[PATCH 7/17] Fixed .make file inclusion in BBB Makefile and UMONTOP in BBB bashrc
Gedare Bloom gedare at gwu.edu
Thu Jun 18 13:26:49 UTC 2015
On Wed, Jun 17, 2015 at 2:02 PM, Jarielle Catbagan
<jcatbagan93 at gmail.com> wrote:
> Minor typo, should be [PATCH 7/16] not [PATCH 7/17].
That's weird. Did you send the whole batch of commits at the same
time, or did you manually specify each one?
$ git send-email HEAD~16
That should work..
> On Wed, Jun 17, 2015 at 11:00 AM, Jarielle Catbagan
>> Fixed .make file inclusion in BBB Makefile and updated UMONTOP in BBB
>> bashrc in order for Umon to build.  During the process when Umon was
>> being updated before the initial commit, top-level directories were
>> renamed.  As a result, this prevented Umon from being built, i.e.
>> 'make' was looking for .make files in directories that didnt exist.
>>  ports/beagleboneblack/Makefile | 6 +++---
>>  ports/beagleboneblack/bashrc   | 2 +-
>>  2 files changed, 4 insertions(+), 4 deletions(-)
>> diff --git a/ports/beagleboneblack/Makefile b/ports/beagleboneblack/Makefile
>> index 29f53c5..511b8e2 100644
>> --- a/ports/beagleboneblack/Makefile
>> +++ b/ports/beagleboneblack/Makefile
>> @@ -39,7 +39,7 @@ ATAGSIZE=0x1000
>>  MACADDRBASE=0x08000020
>>  ALTTFSDEVTBLBASE=0x08000040
>> -include $(TOPDIR)/target/make/common.make
>> +include $(TOPDIR)/make/common.make
>>  # Build each variable from a list of individual filenames...
>> @@ -61,7 +61,7 @@ IODEVSRC = smsc911x.c uart16550.c fb_draw.c
>>  FLASHSRC = s29gl512n_16x1.c
>> -include $(TOPDIR)/target/make/objects.make
>> +include $(TOPDIR)/make/objects.make
>>  OBJS = $(LOCSOBJ) $(CPUSOBJ) $(LOCCOBJ) $(CPUCOBJ) $(COMCOBJ) \
>>   $(FLASHOBJ) $(IODEVOBJ)
>> @@ -116,7 +116,7 @@ $(BUILDDIR)/ramtst.$(FILETYPE): $(BUILDDIR) $(OBJS) libz.a \
>>   $(MAKE_BINARY)
>>   $(MAKE_GNUSYMS)
>> -include $(TOPDIR)/target/make/rules.make
>> +include $(TOPDIR)/make/rules.make
>> diff --git a/ports/beagleboneblack/bashrc b/ports/beagleboneblack/bashrc
>> index 5aaab72..98b038f 100644
>> --- a/ports/beagleboneblack/bashrc
>> +++ b/ports/beagleboneblack/bashrc
>> @@ -1,6 +1,6 @@
>>  PS1=BEAGLEBONEBLACK:
>>  export TITLE="Beaglebone Black"
>> -export UMONTOP=../../umon_main
>> +export UMONTOP=../../main
>>  export tools=$UMONTOP/host
>>  export target=$UMONTOP/target
>>  export cpu=$target/cpu
>> 2.3.3
> umon-devel mailing list
> umon-devel at rtems.org
> http://lists.rtems.org/mailman/listinfo/umon-devel
More information about the umon-devel mailing list
