[PATCH 4/16] Renamed BBB platform file to am335x.h, initial version of am335x.h
Gedare Bloom gedare at gwu.edu
Thu Jun 18 14:14:13 UTC 2015
On Thu, Jun 18, 2015 at 9:49 AM, Ed Sutter <ed.sutter at alcatel-lucent.com> wrote:
> On 6/18/2015 9:36 AM, Gedare Bloom wrote:
>> On Wed, Jun 17, 2015 at 1:52 PM, Jarielle Catbagan
>> <jcatbagan93 at gmail.com> wrote:
>>> Renamed beagleboneblack.h -> am335x.h
>>> Initial version of am335x.h includes a subset of the regsiter base
>>> addresses and offsets specific to the AM335x architecture.
>>>   main/common/warmstart.h                 |   2 +-
>>>   main/make/common.make                   |   0
>>>   ports/beagleboneblack/am335x.h          | 788
>>>   ports/beagleboneblack/beagleboneblack.h | 498 --------------------
>>>   4 files changed, 789 insertions(+), 499 deletions(-)
>>>   mode change 100755 => 100644 main/make/common.make
>>>   create mode 100644 ports/beagleboneblack/am335x.h
>>>   delete mode 100644 ports/beagleboneblack/beagleboneblack.h
>>> diff --git a/main/common/warmstart.h b/main/common/warmstart.h
>>> index 50300eb..a3037ad 100644
>>> --- a/main/common/warmstart.h
>>> +++ b/main/common/warmstart.h
>>> @@ -31,4 +31,4 @@
>>>   #define APPLICATION (5<<4)
>>>   #define APP_EXIT (9<<4)
>>> -#endif
>>> +#endif /* _WARMSTART_H_ */
>>> diff --git a/main/make/common.make b/main/make/common.make
>>> old mode 100755
>>> new mode 100644
>>> diff --git a/ports/beagleboneblack/am335x.h
>>> b/ports/beagleboneblack/am335x.h
>>> new file mode 100644
>>> index 0000000..ed96dfe
>>> --- /dev/null
>>> +++ b/ports/beagleboneblack/am335x.h
>>> @@ -0,0 +1,788 @@
>>> +// am335x.h
>>> +// Author(s):    Luis Torrico, Cogent Computer Systems, Inc.
>>> +// Contributors: Jarielle Catbagan
>>> +// Date:         05/02/2008
>> You should probably list yourself as the author, and I'd get rid of
>> these Date entries, the git log contains sufficient information.
>> Is there a documented umon coding style?
>> Would it be of interest to generate doxygen for umon (headers)?
>> Gedare
> No there isn't.  :-(
> I generally just use 4-space tabs and comment with...
>   * comment here
> but I know I'm not real consistent through the code.
> At various points I started attempting a doxygen format, but never got it
> rolling.  I'm certainly up for converting it though (over time of course).
No time to start like the present. I'd suggest defining the style with
something close to what you have got, that you want a consistent
look-and-feel, and if you find particular rules are desired as you
move forward that you add to them. A simple text document in the repo
will be sufficient to document the style rules for now, since they're
pretty simple.
RTEMS has a fairly comprehensive set of coding conventions that have
grown over years that includes style and doxygen use.
https://devel.rtems.org/wiki/Developer/Coding/Conventions
You don't need so much now, but it really helps to make code review
easier if all the code looks the same.
> Ed
> Ed Sutter
> Alcatel-Lucent Technologies -- Bell Laboratories
> Phone: 908-582-2351
> Email: ed.sutter at alcatel-lucent.com
> umon-devel mailing list
> umon-devel at rtems.org
> http://lists.rtems.org/mailman/listinfo/umon-devel
More information about the umon-devel mailing list
