Still undergoing attempt to boot Umon from SD
Jarielle Catbagan
jcatbagan93 at gmail.com
Tue Jun 30 01:24:25 UTC 2015
On Jun 29, 2015 5:33 PM, "Ed Sutter" <edsutterjr at gmail.com> wrote:
> Jarielle,
> Ok, I think I may have stumbled on some "hope" for the boot-from-sd card
stuff...
> I'm looking at the cpuio.c that is currently in master and unless I'm
missing something,
> it appears to be incomplete. That incompleteness may explain why your
uSD boot
> attempts didn't succeed. Here's what I'm thinking...
You are correct, I have not completed the cpuio.c file yet. I was planning
to update it and implement the parts as I proceeded with the porting
process. I believe that you're absolutely right about the incompleteness
being the cause of the uSD boot to fail.
> When the rom bootloader starts up, it first attempts to boot from SD
card, then if that
> fails it falls through to the UART. When we do the boot from UART stuff,
it works, but I
> think the current version in master is working "luckily"...
> Think about it... for the bootloader in ROM to interact with the UART to
run an XMODEM
> download, IT has to initialize the UART. So, the code it downloads
(boot.bin) doesn't even
> have to do that and it will still appear to work.
I think you might be onto something. I was assuming that I didn't have to
worry about initializing the UART as I was under the impression that since
it was already working it wasn't something I had to worry about. I have no
doubt that my assumption could be wrong all along.
> Now, if we're trying to use that same boot.bin to boot from SD (earlier
in the boot sequence
> than the UART; hence possibly the UART is not initialized) , then its
possible that the
> bootloader hasn't initialized the UART at the time of the SD boot
attempt. That would
> mean that our current boot.bin would not boot properly because it doesn't
have the code in
> it to initialize the UART.
> Know what I mean?
It makes perfect sense. After my attempts at uSD booting, I was already
suspecting that it could be the boot.bin file all along that's causing the
uSD boot to not come through. I just did not know how to verify at the
time during my attempts. Hence why it motivated me to get a JTAG debugger.
> I believe I have that UART initialization code. My version of this
(which I did about 6 weeks
> back) has the UART initialization in there. Its hard to tell if its
right, simply because it still
> may be depending on the bootloader's initialization for something;
however, I *think* its
> correct.
> Am I making any sense?
Crystal clear. I will look into this right now.
> Ed
> umon-devel mailing list
> umon-devel at rtems.org
> http://lists.rtems.org/mailman/listinfo/umon-devel
URL: <http://lists.rtems.org/pipermail/umon-devel/attachments/20150629/a9ae6c44/attachment.html>
More information about the umon-devel
