[PATCH 6/7] Renamed linker script templates in BBB port to match BBB target
Ed Sutter ed.sutter at alcatel-lucent.com
Mon Jun 22 13:39:07 UTC 2015
My original goal with this was to keep the linker file extremely simple.
The core umon does not even support writeable initialized data; because that
used to be a mess to coordinate when trying to build with different toolsets
(cross compilers).
To allow the user to avoid touching the linker file, the makefile is
able to modify
the key base addresses in the system at build time; hence the use of a
template
(*.ldt) linker file to create the actual linker file.
As you've heard me say in the past, much of this is historical back when
I was trying to support
several different cross compilers each with their own set of quirks in
linker language and
libraries.  Most of this is history, so I'm certainly open to adjust
this moving forward.
I suggest we just get over this first hump (BBB port) and then we can
step back and
adjust some of that stuff.
Jarielle, I apologize for my slow-response on the patches.  I should be
able to start looking
through them tonight.
> With all this copy-and-paste, you might want to investigate how to
> share linker script pieces via include directive. This has been done
> on RTEMS for the ARM targets, see rtems/c/src/lib/libbsp/arm/startup
> On Fri, Jun 19, 2015 at 5:32 PM, Jarielle Catbagan
> <jcatbagan93 at gmail.com> wrote:
>> * Renamed CSB740_boot.ldt -> BEAGLEBONEBLACK_boot.ldt
>> * Renamed CSB740_ramtst.ldt -> BEAGLEBONEBLACK_ramtst.ldt
>>   ports/beagleboneblack/BEAGLEBONEBLACK_boot.ldt   | 63 ++++++++++++++++++++++++
>>   ports/beagleboneblack/BEAGLEBONEBLACK_ramtst.ldt | 59 ++++++++++++++++++++++
>>   ports/beagleboneblack/CSB740_boot.ldt            | 63 ------------------------
>>   ports/beagleboneblack/CSB740_ramtst.ldt          | 59 ----------------------
>>   4 files changed, 122 insertions(+), 122 deletions(-)
>>   create mode 100644 ports/beagleboneblack/BEAGLEBONEBLACK_boot.ldt
>>   create mode 100644 ports/beagleboneblack/BEAGLEBONEBLACK_ramtst.ldt
>>   delete mode 100644 ports/beagleboneblack/CSB740_boot.ldt
>>   delete mode 100644 ports/beagleboneblack/CSB740_ramtst.ldt
>> diff --git a/ports/beagleboneblack/BEAGLEBONEBLACK_boot.ldt b/ports/beagleboneblack/BEAGLEBONEBLACK_boot.ldt
>> new file mode 100644
>> index 0000000..c8bc089
>> --- /dev/null
>> +++ b/ports/beagleboneblack/BEAGLEBONEBLACK_boot.ldt
>> @@ -0,0 +1,63 @@
>> +/* CSB740_boot.ld:
>> + * This is the memory map file used for the boot-flash based version
>> + * of MicroMonitor.  The only value that should be considered adjustable
>> + * here is the base address of the 'dram' memory block.
>> +MEMORY
>> +       rom :   org = ROMBASE,  len = ROMLEN
>> +       dram :  org = DRAMBASE, len = DRAMLEN
>> +SECTIONS
>> +       .text   :
>> +               boot_base = .;
>> +               rom_reset.o(.text)
>> +               *(.glue_7t)
>> +               *(.glue_7)
>> +       } >rom
>> +       .data   :
>> +               *(.data)
>> +       } >rom
>> +       .sdata  :
>> +               *(.sdata)
>> +       } >rom
>> +       .sdata2 :
>> +               *(.sdata2)
>> +       } >rom
>> +       .rodata :
>> +               *(.rodata)
>> +               *(.rodata.str1.4)
>> +       } >rom
>> +       .got    :
>> +               *(.got)
>> +       } >rom
>> +       .bss    :
>> +               bss_start = .;
>> +               atag_space = .;
>> +               . += ATAGSIZE;
>> +               end_atag_space = .;
>> +               *(.bss) *(COMMON)
>> +       } >dram
>> +       .sbss   :
>> +               *(.sbss)
>> +               bss_end = .;
>> +       } >dram
>> diff --git a/ports/beagleboneblack/BEAGLEBONEBLACK_ramtst.ldt b/ports/beagleboneblack/BEAGLEBONEBLACK_ramtst.ldt
>> index 0000000..76fbce4
>> --- /dev/null
>> +++ b/ports/beagleboneblack/BEAGLEBONEBLACK_ramtst.ldt
>> @@ -0,0 +1,59 @@
>> +etheraddr              = MACADDRBASE;
>> +alt_tfsdevtbl_base     = ALTTFSDEVTBLBASE;
>> +MEMORY
>> +       rom :   org = RAMTSTROMBASE,    len = RAMTSTROMLEN
>> +SECTIONS
>> +       .text   :
>> +               boot_base = .;
>> +               ram_reset.o(.text)
>> +               *(.glue_7t)
>> +               *(.glue_7)
>> +       } >rom
>> +       .data   :
>> +               *(.data)
>> +       } >rom
>> +       .sdata  :
>> +               *(.sdata)
>> +       } >rom
>> +       .sdata2 :
>> +               *(.sdata2)
>> +       } >rom
>> +       .rodata :
>> +               *(.rodata)
>> +        *(.rodata.str1.4)
>> +       } >rom
>> +       .got    :
>> +               *(.got)
>> +       } >rom
>> +       .bss    :
>> +               bss_start = .;
>> +               atag_space = .;
>> +               . += ATAGSIZE;
>> +               *(.bss) *(COMMON)
>> +       } >rom
>> +       .sbss   :
>> +               *(.sbss)
>> +               bss_end = .;
>> +       } >rom
>> diff --git a/ports/beagleboneblack/CSB740_boot.ldt b/ports/beagleboneblack/CSB740_boot.ldt
>> deleted file mode 100644
>> index c8bc089..0000000
>> --- a/ports/beagleboneblack/CSB740_boot.ldt
>> +++ /dev/null
>> @@ -1,63 +0,0 @@
>> -/* CSB740_boot.ld:
>> - * This is the memory map file used for the boot-flash based version
>> - * of MicroMonitor.  The only value that should be considered adjustable
>> - * here is the base address of the 'dram' memory block.
>> -MEMORY
>> -       rom :   org = ROMBASE,  len = ROMLEN
>> -       dram :  org = DRAMBASE, len = DRAMLEN
>> -SECTIONS
>> -       .text   :
>> -               boot_base = .;
>> -               rom_reset.o(.text)
>> -               *(.glue_7t)
>> -               *(.glue_7)
>> -       } >rom
>> -       .data   :
>> -               *(.data)
>> -       } >rom
>> -       .sdata  :
>> -               *(.sdata)
>> -       } >rom
>> -       .sdata2 :
>> -               *(.sdata2)
>> -       } >rom
>> -       .rodata :
>> -               *(.rodata)
>> -               *(.rodata.str1.4)
>> -       } >rom
>> -       .got    :
>> -               *(.got)
>> -       } >rom
>> -       .bss    :
>> -               bss_start = .;
>> -               atag_space = .;
>> -               . += ATAGSIZE;
>> -               end_atag_space = .;
>> -               *(.bss) *(COMMON)
>> -       } >dram
>> -       .sbss   :
>> -               *(.sbss)
>> -               bss_end = .;
>> -       } >dram
>> diff --git a/ports/beagleboneblack/CSB740_ramtst.ldt b/ports/beagleboneblack/CSB740_ramtst.ldt
>> index 76fbce4..0000000
>> --- a/ports/beagleboneblack/CSB740_ramtst.ldt
>> +++ /dev/null
>> @@ -1,59 +0,0 @@
>> -etheraddr              = MACADDRBASE;
>> -alt_tfsdevtbl_base     = ALTTFSDEVTBLBASE;
>> -MEMORY
>> -       rom :   org = RAMTSTROMBASE,    len = RAMTSTROMLEN
>> -SECTIONS
>> -       .text   :
>> -               boot_base = .;
>> -               ram_reset.o(.text)
>> -               *(.glue_7t)
>> -               *(.glue_7)
>> -       } >rom
>> -       .data   :
>> -               *(.data)
>> -       } >rom
>> -       .sdata  :
>> -               *(.sdata)
>> -       } >rom
>> -       .sdata2 :
>> -               *(.sdata2)
>> -       } >rom
>> -       .rodata :
>> -               *(.rodata)
>> -        *(.rodata.str1.4)
>> -       } >rom
>> -       .got    :
>> -               *(.got)
>> -       } >rom
>> -       .bss    :
>> -               bss_start = .;
>> -               atag_space = .;
>> -               . += ATAGSIZE;
>> -               *(.bss) *(COMMON)
>> -       } >rom
>> -       .sbss   :
>> -               *(.sbss)
>> -               bss_end = .;
>> -       } >rom
>> 2.3.3
>> umon-devel mailing list
>> umon-devel at rtems.org
>> http://lists.rtems.org/mailman/listinfo/umon-devel
Ed Sutter
Alcatel-Lucent Technologies -- Bell Laboratories
Phone: 908-582-2351
Email: ed.sutter at alcatel-lucent.com
More information about the umon-devel mailing list
