BBB/AM335x: isspace() results in data abort exception in strtol() in strtol.c and strtoul() in strtoul.c
Gedare Bloom gedare at gwu.edu
Mon Jun 22 15:12:38 UTC 2015
On Mon, Jun 22, 2015 at 10:59 AM, Jarielle Catbagan
<jcatbagan93 at gmail.com> wrote:
> On Mon, Jun 22, 2015 at 6:54 AM, Ed Sutter <ed.sutter at alcatel-lucent.com> wrote:
>> On 6/22/2015 8:28 AM, Chris Johns wrote:
>>> On 22/06/2015 2:16 pm, Jarielle Catbagan wrote:
>>>> On Sun, Jun 21, 2015 at 4:47 PM, Chris Johns <chrisj at rtems.org> wrote:
>>>>> On 22/06/2015 2:27 am, Jarielle Catbagan wrote:
>>>>>> I was testing the "help", "dm" and "pm" commands on the Umon command
>>>>>> line and they resulted in what appears to cause the program to hang.
>>>>>> I captured the result and it can be found here
>>>>>> https://drive.google.com/file/d/0B_44Dkqbmn75TjQwZjJaczNJYk0/view?usp=sharing.
>>>>>> After doing some debugging, I was able to pinpoint the location that
>>>>>> results in a halt in program execution.  It hangs when isspace() is
>>>>>> executed in strtol() in strtol.c.
>>>>> Where do the libc functions come from ? What is the linker command line
>>>> isspace() seems to be pulled in just fine from
>>>> /usr/arm-none-eabi/include, because removing <ctype.h> from strtol.c
>>>> results in an undefined reference to isspace().
>>> My concern is the multilibs and what is needed by umon and what is
>>> needed by RTEMS. For example on the Zynq I build the Xilinx bootloader
>>> code for ARM in thumb mode while Xilinx do not (I know because I needed
>>> to fix it). I actually use the same flags I use for RTEMS.
>>> With umon having the ability to integrate with RTEMS the need to match
>>> the ABI is important.
>>>>>> Whenever Umon is built, there are two important images built.
>>>>>> boot.bin and boot.elf.  boot.bin is a raw image and is the image that
>>>>>> is booted on the BBB.  I wanted to see how the image was assembled,
>>>>>> and so I ran "arm-none-eabi-objdump -S boot.elf".  I am focusing on
>>>>> What tool set is being used ?
>>>> I am using arm-none-eabi-gcc 4.9.2 and binutils 2.25.0.
>>> Where did you get this compiler from ? Who built it ?
> I obtained the compiler from the Arch Linux repositories via "pacman".
>>> How do we track what is needed by users ? I for one cannot contribute
>>> because I do not have this compiler.
> I agree, having the same toolset among users and contributors will be
> better in the long run.
>>> Why not use the RTEMS compiler ?
> I chose not to modify the existing build process of Umon, (i,e, using
> arm-none-eabi-gcc, etc.), for now.  I am certainly open to the idea of
> transitioning to the RTEMS compiler now, especially if it means that
> complexities would be avoided later down the road.
If you switch to the RTEMS arm compiler, you'll pull in newlib
instead, so the problems and solutions may change. It is probably
worth investigating now rather than later.
More information about the umon-devel mailing list
