location that
results in a halt in program execution. It hangs when isspace() is
executed in strtol() in strtol.c.
I was suspecting that perhaps some exception has occured. I know that
the exception handlers defined by Umon are located in rom_reset.S. I
then realized that the custom exception handlers have no way of being
called when an exception occurs because the AM335x does not know the
location of these custom exception handlers. By referring to the
AM335x TRM, Section 26.1.3.2, it can be found that when an exception
occurs, the default exception handlers are used which are established
by the internal ROM code. The locations of where these default
exception handlers are shown in Table 26-3.
It is also stated in this section that the addresses of the default
exception handlers can be overridden with custom addresses indicating
the locations of the custom exception handlers. The default exception
handlers are replaced with Umon's custom exception handlers with the
previous submitted patch, which can be found here
https://lists.rtems.org/pipermail/umon-devel/2015-June/000072.html.
With Umon's exception handlers in place, the base Umon image was
rebuilt, and executed again. This time, when the command such as
"help" is executed, an exception does occur, and Umon indicates this.
The type of exception is a data abort exception. When this exception
occurs, Umon simply restarts. I captured this exception occurring and
Umon restarting and it can be found here
https://drive.google.com/open?id=0B_44Dkqbmn75WnNsWlJlbkpvTHc&authuser=0.
In the image shown in the previous link, Umon indicates that the data
exception occurs around 0x403082dc. This is a valid memory address as
it is within the 109 KB range of the internal SRAM and that Umon is
mapped within.
I wanted to find out what exact data was located at this address.
strtol() and strtoul() do not hang if the invocation of isspace() in
the while conditional of the do/while loop is replaced with while(c ==
' '). Since "help" uses strtol() and "dm"/"pm" use strtoul(), I
modified strtoul() only so that I can use "dm" to poke around memory
when the data abort exception occurs as a result of executing "help".
This modification is only a temporary mechanism to assist me in
debugging.
Using "dm" to view the contents of memory starting at address
0x403082dc, I then captured the output and it can be found here
https://drive.google.com/open?id=0B_44Dkqbmn75LUVrVUZMLXFNanM&authuser=0.
Before proceeding further, one thing worth mentioning is the general
function invocations leading to isspace(). When the "help" command is
executed, showhelp() is eventually invoked in docmd.c. When Umon
attempts to display the output of the "help" command, it invokes
printf("%-12s", cptr->name) at the end of showhelp(). Eventually
strtol() is invoked which is passed the format string from the printf
but only "12". In the first iteration of the do/while loop in
strtol(), isspace is first passed the first character from "12", i.e.
'1'. The string "12" is stored starting at 0x403082dc as shown in the
output of the "dm" command shown in the previous image and is the
location where Umon indicates where the data exception occurs nearby.
Based on my intuition, this is valid data in valid memory and I
believe that the exception is not triggered by the memory access of
0x403082dc but by a different memory access.
Whenever Umon is built, there are two important images built.
boot.bin and boot.elf. boot.bin is a raw image and is the image that
is booted on the BBB. I wanted to see how the image was assembled,
and so I ran "arm-none-eabi-objdump -S boot.elf". I am focusing on
how the data exception is triggered and I know that it must be
occuring near isspace() in strtol().
A subset of the output of arm-none-eabi-objdump showing strtol() and
isspace() invoked within, is shown below.
402f7b70 <strtol>:
* Assumes that the upper and lower case
* alphabets and digits are each contiguous.
long
strtol(const char * __restrict nptr, char ** __restrict endptr, int base)
402f7b70: e30435a0 movw r3, #17824 ; 0x45a0
402f7b74: e3443030 movt r3, #16432 ; 0x4030
402f7b78: e92d4ff0 push {r4, r5, r6, r7, r8, r9, sl, fp, lr}
402f7b7c: e1a06001 mov r6, r1
402f7b80: e1a08002 mov r8, r2
402f7b84: e24dd00c sub sp, sp, #12
402f7b88: e1a07000 mov r7, r0
402f7b8c: e5931000 ldr r1, [r3]
* Skip white space and pick up leading +/- sign if any.
* If base is 0, allow 0x for hex and 0 for octal, else
* assume decimal; if base is already 16, allow 0x.
s = nptr;
402f7b90: e1a02000 mov r2, r0
402f7b94: ea000000 b 402f7b9c <strtol+0x2c>
402f7b98: e1a02005 mov r2, r5
do {
c = *s++;
402f7b9c: e1a05002 mov r5, r2
402f7ba0: e4d5c001 ldrb ip, [r5], #1
} while (isspace((unsigned char)c));
402f7ba4: e081300c add r3, r1, ip
402f7ba8: e5d33001 ldrb r3, [r3, #1]
402f7bac: e2033008 and r3, r3, #8
402f7bb0: e21330ff ands r3, r3, #255 ; 0xff
402f7bb4: 1afffff7 bne 402f7b98 <strtol+0x28>
if (c == '-') {
402f7bb8: e35c002d cmp ip, #45 ; 0x2d
s = nptr;
do {
c = *s++;
402f7bbc: e1a0900c mov r9, ip
if (c == '-') {
402f7bc0: 0a000061 beq 402f7d4c <strtol+0x1dc>
neg = 1;
c = *s++;
} else {
neg = 0;
if (c == '+')
402f7bc4: e35c002b cmp ip, #43 ; 0x2b
At the very top of the output posted, r3 is set to contain the value
0x403045a0 from the instructions at 0x402f7b70 and 0x402f7b74, where
r3 is then dereferenced at 0x402f7b8c to retrieve the value contained
at this address and is stored in r1.
Looking at the data at this location, there is nothing as shown in the
screen capture here
https://drive.google.com/open?id=0B_44Dkqbmn75VUlxSGt2cWJnck0&authuser=0.
Later on, when a character is obtained from the string "12" with the
instruction at 0x402f7ba0 it is added with the value stored previously
in r1 and stored back in r3 with the instruction at 0x402f7ba4.
If I take into account that r1 contains 0 and that the value of the
character obtained, which in the case of the first character would be
0x31 for '1' in ASCII, then the value is still 0x31 after executing
This value is then added with 1 and is used as the address of a memory
location which is dereferenced and stored in r3 with the instruction
at 0x402f7ba8. Could this instruction, at 0x402f7ba8, be the
instruction that can cause the data abort exception. Looking at the
memory map in the AM335x TRM, this is an address (0x31) within the
GPMC subsystem. This subsystem is used for external memory such as
NAND. The interface to NAND has not been set up yet, so it would
make sense that this could cause a data abort exception. I apologize
that I am not actually able to verify the exact contents of the
registers at the time the data abort exception occurs as I don't have
a JTAG debugger yet.
Is there a possibility that I could be missing something? Am I
interpreting the disassembled output correctly?
More information about the umon-devel
