[PATCH 08/13] Removed nand740.c from BBB port
Jarielle Catbagan jcatbagan93 at gmail.com
Sat Jun 20 02:57:58 UTC 2015
nand740.c is for the NAND device found on the CSB740. Hence, the file is not
relevant to the BBB.  The file has also been removed from the compilation
process in Makefile.
 ports/beagleboneblack/Makefile  |   2 +-
 ports/beagleboneblack/nand740.c | 333 ----------------------------------------
 2 files changed, 1 insertion(+), 334 deletions(-)
 delete mode 100644 ports/beagleboneblack/nand740.c
diff --git a/ports/beagleboneblack/Makefile b/ports/beagleboneblack/Makefile
index ddf60e2..77af32d 100644
--- a/ports/beagleboneblack/Makefile
+++ b/ports/beagleboneblack/Makefile
@@ -42,7 +42,7 @@ include	$(TOPDIR)/make/common.make
 LOCSSRC		=
 CPUSSRC		= vectors_arm.S
-LOCCSRC		= cpuio.c etherdev.c nand740.c
+LOCCSRC		= cpuio.c etherdev.c
 COMCSRC		= arp.c cast.c cache.c chario.c cmdtbl.c \
 			  docmd.c dhcp_00.c dhcpboot.c dns.c edit.c env.c ethernet.c \
 			  flash.c gdb.c icmp.c if.c ledit_vt100.c monprof.c \
diff --git a/ports/beagleboneblack/nand740.c b/ports/beagleboneblack/nand740.c
deleted file mode 100644
index 95a912a..0000000
--- a/ports/beagleboneblack/nand740.c
+++ /dev/null
@@ -1,333 +0,0 @@
- * Board/device specific connection between the generic
- * nand command and the CSB740's NAND memory access through
- * the OMAP3530.
- * The CSB740 uses K9K4GO8UOM NAND (512Mx8bit) device from Samsung.
- * It is connected to the OMAP3530's CS3 through the CPLD.
- * The device ID for this part number should be: 0xECDC109554
- *  Maker code:		0xEC
- *	Device code:	0xDC
- *  Third cycle:	0x10
- *  Fourth cycle:	0x95
- *  Fifth cycle:	0x54
- * Blocksize: 128K	(smallest eraseable chunk)
- * Pagesize:  2K  (64 pages per block)
- * Taken from the NAND datasheet...
- *   The 528M byte physical space requires 30 addresses, thereby
- *   requiring five cycles for addressing :
- *   2 cycles of column address, 3 cycles of row address, in that
- *   order. Page Read and Page Program need the same five address
- *   cycles following the required command input. In Block Erase
- *   operation, however, only the three row address cycles are used.
- *   Device operations are selected by writing specific commands into
- *   the command register.
- * Taken from ONFI Spec:
- *   The address is comprised of a row address and a column address.
- *   The row address identifies the page, block, and LUN to be accessed.
- *   The column address identifies the byte or word within a page to access.
- * Note:
- *	Apparently this Sansung device is not ONFI compliant.  There was an
- *  earlier version of the CSB740 that had a Micron part on it and it was
- *  ONFI compliant (ONFI=Open Nand Flash Interface specification).
-#include "config.h"
-#if INCLUDE_NANDCMD
-#include "stddefs.h"
-#include "genlib.h"
-#include "omap3530.h"
-#include "omap3530_mem.h"
-#include "nand.h"
-static int pgSiz;
-static int blkSiz;
-static char onfi;
-#define NANDSTAT_FAIL	0x01
-#define NANDSTAT_READY	0x40
-#define NANDSTAT_NOTWP	0x80
-#define NAND_CMD(cs) (vuchar *)(0x6e00007C + (0x30 * cs))
-#define NAND_ADR(cs) (vuchar *)(0x6e000080 + (0x30 * cs))
-#define NAND_DAT(cs) (vuchar *)(0x6e000084 + (0x30 * cs))
-#define PREFETCH_READ_MODE()	GPMC_REG(GPMC_PREFETCH_CONFIG1) &= ~1
-#define WRITE_POSTING_MODE()	GPMC_REG(GPMC_PREFETCH_CONFIG1) |= 1
-#define NAND_CS_BASEADDR	0x18000000
-/* some discussion to follow:
- * http://e2e.ti.com/support/dsp/omap_applications_processors/f/42/p/29683/103192.aspx
- * Address is "page/block/column"...
-/* nandBusyWait():
- * Poll the WAIT3 bit of the gmpc-status register, waiting for
- * it to go active.
- * The R/B (ready/busy) pin of the NAND device is low when busy.
- * It is tied to WAIT3 of the CPU.
-void
-nandHardBusyWait(void)
-	while((GPMC_REG(GPMC_STATUS) & 0x800) == 0x800);
-	//while((GPMC_REG(GPMC_STATUS) & 0x800) == 0);
-void
-nandSoftBusyWait(void)
-	do {
-		*NAND_CMD(3) = 0x70;
-	} while((*NAND_DAT(3) & NANDSTAT_READY) == 0);
-void
-nandSetColAddr(unsigned long addr)
-	// Column1 (A07|A06|A05|A04|A03|A02|A01|A00):
-	*NAND_ADR(3) = ((addr & 0x000000ff));
-	// Column2 (---|---|---|---|A11|A10|A09|A08):
-	*NAND_ADR(3) = ((addr & 0x00000f00) >> 8);
-void
-nandSetRowAddr(unsigned long addr)
-	// Row1 (A19|A18|A17|A16|A15|A14|A13|A12):
-	*NAND_ADR(3) = ((addr & 0x000ff000) >> 12);
-	// Row2 (A27|A26|A25|A24|A23|A22|A21|A20):
-	*NAND_ADR(3) = ((addr & 0x0ff00000) >> 20);
-	// Row3 (---|---|---|---|---|---|A29|A28):
-	*NAND_ADR(3) = ((addr & 0x30000000) >> 28);
-/* nandReadChunk():
- * Transfer some chunk of memory from NAND to a destination.
-int
-nandReadChunk(char *src, char *dest, int len)
-	unsigned long addr = (long)src;
-	PREFETCH_READ_MODE();
-	if (nandVerbose)
-		printf("nandReadChunk(src=0x%x,dest=0x%x,len=%d)\n",src,dest,len);
-	while(len > 0) {
-		int tot;
-		*NAND_CMD(3) = 0x00;
-		nandSetColAddr(addr);
-		nandSetRowAddr(addr);
-		*NAND_CMD(3) = 0x30;
-		nandHardBusyWait();
-		tot = len > pgSiz ? pgSiz : len;
-		memcpy(dest,(char *)NAND_CS_BASEADDR,tot);
-		len -= tot;
-		dest += tot;
-	return(0);
-int
-nandWriteChunk(char *dest, char *src, int len)
-	unsigned long addr = (long)dest;
-	WRITE_POSTING_MODE();
-	if (nandVerbose)
-		printf("nandWriteBlock(dest=0x%x,src=0x%x,len=%d)\n",dest,src,len);
-	*NAND_CMD(3) = 0x80;
-	memcpy((char *)NAND_CS_BASEADDR,src,len);
-	*NAND_CMD(3) = 0x10;
-	nandSoftBusyWait();
-	return(0);
-int
-nandEraseChunk(char *base, int len)
-	unsigned long addr = (long)base;
-	if (nandVerbose)
-		printf("nandEraseChunk(addr=0x%x,len=%d)\n",addr,len);
-	*NAND_CMD(3) = 0x60;
-	*NAND_CMD(3) = 0xd0;
-	return(0);
-void
-nandId(void)
-	uchar d[5];
-	uchar d1[4];
-	*NAND_CMD(3) = 0x90;
-	*NAND_ADR(3) = 0x00;
-	d[0] = *NAND_DAT(3);
-	d[1] = *NAND_DAT(3);
-	d[2] = *NAND_DAT(3);
-	d[3] = *NAND_DAT(3);
-	d[4] = *NAND_DAT(3);
-	switch(d[3] & 3) {
-		case 0:
-			pgSiz = 1024;
-			break;
-		case 1:
-			pgSiz = 1024*2;
-			break;
-		case 2:
-			pgSiz = 1024*4;
-			break;
-		case 3:
-			pgSiz = 1024*8;
-			break;
-	switch((d[3] & 0x30) >> 4) {
-		case 0:
-			blkSiz = 1024*64;
-			break;
-		case 1:
-			blkSiz = 1024*128;
-			break;
-		case 2:
-			blkSiz = 1024*256;
-			break;
-		case 3:
-			blkSiz = 1024*512;
-			break;
-	*NAND_ADR(3) = 0x20;
-	d1[0] = *NAND_DAT(3);
-	d1[1] = *NAND_DAT(3);
-	d1[2] = *NAND_DAT(3);
-	d1[3] = *NAND_DAT(3);
-	if (memcmp((char *)d1,"ONFI",4) == 0)
-		onfi = 1;
-	else
-		onfi = 0;
-	if (nandVerbose) {
-		printf("nandID():  %02x%02x%02x%02x%02x\n",d[0],d[1],d[2],d[3],d[4]);
-		printf("nandID+():  %02x%02x%02x%02x%02x\n",d1[0],d1[1],d1[2],d1[3]);
-		printf("Page size:  0x%x\n",pgSiz);
-		printf("Block size: 0x%x\n",blkSiz);
-		printf("%sONFI compliant\n",onfi ? "" : "Not ");
-int
-nandInit(void)
-	vulong cfgreg;
-#if 0
-	printf("CFG1: dm -4 0x%08x 1 = %08x\n",
-		MYGPMC_REG(GPMC_CS3_CONFIG1),GPMC_REG(GPMC_CS3_CONFIG1));
-	printf("CFG2: dm -4 0x%08x 1 = %08x\n",
-		MYGPMC_REG(GPMC_CS3_CONFIG2),GPMC_REG(GPMC_CS3_CONFIG2));
-	printf("CFG3: dm -4 0x%08x 1 = %08x\n",
-		MYGPMC_REG(GPMC_CS3_CONFIG3),GPMC_REG(GPMC_CS3_CONFIG3));
-	printf("CFG4: dm -4 0x%08x 1 = %08x\n",
-		MYGPMC_REG(GPMC_CS3_CONFIG4),GPMC_REG(GPMC_CS3_CONFIG4));
-	printf("CFG5: dm -4 0x%08x 1 = %08x\n",
-		MYGPMC_REG(GPMC_CS3_CONFIG5),GPMC_REG(GPMC_CS3_CONFIG5));
-	printf("CFG6: dm -4 0x%08x 1 = %08x\n",
-		MYGPMC_REG(GPMC_CS3_CONFIG6),GPMC_REG(GPMC_CS3_CONFIG6));
-	printf("CFG7: dm -4 0x%08x 1 = %08x\n",
-		MYGPMC_REG(GPMC_CS3_CONFIG7),GPMC_REG(GPMC_CS3_CONFIG7));
-#endif
-	/* WAIT3 of the CPU is tied to the NAND's READY pin.  The NAND
-	 * is on CS3.  Referring to section 11.1.7.2.10 of the OMAP3530 TRM,
-	 * the GPMC_CONFIGX registers must be programmed...
-	GPMC_REG(GPMC_CONFIG) |= 0x1;				// Force posted write.
-	GPMC_REG(GPMC_CONFIG) &= ~0x800;			// WAIT3 active low.
-	GPMC_REG(GPMC_CS3_CONFIG7) = 0x00000858; 	// Base addr 0x18000000
-	GPMC_REG(GPMC_CS3_CONFIG1) = 0x00030800; 	// 8-bit NAND, WAIT3
- 	GPMC_REG(GPMC_CS3_CONFIG2) = 0x00000000;	// Chipselect timing
- 	GPMC_REG(GPMC_CS3_CONFIG3) |= 0x7;
- 	GPMC_REG(GPMC_CS3_CONFIG6) = 0x8f0307c0;
-	// Set drive strength of BE0/CLE
-	*(vulong *)0x48002444 |= 0x00000020;
-	 * ALE and CLE on the NAND are both active high, so we want
-	 * them to be pulled low...
-	 * ALE config is the low half of this config register, so we only
-	 * touch the bottom half...
-	cfgreg = SCM_REG(PADCONFS_GPMC_NADV_ALE);	// NOE[31:16], NADV_ALE[15:0]
-	cfgreg &= 0xffff0000;
-	cfgreg |= 0x00000008;
-	SCM_REG(PADCONFS_GPMC_NADV_ALE) = cfgreg;
-	 * CLE config is the upper half of this config register, so we only
-	 * touch the upper half...
-	cfgreg = SCM_REG(PADCONFS_GPMC_NWE);		// NBE0_CLE[31:16], NWE[15:0]
-	cfgreg &= 0x0000ffff;
-	cfgreg |= 0x00080000;
-	SCM_REG(PADCONFS_GPMC_NWE) = cfgreg;
-	/* WAIT3 of CPU is tied to R/B pin of NAND...
-	 * So, we configure that pin to run as WAIT3.
-	 * NOTE:
-	 *  There is some confusion between this and what is in cpuio.c.
-	 *  The PADCONFS_GPMC_WAIT2 register sets this pin as GPIO-65 there;
-	 *  however the comments are confusing.
-	cfgreg = SCM_REG(PADCONFS_GPMC_WAIT2);		// WAIT3[31:16], WAIT2[15:0]
-	nandId();
-	return(0);
-int
-nandInfo(void)
-	nandId();
-	return(0);
-#endif
2.3.3
More information about the umon-devel mailing list
